01-Fundamentals
HomeSupportRoutersH3C SR8800-X Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-X Routers Alarm Reference-R838x-6W10001-Fundamentals
02-HH3C-FLASH-MAN-MIB
02-HH3C-FLASH-MAN-MIB 72.57 KB
HH3C-FLASH-MAN-MIB
About this MIB
Use this MIB to obtain information about storage media, partitions, and files as well as manage files on the storage media.
MIB file name
hh3c-flash-man.mib
Notifications
hh3cFlhOperNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.5.1.3.1
A file operation completed.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a file operation completes if the value of hh3cFlhOperEndNotification is true.
The parameters included in this notification vary by file operation. For more information, see the online help for the NMS.
System impact
No negative impact on the system.
Status control
ON
MIB: Set hh3cFlhOperEndNotification to true(1).
OFF
MIB: Set hh3cFlhOperEndNotification to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.5.1.2.1.1.9 (hh3cFlhOperStatus)
File operation status.
N/A
Hh3cFlashOperationStatus
opInProgress(1), opSuccess(2), opInvalid(3), opInvalidProtocol(4), opInvalidSourceName(5), opInvalidDestName(6), opInvalidServerAddress(7), opDeviceBusy(8), opDeviceOpenError(9), opDeviceError(10), opDeviceNotProgrammable(11), opDeviceFull(12), opFileOpenError(13), opFileTransferError(14), opFileChecksumError(15), opNoMemory(16), opAuthFail(17), opTimeout(18), opUnknownFailure(19), opDeleteFileOpenError(20), opDeleteInvalidDevice(21), opDeleteInvalidFunction(22), opDeleteOperationError(23), opDeleteInvalidFileName(24), opDeleteDeviceBusy(25), opDeleteParaError(26), opDeleteInvalidPath(27), opDeleteFileNotExistInSlave(28), opDeleteFileFailedInSlave(29), opSlaveFull(30), opCopyToSlaveFailure(31)
Recommended action
If the operation finishes successfully, no action is required.
If the operation fails, handle the issue according to the failure reason. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFlhUsageOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.5.1.4.0.1
The disk usage exceeded the threshold.
Informational
Minor
1.3.6.1.4.1.25506.2.5.1.4.0.2 (hh3cFlhUsageResume)
ON
This notification is generated when the disk usage exceeds the alarm threshold.
System impact
If disk space is insufficient, file operations that require high disk space might fail, such as transferring, downloading, or loading version files.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.5.1.5.1 (hh3cFlhUsageRate)
Current disk usage.
N/A
Integer32
Standard MIB values.
1.3.6.1.4.1.25506.2.5.1.5.2 (hh3cFlhUsageRateThreshold)
Disk usage threshold.
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.3 (hh3cFlhNameForTrap)
Disk name.
N/A
DisplayString
Recommended action
1.Verify that the disk space is insufficient and clear unnecessary files as needed.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFlhUsageResume
Basic information
OID
Event
Severity
Default status
The disk usage dropped below the threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the disk usage drops below the alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Current disk usage.
N/A
Integer32
N/A
Integer32
Disk name.
N/A
DisplayString
Recommended action
No action is required.
