| 05-HH3C-TELNET-MIB | 40.73 KB |
HH3C-TELNET-MIB
About this MIB
Use this MIB to obtain Telnet server basic information or the notifications sent by the Telnet server.
MIB file name
hh3c-telnet.mib
Notifications
hh3cTelnetsLoginFailed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.249.1.2.0.1 |
A user frequently failed authentication when it logs in to the Telnet server. |
Error |
Warning |
1.3.6.1.4.1.25506.2.249.1.2.0.2 (hh3cTelnetsLoginFailedClear) |
ON |
Notification triggers
This notification might be generated when the number of Telnet login failures reaches the specified upper threshold.
A user might have attempted to log in to the Telnet server for a long time and the attempts have failed.
System impact
The system might be attacked.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.249.1.1.1 (hh3cTelnetsLoginFailedTimes) |
Number of user login failures. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.249.1.1.2 (hh3cTelnetsLoginFailedStatPeriod) |
Statistical period of user login failures. |
N/A |
Unsigned32 |
Recommended action
To resolve this issue:
1.Verify that the username and password are correct.
2.Verify that an ACL has been configured to filter invalid addresses.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.249.1.2.0.2 |
Notification about Telnet user login failures was cleared. |
Recovery |
Informational |
N/A (N/A) |
ON |
This notification might be generated when the number of login failures is smaller than the notification clearance threshold within the specified period.
System impact
No negative impact on the system.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A (N/A) |
N/A |
N/A |
N/A |
N/A |
Recommended action
No action is required.
