H3C MSR Router Series Interface Module Guide-6W129
HomeSupportProduct LiteratureHardware Information & SpecificationsH3C MSR Router Series Interface Module Guide-6W129
01-Text
01-Text 11.18 MB
SIC/DSIC interface modules· 1
Ethernet switching modules· 1
SIC-4FSW/SIC-4FSWP/DSIC-9FSW/DSIC-9FSWP· 1
SIC-4GSW·· 3
SIC-4GSWF· 4
Ethernet interface modules· 5
SIC-1FEA· 5
SIC-1FEF· 6
SIC-1GEC-V2· 7
POS (SDH/SONET) interface modules· 9
RT-SIC-1POS-STM1· 9
E1/T1 interface modules· 9
SIC-E1-F· 10
SIC-2E1-F· 11
SIC-1EPRI 12
SIC-T1-F· 13
Serial interface modules· 14
SIC-8AS· 14
SIC-16AS· 15
SIC-1SAE/SIC-2SAE/SIC-4SAE· 16
SIC-4RS· 18
Analog modem interface modules· 20
SIC-1AM/SIC-2AM·· 20
XDSL interface modules· 21
SIC-1ADSL· 22
SIC-1ADSL-I 23
ISDN BRI interface modules· 24
SIC-1BS/SIC-2BS· 24
Voice interface modules· 25
SIC-1FXS/SIC-1FXO/SIC-2FXS/SIC-2FXO·· 26
SIC-2FXS1FXO·· 27
DSIC-4FXS1FXO·· 28
SIC-1BSV/SIC-2BSV· 29
SIC-1VE1· 31
SIC-1VT1· 32
SIC-1VE1T1· 33
3G interface modules· 34
SIC-3G-CDMA· 34
SIC-3G-TD·· 36
SIC-3G-HSPA· 37
4G interface modules· 39
SIC-4G-LTE-M·· 39
SIC-4G-CNDE· 41
RT-SIC-4G-CAT6· 43
SIC-D4G-CNDE· 45
5G interface modules· 48
RT-SIC-5G·· 48
RT-SIC-5G-CN· 51
Network data encryption modules· 54
SIC-CNDE· 54
SIC-CNDE-SJK· 55
SIC-4G-CNDE-SJK· 55
SIC-D4G-CNDE-SJK· 57
WLAN interface modules· 60
SIC-AP220· 60
SIC-AP320· 61
M.2 riser SIC modules· 62
RT-SIC-M2-SATA· 62
MIM interface modules· 65
ATM interface modules· 65
MIM-1ATM-OC3· 65
POS (SDH/SONET) interface modules· 66
MIM-1POS· 66
E1/T1 interface modules· 67
MIM-1E1/MIM-2E1/MIM-4E1/MIM-1E1-F/MIM-2E1-F/MIM-4E1-F· 67
MIM-8E1/MIM-8E1-F· 69
MIM-2T1/MIM-4T1-F· 70
Interface LEDs· 71
E3/T3 interface modules· 71
MIM-1CE3· 71
Serial interface modules· 72
MIM-2SAE/MIM-4SAE/MIM-8SAE· 73
MIM-8ASE/MIM-16ASE· 74
POS terminal access interface modules· 75
Voice interface modules· 77
MIM-8FXS8FXO·· 77
MIM-16FXS· 78
MIM-2VE1· 79
MIM-2VT1· 80
MIM-1VE1· 81
MIM-1VT1· 82
MIM-4FXS/MIM-4FXO·· 83
MIM-4E&M·· 84
HMIM/DHMIM interface modules· 86
Ethernet switching modules· 86
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE· 86
HMIM-8GSWF· 88
Ethernet interface modules· 89
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE· 89
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2· 90
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF· 92
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2· 93
RT-HMIM-4XP· 94
ATM interface modules· 95
HMIM-1ATM-OC3· 95
POS (SDH/SONET) interface modules· 96
HMIM-1POS· 97
RT-HMIM-2POS-STM1· 97
RT-HMIM-4POS-STM1/4· 99
CPOS (SDH/SONET) interface modules· 100
HMIM-1CPOS/HMIM-2CPOS· 100
E1/T1 interface modules· 101
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F· 102
HMIM-8E1/HMIM-8E1-F· 104
RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3· 105
HMIM-2T1/HMIM-4T1-F· 107
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F· 108
E3/T3 interface modules· 111
HMIM-1CE3· 111
Serial interface modules· 112
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE· 112
RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2· 114
HMIM-8ASE/HMIM-16ASE· 115
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2· 116
POS terminal access interface modules· 117
HMIM-1E1POS· 118
DHMIM-1E1POS1DM·· 119
Digital modem interface modules· 121
DHMIM-1DM·· 121
Voice interface modules· 122
HMIM-16FXS· 123
HMIM-8FXS8FXO·· 123
HMIM-2VE1· 124
HMIM-2VT1· 125
HMIM-1VE1· 126
HMIM-1VT1· 127
HMIM-4FXS/HMIM-4FXO·· 128
HMIM-4E&M/HMIM-8E&M·· 129
Analog modem modules· 130
HMIM-6AM·· 131
HMIM-6FCM·· 131
Network data encryption modules· 132
HMIM-CNDE-SJK· 132
HMIM adapters· 133
HMIM-Adapter/HMIM-Adapter-H· 133
VPM modules· 134
VPM purchase guide· 134
Introduction· 134
Interface specifications· 134
XMIM interface modules· 134
Ethernet interface modules· 135
RT-XMIM-8GEE-R· 135
RT-XMIM-8GEF-R· 136
POS (SDH/SONET) interface modules· 137
RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS· 138
E1 interface modules· 139
RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1· 139
Cables and the connection methods· 142
Ethernet interface· 142
Fiber port 143
E1 interface· 144
T1 interface· 152
E3/T3 interface· 153
Synchronous/asynchronous serial ports· 154
Asynchronous serial ports· 156
ADSL/BS/FXS/FXO/AM/FCM interface· 161
E&M interface· 162
BSV/BSE interface· 163
3G interface· 165
4G interface· 166
5G interface· 170
GPS interface· 174
GNSS interface· 175
WLAN interface· 176
Link mode of interfaces on Ethernet switching modules and interface modules  177
Interface module power consumption· 180
CAUTION
CAUTION:
·     SIC interface modules cannot be hot-swapped, with the exception of those with a remove button.
·     To remove a SIC interface module with a remove button while the device is operating, first press the remove button or execute the remove command. For the specific operation instructions, see the description for the SIC interface module. The remove command and the remove button cannot be used simultaneously, as this might cause the SIC interface module to become unusable.
·     DSIC interface modules cannot be hot-swapped.
MSR series routers use modular design and support a wide range of optional smart interface cards (SICs) and double smart interface cards (DSICs). A SIC occupies one SIC slot and a DSIC occupies two SIC slots. The SIC/DSIC series interface modules provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, ADSL, audio interface, and Layer 2 switching interface.
·     SIC-4FSW
·     SIC-4FSWP
·     DSIC-9FSW
·     DSIC-9FSWP
·     SIC-4GSW
·     SIC-4GSWF
Introduction
The SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP interface modules are 4/9-port 10/100 Mbps Ethernet Layer 2 SIC interface modules that can be used on H3C MSR series routers. They provide up to 4/9 10/100 BASE-Tx Ethernet ports for Layer 2 and Layer 3 switching. A router installed with SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP modules can work as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly. SIC-4FSWP/DSIC-9FSWP interface modules can supply power to powered devices (PDs) through power over Ethernet (PoE).
Functions supported by interface modules are as follows:
·     Effective transmission distance of 100 m (328.08 ft) with category-5 twisted pair cables (both crossover and straight-through)
·     Effective transmission distance of 100 m (328.08 ft) between any interfaces with category-5 twisted pair cables (both crossover and straight-through)
·     Operating speeds of both 100 Mbps and 10 Mbps and autosensing
·     Both full duplex (in common use) and half-duplex operating modes
Table 1 describes the interface specifications of the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, and DSIC-9FSWP interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 1 Interface specifications
Item
SIC-4FSW/SIC-4FSWP
Connector
RJ-45
Interface type
MDI/MDIX
Number of connectors
Four 100 Mbps RJ-45 connectors
Nine 100 Mbps RJ-45 connectors
Cable
Standard (straight-through)/cross-over Ethernet cable
Operation mode
10/100 Mbps autosensing, full/half duplex
Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Medium dependent interfaces crossover (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN switches.
Interface LEDs
Figure 1 SIC-4FSW panel
SIC-4FSW
Figure 2 SIC-4FSWP panel
SIC-4FSW-POE
Figure 3 DSIC-9FSW panel
DSIC-9FSW+口
Figure 4 DSIC-9FSWP panel
DSIC-9FSW-POE+口
On the panel, each port corresponds to one green LED. The following table describes the LEDs on the panel.
Table 2 LED description
Status
Steady on
A link is present, but no data is being transmitted or received.
Off
No link is present.
Flashing
A link is present and data is being transmitted and received (ACT).
In addition, there is a PoE LED on each module, which is provided for the corresponding modules (SIC-4FSWP and DSIC-9FSWP) with the PoE function.
Interface cables and the connection methods
For more information about Ethernet interface cables and the connection methods, see "Ethernet interface."
SIC-4GSW
Introduction
The SIC-4GSW interface module is a 4-port 1000 Mbps Ethernet Layer 2 SIC interface module. The SIC-4GSW provides four 1000 Mbps RJ-45 ports. A router installed with SIC-4GSW modules can operate as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly.
·     Effective transmission distance of 100 m (328.08 ft) over category-5 twisted pair cables (both crossover and straight-through)
·     Line rate of 1000 Mbps between any interfaces over category-5 twisted pair cables (both crossover and straight-through)
·     Autosensing operating speeds of 1000 Mbps, 100 Mbps, and 10 Mbps
·     Both full duplex (typically used) and half-duplex operating modes
Table 3 describes the interface specifications of the SIC-4GSW interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 3 Interface specifications
Item
Connector
RJ-45
Interface type
MDI/MDIX
4
Cable
Operation mode
10/100/1000 Mbps autosensing
Interface LEDs
Figure 5 SIC-4GSW panel
The SIC-4GSW interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table 4 LED description
Status
Off
No link is present.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is sending and receiving data at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
The port is sending and receiving data at 10/100 Mbps.
For information about Ethernet interface cables and the connection methods, see "Ethernet interface."
SIC-4GSWF
Introduction
The 4-port 100/1000 Mbps Ethernet Layer 2/Layer 3 SIC interface module SIC-4GSWF provides four fiber ports. It is designed for switching/routing integrated routers on a small-sized enterprise network. You can use it to connect network devices inside the network.
The interface module has the following features:
·     Support for multiple 100/1000 Mbps transceiver modules.
·     1000/100 Mbps interface rate.
·     Full duplex operating mode.
Table 5 describes the interface specifications of the SIC-4GSWF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 5 Interface specifications
Item
Number of interfaces
4
Connector
SFP/LC
Standard
802.3/802.3u/802.3ab
Operating mode
1000/100 Mbps, full duplex
Interface LEDs
Figure 6 SIC-4GSWF panel
The SIC-4GSWF interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table 6 LED description
Status
Off
No link is present.
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
Steady yellow
A link is present on the port and the port is operating at 100 Mbps.
Flashing yellow
The port is sending and receiving data at 100 Mbps.
Transceiver modules, optical fibers, and connection methods
For more information about transceiver modules, optical fibers, and connection methods, see "Fiber port."
·     SIC-1FEA
·     SIC-1FEF
·     SIC-1GEC-V2
SIC-1FEA
Introduction
The 1-port 10BASE-T/100BASE-TX Ethernet interface module (SIC-1FEA) is used for communication between the router and LAN. It supports:
Table 7 describes the interface specifications of the SIC-1FEA interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 7 Interface specifications
Item
Connector type
RJ-45
Interface type
MDI
1
Cable type
Straight-through Ethernet cable
Operating mode
Full duplex/half duplex
Interface LEDs
Figure 7 SIC-1FEA panel
SIC-1FEA
Table 8 LED description
LED
LINK
·     Off: No link is present;
·     On: A link is present.
ACT
·     Off: No data is being transmitted or received;
·     Flashing: Data is being received or/and transmitted.
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface".
SIC-1FEF
Introduction
The 1-port 100 Mbps fiber Ethernet interface module (SIC-1FEF) is used for the communication between the router and LAN.
SIC-1FEF supports:
·     Various types of transceiver modules.
·     100 Mbps interface rate.
·     Full duplex.
Table 9 describes the interface specifications of the SIC-1FEF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 9 Interface specifications
Item
1
Connector
SFP/LC
Interface standard
802.3, 802.3u, and 802.3ab
Operating mode
100 Mbps
Full duplex
Interface LEDs
Figure 8 SIC-1FEF panel
SIC-1FEF
Table 10 LED description
LED
Status
LINK/ACT
Off
No link is present.
Steady green
The optical module has established a 100 Mbps link.
Flashing green
Data is being received and transmitted.
Steady yellow
Information detection failed.
SIC-1GEC-V2
Introduction
The 1-port 10/100/1000 Mbps electrical and fiber Ethernet interface SIC module (SIC-1GEC-V2) has the following functions:
·     Receipt, transmission and processing of GE data stream
·     CE electrical and fiber port access
·     1000/100/10 Mbps on copper port
·     1000 Mbps on fiber port
Table 11 describes the interface specifications of the SIC-1GEC-V2 interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 11 Interface specifications
Item
Connector
RJ-45
Interface type
MDI
Frame format
·     Ethernet_II
·     Ethernet_SNAP
·     IEEE 802.2
·     IEEE 802.3
Operation mode
Full/half duplex
The SIC-1GEC-V2 provides combo interfaces. The fiber and copper ports of a combo interface cannot be used simultaneously. By default, the copper port is available. To use the fiber port, execute the related command.
Interface LEDs
Figure 9 SIC-1GEC-V2 panel
Table 12 LED description for the copper port on the SIC-1GEC-V2 panel
LED
LINK
·     On: A carrier signal is received.
·     Off: No carrier signal is received.
·     Green: Data is being received and transmitted at a speed of 1000 Mbps.
·     Yellow: Data is being received and transmitted at a speed of 100/10 Mbps.
ACT
·     Off: No data is being received and transmitted;
·     Flashing: Data is being received and transmitted.
Table 13 LED description for the fiber port on the SIC-1GEC-V2 panel
LED
LINK
·     Yellow: Fault.
ACT
·     Off: No data is being received and transmitted.
For information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
RT-SIC-1POS-STM1
Introduction
The RT-SIC-1POS-STM1 1-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The RT-SIC-1POS-STM1 supports PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH. It provides a 155.52 Mbps fractional interface and supports various types of transceiver modules. You can purchase transceiver modules for it as required.
Table 14 Interface specifications
Item
Connector
SFP/LC
1
Interface standard
SONET OC-3/SDH STM-1
Interface rate
155.52 Mbps
Interface LEDs
Figure 10 RT-SIC-1POS-STM1 panel
Table 15 LED description
LED
Status
ACT/ALM
Steady green
A 155.52 Mbps link is present.
Flashing green
The port is receiving or sending data at 155.52 Mbps.
Steady red
An alarm has occurred.
Off
No transceiver module is present or the port is in shutdown state.
·     SIC-E1-F
·     SIC-2E1-F
·     SIC-1EPRI
·     SIC-T1-F
SIC-E1-F
Introduction
The 1-port fractional E1 interface module (SIC-E1-F) supports:
·     Transmission/Receiving and handling of E1 data streams
·     CE1 (channelized E1) access
·     Remote loopback and local loopback functions, facilitating fault test and location.
The timeslots on an interface in FE1 mode on the SIC-E1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 64 Kbps, where n ranges from 1 to 31.)
The SIC-E1-F does not support the PRI mode.
Table 16 Interface specifications
Item
Connector type
D15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
75-ohm unbalanced coaxial cable (D15 to BNC)
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure 11 SIC-E1-F panel
Table 17 LED description
LED
LINK/ACT
·     Flashing: Data is being transmitted or received.
LP/AL
·     On: The interface is in loopback mode.
·     Off: Neither loopback nor alarm is present.
