08-Layer 3 - IP Services
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
13-HH3C-NAT-MIB
13-HH3C-NAT-MIB 169.25 KB
HH3C-NAT-MIB
About this MIB
Use this MIB to obtain NAT information.
MIB file name
hh3c-nat.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNat(18)
Tabular objects
hh3cNATStatVer2Table
About this table
This table obtains NAT statistics of version 2.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cNATStatChassis, hh3cNATStatSlot, and hh3cNATStatCPUID.
Object (OID)
Access
Value range
Implementation
hh3cNATStatChassis (1.3.6.1.4.1.25506.2.18.2.13.1.1)
not-accessible
Unsigned32
0..65534
Chassis number.
As per the MIB.
hh3cNATStatSlot (1.3.6.1.4.1.25506.2.18.2.13.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
hh3cNATStatCPUID (1.3.6.1.4.1.25506.2.18.2.13.1.3)
not-accessible
Unsigned32
0..7
CPU number.
As per the MIB.
hh3cNATTotalNATSessionCount (1.3.6.1.4.1.25506.2.18.2.13.1.4)
read-only
Unsigned32
Standard MIB values.
Total number of NAT sessions.
As per the MIB.
hh3cNATEimTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.5)
read-only
Unsigned32
Number of EIM entries.
As per the MIB.
hh3cNATOutboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.7)
read-only
Unsigned32
NO-PAT entries generated for the outbound NAT translation.
As per the MIB.
hh3cNATMaxDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.8)
read-only
Unsigned32
Number of NAT444 dynamic port blocks.
As per the MIB.
hh3cNATMaxStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.9)
read-only
Unsigned32
Number of NAT444 static port blocks.
As per the MIB.
hh3cNATActiveDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.10)
read-only
Unsigned32
Number of active NAT444 dynamic port blocks.
As per the MIB.
hh3cNATActiveStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.11)
read-only
Unsigned32
Number of active NAT444 static port blocks.
As per the MIB.
hh3cNATCurBandwidthRatio
(1.3.6.1.4.1.25506.2.18.2.13.1.13)
read-only
Unsigned32
0..100
Current CGN card bandwidth usage.
As per the MIB.
hh3cNATAddrGrpStatTable
About this table
This table queries NAT address group statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cNATAddrGrpStatChassis, hh3cNATAddrGrpStatSlot, hh3cNATAddrGrpStatCPUID, and hh3cNATAddrGrpStatAddrGrpNum.
Object (OID)
Access
Value range
Implementation
hh3cNATAddrGrpStatChassis (1.3.6.1.4.1.25506.2.18.2.14.1.1)
not-accessible
Unsigned32
0..65534
Chassis number.
As per the MIB.
hh3cNATAddrGrpStatSlot (1.3.6.1.4.1.25506.2.18.2.14.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
hh3cNATAddrGrpStatCPUID (1.3.6.1.4.1.25506.2.18.2.14.1.3)
not-accessible
Unsigned32
0..7
CPU number.
As per the MIB.
hh3cNATAddrGrpStatAddrGrpNum (1.3.6.1.4.1.25506.2.18.2.14.1.4)
not-accessible
Unsigned32
0..65535
NAT address group ID.
As per the MIB.
hh3cInstAddrGrpUsgTable
About this table
This table queries address group resource usage in NAT instances.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cInstAddrUsgInstName and hh3cInstAddrUsgGrpIndex.
Object (OID)
Access
Value range
Implementation
hh3cInstAddrUsgInstName (1.3.6.1.4.1.25506.2.18.2.16.1.1)
not-accessible
OCTET STRING
SIZE (1..32)
NAT instance name.
As per the MIB.
hh3cInstAddrUsgGrpIndex (1.3.6.1.4.1.25506.2.18.2.16.1.2)
not-accessible
Unsigned32
1..65536
ID of the NAT address group.
As per the MIB.
hh3cInstAddrUsgInstIndex (1.3.6.1.4.1.25506.2.18.2.16.1.3)
read-only
Unsigned32
1..127
NAT instance ID.
