08-Layer 3 - IP Services
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
04-HH3C-BPA-MIB
04-HH3C-BPA-MIB 66.95 KB
HH3C-BPA-MIB
About this MIB
Use this MIB to implement BGP policy accounting (BPA). BGP policy accounting provides the following functionalities:
Classifies IP traffic by BGP path attributes such as NEXT HOP, COMMUNITY, and AS_PATH.
Assigns an index to each class of traffic.
Collects statistics based on indexes.
MIB file name
hh3c-bpa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBpa(144)
Tabular objects
hh3cBpaCfgTable
About this table
This table configures BGP policy accounting on an interface.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cBpaDirection.
Object (OID)
Access
Value range
Implementation
hh3cBpaDirection (1.3.6.1.4.1.25506.2.144.1.1.1.1)
not-accessible
INTEGER
input(1)
output(2)
Direction of traffic to which the BGP policy accounting applies.
As per the MIB.
hh3cBpaSrcOrDest (1.3.6.1.4.1.25506.2.144.1.1.1.2)
read-create
INTEGER
source(1)
destination(2)
both(3)
Address criterion for IP traffic classification.
As per the MIB.
hh3cBpaRowStatus
(1.3.6.1.4.1.25506.2.144.1.1.1.3)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
hh3cBpaStatTable
About this table
Use this table to obtain BGP policy accounting information.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cBpaTrafficType, and hh3cBpaTrafficIndex.
Object (OID)
Access
Value range
Implementation
hh3cBpaTrafficType (1.3.6.1.4.1.25506.2.144.1.2.1.1)
not-accessible
InetAddressType
ipv4(1)
ipv6(2)
Packet type, IPv4 or IPv6.
As per the MIB.
hh3cBpaTrafficIndex (1.3.6.1.4.1.25506.2.144.1.2.1.2)
not-accessible
Integer32
1..128
Index of the BGP route matching the policy.
As per the MIB.
hh3cBpaInPacketCount (1.3.6.1.4.1.25506.2.144.1.2.1.3)
read-only
Counter64
Standard MIB values.
Number of incoming packets for the specified index and type.
As per the MIB.
hh3cBpaInOctetCount (1.3.6.1.4.1.25506.2.144.1.2.1.4)
read-only
Counter64
Number of incoming bytes for the specified index and type.
As per the MIB.
hh3cBpaOutPacketCount (1.3.6.1.4.1.25506.2.144.1.2.1.5)
read-only
Counter64
Number of outgoing packets for the specified index and type.
As per the MIB.
hh3cBpaOutOctetCount (1.3.6.1.4.1.25506.2.144.1.2.1.6)
read-only
Counter64
Number of outgoing bytes for the specified index and type.
As per the MIB.
hh3cBpaInPktRateInLast30Sec (1.3.6.1.4.1.25506.2.144.1.2.1.7)
read-only
Counter64
Number of incoming packets for the specified index and type per second in the last 30 seconds.
As per the MIB.
hh3cBpaInBitRateInLast30Sec (1.3.6.1.4.1.25506.2.144.1.2.1.8)
read-only
Counter64
Incoming traffic amount for the specified index and type per second in the last 30 seconds.
As per the MIB.
hh3cBpaOutPktRateInLast30Sec (1.3.6.1.4.1.25506.2.144.1.2.1.9)
read-only
Counter64
Number of outgoing packets for the specified index and type per second in the last 30 seconds.
As per the MIB.
hh3cBpaOutBitRateInLast30Sec (1.3.6.1.4.1.25506.2.144.1.2.1.10)
read-only
Counter64
Outgoing traffic amount for the specified index and type per second in the last 30 seconds.
As per the MIB.