·     Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty.
For more information about E1 interface cables and the connection methods, see "E1 interface."
SIC-2E1-F
Introduction
The 2-port fractional E1 interface module (SIC-2E1-F), where F indicates fractional, supports:
Table 18 Interface specifications
Item
Connector type
D15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure 12 SIC-2E1-F panel
Table 19 LED description
LED
LINK/ACT (left)
·     On: A carrier signal is received on line RX1.
·     Flashing: Data is being transmitted on line TX1 or received on line RX1.
·     Off: No carrier signal is received on line RX1.
LP/AL (left)
·     On: The interface of lines TX1 and RX1 is in loopback mode.
·     Flashing: No cable is connected to the interface of lines TX1 and RX1, the cable is damaged or not connected correctly, or the peer device is faulty.
·     Off: Neither loopback nor alarm is present on the interface of lines TX1 and RX1.
LINK/ACT (right)
·     On: A carrier signal is received on line RX2.
·     Flashing: Data is being transmitted on line TX2 or received on line RX2.
·     Off: No carrier signal is received on line RX2.
LP/AL (right)
·     On: The interface of lines TX2 and RX2 is in loopback mode.
·     Flashing: No cable is connected to the interface of lines TX2 and RX2, the cable is damaged or not connected correctly, or the peer device is faulty.
·     Off: Neither loopback nor alarm is present on the interface of lines TX2 and RX2.
For more information about E1 interface cables and the connections methods, see "E1 interface."
SIC-1EPRI
Introduction
The SIC-1EPRI is a 1-port E1/CE1/PRI SIC interface module that provides the following features:
·     Transmission/Receiving and handling of E1 data streams.
·     CE1 (channelized E1) access.
·     ISDN PRI function.
You can use the module for multiple purposes through different configurations.
Table 20 Interface specifications
Item
Connector type
D15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
·     75-ohm unbalanced coaxial cable (D15 to BNC)
·     Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter
The default resister for the interface on the SIC-1EPRI is 75 ohm. A 75-ohm to 120-ohm adapter must be used when a 120-ohm cable is connected to the SIC-1EPRI.
Operating mode
·     E1
·     CE1
·     ISDN PRI
Supported service
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure 13 SIC-1EPRI panel
Table 21 LED description
LED
LINK/ACT
LP/AL
SIC-T1-F
Introduction
1-port Fractional T1 interface card (SIC-T1-F) has the following features:
·     The timeslots on an interface in FT1 mode on the SIC-T1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 56 Kbps, where n ranges from 1 to 24.).
·     The SIC-T1-F does not support the PRI mode.
Table 22 Interface specifications
Item
Connector type
RJ-45
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT&T TR 54016
·     AT&T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm standard shielded network cable)
Operating mode
FT1
Supported service
·     Backup
·     Terminal access
Interface LEDs
Figure 14 SIC-T1-F panel
SIC-1T1-F
Table 23 LED description
LED
LINK/ACT
·     Flashing: Data is being transmitted or/and received.
LP/AL
·     Off: No loopback or alarm is present.
For more information about T1 interface cables and the connection methods, see "T1 interface."
·     SIC-8AS
·     SIC-16AS
·     SIC-1SAE
·     SIC-2SAE
·     SIC-4SAE
·     SIC-4RS
SIC-8AS
Introduction
The 8-port asynchronous serial interface module (SIC-8AS) mainly transmits and processes asynchronous data streams.
SIC-8AS has these features:
·     Each asynchronous serial port provides a rate up to 115.2 Kbps.
·     Supports the terminal access service and asynchronous dedicated line.
·     Serves as the small-/medium-sized ISP dial-up access server when an asynchronous serial port is used for dial-up.
Table 24 Interface specifications
Item
Connector
DB60
1
Interface cable
Customized cable with 8-port RJ-45 connector
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 Kbps
Supported services
·     Modem dial-up
·     Backup
·     Terminal access service
·     Asynchronous dedicated line
Interface LEDs
Figure 15 SIC-8AS front panel
SIC-8AS+口
Table 25 LED description
LED
LINK/ACT
·     Off: No link is present.
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
SIC-16AS
Introduction
The 16-port asynchronous serial interface module (SIC-16AS) mainly transmits and processes asynchronous data streams.
SIC-16AS features the following:
·     Each asynchronous serial port provides a rate of up to 115.2 Kbps.
Table 26 Interface specifications
Item
Connector
D28 (male)
1
Interface cable
Customized cable with 16-port RJ-45 connector (female)
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 Kbps
Supported services
·     Modem dial-up
·     Backup
Interface LEDs
Figure 16 SIC-16AS panel
SIC-16AS
Table 27 LED description
LED
LINK/ACT
Introduction
The SIC-1SAE/SIC-2SAE/SIC-4SAE is a 1-port/2-port/4-port enhanced high-speed synchronous/asynchronous serial interface module.
Table 28 Interface specifications
Item
Synchronous
Asynchronous
Connector
D28
·     1 (SIC-1SAE)
·     2 (SIC-2SAE)
·     4 (SIC-4SAE)
Interface standard and operating mode
V.24
·     V.35
·     RS449
·     X.21
·     RS-530
RS-232
·     DTE
·     DCE
·     DTE
·     DCE
Minimum baud rate
(bps)
1200
1200
300
Maximum baud rate
(bps)
64 k
2.048 M
115.2
Cable
·     V.24 (RS-232) DTE cable
·     V.24 (RS-232) DCE cable
·     V.35 DTE cable
·     V.35 DCE cable
·     X.21 DTE cable
·     X.21 DCE cable
·     RS449 DTE cable
·     RS449 DCE cable
·     RS530 DTE cable
·     RS530 DCE cable
Supported service
·     DDN leased line
·     Dialup through modems
·     Backup
·     Asynchronous leased line
·     Terminal access
Interface LEDs
Figure 17 SIC-1SAE panel
SIC-1SAE+口
Figure 18 SIC-2SAE panel
Figure 19 SIC-4SAE panel
The SIC-1SAE provides separate LINK and ACT LEDs for the port and the SIC-2SAE and SIC-4SAE provide one LINK/ACT LED for each port.
Table 29 LED description for the port on the SIC-1SAE
LED
LINK
ACT
Table 30 LED description for ports on the SIC-2SAE/SIC-4SAE
LED
LINK/ACT
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
SIC-4RS
Introduction
The SIC-4RS is a 4-port asynchronous serial interface module.
The SIC-4RS has these features:
·     Allows users to make matching wires connected to the terminal block themselves.
·     Supports simultaneous connection to four asynchronous serial ports.
Table 31 Interface specifications
Item
Connector
Terminal block
1
Interface cable
Allows users to make matching cables themselves.
RS-232/485/422
Minimum baud rate (bps)
300
Maximum baud rate (bps)
115200
Supported service
·     4 asynchronous serial port connection
·     2-channel digital input (DI) detection
Interface LEDs
Figure 20 SIC-4RS panel
Table 32 LED description
LED
0 to 3
The SIC-4RS interface module allows users to make matching cables themselves for connection to it. Figure 21 and Table 33 describe the requirements for making matching cables.
Figure 21 Pin numbering
Table 33 Interface pinouts
Pin
Interface standards and working modes
RS-232
RS-422
RS-485
1
RTS0
TX0+
Data0+
2
TXD0
TX0-
Data0-
3
RXD0
RX0+
4
CTS0
RX0-
5
GND
6
GND
7
RTS1
TX1+
Data1+
8
TXD1
TX1-
Data1-
9
RXD1
RX1+
10
CTS1
RX1-
11
GND
12
GND
13
RTS2
TX2+
Data2+
14
TXD2
TX2-
Data2-
15
RXD2
RX2+
16
CTS2
RX2-
17
GND
18
GND
19
RTS3
TX3+
Data3+
20
TXD3
TX3-
Data3-
21
RXD3
RX3+
22
CTS3
RX3-
23
GND
24
GND
25
DN0_P
26
DN0_N
27
DN1_P
28
DN1_N
·     SIC-1AM
·     SIC-2AM
SIC-1AM/SIC-2AM
Introduction
The 1/2-port analog modem interface module (SIC-1AM/SIC-2AM) integrates the functions of asynchronous interface and external modem, that is, allowing 1/2 channel(s) of remote modem subscribers to directly access the Router. They support:
·     Data rate of 56 kbps.
·     Accessing and handling analog signals and transmitting the processed data to the Router host through the serial interface bus. And also, processing the data received from the host and then transmitting them to the PSTN via the telephone port.
Table 34 Interface specifications
Item
Connector type
RJ-11
·     1 (SIC-1AM)
·     2 (SIC-2AM)
Cable type
Telephone cable with ferrite core
Maximum speed
56 kbps
Supported standard
·     ITU-T V.90
·     K56flex
·     V.34 (33.6 kbps)
·     V.FC
·     V.32 bis
·     V.32
·     V.22 bis
·     V.22A/B
·     V.23
·     V.21
·     Bell 212A a
·     Bell 103
Supported service
Modem dial-up
Interface LEDs
Figure 22 SIC-1AM panel
Figure 23 SIC-2AM panel
Table 35 LED description
LED
LINK
·     Off: The link is idle.
·     On: The connection has been established.
·     Flashing: The connection is being set up.
ACT
For more information about the Ethernet interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
·     SIC-1ADSL
·     SIC-1ADSL-I
SIC-1ADSL
Introduction
The 1-port ADSL over PSTN interface module (SIC-1ADSL) provides an RJ-11 interface that can work as a WAN interface. It allows a LAN subscriber to connect to the digital subscriber's loop access multiplexer (DSLAM) at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
ADSL transmits data in the high frequency band above 26 kHz. Therefore, it can provide services without interfering with the voice service being provided in the low frequency band (0 to 4 kHz) on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL delivers these features:
·     Manual ADSL line activation and deactivation, providing a convenient fault location means.
·     Interface standards of G. DMT, G. Lite, and T1.413, autosensing.
·     Trellis coding (except for G. Lite) on ADSL interfaces, enhancing the stability of ADSL connection.
Table 36 Interface specifications
Item
Connector
RJ-11
1
Interface rate
·     In ADSL full rate mode (ITU-T 992.1 G.DMT/ANSI T1.413):
¡     8 Mbps (downlink rate)
¡     1024 kbps (uplink rate)
·     In ADSL Lite mode (ITU-T 992.2 G.Lite):
¡     64 kbps to 1 Mbps (downlink rate)
¡     64 kbps to 512 kbps (uplink rate)
·     In ADSL2+ full rate mode (ITU-T 992.5):
¡     24 Mbps (downlink rate)
Interface standard
·     ITU-T 992.1 G.DMT
·     ITU-T 992.2 G.Lite
·     ANSI T1.413 Issue 2
·     ITU-T 992.3
·     ITU-T 992.5
Cable
Telephone cable
Supported service
ADSL over the regular telephone line
Maximum received and sent frame
1700 bytes
Interface LEDs
Figure 24 SIC-1ADSL panel
SIC-1ADSL
Table 37 LED description
LED
LINK
·     Off: The loop is inactive.
·     On: The loop has been activated and has entered the data mode
·     Flashing: The loop is being activated.
ACT
·     Off: No data is being transmitted or received.
For more information about ADSL interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-1ADSL-I
Introduction
The 1-port ADSL over ISDN interface module (SIC-1ADSL-I) uses the RJ-11 connector for the WAN interface. It allows a LAN subscriber to connect to the DSLAM at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
The module transmits data in the high frequency band above 138 kHz. Therefore, it can provide services on the same line without interfering with the ISDN service being provided on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL-I interface module delivers these features:
·     A G.992.1-compliant interface, autosensing
·     Trellis coding on ADSL interfaces, enhancing the stability of ADSL connection
Table 38 Interface specifications
Item
Connector
RJ-11
1
Interface rate
Interface standard
·     ITU-T 992.1 G.DMT
·     ITU-T 992.3
·     ITU-T 992.5
Interface rate
·     Downlink: 8 Mbps
·     Uplink: 1024 kbps
Interface cable
Regular telephone cable
Supported services
ADSL over ISDN
1700 bytes
Interface LEDs
Figure 25 SIC-1ADSL-I panel
SIC-1ADSL-I-新+口
Table 39 LED description
LED
LINK
ACT
·     SIC-1BS
·     SIC-2BS
SIC-1BS/SIC-2BS
Introduction
The 1/2-port ISDN BRI S/T interface module (SIC-1BS/SIC-2BS) is mainly used to transmit, receive, and process ISDN BRI S/T traffic flows.
The SIC-1BS/SIC-2BS has two operating modes: dial-up and leased line.
Table 40 Interface specifications
Item
Connector
RJ-45
·     1 (SIC-1BS)
·     2 (SIC-2BS)
Cable type
Interface standard
·     ITU-T I.430
·     Q.921
·     Q.931
Operating mode
·     ISDN Dial-up
·     ISDN leased line
Supported services
·     ISDN
·     ISDN supplementary services
·     Multi-subscriber number
·     Sub-address
·     Backup
Interface LEDs
Figure 26 SIC-1BS panel
SIC-1BS
Figure 27 SIC-2BS panel
Table 41 LED description
LED
B1
·     Off indicates the B1 channel is idle.
·     Flashing indicates the B1 channel is being used for data communication.
B2
·     Off indicates the B2 channel is idle.
ACT
·     Off indicates the inactive state.
·     Steady on indicates the active state.
ON
·     Off indicates interface module is powered off.
·     On indicates the interface module is powered on.
For more information about BS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
·     SIC-1FXS
·     SIC-1FXO
·     SIC-2FXS
·     SIC-2FXO
·     SIC-2FXS1FXO
·     DSIC-4FXS1FXO
·     SIC-1BSV
·     SIC-2BSV
·     SIC-1VE1
·     SIC-1VT1
·     SIC-1VE1T1
Introduction
The 1/2-port voice subscriber circuit interface module (SIC-1FXS/SIC-2FXS) and 1/2-port voice AT0 analog trunk interface module (SIC-1FXO/SIC-2FXO) serve to access and handle 1/2 channel(s) of analog voice signals over data communication networks. The differences between SIC-FXS and SIC-FXO are listed below:
·     SIC-FXS modules are analog subscriber line modules that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
·     SIC-FXO modules are loop trunk modules that provide access of common subscriber lines of exchanges.
Table 42 Interface specifications
Item
Connector type
RJ-11
1 (SIC-1FXS/SIC-1FXO)
2 (SIC-2FXS/SIC-2FXO)
Interface standard
·     Subscriber circuit interface (SIC-1FXS/SIC-2FXS) compliant with ITU Q.512.
·     Loop trunk interface (SIC-1FXO/SIC-2FXO) compliant with ITU Q.552.
·     Over-current and over-voltage protection compliant with ITU K.20
Cable type
Telephone cable with ferrite core.
Dialing mode
Supports DTMF, not supports pulse dial-up.
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 28 SIC-1FXS panel
SIC-1FXS
Figure 29 SIC-1FXO panel
SIC-1FXO
Figure 30 SIC-2FXS panel
SIC-2FXS
Figure 31 SIC-2FXO panel
SIC-2FXO
Table 43 LED description
LED
LINK
·     On: The link is being occupied for call connection.
ACT
·     On: The link is being occupied for communication.
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-2FXS1FXO
Introduction
The 2-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (SIC-2FXS1FXO) serve to access and handle three channels of analog voice signals over data communication networks. Two FXS interfaces and one FXO interface are available on a SIC-2FXS1FXO module:
·     FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
·     FXO interfaces are loop trunk interfaces that provide access of common subscriber lines of exchanges.
Table 44 Interface specifications
Item
Connector type
RJ-11
2 FXS interfaces
1 FXO interface
Interface standard
·     Supports subscriber circuit interface (FXS), compliant with ITU Q.512
·     Supports loop trunk interface (FXO), compliant with ITU Q.552
Cable type
Dial-up mode
Supports DTMF, compliant with GB3378, but does not support pulse dial-up.
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 32 SIC-2FXS1FXO panel
SIC-2FXS1FXO+口
Table 45 LED description
LED
LINK/ACT
·     Steady green: The link is being occupied for call connection.
·     Flashing yellow: The link is being occupied for communication.