As per the MIB.
hh3cInstAddrUsgGrpUsage (1.3.6.1.4.1.25506.2.18.2.16.1.4)
read-only
Unsigned32
0..100
NAT address group usage.
As per the MIB.
hh3cInstAddrUsgTotalIPCount
(1.3.6.1.4.1.25506.2.18.2.16.1.5)
read-only
Unsigned32
0..65536
Total number of public IP addresses in the NAT address group.
As per the MIB.
hh3cInstAddrUsgUsedIPCount
(1.3.6.1.4.1.25506.2.18.2.16.1.6)
read-only
Unsigned32
0..65536
Number of used public IP addresses in the NAT address group.
As per the MIB.
hh3cInstAddrUsgUnusedIPCount
(1.3.6.1.4.1.25506.2.18.2.16.1.7)
read-only
Unsigned32
0..65536
Number of unused public IP addresses in the NAT address group.
As per the MIB.
hh3cInstAddrGrpMemberUsgTable
About this table
Use this table to obtain NAT address group member (address range) resources usage in a NAT instance.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cInstAddrMemUsgInstName, hh3cInstAddrMemUsgGrpIndex, and hh3cInstAddrMemUsgGrpStartIP.
Object (OID)
Access
Value range
Implementation
hh3cInstAddrMemUsgInstName (1.3.6.1.4.1.25506.2.18.2.17.1.1)
not-accessible
OCTET STRING
SIZE (1..32)
NAT instance name.
As per the MIB.
hh3cInstAddrMemUsgGrpIndex (1.3.6.1.4.1.25506.2.18.2.17.1.2)
not-accessible
Unsigned32
1..65536
As per the MIB.
hh3cInstAddrMemUsgGrpStartIP (1.3.6.1.4.1.25506.2.18.2.17.1.3)
not-accessible
IpAddress
Start IP address of a NAT address range.
As per the MIB.
hh3cInstAddrMemUsgGrpEndIP (1.3.6.1.4.1.25506.2.18.2.17.1.4)
read-only
IpAddress
End IP address of a NAT address range.
As per the MIB.
hh3cInstAddrMemUsgInstIndex (1.3.6.1.4.1.25506.2.18.2.17.1.5)
read-only
Unsigned32
1..127
NAT instance ID.
As per the MIB.
hh3cInstAddrMemUsgGrpUsage (1.3.6.1.4.1.25506.2.18.2.17.1.6)
read-only
Unsigned32
0..100
NAT address range usage.
As per the MIB.
hh3cInstAddrMemUsgGrpIPMask
(1.3.6.1.4.1.25506.2.18.2.17.1.7)
read-only
OCTET STRING
SIZE(0..32)
Mask for a NAT address range.
hh3cNatIPPoolGroupTable
About this table
Use this table to obtain NAT address pool resources usage in a NAT instance.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cNatIPPoolName.
Object (OID)
Access
Value range
Implementation
hh3cNatIPPoolName (1.3.6.1.4.1.25506.2.18.2.19.1.1)
not-accessible
Unsigned32
OCTET STRING
Name of the NAT address pool.
As per the MIB.
hh3cNatIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.19.1.2)
read-only
IpAddress
Unsigned32
NAT address pool usage.
As per the MIB.
hh3cNatIPPoolTotalCount (1.3.6.1.4.1.25506.2.18.2.19.1.3)
read-only
Unsigned32
Unsigned32
Total number of IP addresses in the NAT address pool.
As per the MIB.
hh3cNatIPPoolUsedCount (1.3.6.1.4.1.25506.2.18.2.19.1.4)
read-only
Unsigned32
Unsigned32
Number of used IP addresses in the NAT address pool.
As per the MIB.
hh3cNatIPPoolUnusedCount
(1.3.6.1.4.1.25506.2.18.2.19.1.5)
read-only
OCTET STRING
Unsigned32
Number of unused IP addresses in the NAT address pool.
As per the MIB.
Notifications
hh3cNATBandwidthTraps
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.18.2.15
The CGN card bandwidth usage exceeded the alarm threshold.
