04-Layer 3—IP Services Command Reference
HomeSupportSwitchesS6520X-EI SeriesReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Command References-R6636Pxx-6W10004-Layer 3—IP Services Command Reference
18-HTTP redirect commands
18-HTTP redirect commands 37.46 KB
http-redirect https-port
Use http-redirect https-port to specify the HTTPS redirect listening port number.
Use undo http-redirect https-port to restore the default.
http-redirect https-port port-number
The HTTPS redirect listening port number is 6654.
port-number: Specifies the TCP port number on which the HTTPS redirect service listens for HTTPS requests. The value range for the port number is 1 to 65535.
To avoid service unavailability caused by port conflict, do not specify a TCP port number used by a well-known protocol or used by any other service. To display TCP port numbers that have been used by services, use the display tcp command.
# Specify 8888 as the HTTPS redirect listening port number.
[Sysname] http-redirect https-port 8888
http-redirect ssl-server-policy
Use http-redirect ssl-server-policy to associate an SSL server policy with the HTTPS redirect service.
Use undo http-redirect ssl-server-policy to restore the default.
http-redirect ssl-server-policy policy-name
No SSL server policy is associated with the HTTPS redirect service. The HTTPS redirect service uses a self-assigned certificate and the default SSL parameters.
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
HTTPS redirect is unavailable if the associated SSL server policy does not exist. You can first associate a nonexistent SSL server policy with the HTTPS redirect service and then configure the SSL server policy.
If you change the SSL server policy associated with the HTTPS redirect service, the new policy takes effect immediately.
If you perform this task multiple times, the most recent configuration takes effect.
# Associate SSL server policy policy1 with the HTTPS redirect service.
[Sysname] http-redirect ssl-server-policy policy1
ssl server-policy