DSIC-4FXS1FXO
Introduction
The 4-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (DSIC-4FXS1FXO) serve to access and handle five channels of analog voice signals over data communication networks.
Table 46 Interface specifications
Item
Connector type
RJ-11
4 FXS interfaces
1 FXO interface
Interface standard
Cable type
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 33 DSIC-4FXS1FXO panel
DSIC-4FXS1FXO+口
Table 47 LED description
LED
LINK/ACT
SIC-1BSV/SIC-2BSV
Introduction
The 1/2-port ISDN BRI S/T voice interface module (SIC-1BSV/SIC-2BSV) is mainly used to process (receive/transmit and compress/decompress) the ISDN interface voice traffic. The interface(s) on the SIC-1BSV/SIC-2BSV module is (are) ITU-T I.430-compliant, adopting pseudo-ternary coding, providing 192 Kbps interface rate, and allowing the maximum transmission distance of 1 km (0.6 miles) in point-to-point mode. In the upstream direction, the SIC-1BSV/SIC-2BSV module can be connected to a user interface on an ISDN switch to receive and decompress, compress and transmit ISDN BRI digital voice traffic. In the downstream direction, the module can be connected to a TE device to forward the voice packets from the TE device to the Internet through a WAN interface on the router, thus implementing VoIP. The module has the following features.
·     A BSV interface supports two modes: user and network, respectively for connecting an ISDN network and a TE device.
·     When a BSV interface works in network mode, traffic is processed as follows: The digital voice traffic received on the BSV interface is compressed and forwarded through the CPU on the main control board to a WAN interface. The IP voice traffic received on a WAN interface is forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is decompressed and sent to the TE device.
·     When a BSV interface works in user mode, traffic is processed as follows: The digital voice traffic received from the B channels on the BSV interface is decompressed and forwarded through the CPU on the main control board to a local FXS or FXO analog voice interface. The voice signals received on the local FXS or FXO analog voice interface are processed by VoIP and forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is compressed and sent out of the BSV interface to the ISDN switch.
·     Working in conjunction with the FXS or FXO analog voice interface modules, SIC-2BSV provides flexibility in voice call routing.
·     The ISDN BRI D channel signaling is processed separately on CPU.
·     A BSV interface supports remote power supply and thus can be connected directly to an ISDN phone, saving extra power supply device.
·     The SIC-1BSV/SIC-2BSV is dedicated to voice applications, which is different from the BS interface modules where BRI data applications are supported.
Table 48 Interface specifications
Item
SIC-1BSV
SIC-2BSV/
Connector
RJ-45
1
2
Interface standard
·     ITU-T I.430
·     Q.921
·     Q.931
Interface rate
192 Kbps
Cable
ISDN S interface cable
Supported service
Voice access over ISDN S interface cable
Interface LEDs
Figure 34 SIC-1BSV panel
SIC-1BSV
Figure 35 SIC-2BSV panel
SIC-2BSV
Table 49 LED description
LED
B1
Green
Flashing indicates data is being transmitted or received on B1 channel.
B2
Green
Flashing indicates data is being transmitted or received on B2 channel.
ACT
Yellow
·     Flashing indicates the link is being activated.
·     Steady on indicates the link is active.
ON
Green, power LED.
Steady on indicates the module is powered on.
For more information about BSV interface cables and the connection methods, see "BSV/BSE interface."
SIC-1VE1
Introduction
The 1-port E1 voice interface module (SIC-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 50 Interface specifications
Item
Connector
DB 15
Number of connector
1
Interface standard
G.703, G.704
Interface rate
2.048 Mbps
Frame format
·     Ethernet_II
·     Ethernet_SNAP
·     IEEE 802.2
·     IEEE 802.3
Cable type
·     120-ohm balanced twisted pair cable
·     Coaxial connector, network interface connector and 75-ohm to 120-ohm adapter (with BNC connector)
Operation mode
CE1
ISDN PRI (only supported by SIC-1VE1)
R2
Services
·     Backup
·     Terminal access
·     ISDN (only supported by SIC-1VE1)
Interface LEDs
Figure 36 SIC-1VE1 panel
SIC-1VE1面板
Table 51 LED description
LED
LINK
ACT
SIC-1VT1
Introduction
The 1-port T1 voice interface module (SIC-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI/R2 port, allowing the access of 23 channels of voice signals.
Table 52 Interface specifications
Item
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm standard shielded cable)
Operation mode
CT1
ISDN PRI
Services
Backup
Terminal access
ISDN
Interface LEDs
Figure 37 SIC-1VT1 panel
SIC-1VT1面板
Table 53 LED description
LED
LINK
ACT
SIC-1VE1T1
Introduction
The 1-port E1/T1 voice interface module SIC-1VE1T1 handles dense voice signals in VoIP and FoIP systems. The E1 module transmits, receives, and processes E1 voice signals. It allows the interface to operate in CE1 mode or ISDN PRI mode to process a maximum of 30 channels of voice signals. The T1 module transmits, receives, and processes T1 voice signals. It allows the interface to operate in CT1 mode or ISDN PRI mode to process a maximum of 23 channels of voice signals.
You can use command lines and a jumper to configure the interface as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, the interface is a 75-ohm E1 interface.
·     To configure the interface as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
·     To configure the interface as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure 38 Jumper connecting methods
Table 54 Interface specifications
Item
Specification
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703
·     G.704
Interface rate
·     E1 interface: 2.048 Mbps
·     T1 interface: 1.544 Mbps
Cable type
·     E1 75-ohm coaxial cable
·     E1 120-ohm twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft)
·     T1 100-ohm standard shielded cable
·     Coaxial connector, network interface connector, or 75-to-120-ohm adapter (with BNC connector)
Operating mode
·     E1
·     T1
·     CE1T1
·     ISDN PRI
Services
Backup
Terminal access
ISDN PRI
Interface LEDs
Figure 39 SIC-1VE1T1 panel
Table 55 LED description
LED
LINK/ACT
·     Steady green: Carrier signal has been received.
·     Flashing green at 4 Hz: Data is being transmitted or received.
·     Off: No carrier signals have been received.
LP/AL
·     Steady yellow: The interface is in loopback mode.
·     Flashing yellow at 0.5 Hz: An AIS, LFA, or RAI alarm is present.
Interface cables and connection methods
·     SIC-3G-CDMA
·     SIC-3G-TD
·     SIC-3G-HSPA
SIC-3G-CDMA
Introduction
The SIC-3G-CDMA module is used to access 3G WLANs. It supports:
·     CDMA 2000 1x RTT
·     1x EV-DO Rev.0
·     1x EV-DO Rev.A
Table 56 Interface specifications
Item
Connector type
·     TNC RF: Antenna for accessing WLANs.
·     RJ-45: For connecting to a third-party WLAN debugging and testing software such as CAIT of Qualcomm.
·     2 TNC RF
·     1 RJ-45
Interface standard
·     TNC RF: Omni antenna, supporting CDMA 2000 1 No RTT, 1 No EV-DO Rev.0, 1 No EV-DO Rev.A.
·     RJ-45: RS-232
Cable type
·     TNC RF: None
·     RJ-45: AUX cable
Rates
Network standards:
·     1 No EV-DO Rev.A (Downlink: 3.1 Mbps, uplink: 1.8 Mbps)
·     1 No EV-DO Rev.0 (Downlink: 2.4 Mbps, uplink: 153.6 Kbps)
·     1 No RTT (Downlink: 153.6 Kbps, uplink: 153.6 Kbps)
Services
·     CDMA 2000 1x RTT
·     1 No EV-DO Rev.0
·     1 No EV-DO Rev.A
Interface LEDs
Figure 40 SIC-3G-CDMA panel
Table 57 LED description
LED
WWAN
·     Steady green indicates that a link is present.
·     Flashing green indicates that data is being transmitted or received.
RSSI
·     Steady green indicates strong signal.
·     Flashing green indicates middle or low signal.
·     Off indicates weak signal or no signal.
1xRTT
·     Steady yellow indicates the service is valid.
·     Off indicates no service.
EVDO
Antennas, interface cables, and the connection methods
For more information about SIC-3G-CDMA antennas, interface cables, and the connection methods, see "3G interface."
Installing a SIM card
CAUTION
CAUTION:
Make sure the beveled corner of the SIM card fits into the beveled corner of the SIM socket.
To installing a SIM card:
1.     Open the SIM card socket in the direction marked OPEN so the holder projects upwards.
2.     Insert the SIM card into the SIM card socket along the guide rails.
3.     Close the SIM card socket in the direction marked LOCK to lock the card in position.
4.     Execute the display cellular [ interface-number ] command after the router is started. When "SIM Status = OK" appears in the output information, the SIM card is identified.
SIC-3G-TD
Introduction
The SIC-3G-TD module provides access to 3 G WLANs. It supports the following features:
·     GPRS
·     EDGE
·     TD-SCDMA
·     HSDPA
Table 58 Interface specifications
Item
Connector type
TNC: For connecting an antenna and accessing WLANs.
1 TNC RF
1 RJ-45
Interface standard
TNC RF: Omni antenna, supporting GPRS/EDGE/TD-SCDMA//HSDPA
RJ-45: RS-232
Cable type
TNC RF: None
RJ-45: AUX cable
Rates
·     HSDPA (downlink: 2.8 Mbps, uplink: 384 Kbps)
·     TD-SCDMA (downlink: 384 Mbps, uplink: 384 Kbps)
·     EDGE (downlink: 236.8 Kbps, uplink: 236.8 Kbps)
·     GPRS (downlink: 85.6 Kbps, uplink: 85.6 Kbps)
Services
GPRS/EDGE/TD-SCDMA/HSDPA
Interface LEDs
Figure 41 SIC-3G-TD panel
rtvm1std
Table 59 LED description
LED
WWAN
·     Steady green: A link is present.
·     Flashing green: Data is being transmitted or received.
RSSI
·     Steady green: Strong signal.
·     Flashing green: Middle or low signal.
·     Off: Weak signal or no signal.
TD
·     Steady yellow: The service is valid.
·     Off: No service.
HSDPA
·     Off: No service.
For more information about SIC-3G-GSM antennas, interface cables, and the connection methods, see "3G interface."
CAUTION
CAUTION:
To install a SIM card:
SIC-3G-HSPA
Introduction
The SIC-3G-HSPA module serves to access 3G networks. It supports:
·     GPRS
·     EDGE
·     UMTS
·     HSDPA
Table 60 Interface specifications
Item
Connector type
2 TNC RF
1 RJ-45
Interface standard
TNC RF: Omni antenna, supporting GPRS/EDGE/UMTS/HSDPA.
RJ-45: RS-232
Cable type
TNC RF: None
RJ-45: AUX cable
Rates
·     HSDPA (downlink: 7.2 Mbps)
·     HSUPA (uplink: 5.76 Mbps)
·     UMTS (downlink: 384 Mbps, uplink: 384 Kbps)
Services
Supported wireless band
850/900/1900/2100 MHz WCDMA/HSDPA/HSUPA
850/900/1800/1900 MHz GPRS/EDGE
Interface LEDs
Figure 42 SIC-3G-HSPA panel
SIC-3G-HSPA
Table 61 LED description
LED
WWAN
RSSI
UMTS
·     Off: No service.
HSDPA
·     Off: No service.
CAUTION
CAUTION:
The 3G antenna provided with the SIC-3G-HSPA must be installed on the antenna port that has a MAIN mark.
For more information about SIC-3G-HSPA antennas, interface cables, and the connection methods, see "3G interface."
CAUTION
CAUTION:
·     SIC-4G-LTE-M
·     SIC-4G-CNDE
·     RT-SIC-4G-CAT6
·     SIC-D4G-CNDE
SIC-4G-LTE-M
Introduction
The SIC-4G-LTE-M module provides 4G WLAN access and supports the following features:
·     LTE
·     UMTS
·     HSPA+
·     TD-SCDMA
·     CDMA2000 1xRTT
·     CDMA2000 1x-Ev-Do
·     Quad-Band EDGE
·     GPRS
·     GSM
Table 62 Interface specifications
Item
Connector type
·     TNCFor accessing WLANs.
·     SMA—For accessing GPS.
·     Mini USB Type ABFor connecting to third-party WLAN debugging and testing software such as CAIT of Qualcomm.
·     2 TNCs
·     1 SMA
·     1 Mini USB Type AB
Interface standard
·     TNCSupports LTE, UMTS, HSPA+, CDMA 1x, EV-DO Rev A, Quad-Band EDGE, GPRS, and GSM
·     SMAGPS
·     Mini USB Type ABRS-232
Cable type
·     SMAFlexible 174 sized cable
·     TNCNone
·     Mini USB Type ABUSB console cable
Services
·     LTE
·     UMTS
·     HSPA+
·     TD-SCDMA
·     CDMA2000 1xRTT
·     CDMA2000 1x-Ev-Do
·     Quad-Band EDGE
·     GPRS
·     GSM
Interface LEDs
Figure 43 SIC-4G-LTE-M panel
Table 63 LED description
LED
WWAN
·     Fast flashing green indicates that data is being transmitted or received.
·     Slowly flashing green indicates network searching.
·     Off indicates that no link is present.
RSSI
·     Steady green indicates strong signal (RSSI ≥ –69 dBm).
·     Fast flashing green indicates middle signal (–89 dBm ≤ RSSI <–69 dBm).
·     Slowly flashing green indicates low signal (–99 dBm ≤ RSSI < –89 dBm).
·     Off indicates weak signal or no signal (RSSI < –99 dBm).
HSPA+
·     Steady green indicates that the HSPA+ service or HSDPA service is valid.
·     Flashing green indicates that the EVDO service is valid.
LTE
·     Steady green indicates that the LTE service is valid.
·     Off indicates no LTE service.
GPS
·     Steady green indicates that the GPS service is valid.
·     Off indicates no GPS service.
For more information about SIC-4G-LTE-M interface module antennas, interface cables, and the connection methods, see "4G interface."
CAUTION
CAUTION:
SIC-4G-CNDE
Introduction
The SIC-4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table 64 Interface specifications
Item
Connectors
3 SMA connectors
Supported antenna types
·     GPS
·     Omnidirectional antenna, support for FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/GPRS/GSM/EVDO/CDMA
Technologies and supported frequency bands
·     LTE-TDD band 38/39/40/41
·     LTE-FDD band 1/3/5/7/8
·     TD-SCDMA band 34/39
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure 44 SIC-4G-CNDE panel
Table 65 LED description
LED
WWAN
RSSI
·     Steady yellow is reserved for future use.
LTE
·     Steady green indicates the 4G-LTE service is valid.
·     Flashing green (8 Hz) indicates the high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is valid.
·     Steady yellow indicates the 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is valid.
·     Flashing yellow is reserved for future use.
GPS
CNDE
·     Steady green indicates that the module is operating correctly and is not sending or receiving data.
·     Flashing green indicates that the module is operating correctly and is sending or receiving data.
·     Steady yellow indicates that the module is faulty.
·     Off indicates that the module is not installed securely, or no power is present.
For more information about SIC-4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing Micro SIM card
CAUTION
CAUTION:
Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
The SIC-4G-CNDE interface module supports Micro SIM cards.
The SIC-4G-CNDE has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
To install a Micro SIM card:
1.     Use a Phillips screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer.
3.     Insert SIM cards into the SIM card slots on the retainer.
4.     Reattach the retainer cover and use the two screws to secure the cover.
5.     Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the Micro SIM card is identified.
Figure 45 Installing Micro SIM cards
RT-SIC-4G-CAT6
IMPORTANT
IMPORTANT:
The RT-SIC-4G-CAT6 module is hot swappable. However, to avoid unexpected reboot of the host, execute the remove command or press the remove button for over 3 seconds and wait for the remove LED to turn off before removing the module.
Introduction
The RT-SIC-4G-CAT6 module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     WCDMA
Table 66 Interface specifications
Item
Connectors
3 SMA connectors
Standard and operating mode
·     GNSS: GPS/GLONASS/BDS/Galileo
·     Omnidirectional antenna: FDD-LTE, TDD-LTE, WCDMA
Supported services
·     LTE-TDD
·     LTE-FDD
·     WCDMA
Interface LEDs
Figure 46 RT-SIC-4G-CAT6 panel
Table 67 LED description
LED
Status
WWAN
Steady green
A WWAN link is present.