Error
Major
1.3.6.1.4.1.25506.2.18.2.15.0.2 (hh3cNATBandwidthRecoveryTrap)
ON
Notification triggers
This notification is generated when the CGN card bandwidth usage exceeds the specified alarm threshold.
System impact
An increasing forwarding bandwidth of the CGN card might interrupt services.
Status control
ON
CLI: Use the snmp-agent trap enable nat bandwith command.
OFF
CLI: Use the undo snmp-agent trap enable nat bandwith command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.18.2.15.1.1 (hh3cNATBandwidthRatio)
Bandwidth usage threshold.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.18.2.15.1.2 (hh3cNATChassis)
Chassis number.
N/A
Unsigned32
(0..65534)
1.3.6.1.4.1.25506.2.18.2.15.1.3 (hh3cNATSlot)
Slot number.
N/A
Unsigned32
(0..65534)
1.3.6.1.4.1.25506.2.18.2.15.1.4 (hh3cNATCpu)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
To resolve this issue:
1.Execute the display nat statistics packet command in any view to identify whether the current bandwidth or history maximum bandwidth of the CGN card exceeds the maximum forwarding bandwidth.
  - If the current bandwidth or history maximum bandwidth has approached the maximum forwarding bandwidth, go to step 2.
  - If the current bandwidth or history maximum bandwidth does not approach the maximum forwarding bandwidth, go to step 3.
2.Expand the card capacity and identify whether the notification occurs again.
  - If the notification does not occur any longer, the issue has been resolved.
  - If the notification occurs again, go to step 3.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The CGN card bandwidth usage dropped below the alarm threshold.
Recovery
Warning
ON
This notification is generated when the CGN card bandwidth usage drops below the specified alarm threshold.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
(0..65534)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
No action is required.
hh3cInstAddrGrpUsageTraps
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.18
Resource usage of the NAT address group exceeded the threshold.
Error
Major
1.3.6.1.4.1.25506.2.18.2.18.0.2 (hh3cInstAddrGrpUsageRecovTrap)
ON
This notification is generated when the resource usage of a NAT address group reaches or exceeds the threshold specified by using the nat address-group-usage threshold or nat log port-block usage threshold command.
System impact
When the notification has just generated, services are not affected. If the maximum number of assignable ports for the NAT address group is reached, new users will fail to apply for public ports.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.18.2.18.1.1 (hh3cInstAddrTrapInstName)
Global NAT instance name.
N/A
DisplayString
(1..32)
1.3.6.1.4.1.25506.2.18.2.18.1.2 (hh3cInstAddrTrapGrpIndex)
Index of the address group.
N/A
Unsigned32
(1..65536)
1.3.6.1.4.1.25506.2.18.2.18.1.3 (hh3cInstAddrTrapInstIndex)
Index of the global NAT instance.
N/A
Unsigned32
(1..127)
1.3.6.1.4.1.25506.2.18.2.18.1.4 (hh3cInstAddrTrapUsgThreshold)
Resource usage threshold for the NAT address group.
N/A
Unsigned32
(0..100)
Recommended action
1.Execute the display nat instance instance-name address-group command to identify whether the address group resource usage drops below the threshold.
  - If the resource usage drops below the threshold set by the nat log port-block usage threshold command, go to step 4.
  - If the resource usage is equal to or greater than the threshold set by the nat log port-block usage threshold command, go to step 2.
2.Execute the nat log port-block usage threshold command to set a greater port block usage threshold and verify if the notification occurs again.
3.Add resources to the address pool and verify if the notification occurs again.
  - If the notification occurs again, go to step 4.
4.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The global address group recovered from a resource usage alarm.
Recovery
Warning
ON
This notification is generated when the address group resource usage drops below 87.5% of the alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
DisplayString
(1..32)
N/A
Unsigned32
(1..65536)
N/A
Unsigned32
(1..127)
Recommended action
hh3cNatIPPoolAddrUsageExceedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.20.0.1
Address usage of the NAT address pool reached or exceeded the threshold.
