| 00-Preface | 100.44 KB |
Preface
· This configuration guide describes the MCE fundamentals and configuration procedures.
· CLI.
· RBAC, switch login, and switch access control.
· Management of the switch, file systems, and configuration files.
· FTP and TFTP.
· Tcl and Python.
· Common software upgrade.
· Automatic configuration.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S5170-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