Fast flashing green
Data is being transmitted or received on the WWAN link.
Slow flashing green
Searching and connecting to a WWAN network.
Off
Not connected to a WWAN.
WCDMA
Steady green
Strong 3G signal strength (RSSI ≥ –70 dBm)
Fast flashing green
Medium 3G signal strength (–100 dBm ≤ RSSI < –70 dBm)
Slow flashing green
Low 3G signal strength (–125 dBm ≤ RSSI < –100 dBm)
Off
No 3G service (RSSI < –125 dBm)
LTE
Steady green
The module is operating in 4G mode and the 4G signal strength is strong (RSSI ≥ –70 dBm).
Fast flashing green
The module is operating in 4G mode and the 4G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm).
Slow flashing green
The module is operating in 4G mode and the 4G signal strength is low (–125 dBm ≤ RSSI < –100 dBm).
Off
No 4G service (RSSI < –125 dBm)
SIM
Steady green
The SIM card in SIM card slot 0 is working.
Steady yellow
The SIM card in SIM card slot 1 is working.
Off
No SIM cards are present in the two SIM card slots.
GNSS
Steady green
Valid GNSS service.
Off
No GNSS service.
REMOVE
Steady green
The module is operating correctly. You can remove it.
Fast flashing green
The module is initializing. You cannot remove it.
Off
You can remove the module if all the other LEDs on the module are also off.
Antennas, interface cables, and connection methods
For more information about RT-SIC-4G-CAT6 module antennas, interface cables, and the connection methods, see "4G interface" and "GNSS interface."
CAUTION
CAUTION:
The RT-SIC-4G-CAT6 module supports Micro SIM cards.
The RT-SIC-4G-CAT6 has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM0 slot is active and the SIM1 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
3.     Insert SIM cards into the SIM card slots on the retainer. Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
Figure 47 Installing Micro SIM cards
SIC-D4G-CNDE
Introduction
The SIC-D4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table 68 Interface specifications
Item
Connectors
5 SMA connectors
·     GPS
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure 48 SIC-D4G-CNDE panel
Table 69 LED description
LED
WWAN
RSSI
LTE
GPS
CNDE
For more information about SIC-D4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE interface module supports Micro SIM cards.
The SIC-D4G-CNDE has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure 49 Installing Micro SIM cards
·     RT-SIC-5G
·     RT-SIC-5G-CN
RT-SIC-5G
CAUTION
CAUTION:
Before removing an RT-SIC-5G module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a SIC-5G module with its remove LED on.
Introduction
The RT-SIC-5G module provides 5G WLAN access and supports the following technologies:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
Table 70 Interface specifications
Item
Connectors
4 SMA connectors
Standard and working mode
·     GNSS: GPS/GLONASS/BeiDou/Galileo
·     Omnidirectional antenna, support for WCDMA/FDD-LTE/TDD-LTE/5G NR
Supported service
·     5G/4G/3G networking
·     5G and LTE-A full coverage
·     NSA and SA modes
·     Integrating multi-constellation GNSS receiver for fast and precise positioning in different environments
Interface LEDs
Figure 50 RT-SIC-5G panel
Table 71 LED description
LED
Status
WWAN
Steady green
Fast flashing green
Slow flashing green
Off
5G
Steady green (SA mode)
Strong 5G signal strength (RSRP ≥ –85 dBm)
Fast flashing green (SA mode)
Medium 5G signal strength (–100 dBm ≤ RSRP < –85 dBm)
Slow flashing green (SA mode)
Low 5G signal strength (–115 dBm ≤ RSRP < –100 dBm)
Steady yellow (NSA mode)
Fast flashing yellow (NSA mode)
Slow flashing yellow (NSA mode)
Off
No 5G service
LTE
Steady green
Fast flashing green
Slow flashing green
Steady yellow
The module is operating in 3G mode and the 3G signal strength is strong (RSSI ≥ –70 dBm).
The module is operating in 3G mode and the 3G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm).
The module is operating in 3G mode and the 3G signal strength is low (–125 dBm ≤ RSSI < –100 dBm).
Off
No 3G and 4G services.
SIM
Steady green
Steady yellow
The SIM card in SIM card slot 2 is working.
Off
GNSS
Steady green
Valid GNSS service.
Off
No GNSS service.
REMOVE
Steady green
The module is operating correctly. You can hot-remove it.
Fast flashing green
The module is initializing. You cannot hot-remove it.
Off
For more information about RT-SIC-5G interface module antennas, interface cables, and the connection methods, see "5G interface."
Installing a 5G SIM card
CAUTION
CAUTION:
To avoid damage to the SIM card or the 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration.
The RT-SIC-5G interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the SIC-5G interface module. In Figure 51, two SIM cards are installed.
To install a 5G SIM card:
1.     Use a screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer, as shown by callout 2 in Figure 51.
3.     Orient the SIM card with the cut corner as shown in the illustration.
4.     Insert the SIM card into the SIM card slot along the guide rails.
5.     Slightly push SIM card edge to secure it into the slot.
6.     Reattach the retainer cover and use the two screws to secure the cover.
7.     Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the SIM card is identified.
Figure 51 Installing 5G SIM cards
RT-SIC-5G-CN
CAUTION
CAUTION:
Before removing an RT-SIC-5G-CN module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a RT-SIC-5G-CN module with its remove LED on.
Introduction
The RT-SIC-5G-CN module provides 5G WLAN access and supports the following technologies:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
Table 72 Interface specifications
Item
Connectors
4 SMA connectors
SMA
Supported service
·     NSA and SA modes
Interface LEDs
Figure 52 RT-SIC-5G-CN panel
Table 73 LED description
LED
Status
WWAN
Steady green
Fast flashing green
Slow flashing green
Off
5G
Off
No 5G service
LTE
Steady green
Fast flashing green
Slow flashing green
Steady yellow
Off
SIM
Steady green
Steady yellow
Off
REMOVE
Steady green
Fast flashing green
Off
For more information about RT-SIC-5G-CN interface module antennas, interface cables, and the connection methods, see "5G interface."
CAUTION
CAUTION:
To avoid damage to the SIM card and 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration.
The RT-SIC-5G-CN interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the RT-SIC-5G-CN interface module. In Figure 51, two SIM cards are installed.
Figure 53 Installing 5G SIM cards
·     SIC-CNDE
·     SIC-CNDE-SJK
·     SIC-4G-CNDE-SJK
·     SIC-D4G-CNDE-SJK
SIC-CNDE
Introduction
The SIC-CNDE is a China Network Data Encryption (CNDE) module. The SIC-CNDE provides high performance and reliable data encryption features for routers by using the SM1 mechanism.
Insert SIC-CNDE module in the SIC slot. The main board forwards IP packets and implements VPN with the encryption feature, where SM1 encryption and decryption is implemented by the encryption module.
Table 74 Interface specifications
Item
Hardware algorithm
Key algorithm:
·     SM1-128
·     SM1-256
Interface LEDs
Figure 54 SIC-CNDE panel
Table 75 LED description
LED
ACT
·     Flashing: Data is being transmitted or received between the module and the host.
·     Steady green: No data is being transmitted or received.
SIC-CNDE-SJK
Introduction
The SIC-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers.
LEDs
Figure 55 SIC-CNDE-SJK panel
Table 76 LED description
LED
CNDE
·     Steady green: The module is operating correctly and is not sending or receiving data.
·     Flashing green: The module is operating correctly and is sending or receiving data.
·     Steady yellow: The module is faulty.
·     Off: The module is not installed securely, or no power is present.
SIC-4G-CNDE-SJK
Introduction
The SIC-4G-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table 77 Interface specifications
Item
Connectors
3 × SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure 56 SIC-4G-CNDE-SJK panel
Table 78 LED description
LED
WWAN
·     Fast flashing: Data is being transmitted or received.
·     Slowly flashing: The module is searching for wireless networks.
RSSI
·     Steady green: Strong signal strength (RSSI ≥ –69 dBm).
·     Fast flashing: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm).
·     Slowly flashing green: Low signal strength (–99 dBm ≤ RSSI < –89 dBm).
·     Off: Weak or no signal strength (RSSI < –99 dBm).
LTE
·     Steady green: The 4G-LTE service is running.
·     Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is running.
·     Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is running.
·     Off: No LTE service.
GPS
·     Steady green: The GPS service is running.
·     Off: No GPS service.
CNDE
For more information about SIC-4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing a Micro SIM card
CAUTION
CAUTION:
The SIC-4G-CNDE-SJK interface module supports Micro SIM cards.
The SIC-4G-CNDE-SJK has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
Figure 57 Installing Micro SIM cards
SIC-D4G-CNDE-SJK
Introduction
The SIC-D4G-CNDE-SJK (D4G indicates that the module supports two SIM cards that can operate simultaneously; CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-D4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table 79 Interface specifications
Item
Connectors
5 SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure 58 SIC-D4G-CNDE-SJK panel
Table 80 LED description
LED
WWAN
·     Fast flashing green: Data is being transmitted or received.
·     Slowly flashing green: The module is searching for wireless networks.
RSSI
·     Fast flashing green: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm).
LTE
·     Off: No LTE service is running.
GPS
·     Off: No GPS service is running.
CNDE
For more information about SIC-D4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE-SJK has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE-SJK interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure 59 Installing Micro SIM cards
WLAN interface modules
·     SIC-AP220
·     SIC-AP320
SIC-AP220
Introduction
The SIC-AP220 WLAN interface module receives and sends wireless data. Two external antennas can be installed on the module. The module supports the 802.11a/b/g/n/ac standard and can operate on both the 2.4 G and 5G frequency bands.
Table 81 Interface specifications
Item
Connector type
RJ-45
Two: one for the FE port and one for the console port
Interface standard
FE port: 802.3/802.3u, 10/100Mbps autosensing, full/half duplex
Console port: RS/EIA-232
Radio interface: Radio 1 operates on the 5 GHz frequency band and supports the 1×1 MIMO technology. Radio 2 operates on the 2.4 GHz frequency band and support the 2×2 MIMO technology.
Cable type
FE port: Standard (straight-through)/cross-over Ethernet cable
Console port: Console cable
Interface LEDs
Figure 60 SIC-AP220 panel
Table 82 LED description
LED
SYS
·     Steady amber: The module is starting up.
·     Flashing green: Only the 2.4G radio has associated clients.
·     Flashing amber: Only the 5G radio has associated clients.
·     Flashing alternatively between amber and green: Both the 2.4G and 5G radios have associated clients.
For more information about WLAN interface cables and the connection methods, see "WLAN interface."
SIC-AP320
Introduction
The SIC-AP320 WLAN interface module receives and sends wireless data. Two external antennas can be installed on the module. The module supports the 802.11a/b/g/n/ac standard and can operate on both the 2.4 G and 5G frequency bands.
Table 83 Interface specifications
Item
Connector
1 RJ-45 connector for the console port
Interface standard
Radio interface: Radio 1 operates on the 5 GHz frequency band and supports the 2×2 MIMO technology. Radio 2 operates on the 2.4 GHz frequency band and support the 1×1 MIMO technology.
Cable type
Console cable for the console port
Interface LEDs
Figure 61 SIC-AP320 panel
Table 84 LED description
LED
SYS
M.2 riser SIC modules
RT-SIC-M2-SATA
CAUTION
CAUTION:
·     The RT-SIC-M2-SATA module is hot swappable. To remove an RT-SIC-M2-SATA module, first press and hold the remove button for a minimum of three seconds. You can remove the module only when the remove LED is turned off. If the remove LED is flashing green, wait for the remove LED to turn off and then remove the module.
·     No M.2 SSD drive is provided with the RT-SIC-M2-SATA module. Purchase one as required.
·     To build a redundant array of independent disks (RAID), install two SSD drives of the same size in two RT-SIC-M2-SATA modules.
Introduction
The RT-SIC-M2-SATA module is an M.2 SSD riser SIC module that provides high data availability through RAID. RAID combines multiple physical drives into one logical drive to provide better storage performance and data backup than a single drive.
Module specifications
Table 85 Module specifications
Item
Drive type
M.2 SATA SSD
Drive dimensions (D × W)
80 × 22 mm (3.15 × 0.87 in)
Number of drives
1
RAID level
RAID 1
Theoretical transmission rate
1.5/3/6 Gbps
Interface LEDs
Figure 62 RT-SIC-M2-SATA panel
Table 86 LED description
LED
Status
PWR
Steady green
The module has normal power input.
Off
The module does not have power input.
SSD
Steady green
A SSD drive is present.
Steady yellow
The SSD drive is damaged.
Off
No SSD drive is present.
ACT
The system is reading or writing data to the drive.
Off
The system is not reading or writing data to the drive.
REMOVE
·     The module is being initialized. Pressing the remove button or removing the module is not allowed.
·     A removal operation is being performed.
Steady green
The module is operating correctly. Pressing the remove button to remove the module is allowed.
Off
The module can be removed.
Installing an SSD drive on the module
CAUTION
CAUTION:
To use the RT-SIC-M2-SATA module, install an SSD drive in it.
To install an SSD drive on the module:
1.     Insert the SSD drive into the M.2 slot on the module at a 45° angle.
2.     Slightly press the SSD drive until it is level with the surface of the connector.
3.     Use a Phillips screwdriver to screw the SSD drive into place.
Figure 63 Installing an SSD drive
MIM interface modules
CAUTION
CAUTION:
MIM interface modules can be hot-swapped. To install a MIM interface module in an HMIM slot, first attach the MIM to an HMIM adapter and then insert the MIM into the HMIM slot. This can be performed when the device is operating. To remove a MIM interface module during device operation, first execute the remove command.
For the modular MSR series routers, a wide range of optional multiple interface modules (MIMs) are available, which provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, audio interface, and Layer 2 switching interface.
ATM interface modules
·     MIM-1ATM-OC3
MIM-1ATM-OC3
Introduction
The 1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (MIM-1ATM-OC3) provides ATM interfaces for routers and supports:
·     Two frame formats: SDH STM-1 and SONET OC-3
·     Scrambling in data transmission
·     Both line clock (when working as DTE interface), and internal clock (when working as DCE interface)
·     Three types of test measures, that is, local cell loopback, local payload loopback, and remote loopback.
Table 87 Interface specifications
Item
1
Connector
SFP/LC
Interface standard
Operating mode
155 Mbps
Interface LEDs
Figure 64 MIM-1ATM-OC3 panel
MIM-1ATM-OC3
Table 88 LED description
LED
LINK/ACT
LP/AL
·     Flashing: An alarm indication signal (AIS), loss of frame alignment (LFA) signal, or remote alarm indication (RAI) signal is present.
For more information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
POS (SDH/SONET) interface modules
·     MIM-1POS
MIM-1POS
Introduction
The 1-port SDH/SONET interface module (MIM-1POS) supports interface rates up to 155.52 Mbps (STM-1/OC-3).
The MIM-1POS can use the protocols such as PPP, Frame Relay and HDLC at the data link layer and IP at the network layer. It allows direct transmission of packets over SONET/SDH. It supports:
·     155.52 Mbps fractional interface.
Table 89 Interface specifications
Item
MIM-1POS
Connector
SFP/LC
Interface standard
1
Interface rate
155.52 Mbps
Interface LEDs
Figure 65 MIM-1POS panel
MIM-1POS
Table 90 LED description
LED
LINK/ACT
LP/AL
E1/T1 interface modules
·     MIM-1E1
·     MIM-2E1
·     MIM-4E1
·     MIM-1E1-F
·     MIM-2E1-F
·     MIM-4E1-F
·     MIM-8E1
·     MIM-8E1-F
·     MIM-2T1
·     MIM-4T1-F
MIM-1E1/MIM-2E1/MIM-4E1/MIM-1E1-F/MIM-2E1-F/MIM-4E1-F
Introduction
·     MIM-1E1/MIM-2E1/MIM-4E1
The 1-/2-/4-port channelized E1/PRI interface module (MIM-1E1/MIM-2E1/MIM-4E1) transmits, receives, and processes E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
·     MIM-1E1-F/MIM-2E1-F/MIM-4E1-F
The MIM-1E1-F/MIM-2E1-F/MIM-4E1-F module is different from the MIM-1E1/MIM-2E1/MIM-4E1 module in the sense that:
¡     The FE1 operating mode supported by the E1-F modules allows only one n No 64 kbps bundle to be formed on each interface, where n = 1 to 31. However, an E1 module allows arbitrary grouping of 31 channels and multiple bundles.
