08-Layer 3 - IP Services
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
16-HH3C-TCP-MIB
16-HH3C-TCP-MIB 50.99 KB
HH3C-TCP-MIB
About this MIB
Use this MIB to test whether the MD5 authentication for the current TCP connection is successful.
MIB file name
hh3c-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTcp(215)
Scalar objects
hh3cTcpConnLocalAddressTCP (1.3.6.1.4.1.25506.2.215.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING  (0..255)
Local IP address of the TCP connection
As per the MIB.
hh3cTcpConnLocalPortTCP (1.3.6.1.4.1.25506.2.215.1.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(0..65535)
Local port number of the TCP connection
As per the MIB.
hh3cTcpConnRemAddressTCP (1.3.6.1.4.1.25506.2.215.1.1.3)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Remote IP address of the TCP connection
As per the MIB.
hh3cTcpConnRemPortTCP (1.3.6.1.4.1.25506.2.215.1.1.4)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(0..65535)
Remote port number of the TCP connection
As per the MIB.
hh3cTcpProtocol (1.3.6.1.4.1.25506.2.215.1.1.5)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the upper layer protocol of TCP
As per the MIB.
hh3cTcpVrfNameVRF (1.3.6.1.4.1.25506.2.215.1.1.6)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the VRF of the TCP connection
As per the MIB.
Notifications
hh3cTcpMD5AuthenFail
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.215.1.0.1
TCP connection MD5 authentication failed.
Error
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the MD5 keys of the two ends of a TCP connection are different or only one end is configured with an MD5 key.
System impact
The TCP connection cannot be established, upper-layer routing protocols, such as LDP and BGP, cannot establish sessions.
Status control
ON
CLI: Use the snmp-agent trap enable tcp command.
OFF
CLI: Use the undo snmp-agent trap enable tcp command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.215.1.1.1 (hh3cTcpConnLocalAddressTCP)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.2 (hh3cTcpConnLocalPortTCP)
N/A
Integer32
Integer32(0..65535)
1.3.6.1.4.1.25506.2.215.1.1.3 (hh3cTcpConnRemAddressTCP)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.4 (hh3cTcpConnRemPortTCP)
N/A
Integer32
Integer32(0..65535)
1.3.6.1.4.1.25506.2.215.1.1.5 (hh3cTcpProtocol)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.6 (hh3cTcpVrfNameVRF)
N/A
OCTET STRING
Recommended action
To resolve this issue:
1.Use the display current-configuration command on each end to check whether an MD5 key is configured.
  - If only one end is configured with an MD5 key, configure an MD5 key on the other end. If the issue persists, go to step 3.
  - If the MD5 keys configured on the two ends are different, go to step 2.
2.Configure the same MD5 key on the two ends.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
