01-Fundamentals
HomeSupportRoutersH3C SR8800-X Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-X Routers Alarm Reference-R838x-6W10001-Fundamentals
06-HH3C-UI-MAN-MIB
06-HH3C-UI-MAN-MIB 56.75 KB
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to obtain and manage alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Notifications
hh3cLogIn
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.1
User login
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a user logs in to the system.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName)
Username.
N/A
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource)
User line, including console, AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
No action is required.
hh3cLogOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.2
User logout
Informational
Warning
N/A (N/A)
ON
This notification is generated when a user logs out of the system.
System impact
Status control
Object
OID (object name)
Index
Value range
Username.
N/A
DisplayString
User line, including AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
hh3cLogInAuthenFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.3
User authentication failed
Informational
Warning
N/A (N/A)
ON
This notification is generated when a user failed to log in to the system.
System impact
If this notification is generated consecutively, the system might be attacked.
Status control
Object
OID (object name)
Index
Value range
Username.
N/A
DisplayString
N/A
DisplayString
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason)
Failure reason for user authentication.
N/A
INTEGER
exceedRetries(1), authTimeout(2), otherReason(3)
Recommended action
1.Verify that the login username and password are correct.
2.Verify that the server settings such as server type are correct.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
hh3cVtyUsageExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.4
The number of used VTY lines reached or exceeded the alarm threshold.
Informational
Warning
1.3.6.1.4.1.25506.2.2.1.1.3.0.5 (hh3cVtyUsageResume)
ON
This notification is generated when the number of used VTY lines reaches or exceeds the alarm threshold.
System impact
Users cannot log in to the system through VTY lines.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.4
 (hh3cVtyCurrentVty)
Number of used VTY lines.
N/A
Integer
Standard MIB values.
1.3.6.1.4.1.25506.2.2.1.1.2.5
 (hh3cVtyMaxVty)
Maximum number of VTY lines that the system allows users to log in to concurrently.
N/A
Integer
1.3.6.1.4.1.25506.2.2.1.1.2.6 (hh3cVtyThreshold)
VTY usage alarm threshold.
N/A
Integer
Recommended action
Quit unnecessary sessions to release user lines.
hh3cVtyUsageResume
Basic information
OID
Event
Severity
Default status
VTY usage alarm was cleared.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of used VTY lines drops below the VTY usage alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cVtyCurrentVty)
N/A
Integer
 (hh3cVtyMaxVty)
N/A
Integer
N/A
Integer
Recommended action