¡     The E1-F modules do not support PRI mode.
Table 91 Interface specifications
Item
MIM-1E1/1E1-F module
MIM-2E1/2E1-F module
MIM-4E1/4E1-F module
Connector
DB-15
DB-15
DB-25
Number of connectors
1
2
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
·     E1 75-ohm unbalanced coaxial cable
·     E1 120-ohm balanced twisted pair cable
·     120-ohm 4E1 conversion cable (MIM-4E1/MIM-4E1-F modules)
·     75-ohm 4E1 conversion cable (MIM-4E1/MIM-4E1-F modules)
Operating mode
·     E1, CE1, ISDN PRI (only supported by MIM-1E1/MIM-2E1/MIM-4E1)
·     FE1 (only supported by MIM-1E1-F/MIM-2E1-F/MIM-4E1-F)
Supported service
·     Backup
·     ISDN PRI (only supported by MIM-1E1/MIM-2E1/MIM-4E1)
Interface LEDs
MIM-1E1 and MIM-1E1-F panels are similar. The following figure illustrates an MIM-1E1 panel.
Figure 66 MIM-1E1 panel
The panels of MIM-2E1 and MIM-2E1-F are similar. The following figure illustrates an MIM-2E1 panel.
Figure 67 MIM-2E1 panel
MIM-4E1 and MIM-4E1-F panels are similar. The following figure illustrates an MIM-4E1 module.
Figure 68 MIM-4E1 panel
Table 92 LED description
LED
LINK
·     Off: The link is not set up.
·     On: The link has been set up.
ACT
·     Off: No data is being transmitted or received;
·     Flashing: Data is being received or/and transmitted.
Interface cables and the connection methods
MIM-8E1/MIM-8E1-F
Introduction
·     MIM-8E1 module
The 8-port channelized E1/PRI interface module (MIM-8E1) transmits, receives, and processes eight channels of E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
·     MIM-8E1-F module
The 8-port fractional E1 interface module (MIM-8E1-F) is different from the MIM-8E1 module in the sense that:
¡     The FE1 operating mode supported by the MIM-8E1-F module allows only one n No 64 kbps bundle to be formed on each interface, where n = 1 to 31. However, an MIM-8E1 module allows arbitrary grouping of 31 channels and therefore multiple bundles.
¡     The MIM-8E1-F module does not support PRI mode.
For a MIM-8E1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller E1 interface.
Table 93 Interface specifications
Item
Connector
D68
1
Interface standard
G.703
Interface rate
2.048 Mbps
Cable type
75-ohm 8E1 conversion cable
Cable characteristic impedance
75-ohm
Operating mode
·     E1, CE1, ISDN PRI (only supported by MIM-8E1)
·     FE1 (only supported by MIM-8E1-F)
Supported service
·     Backup
·     ISDN PRI (only supported by MIM-8E1)
Interface LEDs
MIM-8E1 and MIM-8E1-F panels are similar.
Figure 69 MIM-8E1 (75-ohm) panel
Figure 70 MIM-8E1-F (75-ohm) panel
dkba41303912_8E1_75_MIM
Table 94 LED description
LED
LINK
ACT
MIM-2T1/MIM-4T1-F
Introduction
·     MIM-2T1 module
The 2-port channelized T1/PRI interface module (MIM-2T1) serves to transmit/receive and handle T1 data streams, provide CT1 access, and fulfill the function of ISDN PRI. Thereby, one module can be used for multiple purposes.
·     MIM-4T1-F
The 4-port fractional T1 interface module (MIM-4T1-F) provides the following features:
¡     FT1 operating mode supported by T1-F modules allows only one bundle. In other words, the time slots can only be bundled into one n x 64 kbps or 56 kbps channel, where n=1-24.
¡     T1-F does not support PRI mode.
For a MIM-1T1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller T1 interface.
Table 95 Interface specifications
Item
Connector
RJ-45
·     2 (MIM-2T1 module)
·     4 (MIM-4T1-F module)
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm shielding network cable)
Operating mode
·     CT1/ISDN PRI (MIM-2T1 module)
·     FT1 (MIM-4T1-F module)
Supported service
·     Backup
·     ISDN PRI (MIM-2T1 module)
Interface LEDs
Figure 71 MIM-2T1 panel
MIM-2T1
Figure 72 MIM-4T1-F panel
Table 96 LED description
LED
LINK/ACT
·     On: A carrier signal is received.
·     Off: No carrier signal is received.
LP/AL
E3/T3 interface modules
·     MIM-1CE3
MIM-1CE3
Introduction
The 1-port channelized E3 interface module (MIM-1CE3) serves to:
·     Transmit/Receive and handle one channel of E3 fast traffic, as well as provide the accessing of E3 traffic when working in E3 mode.
·     Provide the low-speed accessing service at the speed of n No 64 kbps, where n is smaller than or equal to 128, when working in CE3 mode.
E3 represents the tertiary group rate of E system in the TDM system, that is, 34.368 Mbps. An E3 channel can be channelized into 16 E1 lines through the demultiplexing processes of E23 and E12, each E1 line supporting both the operating modes of E1 and CE1. E23 is used to indicate either E2-to-E3 multiplex or E3-to-E2 demultiplex, and E12 to indicate E1-to-E2 multiplex or E2-to-E1 demultiplex. "E23" and "E12" discussed here represent the demultiplex process.
Table 97 Interface specifications
Item
Connector
SMB
2
Interface standard
·     G.703
·     G.704
·     G.751
Interface rate
34.368 Mbps
Interface cable type
E3 cable (75ohm coaxial cable)
Operating mode
E3
CE3
Supported service
E3 leased line
Interface LEDs
Figure 73 MIM-1CE3 panel
MIM-1CE3
Table 98 LED description
LED
LINK
ACT
For more information about E3 interface cables and the connection methods, see "E3/T3 interface."
Serial interface modules
·     MIM-2SAE
·     MIM-4SAE
·     MIM-8SAE
·     MIM-8ASE
·     MIM-16ASE
MIM-2SAE/MIM-4SAE/MIM-8SAE
Introduction
The MIM-2SAE/MIM-4SAE/MIM-8SAE stands for 2/4/8-port enhanced high-speed synchronous/asynchronous serial interface module. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 99 Interface specifications
Item
Synchronous
Asynchronous
Connector
D28
2 (MIM-2SAE)
4 (MIM-4SAE)
8 (MIM-8SAE)
V.24
V.35, RS449, X.21, RS530
RS-232
DTE, DCE
DTE, DCE
Minimum baud rate
(bps)
1200
1200
300
Maximum baud rate
(bps)
64 k
2.048 M
115.2
Cable
·     V.35 DTE cable
·     V.35 DCE cable
·     X.21 DTE cable
·     X.21 DCE cable
·     RS449 DTE cable
·     RS449 DCE cable
·     RS530 DTE cable
·     RS530 DCE cable
Supported service
·     DDN leased line
·     Backup
·     Dumb terminal access
Interface LEDs
Figure 74 MIM-2SAE panel
MIM-2SAE
Figure 75 MIM-4SAE panel
MIM-4SAE
Table 100 LED description
LED
LINK
·     Off: No link is present;
·     On: A link is present.
ACT
Figure 76 MIM-8SAE panel
MIM-8SAE
The MIM-8SAE module provides a LED for each channel. When the LED is on, a link is present. When the LED is flashing, data is being transmitted or received.
MIM-8ASE/MIM-16ASE
Introduction
The 8/16-port enhanced asynchronous serial interface module (MIM-8ASE/MIM-16ASE) transmits/receives and handles asynchronous serial interface data streams. ASE modules, however, use RJ-45 connectors and AUX cables.
Table 101 Interface specifications
Item
MIM-8ASE module
MIM-16ASE module
Connector
RJ-45
8 (MIM-8ASE)
16 (MIM-16ASE)
RS-232
Cable
·     AUX cable
·     Ethernet straight-through cable
·     MIM-8ASE/MIM-16ASE dumb terminal cable
300
115.2 k
Service supported
·     Dialup through Modem
·     Backup
·     Asynchronous leased line service
Interface LEDs
Figure 77 MIM-8ASE panel
MIM-8ASE
Figure 78 MIM-16ASE panel
MIM-16ASE
Each channel on the MIM-8ASE/MIM-16ASE has only one LED.
Table 102 LED description
LED
LINK/ACT
·     Flashing: Data is being transmitted or received.
POS terminal access interface modules
·     MIM-6FCM
Introduction
The 6-port fast connect modem interface module (FIC-6FCM) provides services for point of sale (POS) terminal devices to fast dial up to a bank card accounting system.
The point of sale (POS) access service refers to a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services.
Table 103 Interface specifications
Item
Connector
RJ-45
6
Cable
Supported protocols
·     ITU-T-V.22 (PSK/QPSK)
·     V.22 BIS (QAM)
Interface LEDs
Figure 79 MIM-6FCM panel
6fcm面板
Each connector of the POS access port has two LEDs: carrier detect (CD) and ACT.
Table 104 LED description
LED
CD
·     Off: No carrier signals are detected.
·     On: A carrier signal is detected.
ACT
·     Flashing: Data is being received or transmitted.
·     Off: No data is being received or transmitted.
Interface cable
The MIM-6FCM uses telephone cables with ferrite core.
The standard equipment package for the MIM-6FCM includes the appropriate number of interface cables.
Connecting the interface cable
CAUTION
CAUTION:
·     Before connecting a port, read its label carefully. A wrong connection might damage the interface module or the device.
·     Add a special lightning arrester at the input end of the telephone cable for better protection.
To connect the interface cable:
1.     Connect one end of a telephone cable to the RJ-11 or RJ-45 connector of the FCM interface.
2.     Connect the other end of the telephone cable to the PSTN network.
3.     Check the LED on the MIM-6FCM panel. When the LED is on, the self-test succeeds. The LED is off, the self-test failed. In the latter case, contact your agent.
Upgrading the FCM module software
1.     Download the FCM module software to the CF module or flash of the router.
2.     After the router that is inserted with the FCM module is powered on and starts up, input bootrom update file cfa0:/ filename slot slotnum all in the user mode to upgrade FCM module software.
3.     Run the display version command to display the driver version. If the version number is changed, the upgrade is completed.
The driver version number is just like (Driver) 1.0 in the module information displayed as follows:
[SLOT  5]MIM-6FCM       (Hardware)1.0,   (Driver)1.0,    (Cpld)1.0
Voice interface modules
·     MIM-4FXS
·     MIM-4FXO
·     MIM-8FXS8FXO
·     MIM-16FXS
·     MIM-4E&M
·     MIM-2VE1
·     MIM-2VT1
·     MIM-1VE1
·     MIM-1VT1
MIM-8FXS8FXO
Introduction
The 8-port voice subscriber circuit and 8-port voice AT0 analog trunk interface module (MIM-8FXS8FXO) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides eight FXS interfaces and eight FXO interfaces:
CAUTION
CAUTION:
While using MIM-8FXS8FXO, make sure the device can be connected to IP networks or other WANs.
Table 105 Interface specifications
Item
Connector type
RJ-11
·     8 (FXS interfaces)
·     8 (FXO interfaces)
Interface standard
·     Subscriber circuit interface (FXS) compliant with ITU Q.512.
·     Loop trunk interface (FXO) compliant with ITU Q.552.
·     Over-current and over-voltage protection compliant with ITU K.20.
Cable type
Dial-up mode
DTMF, compliant with GB3378 (Pulse dial-up is not available.)
Bandwidth
300 to 3400 Hz
Interface LEDs
Figure 80 MIM-8FXS8FXO panel
MIM-8FXS8FXO
Table 106 LED description
LED
LINK/ACT
·     Off: No link is present.
·     Steady green: A link is present and a call connection is being established.
·     Flashing yellow: A link is present and there is a call activity.
MIM-16FXS
Introduction
The 16-port loop trunk interface module (MIM-16FXS) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides 16 FXS interfaces:
Table 107 Interface specifications
Item
Connector type
RJ-11
16 (FXS interfaces)
Interface standard
Cable type
Dial-up mode
Bandwidth
300 to 3400 Hz
Interface LEDs
Figure 81 MIM-16FXS panel
MIM-16FXS+口
Table 108 LED description
LED
LINK/ACT
For more information about FXS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
MIM-2VE1
Introduction
The 2-port E1 voice interface module (MIM-2VE1) handles dense voice signals in a VoIP system. It provides two CE1/PRI/R2 ports, allowing the access of 60 channels of voice signals.
Table 109 Interface specifications
Item
Connector
D15
2
Operating mode
CE1
ISDN PRI
R2
Interface rate
2.048 Mbps
Cable
75ohm-to-120ohm adapter
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
·     General VoIP features in Comware
Interface LEDs
Figure 82 MIM-2VE1 panel
MIM-2VE1面板
Table 110 LED description
LED
LINK
ACT
·     Off: No data is being transmitted or received on the interface.
·     Flashing: Data is being transmitted and/or received.
For more information about E1 interface cables and the connection methods, see "E1 interface."
MIM-2VT1
Introduction
The 2-port T1 voice interface module (MIM-2VT1) can handle dense voice signals in VoIP system. It provides two CT1/PRI ports, allowing the access of 48 channels of voice signals.
Table 111 Interface specifications
Item
Connector
RJ-45
Number of connector
2
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
Operation mode
·     CT1
·     ISDN PRI
Services
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure 83 MIM-2VT1 panel
MIM-2VT1面板
Table 112 LED description
LED
LINK
ACT
For more information about T1 interface cables and the connection methods, see "T1 interface."
MIM-1VE1
Introduction
The 1-port E1 voice interface module (MIM-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 113 Interface specifications
Item
Connector
D15
1
Operating mode
CE1
ISDN PRI
R2
Interface rate
2.048 Mbps
Cable
75-ohm-to-120-ohm adapter (with BNC connector)
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
Interface LEDs
Figure 84 MIM-1VE1 panel
MIM-1VE1面板
Table 114 LED description
LED
LINK
ACT
MIM-1VT1
Introduction
The 1-port T1 voice interface module (MIM-1VT1) can handle dense voice signals in VoIP system.
The MIM-1VT1 module is structured in the form of board plus VCPM module plus VPM strip. It provides a CT1/PRI port, allowing the access of 24 channels of voice signals.
Table 115 Interface specifications
Item
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
Operation mode
CT1
ISDN PRI
Services
Backup
Terminal access
ISDN
Interface LEDs
Figure 85 MIM-1VT1 panel
MIM-1VT1面板
Table 116 LED description
LED
LINK
ACT
MIM-4FXS/MIM-4FXO
Introduction
·     The 4-port voice subscriber circuit interface module (MIM-4FXS) serves to access and handle 4 channels of ordinary analog phone, fax, or AT0 loop trunk of telephone exchange.
·     The 4-port voice AT0 analog trunk interface module (MIM-4FXO) serves to access and handle 4 channels of common user lines of telephone exchange.
These modules make it possible to transfer voice signals over data communication networks.
Table 117 Interface specifications
Item
Connector
RJ-45
4
Cable
·     Telephone cable with ferrite core
·     E&M trunk (for E&M module, which should be made by users depending on the actual needs at the site.)
Interface standard
·     ITU Q.512-compliant subscriber circuit interface (MIM-4FXS)
·     ITU Q.552-compliant loop trunk interface (MIM-4FXO)
·     ITU K.20-compliant overcurrent and overvoltage protection
Dial-up mode
DTMF (Dual-Tone Multi-Frequency) but not pulse dial-up
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 86 MIM-4FXS panel
MIM-4FXS
Figure 87 MIM-4FXO panel
MIM-4FXO+口
Table 118 LED description
LED
LINK
ACT
·     Off: The channel is idle.
·     On: There is call activity.
MIM-4E&M
Introduction
The 4-port voice E&M analog trunk interface module (MIM-4E&M) serves to access and handle 2/4 channels of E&M analog trunks.