Error
Major
1.3.6.1.4.1.25506.2.18.2.20.0.2 (hh3cNatIPPoolAddrUsageRecoveryTrap)
ON
This notification is generated when the address usage of a NAT address pool reaches or exceeds the subnet acquisition threshold set by using the ip-usage-threshold command.
System impact
When the notification has just generated, services are not affected. If the maximum number of assignable addresses is reached, addresses in the NAT address pool cannot be applied.
Status control
ON
CLI: Use the snmp-agent trap enable nat ip-pool-usage command.
OFF
CLI: Use the undo snmp-agent trap enable nat ip-pool-usage command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.18.2.20.1.1 (hh3cNatTrapIPPoolName)
NAT address pool name.
N/A
OCTET STRING
SIZE (1..32)
1.3.6.1.4.1.25506.2.18.2.20.1.2 (hh3cNatTrapIPPoolAddrUsage)
IP usage of the NAT address pool.
N/A
Unsigned32
(1..100)
Recommended action
1.Execute the display nat ip-pool command to identify whether the address usage for the global address pool reaches or exceeds the threshold.
  - If the address usage for the global address pool reaches or exceeds the threshold, go to step 2.
  - If the address usage for the global address pool is lower than the threshold, go to step 3.
2.Reduce the address usage for the global address pool or execute the ip-usage-threshold command to set a larger subnet acquisition threshold, and then verify if the notification occurs again.
Basic information
OID
Event
Severity
Default status
The NAT address pool recovered from an address usage alarm.
Recovery
Warning
ON
This notification is generated when the address usage for a NAT address pool drops below 87.5% of the threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
SIZE (1..32)
N/A
Unsigned32
(1..100)
Recommended action
hh3cNatIPPoolIpAllocFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.20.0.3
Public address resources in the NAT address pool ran out.
Error
Major
1.3.6.1.4.1.25506.2.18.2.20.0.4 (hh3cNatIPPoolIpAllocFailRecoveryTrap)
ON
This notification is generated when the public address resources in a NAT address pool run out.
System impact
The NAT address pool cannot allocate public addresses any longer.
Status control
ON
CLI: Use the snmp-agent trap enable nat ip-pool-alloc-fail command.
OFF
CLI: Use the undo snmp-agent trap enable nat ip-pool-alloc-fail command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
SIZE (1..32)
Recommended action
1.Execute the display nat ip-pool command to identify whether the public address resources in the global address pool run out.
  - If the public address resources in the global address pool run out, go to step 2.
  - If the public address resources in the global address pool do not run out, go to step 3.
2.Reduce the address usage for the global address pool or add new public addresses to the address pool as required, and then verify if the notification occurs again.
3.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The NAT address pool recovered from a public address resource usage alarm.
Recovery
Warning
ON
This notification is generated when the public address usage for a NAT address pool reaches or drops below 87.5%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
SIZE (1..32)
Recommended action
hh3cNatIPPoolIpApplyFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.20.0.5
Failed to add an address range to a NAT address pool.
Error
Major
N/A (N/A)
ON
This notification is generated when you fail to add an address range to a NAT address pool.
This notification might be generated when the following events occur:
The IP addresses on the subnet requested by a dynamic global address pool on the UP from the CP overlap with IP addresses in another global address pool.
The number of addresses in a global address pool on the UP has reached the upper limit.
System impact
You fail to add an address range to a NAT address pool. As a result, the NAT address pool cannot allocate addresses.
Status control
ON
CLI: Use the snmp-agent trap enable nat ip-pool-add-fail command.
OFF
CLI: Use the undo snmp-agent trap enable nat ip-pool-add-fail command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
SIZE (1..32)
1.3.6.1.4.1.25506.2.18.2.20.1.3 (hh3cNatTrapIPPoolMemStartIP)
Start address of the address range.
N/A
IpAddress
1.3.6.1.4.1.25506.2.18.2.20.1.4 (hh3cNatTrapIPPoolMemIPMask)
Mask for the address range.
N/A
OCTET STRING
SIZE(0..32)
1.3.6.1.4.1.25506.2.18.2.20.1.5 (hh3cNatTrapIPPoolFailReason)
Reason why the address range fails to be added.
