| 05-OSPF-TRAP-MIB | 175.94 KB |
OSPF-TRAP-MIB
About this MIB
Use this MIB to set, edit, and view OSPF protocol and notification information about network devices.
MIB file name
rfc4750-ospf-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14)
Scalar objects
ospfSetTrap
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfSetTrap (1.3.6.1.2.1.14.16.1.1) |
read-write |
OCTET STRING |
OCTET STRING (4) |
Whether OSPF notification is enabled. |
As per the MIB. |
ospfConfigErrorType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfConfigErrorType (1.3.6.1.2.1.14.16.1.2) |
read-only |
INTEGER |
badVersion (1), areaMismatch (2), unknownNbmaNbr (3), unknownVirtualNbr (4), authTypeMismatch(5), authFailure (6), netMaskMismatch (7), helloIntervalMismatch (8), deadIntervalMismatch (9), optionMismatch (10), mtuMismatch (11), duplicateRouterId (12), noError (13) |
Possible configuration error type. |
As per the MIB. |
ospfPacketType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfPacketType (1.3.6.1.2.1.14.16.1.3) |
read-only |
INTEGER |
hello (1), dbDescript (2), lsReq (3), lsUpdate (4), lsAck (5), nullPacket (6) |
OSPF packet type. |
As per the MIB. |
ospfPacketSrc
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfPacketSrc (1.3.6.1.2.1.14.16.1.4) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address that cannot be identified by a neighbor. |
As per the MIB. |
Notifications
ospfVirtIfStateChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.14.16.2.1 |
Virtual interface state changes. |
Informational |
Warning |
ON |
A notification sent when the state of a virtual interface regresses (for example, changing from P2P to Down) or progresses to a terminal state (for example, P2P).
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtif-state-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.14.1.1 (ospfRouterId) |
Unique identifier of a router in an AS. |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.9.1.1 (ospfVirtIfAreaId) |
ID of the area to which the virtual link belongs. |
No |
AreaID |
IpAddress |
1.3.6.1.2.1.14.9.1.2 (ospfVirtIfNeighbor) |
Router ID of the virtual neighbor. |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.9.1.7 (ospfVirtIfState) |
Virtual interface state. |
No |
INTEGER |
down (1) pointToPoint (4) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
ospfNbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.2 |
Neighbor state changes. |
Informational |
Warning |
ON |
A notification sent when the state of a neighbor regresses (for example, changing from Attempt or Full to 1-Way or Down) or progresses to a terminal state (for example, 2-Way or Full). When the state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full, the notification is generated by the DR. An ospfIfStateChange notification will be generated when the DR does down.
Status control
ON
CLI: Use the snmp-agent trap enable ospf neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf neighbor-state-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.10.1.1 (ospfNbrIpAddr) |
IP address of the neighbor. |
No |
IpAddress |
Standard MIB values. |
1.3.6.1.2.1.14.10.1.2 (ospfNbrAddressLessIndex) |
Set to 0 on an interface having an IP address, and set to the value of interface index in the Internet Standard MIB on an interface having no IP address. |
No |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
1.3.6.1.2.1.14.10.1.3 (ospfNbrRtrId) |
Router ID of the neighbor. |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.10.1.6 (ospfNbrState) |
Neighbor state. |
No |
INTEGER |
down (1) attempt (2) init (3) twoWay (4) exchangeStart (5) exchange (6) loading (7) full (8) |
1.3.6.1.2.1.31.1.1.1.1 (ifName) |
Interface name |
No |
DisplayString |
OCTET STRING(0..255) |
Recommended action
ospfVirtNbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.3 |
Virtual neighbor state changes. |
Informational |
Warning |
ON |
A notification sent when the state of a virtual neighbor regresses (for example, changing from Attempt or Full to 1-Way or Down) or progresses to a terminal state (for example, Full).
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtneighbor-state-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.11.1.1 (ospfVirtNbrArea) |
ID of the area to which the virtual neighbor belongs. |
No |
AreaID |
IpAddress |
1.3.6.1.2.1.14.11.1.2 (ospfVirtNbrRtrId) |
A 32-bit integer that uniquely identifies the neighboring router in the AS. |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.11.1.5 (ospfVirtNbrState) |
Neighbor state. |
No |
INTEGER |
Recommended action
ospfIfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.4 |
Interface configuration error. |
Error |
Warning |
ON |
A notification sent when an interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents an adjacency from establishing.