Table 119 Interface specifications
Item
Connector
RJ-45
4
Cable
Interface standard
·     G.712-compliant E&M trunk interface, E&M interface (supporting Bell type I, II, III, V, and support 4-wire).
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 88 MIM-4E&M panel
MIM-4EM+口
Table 120 LED description
LED
LINK
ACT
For more information about E&M interface cables and the connection methods, see "E&M interface."
HMIM/DHMIM interface modules
CAUTION
CAUTION:
·     HMIM interface modules can be hot-swapped. To remove a HMIM when the device is operating, first execute the remove command or press the remove button. For the specific operation instructions, see the description for the HMIM interface module. The remove command and the remove button cannot be used simultaneously, as this might cause the HMIM interface module to become unusable.
·     DHMIM interface modules can be hot-swapped. To remove a DHMIM when the device is operating, first execute the remove command.
For the modular MSR series routers, a wide range of optional high-performance multiplex interface modules (HMIMs) and double high-performance multiplex interface modules (DHMIMs) are available, which provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, audio interface, and Layer 2 switching interface.
Ethernet switching modules
·     HMIM-8GSW
·     HMIM-24GSW
·     HMIM-24GSW-PoE
·     HMIM-8GSWF
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE
Introduction
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE module is an 8/24/24 1000 Mbps Ethernet Layer 2 switching HMIM interface module. Each HMIM-8GSW/HMIM-24GSW module provides 8/24 1000 Mbps RJ-45 ports. HMIM-8GSW/HMIM-24GSW modules are suitable for a small enterprise network to act as a switching and routing device, which can be directly connected to PCs and network devices of the enterprise. The HMIM-24GSW-PoE can supply power to remote PDs.
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE supports the following functions:
·     A transmission distance of 100 m (328.08 ft) over a category-5 twisted pair cable (crossover or straight-through cable).
·     1000 Mbps wire-speed forwarding between any two ports connected with a category-5 twisted pair cable (crossover or straight-through cable).
·     Autosensing at a rate of 10 Mbps, 100 Mbps, or 1000 Mbps.
·     Full duplex (typically used) and half duplex operating modes.
Table 121 describes the interface specifications of the HMIM-8GSW, HMIM-24GSW, and HMIM-24GSW-PoE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 121 Interface specifications
Item
Connector type
RJ-45
Interface type
MDI/MDIX
·     8 (HMIM-8GSW)
·     24 (HMIM-24GSW and HMIM-24GSW-PoE)
Cable type
Standard (straight-through) Ethernet cable/crossover Ethernet cable
Operation mode
Autosensing 10/100/1000 Mbps, full duplex/half duplex
Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Cross medium dependent interfaces (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN Switches.
Interface LEDs
Figure 89 HMIM-8GSW panel
Figure 90 HMIM-24GSW panel
Figure 91 HMIM-24GSW-PoE panel
Each 1000 Mbps Ethernet interface on the panel has one LED.
Table 122 LED description
LED status
Off
No link is present.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is sending and receiving data at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
The port is sending and receiving data at 10/100 Mbps.
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface."
HMIM-8GSWF
Introduction
The 8-port 100/1000 Mbps Ethernet Layer 2/Layer 3 HMIM interface module HMIM-8GSWF provides four SFP fiber ports and four combo interfaces. It is designed for a switching/routing integrated device on a small-sized enterprise network. You can connect it to network devices inside the network.
Functions supported by interface modules are as follows:
·     Various types of transceiver modules.
·     Operating speeds of 1000 Mbps and 100 Mbps.
·     Full duplex operating mode.
Table 123 describes the interface specifications of the HMIM-8GSWF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 123 Interface specifications
Item
Number of ports
8
Connector type
SFP/LC/RJ-45
Interface standard
·     802.3
·     802.3u
·     802.3ab
Operation mode
Interface LEDs
Figure 92 HMIM-8GSWF panel
Table 124 SFP fiber port LED description
LED status
Off
No link is present.
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
The port is sending and receiving data at 100 Mbps.
Table 125 RJ-45 port LED description
LED
Green LED
·     On: A 1000 Mbps link is present.
·     Flashing: The port is sending and receiving data at 1000 Mbps.
Yellow LED
·     On: A100 Mbps link is present.
·     Flashing: The port is sending and receiving data at 100 Mbps.
Transceiver modules, optical fibers, and connection methods
Ethernet interface modules
·     HMIM-2GEE
·     HMIM-4GEE
·     HMIM-8GEE
·     RT-HMIM-4GEE-V2
·     RT-HMIM-8GEE-V2
·     HMIM-2GEF
·     HMIM-4GEF
·     HMIM-8GEF
·     RT-HMIM-4GEF-V2
·     RT-HMIM-8GEF-V2
·     RT-HMIM-4XP
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE
Introduction
The HMIM-GEE module is used to complete the communication between a router and a LAN, which includes the following types:
·     HMIM-2GEE2-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
·     HMIM-4GEE4-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
·     HMIM-8GEE8-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
The HMIM-2GEE/HMIM-4GEE/HMIM-8GEE supports:
·     100 m (328.08 ft) of transmission distance over a category-5 twisted-pair cable.
·     Operation at 10/100/1000 Mbps and autosensing.
·     Full duplex and half-duplex, autonegotiation.
Table 126 describes the interface specifications of the HMIM-2GEE, HMIM-4GEE, and HMIM-8GEE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 126 Interface specifications
Item
HMIM-2GEE
HMIM-4GEE
HMIM-8GEE
Connector type
RJ-45
2
4
8
Interface type
MDI/MDIX
Interface standard
·     802.3
·     802.3u
·     802.3ab
Supported cable
Ethernet cable
Operating mode
·     10/100/1000 Mbps, autosensing
·     Full duplex/half-duplex, autonegotiation
Interface LEDs
Figure 93 HMIM-2GEE panel
Figure 94 HMIM-4GEE panel
Figure 95 HMIM-8GEE panel
Table 127 LED description
LED
Green LED
Yellow LED
·     On: A 10/100 Mbps link is present.
·     Flashing: The port is sending and receiving data at 10/100 Mbps.
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2
CAUTION
CAUTION:
The RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The 4/8-port 10Base-T/100Base-TX/1000Base-T Ethernet copper interface module (RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2) is used to complete the communication between a router and a LAN.
The RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2 supports:
Table 128 describes the interface specifications of the RT-HMIM-4GEE-V2 and RT-HMIM-8GEE-V2 interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 128 Interface specifications
Item
RT-HMIM-4GEE-V2
RT-HMIM-8GEE-V2
Connector type
RJ-45
4
8
Interface type
MDI/MDIX
Interface standard
·     802.3
·     802.3u
·     802.3ab
Supported cable
Ethernet cable
Operating mode
Interface LEDs
Figure 96 RT-HMIM-4GEE-V2 panel
Figure 97 RT-HMIM-8GEE-V2 panel
Table 129 LED description
LED
Status
LINK/ACT
Green
A 1000 Mbps link is present on the port.
Flashing green
Yellow
A 10/100 Mbps link is present on the port.
Flashing yellow
Off
No link is present on the port.
RUN
Steady green
The interface module is operating correctly. You cannot remove it.
Off
The interface module is not recognized and you can remove it, or the interface module has been removed.
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF
Introduction
The HMIM-GEF module is used to complete the communication between a router and a LAN, which includes the following types:
·     HMIM-2GEF2-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
·     HMIM-4GEF4-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
·     HMIM-8GEF8-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
The HMIM-2GEF/HMIM-4GEF/HMIM-8GEF supports:
·     Operation at 1000 Mbps.
·     Full duplex.
Table 130 describes the interface specifications of the HMIM-2GEF, HMIM-4GEF, and HMIM-8GEF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 130 Interface specifications
Item
HMIM-2GEF
HMIM-4GEF
HMIM-8GEF
2
4
8
Connector type
SFP/LC
Interface standard
·     802.3
·     802.3u
·     802.3ab
Operating mode
·     1000 Mbps
·     Full duplex
Interface LEDs
Figure 98 HMIM-2GEF panel
Figure 99 HMIM-4GEF panel
Figure 100 HMIM-8GEF panel
Table 131 LED description
Status
Steady green
Flashing green
Data is being transmitted and/or received at 1000 Mbps.
Steady yellow
Flashing yellow
Data is being transmitted and/or received at 100 Mbps.
Off
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2
CAUTION
CAUTION:
The RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The 4/8-port 1000Base-SX/1000Base-LX Ethernet fiber interface module (RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2) is used to complete the communication between a router and a LAN.
The RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2 supports:
·     Full duplex.
Table 132 describes the interface specifications of the RT-HMIM-4GEF-V2 and RT-HMIM-8GEF-V2 interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 132 Interface specifications
Item
RT-HMIM-4GEF-V2
RT-HMIM-8GEF-V2
4
8
Connector type
SFP/LC
Interface standard
·     802.3
·     802.3u
·     802.3ab
Operating mode
·     1000 Mbps
·     Full duplex
Interface LEDs
Figure 101 RT-HMIM-4GEF-V2 panel
Figure 102 RT-HMIM-8GEF-V2 panel
Table 133 LED description
LED
Status
LINK/ACT
Green
Flashing green
Yellow
A 100 Mbps link is present on the port.
Flashing yellow
Off
RUN
Steady green
Off
RT-HMIM-4XP
CAUTION
CAUTION:
The RT-HMIM-4XP interface module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The RT-HMIM-4XP is a 10GBASE-R Ethernet interface module that provides four SFP+ ports. Each port is a Layer 3 service port. The RT-HMIM-4XP module supports SFP transceiver modules and 10 Gbps SFP+ transceiver modules.
Table 134 describes the interface specifications of the RT-HMIM-4XP interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 134 Interface specifications
Item
Number of interfaces
4
Connector
SFP+/LC
Interface standard
10GBASE-R
Interface rate and duplex mode
1000 Mbps/10 Gbps autosensing, full duplex
Interface LEDs
Figure 103 RT-HMIM-4XP panel
Table 135 LED description
LED
Status
RUN
Steady green
Off
The interface module has not been recognized or is not present.
You can remove the module when the RUN LED is off.
LINK/ACT
Steady green
A 10 Gbps link is present on the port.
Flashing green (12 Hz)
Data is being transmitted and/or received at 10 Gbps on the port.
Steady yellow
Flashing yellow (12 Hz)
Data is being transmitted and/or received at 1000 Mbps on the port.
Off
·     HMIM-1ATM-OC3
HMIM-1ATM-OC3
Introduction
The 1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (HMIM-1ATM-OC3) provides ATM interfaces for routers and supports the following features:
·     Three types of test measures: local cell loopback, local payload loopback, and remote loopback.
Table 136 Interface specifications
Item
1
Connector
SFP/LC
Interface standard
·     SONET OC-3
·     SDH STM-1
Operating mode
155 Mbps
Interface LEDs
Figure 104 HMIM-1ATM-OC3 panel
Table 137 LED description
LED
LINK/ACT
LP/AL
·     On: The interface is in loopback mode.
·     Off: No loopback or alarm is present.
·     Flashing: An alarm is present.
·     HMIM-1POS
·     RT-HMIM-2POS-STM1
·     RT-HMIM-4POS-STM1/4
HMIM-1POS
Introduction
The 1-port SDH/SONET interface module (HMIM-1POS) supports interface rates up to 155.52 Mbps (STM-1/OC-3).
The HMIM-1POS can use the protocols such as PPP, Frame Relay, and HDLC at the data link layer and IP at the network layer. It allows direct transmission of packets over SONET/SDH.
The HMIM-1POS provides 155.52 Mbps fractional interface and supports various types of transceiver modules.
Table 138 Interface specifications
Item
Interface standard
SONET OC-3/SDH STM-1
1
Connector type
SFP/LC
Interface rate
155.52 Mbps
Interface LEDs
Figure 105 HMIM-1POS front panel
Table 139 LED description
LED
LINK/ACT
LP/AL
RT-HMIM-2POS-STM1
CAUTION
CAUTION:
The RT-HMIM-2POS-STM1 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The RT-HMIM-2POS-STM1 2-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The RT-HMIM-2POS-STM1 module supports the PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH.
The RT-HMIM-2POS-STM1 module provides 155.52 Mbps fractional interface and supports various types of transceiver modules.
Table 140 Interface specifications
Item
Interface standard
2
Connector type
SFP/LC
Interface rate
155.52 Mbps
Interface LEDs
Figure 106 RT-HMIM-2POS-STM1 front panel
Table 141 LED description
LED
Status
ACT/ALM
Steady green
A 155.52 Mbps link is present on the port.
Flashing green
Data is being transmitted and/or received at 155.52 Mbps on the port.
Steady red
An alarm has occurred on the port.
Off
No transceiver module is present on the port or the port is in shutdown state.
RUN
Steady green
Flashing green
The interface module is upgrading firmware.
Steady red
The interface module is faulty.
Off
RT-HMIM-4POS-STM1/4
CAUTION
CAUTION:
The RT-HMIM-4POS-STM1/4 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The RT-HMIM-4POS-STM1/4 4-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3) or 622.08 Mbps ( STM-4/OC-12).
The RT-HMIM-4POS-STM1/4 module supports the PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH.
You can use command lines to configure the POS ports on the RT-HMIM-4POS-STM1/4 module to operate at STM-1/OC-3 POS or STM-4/OC-12 POS mode. The operation mode configuration applies to the ports rather than the whole interface module.
Table 142 Interface specifications
Item
Interface standard
·     SONET OC-3/SDH STM-1
·     SONET OC-12/SDH STM-4
4
Connector type
SFP/LC
Interface rate
·     155.52 Mbps
·     622.08 Mbps
Interface LEDs
Figure 107 RT-HMIM-4POS-STM1/4 front panel
Table 143 LED description
LED
Status
ACT/ALM
Steady green
A 155.52 or 622.08 Mbps link is present on the port.
Flashing green
Data is being transmitted and/or received at 155.52 or 622.08 Mbps on the port.
Steady red
Off
RUN
Steady green
Flashing green
Steady red
Off
CPOS (SDH/SONET) interface modules
·     HMIM-1CPOS
·     HMIM-2CPOS
HMIM-1CPOS/HMIM-2CPOS
Introduction
The HMIM-1CPOS/HMIM-2CPOS is a 1-port/2-port channelized SDH/SONET interface module. C stands for channelized, and POS for Packet over SDH/SONET. The HMIM-1CPOS/HMIM-2CPOS provides one/two STM-1/OC3-compliant multi-channel interfaces and supports communication speeds up to 155.52 Mbps.
HMIM-1CPOS/HMIM-2CPOS can change between the E1 system and T1 system.
HMIM-1CPOS is inserted in an HMIM slot of a modular router and communicates with the CPU through the PCI interface to receive and transmit data on STM-1 channelized POS interface. It supports:
·     Clear channel (unframed) E1 or T1
·     Fractional (framed) E1 or T1
·     Up to 256 64 kbps logical channels
Table 144 Interface specifications
Item
Connector
SFP/LC
Number of Connectors
1
Interface standard
Interface rate
155.52 Mbps
IMPORTANT
IMPORTANT:
If the interface receives signal over a long-haul optical fiber, make sure the transmission distance is longer than 25 km (15.53 miles). If the transmission distance is shorter than 25 km (15.53 miles), use an optical attenuator to reduce the optical power.
Interface LEDs
Figure 108 HMIM-1CPOS front panel
Figure 109 HMIM-2CPOS front panel
Table 145 LED description
LED
LINK/ACT
LP/AL
Interface mode switchover
You can switch the HMIM-1CPOS/HMIM-2CPOS to operate in E1 and T1 interface modes at the command line interface (CLI).
To switch the interface mode:
1.     Insert the HMIM-1CPOS/HMIM-2CPOS into the HMIM slot of the router and then power on the router.
2.     Use the card-mode command in system view to set the interface mode. The HMIM-1CPOS/HMIM-2CPOS module is inserted in slot 4 of the router in the following example.
# Enter system view.
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in E1 interface mode.
[Sysname] module-mode slot 4 e1
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in T1 interface mode.