N/A
OCTET STRING
SIZE (1..127)
Recommended action
1.Obtain the value for the hh3cNatTrapIPPoolFailReason field in the notification.
  - If the value is The number of addresses in the global address pool has reached the upper limit, the number of addresses in the address pool has reached the upper limit and you cannot add new addresses to the address pool. Go to step 2.
  - If the value is not The number of addresses in the global address pool has reached the upper limit, the address range to be added conflicts with the local address. Use the display nat ip-pool, display nat address-group, display nat port-block-group, or display nat server command to identify the public address conflicting with the address range to be added, and then go to step 3.
2.Reduce NAT addresses and verify if the notification occurs again.
3.Delete the public address conflicting with the address range to be added and verify if the notification occurs again.
hh3cNatPortBlockAllocFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.21.0.1
Resources in a NAT address group ran out.
Error
Major
1.3.6.1.4.1.25506.2.18.2.21.0.2 (hh3cNatPortBlockAllocFailRecoveryTrap)
ON
This notification is generated when the resource of a NAT address group run out.
System impact
The address group cannot allocate public addresses or process new services.
Status control
ON
CLI: Use the snmp-agent trap enable nat address-group-alloc-fail command.
OFF
CLI: Use the undo snmp-agent trap enable nat address-group-alloc-fail command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.18.2.21.1.1 (hh3cNatTrapAddrGrpIndex)
Address group index.
N/A
INTEGER32
(1..65536)
1.3.6.1.4.1.25506.2.18.2.21.1.10 (hh3cNatTrapAddrGrpChassis)
Chassis number.
N/A
INTEGER32
(0..65534)
1.3.6.1.4.1.25506.2.18.2.21.1.11 (hh3cNatTrapAddrGrpSlot)
Slot number.
N/A
INTEGER32
(0..65534)
1.3.6.1.4.1.25506.2.18.2.21.1.12 (hh3cNatTrapAddrGrpCpu)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
1.Execute the display nat instance instance-name address-group group-id command to identify whether the address group resource usage reaches 100%.
  - If the address pool resource usage has reached 100%, add resources to the address pool and verify if the notification occurs again. If the notification occurs again, go to step 2.
  - If the address pool resource usage does not reach 100%, go to step 2.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The NAT address group recovered from a resource usage alarm.
Recovery
Warning
ON
This notification is generated when the NAT address group resource usage drops to or below 87.5%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Global address pool index.
N/A
INTEGER32
(1..65536)
Chassis number.
N/A
INTEGER32
(0..65534)
Slot number.
N/A
INTEGER32
(0..65534)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
hh3cNatPortAllocFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.21.0.3
Port resources in a NAT port block ran out.
Error
Major
1.3.6.1.4.1.25506.2.18.2.21.0.4 (hh3cNatPortAllocFailRecoveryTrap)
ON
This notification is generated when the port resources in a NAT port block run out.
System impact
Establishment of new sessions fails.
Status control
ON
CLI: Use the snmp-agent trap enable nat port-alloc-fail command.
OFF
CLI: Use the undo snmp-agent trap enable nat port-alloc-fail command.
Object
OID (object name)
Index
Value range
Address pool index.
N/A
INTEGER32
(1..65536)
1.3.6.1.4.1.25506.2.18.2.21.1.2 (hh3cNatTrapUserIPType)
Type of the user private IP address.
N/A
InetAddressType
ipv4(1), ipv6(2)
1.3.6.1.4.1.25506.2.18.2.21.1.3 (hh3cNatTrapUserIP)
Private IP address.
N/A
InetAddress
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.18.2.21.1.4 (hh3cNatTrapUserID)
User ID.
N/A
INTEGER32
1.3.6.1.4.1.25506.2.18.2.21.1.5 (hh3cNatTrapAddrGrpMemberIP)
Public IP address.
N/A
IpAddress
1.3.6.1.4.1.25506.2.18.2.21.1.6 (hh3cNatTrapMemberIPPortNums)
Port count.
N/A
INTEGER32
(1..65536)
Chassis number.