Status control
ON
CLI: Use the snmp-agent trap enable ospf config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf config-error command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.7.1.1 (ospfIfIpAddress) |
IP address of the interface. |
No |
IpAddress |
1.3.6.1.2.1.14.7.1.2 (ospfAddressLessIf) |
Used to distinguish interface instances with addresses configured and those without addresses configured. |
No |
1.3.6.1.2.1.14.16.1.4 (ospfPacketSrc) |
No |
IpAddress |
1.3.6.1.2.1.14.16.1.2 (ospfConfigErrorType) |
Configuration error type. |
No |
INTEGER |
badVersion (1) areaMismatch (2) unknownNbmaNbr (3) unknownVirtualNbr (4) authTypeMismatch(5) authFailure (6) netMaskMismatch (7) helloIntervalMismatch (8) deadIntervalMismatch (9) optionMismatch (10) mtuMismatch (11) duplicateRouterId (12) noError (13) |
1.3.6.1.2.1.14.16.1.3 (ospfPacketType) |
OSPF packet type. |
No |
INTEGER |
hello (1) dbDescript (2) lsReq (3) lsUpdate (4) lsAck (5) nullPacket (6) |
Recommended action
To resolve this issue:
1. Verify that the interface configuration is correct.
2. If the issue persists, contact H3C Support.
ospfVirtIfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.5 |
Virtual interface configuration error. |
Error |
Warning |
ON |
A notification sent when an OSPF virtual interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents establishment of an adjacency.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-config-error command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
RouterID |
IpAddress |
No |
INTEGER |
OSPF packet type. |
No |
INTEGER |
Recommended action
1. Verify that the virtual interface configuration is correct.
ospfIfAuthFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.6 |
Interface authentication failure. |
Error |
Warning |
ON |
A notification sent when an interface on a router receives a packet from another router with mismatched authentication key or authentication type.
Status control
ON
CLI: Use the snmp-agent trap enable ospf authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf authentication-failure command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
IpAddress |
No |
IP address that cannot be identified by a neighbor instance. |
No |
IpAddress |
No |
INTEGER |
OSPF packet type. |
No |
INTEGER |
Recommended action
1. Verify that the interface authentication settings are correct.
ospfVirtIfAuthFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.7 |
Virtual interface authentication failure. |
Error |
Warning |
ON |
A notification sent when an OSPF virtual interface on a router receives a packet from another router with mismatched authentication key or authentication type.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-authentication-failure command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
RouterID |
IpAddress |
No |
INTEGER |
OSPF packet type. |
No |
INTEGER |
Recommended action
1. Verify that the virtual interface authentication settings are correct.
ospfIfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.8 |
An interface receives an error packet. |
Informational |
Warning |
ON |
A notification sent when an interface receives an OSPF packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospf bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf bad-packet command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
IpAddress |
No |
No |
IpAddress |
OSPF packet type. |
No |
INTEGER |
Recommended action
ospfVirtIfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.9 |
A virtual interface receives an error packet. |
Informational |
Warning |
ON |
A notification sent when a virtual interface receives an OSPF packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-bad-packet command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
RouterID |
IpAddress |
OSPF packet type. |
No |
INTEGER |
Recommended action
ospfTxRetransmit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.10 |
An interface retransmits an OSPF packet. |
Informational |
Warning |
ON |
A notification sent when an interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
Status control
ON
CLI: Use the snmp-agent trap enable ospf retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf retransmit command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
IpAddress |
No |
No |
RouterID |
IpAddress |
OSPF packet type. |
No |
INTEGER |
1.3.6.1.2.1.14.4.1.2 (ospfLsdbType) |
LSA type. Type-5 LSAs are not displayed. |
No |
INTEGER |
routerLink (1) networkLink (2) summaryLink (3) asSummaryLink (4) asExternalLink (5) multicastLink (6) nssaExternalLink (7) areaOpaqueLink (10) |
1.3.6.1.2.1.14.4.1.3 (ospfLsdbLsid) |
LS ID. |
No |
IpAddress |
1.3.6.1.2.1.14.4.1.4 (ospfLsdbRouterId) |
Router ID of the device that generates the LSA. |
No |
RouterID |
IpAddress |
Recommended action
ospfVirtIfTxRetransmit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.11 |
A virtual interface retransmits an OSPF packet. |
Informational |
Warning |
ON |
A notification sent when a virtual interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-retransmit command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
RouterID |
IpAddress |
OSPF packet type. |
No |
INTEGER |
No |
INTEGER |
LS ID |
No |
IpAddress |
No |
RouterID |
IpAddress |
Recommended action
ospfOriginateLsa
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.12 |
The local device generates a new LSA. |
Informational |
Warning |
ON |
A notification sent when the local device generates a new LSA. This notification is generated only when an LSA is originated because of a topology change. Flushing of aged LSAs and refreshes of LSAs will not trigger this notification.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-originate command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-originate command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.4.1.1 (ospfLsdbAreaId) |
ID of the area from which the LSA was received. |
No |
AreaID |
IpAddress |
No |
INTEGER |
LS ID. |
No |
IpAddress |
No |
RouterID |
IpAddress |
Recommended action
ospfMaxAgeLsa
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.13 |
An LSA in the LSDB ages. |
Informational |
Warning |
ON |
A notification sent when an LSA in the LSDB ages.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-maxage command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-maxage command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
INTEGER |
LS ID. |
No |
IpAddress |
No |
RouterID |
IpAddress |
Recommended action
ospfLsdbOverflow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.14 |
The number of LSAs in the LSDB of a device exceeds the upper limit. |
Error |
Warning |
ON |
A notification sent when the number of LSAs in the LSDB of a device exceeds the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-overflow command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.1.11 (ospfExtLsdbLimit) |