[Sysname] module-mode slot 4 t1
·     HMIM-1E1
·     HMIM-2E1
·     HMIM-4E1
·     HMIM-1E1-F
·     HMIM-2E1-F
·     HMIM-4E1-F
·     HMIM-8E1
·     HMIM-8E1-F
·     RT-HMIM-2E1-V3
·     RT-HMIM-4E1-V3
·     RT-HMIM-8E1-V3
·     HMIM-2T1
·     HMIM-4T1-F
·     HMIM-2E1T1
·     HMIM-4E1T1
·     HMIM-8E1T1
·     HMIM-2E1T1-F
·     HMIM-4E1T1-F
·     HMIM-8E1T1-F
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F
Introduction
The 1-port channelized E1/PRI interface module (HMIM-1E1), 2-port channelized E1/PRI interface module (HMIM-2E1), and 4-port channelized E1/PRI interface module (HMIM-4E1) transmit, receive, and process E1 data traffic. In addition, you can use these modules for other purposes, such as CE1 access and the ISDN PRI function.
The HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F module is different from the HMIM-1E1/HMIM-2E1/HMIM-4E1 module in the sense that:
·     The FE1 operating mode supported by the E1-F modules allows only one n No 64 Kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an E1 module allows arbitrary grouping of 31 channels and multiple bundles.
·     The E1-F modules do not support PRI mode.
Table 146 Interface specifications
Item
HMIM-1E1/HMIM-1E1-F
HMIM-2E1/HMIM-2E1-F
HMIM-4E1/HMIM-4E1-F
Connector type
DB15
DB15
DB25
1
2
1
Interface standard
G.703 and G.704
Interface rate
2.048 Mbps
Cable type
·     120-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F)
·     75-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F)
·     Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector)
Operating mode
·     E1, CE1, ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1)
·     FE1 (only supported by the HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F)
Supported services
·     Backup
·     Terminal access service
·     ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1)
Interface LEDs
Figure 110 HMIM-E1 panel
Figure 111 HMIM-E1-F panel
Figure 112 HMIM-2E1 panel
Figure 113 HMIM-2E1-F panel
Figure 114 HMIM-4E1 panel
Figure 115 HMIM-4E1-F panel
Table 147 LED description
LED
LINK/ACT
LP/AL
·     Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty.
LINK
ACTIVE
·     Off: No data is being transmitted or received.
HMIM-8E1/HMIM-8E1-F
Introduction
The 8-port channelized E1/PRI interface module (HMIM-8E1) transmits, receives, and processes eight channels of E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
The 8-port fractional E1 interface module (HMIM-8E1-F) is different from the HMIM-8E1 module in the sense that:
·     The FE1 operating mode supported by the HMIM-8E1-F module allows only one n No 64 Kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an HMIM-8E1 module allows arbitrary grouping of 31 channels and therefore multiple bundles.
·     The HMIM-8E1-F module does not support PRI mode.
For an HMIM-8E1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller E1 interface.
Table 148 Interface specifications
Item
Connector type
D68
1
Interface standard
G.703
Interface rate
2.048 Mbps
Cable type
75 ohm
Operating mode
·     E1, CE1, ISDN PRI (only supported by the HMIM-8E1)
·     FE1 (only supported by the HMIM-8E1-F)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-8E1)
Interface LEDs
Figure 116 HMIM-8E1 (75-ohm) panel
Figure 117 HMIM-8E1-F (75-ohm) panel
Table 149 LED description
LED
LINK/ACT
LP/AL
RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3
CAUTION
CAUTION:
The RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3 module stands for 2/4/8-port channelized CE1/PRI and fractional E1 (E1-F) interface module.
The module provides the following features:
·     Channelized CE1/PRI modeThe module allows arbitrary grouping of 31 channels and multiple bundles. It transmits/receives and handles E1 data streams, provides CE1 access, and supports ISDN PRI.
·     Unchannelized E1 modeInterfaces on the module are 2048 Mbps synchronous serial interfaces without timeslot division.
·     Fractional E1 (E1-F) modeThe time slots can only be bundled into one n x 64 kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
Table 150 Interface specifications
Item
RT-HMIM-2E1-V3
RT-HMIM-4E1-V3
RT-HMIM-8E1-V3
Connector type
RJ-45
RJ-45
RJ-45
2
4
8
Interface standard
G.703
Interface rate
2.048 Mbps
Cable type
·     E1 120-ohm balanced twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft)
·     75-ohm adapter cable
Operating mode
·     Unchannelized E1 (G.703)
·     Channelized E1 (CE1/PRI)
Supported services
·     Backup
·     ISDN PRI
Interface LEDs
Figure 118 RT-HMIM-2E1-V3 panel
Figure 119 RT-HMIM-4E1-V3 panel
Figure 120 RT-HMIM-8E1-V3 panel
On the panel, each port corresponds to one green LED and one yellow LED. Table 151 describes the LEDs on the panel.
Table 151 LED description
LED
Status
LINK/ACT
Steady green
A carrier signal has been received.
Flashing green
Data is being transmitted or/and received.
Off
No carrier signal has been received.
LP/AL
Steady yellow
Flashing yellow
Off
RUN
Steady green
The module is operating correctly. You cannot remove it.
Off
The module is not recognized and you can remove it, or the module has been removed.
HMIM-2T1/HMIM-4T1-F
Introduction
The 2-port channelized CT1/PRI interface module (HMIM-2T1) serves to transmit/receive and handle T1 data streams, provide CT1 access, and fulfill the function of ISDN PRI. Thereby, one module can be used for multiple purposes.
The 4-port fractional T1 interface module (HMIM-4T1-F) is different from the HMIM-CT1 module in the sense that:
·     FT1 operating mode supported by T1-F modules allows only one bundle. In other words, the time slots can only be bundled into one n x 64 Kbps/56 Kbps channel, where the value range of n is 1 to 24. However, a CT1 module allows of arbitrary grouping of the 24 channels.
·     T1-F does not support PRI mode.
For a T1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller T1 interface.
Table 152 Interface specifications
Item
Connector type
RJ-45
·     2 (HMIM-2T1)
·     4 (HMIM-4T1-F)
Interface standard
·     G.703/T1 102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
cable type
Operating mode
CT1, ISDN PRI (only supported by the HMIM-2T1)
FT1 (only supported by the HMIM-4T1-F)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-2T1)
Interface LEDs
Figure 121 HMIM-2T1 panel
Figure 122 HMIM-4T1-F panel
Table 153 LED description
LEDs
LINK/ACT
·     Flashing: Data is being transmitted or/and received.
LP/AL
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F
Introduction
·     HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module
The 2/4/8-port channelized E1/CE1/T1/CT1/PRI interface module transmits/receives and handles T1 data streams, provides CT1 access, and supports ISDN PRI. The module allows arbitrary grouping of 31 channels.
·     HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module
The 2/4/8-port fractional T1 interface module allows only one bundle. The time slots can only be bundled into one n x 64 Kbps/56 Kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
·     HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1(-F) jumper settings
You can use command lines and a jumper to configure an interface on the interface module as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, an interface is a 75-ohm E1 interface.
¡     To configure an interface on the interface module as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
¡     To configure an interface on the interface module as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure 123 Jumper connecting methods
·     An interface corresponds to a jumper connector. Pin settings for the jumper connectors are the same.
·     Each interface comes with four jumper caps.
·     All interfaces must operate in the same mode.
Table 154 Interface specifications
Item
HMIM-2E1T1/
HMIM-2E1T1-F
HMIM-4E1T1/
HMIM-4E1T1-F
HMIM-8E1T1/
HMIM-8E1T1-F
Connector type
RJ-45
RJ-45
RJ-45
2
4
8
Interface standard
·     G.703/G.704
·     T1 102
·     AT&T TR 54016
·     AT&T TR 62411
·     ANSI T1.403
Interface rate
·     1.544 Mbps
·     2.048 Mbps
Supported cable
·     E1 75-ohm unbalanced twisted pair cable
·     T1 cable (100-ohm shielding network cable)
·     Coaxial connector, network connector, 75-to-120-ohm adapter (with BNC connector)
Operating mode
·     E1/T1/CE1T1/ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module)
·     FE1T1 (only supported by the HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module)
Interface LEDs
Figure 124 HMIM-2E1T1 panel
Figure 125 HMIM-2E1T1-F panel
Figure 126 HMIM-4E1T1 panel
Figure 127 HMIM-4E1T1-F panel
Figure 128 HMIM-8E1T1 panel
Figure 129 HMIM-8E1T1-F panel
Table 155 LED description
LED
Status
LINK/ACT
Steady green
Flashing green
Off
LP/AL
Steady yellow
Flashing yellow
Off
·     HMIM-1CE3
HMIM-1CE3
Introduction
The 1-port channelized E3 interface module (HMIM-1CE3) serves to:
·     Transmit/receive and handle one channel of E3 fast traffic, as well as provide the accessing of E3 traffic when operating in E3 mode.
·     Provide the low-speed accessing service at the speed of n No 64 kbps, where "n" is smaller than or equal to 128, when operating in CE3 mode.
Table 156 Interface specifications
Item
Connector type
SMB
2
Interface standard
G.703, G.704, and G.751
Interface rate
34.368 Mbps
Cable type
E3 cable (75-ohm coaxial cable)
Operating mode
·     E3
·     CE3
Supported services
E3 leased line
Interface LEDs
Figure 130 HMIM-1CE3 panel
Table 157 LED description
LED
LINK/ACT
LP/AL
·     HMIM-2SAE
·     HMIM-4SAE
·     HMIM-8SAE
·     RT-HMIM-4SAE-V2
·     RT-HMIM-8SAE-V2
·     HMIM-8ASE
·     HMIM-16ASE
·     RT-HMIM-8ASE-V2
·     RT-HMIM-16ASE-V2
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE
Introduction
The 2-port SAE module (HMIM-2SAE), 4-port SAE module (HMIM-4SAE), and 8-port SAE module (HMIM-8SAE) are enhanced high-speed synchronous/asynchronous serial interface modules. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 158 Interface specifications
Item
Synchronous
Asynchronous
Connector type
D28
2 (HMIM-2SAE)
4 (HMIM-4SAE)
8 (HMIM-8SAE)
Interface standard and operating mode
V.24
V.35, RS449, X.21, and RS530
RS-232
DTE and DCE
DTE and DCE
Minimum baud rate (bps)
1200
1200
300
Maximum baud rate (bps)
64000
2048000
115200
cable type
V.24 DTE cable
V.24 DCE cable
V.35 DTE cable
V.35 DCE cable
X.21 DTE cable
X.21 DCE cable
RS449 DTE cable
RS449 DCE cable
RS530 DTE cable
RS530 DCE cable
Supported services
·     DDN leased line
·     Dialup through modems
·     Backup
Interface LEDs
Figure 131 HMIM-2SAE panel
Figure 132 HMIM-4SAE panel
Table 159 LED description
LED
LINK
ACT
Figure 133 HMIM-8SAE panel
On the HMIM-8SAE module, each link corresponds to a LED. The LED state indicates the link state as follows:
·     OnA link is present.
·     Flashing—Data is being transmitted or received.
·     Off—No data is being transmitted or received.
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2
CAUTION
CAUTION:
The RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The 4-port SAE module (RT-HMIM-4SAE-V2) and 8-port SAE module (RT-HMIM-8SAE-V2) are enhanced high-speed synchronous/asynchronous serial interface modules. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 160 Interface specifications
Item
Synchronous
Asynchronous
Connector type
D28
4 (RT-HMIM-4SAE-V2)
8 (RT-HMIM-8SAE-V2)
V.24
RS-232
DTE and DCE
DTE and DCE
1200
1200
300
64000
2048000
115200
Cable type
V.24 DTE cable
V.24 DCE cable
V.35 DTE cable
V.35 DCE cable
X.21 DTE cable
X.21 DCE cable
RS449 DTE cable
RS449 DCE cable
RS530 DTE cable
RS530 DCE cable
Supported services
·     DDN leased line
·     Backup
·     Terminal access
Interface LEDs
Figure 134 RT-HMIM-4SAE-V2 panel
Figure 135 RT-HMIM-8SAE-V2 panel
Table 161 LED description
LED
Status
RUN
Steady green
Off
LINK/ACT
Steady green
A link is present.
Flashing green
Off
No link is present.
HMIM-8ASE/HMIM-16ASE
Introduction
The 8-port ASE module (HMIM-8ASE) and the 16-port ASE module (HMIM-16ASE) are enhanced asynchronous serial interface modules that are used to transmit, receive, and handle asynchronous serial interface data streams. ASE modules use RJ-45 connectors and AUX cables.
Table 162 Interface specifications
Item
HMIM-8ASE
HMIM-16ASE
Connector type
RJ-45
8 (HMIM-8ASE)
16 (HMIM-16ASE)
RS-232
cable type
·     AUX cable
·     Standard (straight-through) Ethernet cable
·     HMIM-8ASE/HMIM-16ASE dumb terminal cable
300
115.2 k
Supported services
·     Dialup through a modem
·     Backup
Interface LEDs
Figure 136 HMIM-8ASE panel
Figure 137 HMIM-16ASE panel
Each channel on HMIM-8ASE/HMIM-16ASE has only one LED. The LED state indicates the link state as follows:
·     On—A link is present.
·     Off—No link is present.
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2
CAUTION
CAUTION:
The RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The 8-port ASE module (RT-HMIM-8ASE-V2) and the 16-port ASE module (RT-HMIM-16ASE-V2) are enhanced asynchronous serial interface modules that are used to transmit, receive, and handle asynchronous serial interface data streams. ASE modules use RJ-45 connectors and AUX cables.
Table 163 Interface specifications
Item
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
Connector type
RJ-45
·     8 (RT-HMIM-8ASE-V2)
·     16 (RT-HMIM-16ASE-V2)
RS-232
cable type
·     AUX cable
·     Dumb terminal cable
300
115.2 k
Supported services
·     Backup
Interface LEDs
Figure 138 RT-HMIM-8ASE-V2 panel
Figure 139 RT-HMIM-16ASE-V2 panel
Each channel on RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 has only one LED. The LED state indicates the link state as follows:
·     HMIM-1E1POS
·     DHMIM-1E1POS1DM
HMIM-1E1POS
Introduction
The HMIM-1E1POS is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The HMIM-1E1POS is applicable to the bank data transaction center for smart card accounting management.
The POS access service is a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services.
·     The HMIM-1E1POS uses the PRI voice protocol, but cannot be used for regular voice calling. The voice subscriber lines that the HMIM-1E1POS generates cannot be used as regular voice interfaces, and cannot be bound to the voice entities.
·     The PRI interface is used for transmitting service data. The interfaces Diag Port0 and Diag Port1 are used only for device debugging.
Table 164 Interface specifications
Item
Connector
RJ-45
1
Cable
120-ohm standard non-shield cable
Operating mode
PRI
Supported protocols
Synchronous mode:
·     V.22 BIS (QAM)
Supported services
POS call in PRI mode
Interface LEDs
Figure 140 HMIM-1E1POS panel
Table 165 LED description
LED
LINK/ACT
·     Steady green: A carrier signal is detected.
·     Flashing green: Data is being received or transmitted.
LP/AL
·     Steady yellow: The interface is in loopback.
·     Flashing yellow: An alarm is present.
Interface cable
The HMIM-1E1POS uses the 120-ohm unshielded E1 cable with RJ-45 connecters at both ends.
Figure 141 HMIM-1E1POS interface cable
标准网线
The HMIM-1E1POS does not come with the interface cable. You need to order for the E1 cable.
CAUTION
CAUTION:
·     Before connecting a port, read its label carefully. A wrong connection can cause damages to the interface module and even the device.
·     As a best practice, add a lightning arrester between an interface cable and interface module for better lightning protection when the cable is routed outdoors.
1.     Connect one end of the interface cable to the RJ-45 port on the HMIM-1E1POS.
2.     Connect the other end of the interface cable to the peer device.
3.     Examine the status of the LINK LED on the HMIM-1E1POS. If the LINK LED is off, examine the cable connection and cable condition.
DHMIM-1E1POS1DM
Introduction
The DHMIM-1E1POS1DM is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The DHMIM-1E1POS1DM is applicable to the bank data transaction center for smart card accounting management.
The DHMIM-1E1POS1DM can operate as the HMIM-1E1POS or the DHMIM-1DM. When the E1 port of the DHMIM-1E1POS1DM operates in asynchronous mode, you can upgrade the POS device remotely.