N/A
INTEGER32
(0..65534)
Slot number.
N/A
INTEGER32
(0..65534)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
1.Execute the display nat user-table command to identify whether the number of user sessions reaches the upper limit of assignable resources for the port blocks.
  - If the user session number has reached the upper limit, expand the pre-allocated port block size or configure extended port blocks, and then verify if the notification occurs again. If the notification occurs again, go to step 2.
  - If the user session number does not reach the upper limit, go to step 2.
Basic information
OID
Event
Severity
Default status
The NAT port block recovered from a port resource usage alarm.
Recovery
Warning
ON
This notification is generated when the port usage of a NAT port block drops below 87.5%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
INTEGER32
(1..65536)
N/A
InetAddressType
ipv4(1), ipv6(2)
Private IP address.
N/A
InetAddress
User ID.
N/A
INTEGER32
Public IP address.
N/A
IpAddress
Port count.
N/A
INTEGER32
(1..65536)
Chassis number.
N/A
INTEGER32
(0..65534)
Slot number.
N/A
INTEGER32
(0..65534)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
hh3cNatPortUsageTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.18.2.21.0.5
The port usage of a NAT port block reached or exceeded the threshold.
Error
Major
1.3.6.1.4.1.25506.2.18.2.21.0.6 (hh3cNatPortUsageRecoveryTrap)
ON
This notification is generated when the port usage of a NAT port block reaches or exceeds the threshold specified by using the nat log port-block port-usage threshold command.
System impact
When the notification has just generated, services are not affected. If the maximum number of available ports for users is reached, new sessions fail to be established.
Status control
ON
CLI: Use the snmp-agent trap enable nat port-usage command.
OFF
CLI: Use the undo snmp-agent trap enable nat port-usage command.
Object
OID (object name)
Index
Value range
N/A
INTEGER32
(1..65536)
N/A
InetAddressType
ipv4(1), ipv6(2)
Private IP address.
N/A
InetAddress
User ID.
N/A
INTEGER32
Public IP address.
N/A
IpAddress
Port count.
N/A
INTEGER32
(1..65536)
1.3.6.1.4.1.25506.2.18.2.21.1.7 (hh3cNatTrapPortAllocMode)
Port allocation mode.
N/A
INTEGER
cdm(1), eim(2)
1.3.6.1.4.1.25506.2.18.2.21.1.8 (hh3cNatTrapPortUsgProtocol)
Protocol type.
N/A
INTEGER32
0..255
1.3.6.1.4.1.25506.2.18.2.21.1.9 (hh3cNatTrapPortUsgThreshold)
Alarm threshold for the port block usage.
N/A
INTEGER32
Chassis number.
N/A
INTEGER32
(0..65534)
Slot number.
N/A
INTEGER32
(0..65534)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
1.Execute the display nat user-table command to identify whether the port usage of the NAT port block reaches or exceeds the threshold.
  - If the port usage of the NAT port block is equal to or greater than the specified alarm threshold, go to step 2.
  - If the port usage of the NAT port block is lower than the specified alarm threshold, go to step 3.
2.Execute the nat log port-block port-usage threshold command to set a greater port usage threshold for the port block and verify if the notification occurs again.
Basic information
OID
Event
Severity
Default status
The NAT port block recovered from a port usage alarm.
Recovery
Warning
ON
This notification is generated when the port usage of a NAT port block drops below 87.5% of the threshold specified by using the nat log port-block port-usage threshold command.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
INTEGER32
(1..65536)
N/A
InetAddressType
ipv4(1), ipv6(2)
Private IP address.
N/A
InetAddress
User ID.
N/A
INTEGER32
Public IP address.
N/A
IpAddress
Port count.
N/A
INTEGER32
(1..65536)
N/A
INTEGER
cdm(1), eim(2)
Protocol type.
N/A
INTEGER32
0..255
N/A
INTEGER32
Chassis number.
N/A
INTEGER32
(0..65534)
Slot number.
N/A
INTEGER32
(0..65534)
CPU number.
N/A
INTEGER32
(0..7)
Recommended action