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit. |
No |
Integer32 |
-1..'7FFFFFFF'h |
Recommended action
1. Reduce the number of LSAs.
ospfLsdbApproachingOverflow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.15 |
The number of LSAs in the LSDB of a device reaches 90% the upper limit. |
Error |
Warning |
ON |
A notification sent when the number of LSAs in the LSDB of a device reaches 90% the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-approaching-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-approaching-overflow command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
Integer32 |
-1..'7FFFFFFF'h |
Recommended action
ospfIfStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.16 |
Interface state changes. |
Informational |
Warning |
ON |
A notification sent when the state of an OSPF interface regresses (for example, changing from Dr to Down) or progresses to a terminal state (for example, Point-to-Point, DR Other, Dr, or Backup).
Status control
ON
CLI: Use the snmp-agent trap enable ospf if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf if-state-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
IpAddress |
No |
1.3.6.1.2.1.14.7.1.12 (ospfIfState) |
Interface state. |
No |
INTEGER |
down (1) loopback (2) waiting (3) pointToPoint (4) designatedRouter (5) backupDesignatedRouter (6) otherDesignatedRouter (7) |
Recommended action
ospfNssaTranslatorStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.17 |
A router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes. |
Informational |
Warning |
ON |
A notification sent when a router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf nssatranslator-status-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.2.1.1 (ospfAreaId) |
Area ID, a 32-bit integer that uniquely identifies an area. |
No |
AreaID |
IpAddress |
1.3.6.1.2.1.14.2.1.12 (ospfAreaNssaTranslatorState) |
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs. |
No |
INTEGER |
enabled (1) elected (2) disabled (3) |
Recommended action
ospfRestartStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.18 |
GR restarter state changes. |
Informational |
Warning |
ON |
A notification sent when the state of the GR restarter changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grrestarter-status-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.1.21 (ospfRestartStatus) |
GR restarter state. |
No |
INTEGER |
notRestarting (1) plannedRestart (2) unplannedRestart (3) |
1.3.6.1.2.1.14.1.19 (ospfRestartInterval) |
Graceful restart timeout interval. |
No |
Integer32 |
1..1800 |
1.3.6.1.2.1.14.1.23 (ospfRestartExitReason) |
Reason why the GR restarter exited. |
No |
INTEGER |
none (1) inProgress (2) completed (3) timedOut (4) topologyChanged (5) |
Recommended action
ospfNbrRestartHelperStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.19 |
GR helper state changes. |
Informational |
Warning |
ON |
A notification sent when the GR helper state of a neighbor changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grhelper-status-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
IpAddress |
No |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.10.1.12 (ospfNbrRestartHelperStatus) |
GR helper state. |
No |
INTEGER |
notHelping (1) helping (2) |
1.3.6.1.2.1.14.10.1.13 (ospfNbrRestartHelperAge) |
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor. |
No |
Unsigned32 |
1.3.6.1.2.1.14.10.1.14 (ospfNbrRestartHelperExitReason) |
Reason why the GR helper exited. |
No |
INTEGER |
Recommended action
ospfVirtNbrRestartHelperStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.14.16.2.20 |
The GR helper state of a virtual neighbor changes. |
Informational |
Warning |
ON |
A notification sent when the GR helper state of a virtual neighbor changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtgrhelper-status-change command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
RouterID |
IpAddress |
No |
AreaID |
IpAddress |
No |
RouterID |
IpAddress |
1.3.6.1.2.1.14.11.1.9 (ospfVirtNbrRestartHelperStatus) |
Whether the router is acting as a GR helper for the virtual neighbor. |
No |
INTEGER |
1.3.6.1.2.1.14.11.1.10 (ospfVirtNbrRestartHelperAge) |
No |
Unsigned32 |
1.3.6.1.2.1.14.11.1.11 (ospfVirtNbrRestartHelperExitReason) |
No |
INTEGER |
none (1) inProgress (2) completed (3) timedOu t 4) topologyChanged (5) |
Recommended action