Table 166 Interface specifications
Item
Connector
RJ-45
1
Cable
120-ohm standard non-shielded cable
Operation mode
PRI
Supported protocols
·     Synchronous mode:
¡     ITU-T-V.22 (PSK/QPSK)
¡     V.22 BIS (QAM)
·     Asynchronous mode:
¡     ITU-T V.92
¡     V.90
¡     V.34
¡     V.32 bis
¡     V.32
¡     V.23
¡     V.22 bis
¡     V.22
¡     V.21
¡     Bell 212a
¡     Bell 103
Supported services
Interface LEDS
Figure 142 DHMIM-1E1POS1DM panel
Table 167 LED description
LED
LINK/ACT
·     Steady green: The carrier signal is detected.
·     Flashing green (8 Hz): Data is being received or transmitted.
LP/AL
·     Flashing yellow (1 Hz): An alarm is present.
CAUTION
CAUTION:
·     Before connecting a port, read its label carefully. A wrong connection might cause damages to the interface module and even the device.
If the interface module has been properly installed, follow these steps to connect the cable:
1.     Connect one end of the interface cable to the RJ-45 port on the DHMIM-1E1POS1DM.
3.     Examine the status of the LINK LED on the DHMIM-1E1POS1DM. If the LINK LED is off, examine the cable connection and cable condition.
Digital modem interface modules
·     DHMIM-1DM
DHMIM-1DM
Introduction
The DHMIM-1DM is a 1-port channelized E1 high-density digital modem interface module. You can upgrade the POS device remotely.
Table 168 Interface specifications
Item
Connector
RJ-45
1
Cable
Operation mode
PRI
Supported protocols
Asynchronous mode:
·     ITU-T V.92
·     V.90
·     V.34
·     V.32 bis
·     V.32
·     V.23
·     V.22 bis
·     V.22
·     V.21
·     Bell 212a
·     Bell 103
Supported services
Interface LEDs
Figure 143 DHMIM-1DM panel
Table 169 LED description
LED
LINK/ACT
LP/AL
CAUTION
CAUTION:
1.     Connect one end of the interface cable to the RJ-45 port on the DHMIM-1DM.
3.     Examine the status of the LINK LED on the DHMIM-1DM. If the LINK LED is off, examine the cable connection and cable condition.
·     HMIM-16FXS
·     HMIM-8FXS8FXO
·     HMIM-2VE1
·     HMIM-2VT1
·     HMIM-1VE1
·     HMIM-1VT1
·     HMIM-4FXS
·     HMIM-4FXO
·     HMIM-4E&M
HMIM-16FXS
Introduction
The 16-port loop trunk interface module (HMIM-16FXS) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides 16 FXS interfaces.
FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
Table 170 Interface specifications
Item
Connector type
RJ-11
16 (FXS interfaces)
Interface standard
·     ITU Q.512-compliant subscriber circuit interface (FXS)
·     ITU K.20-compliant over-current and over-voltage protection
Cable type
Dial-up mode
Bandwidth
300 to 3400 Hz
Ringing voltage
40 V
Interface LEDs
Figure 144 HMIM-16FXS front panel
Table 171 LED description
LED
LINK/ACT
HMIM-8FXS8FXO
Introduction
The 8-port analog subscriber circuit interface module and 8-port voice AT0 loop trunk interface module (HMIM-8FXS8FXO) serve to access and handle 16 channels of analog voice signals over data communication networks. Eight FXS interfaces and eight FXO interfaces are available on an HMIM-8FXS8FXO module:
·     FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges;
·     FXO interfaces are loop trunk interfaces that provide access of common subscriber lines of exchanges.
When you use the HMIM-8FXS8FXO module in a device, make sure the device has been connected to the IP network or other WAN.
Table 172 Interface specifications
Item
Connector type
RJ-11
·     8 FXS interfaces
·     8 FXO interfaces
Interface standard
·     ITU Q.552-compliant loop trunk interface (FXO)
Cable type
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Ringing voltage
40 V
Interface LEDs
Figure 145 HMIM-8FXS8FXO front panel
Table 173 LED description
LED
LINK/ACT
·     Steady green: The link is being occupied for a call connection.
·     Off: The link is idle.
·     Flashing yellow: The link is being occupied for communication.
HMIM-2VE1
Introduction
The 2-port E1 voice interface module (HMIM-2VE1) can handle dense voice signals in VoIP system. It provides two CE1/PRI/R2 ports, allowing the access of 60 channels of voice signals.
Table 174 Interface specifications
Item
Connector
D15
2
Operating mode
·     CE1
·     ISDN PRI
·     R2
Interface rate
2.048 Mbps
Cable type
·     Coaxial connector, network interface connector, and 75-to-120-ohm adapter (with BNC connector)
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
Interface LEDs
Figure 146 HMIM-2VE1 panel
Table 175 LED description
LED
LINK/ACT
·     Flashing: Data is being received and/or transmitted.
LP/AL
HMIM-2VT1
Introduction
The 2-port T1 voice interface module (HMIM-2VT1) can handle dense voice signals in VoIP system. It provides two CT1/PRI ports, allowing the access of 48 channels of voice signals.
Table 176 Interface specifications
Item
Connector
RJ-45
Number of connector
2
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm standard shielded cable)
Operation mode
·     CT1
·     ISDN PRI
Services
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure 147 HMIM-2VT1 panel
Table 177 LED description
LED
LINK/ACT
LP/AL
HMIM-1VE1
Introduction
The 1-port E1 voice interface module (HMIM-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 178 Interface specifications
Item
Connector
D15
1
Operating mode
·     CE1
·     ISDN PRI
·     R2
Interface rate
2.048 Mbps
Cable
·     Coaxial connector, network interface connector, and 75ohm-to-120ohm adapter (with BNC connector)
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
Interface LEDs
Figure 148 HMIM-1VE1 panel
Table 179 LED description
LED
LINK/ACT
LP/AL
HMIM-1VT1
Introduction
The 1-port T1 voice interface module (HMIM-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI port, allowing the access of 24 channels of voice signals.
Table 180 Interface specifications
Item
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
Operation mode
·     CT1
·     ISDN PRI
Services
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure 149 HMIM-1VT1 panel
Table 181 LED description
LED
LINK/ACT
LP/AL
HMIM-4FXS/HMIM-4FXO
Introduction
The 4-port voice subscriber circuit interface module (HMIM-4FXS) processes and transmits over data communications networks voice signals for 2/4 regular analog phones, faxes, or AT0 loop trunks of telephone exchanges.
The 4-port voice AT0 analog trunk interface module (HMIM-4FXO) processes and transmits over data communications networks voice signals for 2/4 loops of telephone exchanges.
Table 182 Interface specifications
Item
Connector
RJ-45
4
Cable
·     E&M trunk cable (only for E&M modules, made on site)
Interface standard
·     ITU Q.512-compliant subscriber circuit interface (HMIM-4FXS)
·     ITU Q.552-compliant loop trunk interface (HMIM-4FXO)
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 150 HMIM-4FXS panel
Figure 151 HMIM-4FXO panel
Table 183 LED description
LED
LINK
ACT
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-4E&M/HMIM-8E&M
Introduction
The 4/8-port voice E&M analog trunk interface module (HMIM-4E&M/HMIM-8E&M) provides and transmits over data communications networks voice signals for 4/8 E&M analog trunks.
Table 184 Interface specifications
Item
Connector
RJ-45
·     4 (HMIM-4E&M)
·     8 (HMIM-8E&M)
Cable type
Interface standard
·     G.712-compliant E&M trunk interface (HMIM-4E&M/HMIM-8E&M), E&M interface (supporting Bell type I, II, III, V, and support 2-wire and 4-wire)
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure 152 HMIM-4E&M panel
Figure 153 HMIM-8E&M panel
Table 185 LED description
LED
Status
LINK
Steady green
A link is present.
Off
No link is present.
ACT
Steady yellow
There is call activity..
Off
Analog modem modules
·     HMIM-6AM
·     HMIM-6FCM
HMIM-6AM
Introduction
The 6-port analog modem interface module (HMIM-6AM) provides six channels of user dial-in and dial-out, and provides a connection speed of 56 kbps when ITU-T V.90 is applied. Working with the MSR routers, it provides medium-density RAS functions.
Table 186 Interface specifications
Item
Connector
RJ-45
6
Cable
Telephone cable
Interface rate
56 kbps
Interface standard
ITU-T V.90, K56flex, V.34 (33.6 kbps), V.FC, V.32 bis, V.32, V.22 bis, V.22A/B, V.23, V.21, Bell 212A a, and Bell 103
Supported service
Interface LEDs
Figure 154 HMIM-6AM panel
Table 187 LED description
LED
LINK
·     Flashing: A link is being established.
ACT
For more information about AM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-6FCM
Introduction
The 6-port fast connect modem interface module (HMIM-6FCM) provides POS terminal devices to fast dial up to a bank card accounting system.
The POS access service refers to a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services.
Table 188 Interface specifications
Item
Connector
RJ-45
Number of connectors
6
Cable
Supported protocols
ITU-T V.22
Interface LEDs
Figure 155 HMIM-6FCM panel
Table 189 LED description
LED
CD
ACT
For more information about FCM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
Network data encryption modules
HMIM-CNDE-SJK
Introduction
The HMIM-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers.
Interface LEDs
Figure 156 HMIM-CNDE-SJK panel
Table 190 LED description
LED
RUN
·     Steady green: The module is operating correctly and is not sending or receiving data.
·     Flashing green: The module is operating correctly and is sending or receiving data.
·     Steady yellow: The module is faulty.
·     Off: The module is not installed securely, or no power is present.
HMIM adapters
·     HMIM-Adapter
·     HMIM-Adapter-H
HMIM-Adapter/HMIM-Adapter-H
Introduction
The HMIM-Adapter/HMIM-Adapter-H is designed for MIM-to-HMIM conversions. Some MIMs can operate as HMIMs with an HMIM-Adapter/HMIM-Adapter-H adapter installed. For the MIM-to-HMIM conversion relations, see "Appendix B  Purchase guide."
Figure 157 HMIM-Adapter view
Figure 158 HMIM-Adapter-H view
VPM modules
VPM purchase guide
·     The HMIM-1VE1/HMIM-1VT1 module provides a voice processing module (VPM) slot. The HMIM-2VE1/HMIM-2VT1 module provides two VPM slots. Each VPM slot is installed with a VPM when the HMIM-1VE1/HMIM-1VT1 module or HMIM-2VE1/HMIM-2VT1 module is shipped from the factory.
·     The main board of the MSR 36-20 router provides a VPM slot. The main boards of the MSR 36-40, MSR 36-60, MSR 56-60, and MSR 56-80 routers provide two VPM slots. The routers do not provide VPMs when shipped from the factory. The number and specifications of VPMs needed depend on the number of calls.
·     The SIC-1VE1/SIC-1VT1 module does not provide any VPM slot, and can only use the VPMs installed on the main board of MSR.
·     The MIM-1VE1/MIM-1VT1 module provides a VPM slot, and the MIM-2VE1/MIM-2VT1 module provides two VPM slots. No VPM is installed when the MIM-1VE1/MIM-1VT1 or MIM-2VE1/MIM-2VT1 module is shipped from the factory.
·     The MIM-1VE1/MIM-1VT1 module must be used with VPM installed. The number of VPMs needed depends on the number of calls.
·     Because the initiator of a three-party conference is responsible for audio mixing, so when using MSR as the initiator of a three-party conference, the main board of MSR must have VPM installed.
Introduction
The voice processing module (VPM) functions encoding/decoding, echo cancellation (EC) and comfortable noise generation (CNG) of voices.
Table 191 Interface specifications
Item
Number of calls supported
·     8
·     16
·     24
·     32
·     128
·     256
·     512
XMIM interface modules
CAUTION
CAUTION:
XMIM interface modules can be hot-swapped. However, do not install an XMIM interface module during an active/standby MSU switchover. To view the status of dual MSUs, execute the display system stable state command in any view. To remove an XMIM while the device is operating, confirm that the RUN LED on the module is steady green.
·     RT-XMIM-8GEE-R
·     RT-XMIM-8GEF-R
RT-XMIM-8GEE-R
The RT-XMIM-8GEE-R is an 8-port GE copper port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEE-R has the following features:
·     Provides a transmission distance of up to 100 m (328.08 ft) when used with category-5 twisted-pair cables.
·     The interfaces can operate at a data rate of 10 Mbps, 100 Mbps, or 1000 Mbps and support data rate auto-sensing.
·     Supports half-/full-duplex auto-negotiation.
The following table describes the interface specifications of the RT-XMIM-8GEE-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 192 Interface specifications
Item
Connector type
RJ-45
8
Interface type
MDI/MDIX
Interface standard
802.3/802.3u/802.3ab
Cable
Straight-through and crossover Ethernet cable
Operating mode
10/100/1000 Mbps autosensing
Half/full-duplex auto-negotiation
Front panel and LEDs
The RT-XMIM-8GEE-R front panel is as shown in the following figure.
Figure 159 RT-XMIM-8GEE-R front panel
The following table describes the LEDs on the RT-XMIM-8GEE-R front panel.
Table 193 LED description
LED
Status
LINK/ACT
Green LED: On
A link is present on the interface and the interface is operating in 1000 Mbps mode
Green LED: Flashing
The interface is transmitting or receiving data, and is operating in 1000 Mbps mode.
Yellow LED: On
A link is present on the interface and the interface is operating in 10 or 100 Mbps mode.
Yellow LED: Flashing
The interface is transmitting or receiving data, and is operating in 10 or 100 Mbps mode.
Off
RUN
Steady green
The interface module has been detected by the device, which is the first stage of the initialization process.
Flashing green (1 Hz)
The device has successfully identified the interface module and has begun initializing the interface chips, which is the second stage of the initialization process.
Steady yellow
The interface module has failed to complete initialization successfully.
Off
The interface module has not been recognized or has been removed.
Interface cables and connection methods
For information about the Ethernet interface cables and connection methods, see "Ethernet interface."
RT-XMIM-8GEF-R
The RT-XMIM-8GEF-R is an 8-port GE fiber port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEF-R has the following features:
·     Supports multiple types of transceiver modules, providing the flexibility for users to select the transceiver modules that meet their specific needs.
·     The interfaces can operate at a data rate of 100 Mbps or 1000 Mbps and support data rate auto-sensing.
The following table describes the interface specifications of the RT-XMIM-8GEF-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 194 Interface specifications
Item
Interface quantity
8
Connector type
SFP/LC
Interface standard
Operating mode
100/1000 Mbps auto-sensing
The RT-XMIM-8GEF-R front panel is as shown in the following figure.
Figure 160 RT-XMIM-8GEF-R front panel
The interface module provides a LED at the bottom of the front panel for each LED.
Table 195 RT-XMIM-8GEF-R LED description
LED
Status
LINK/ACT
Steady green
A link is present on the interface and the interface is operating in 1000 Mbps mode.
Flashing green
Steady yellow
A link is present on the interface and the interface is operating in 100 Mbps mode.
Flashing yellow
The interface is transmitting or receiving data, and is operating in 100 Mbps mode.
Off
No link is present on the interface.
RUN
Steady green
Steady yellow
Off
For more information about the transceiver modules, optical fibers, and connection methods, see "Fiber port."
·     RT-XMIM-1POS
·     RT-XMIM-2POS
·     RT-XMIM-4POS
RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS
Introduction
The RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS is a 1/2/4-port packet over SDH/SONET (POS) XMIM interface module. The transmission rates of the modules are STM-1/OC-3 (155.52 Mbit/s) and STM-4/OC-12 (622.08 Mbit/s).
The RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS module supports PPP, frame relay, and HDLC at the data link layer and IP at the network layer. Interfaces on the RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS implements direct packet transmission over SONET/SDH.
Follow these restrictions and guidelines when using the RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS interface module:
·     You can use the line-card-mode command to set the POS interfaces on the interface module to operate in STM-1/OC-3 POS mode or STM-4/OC-12 POS mode.
·     The setting of the POS interface-operating mode is applicable to the entire interface module, rather than being specific to an individual interface.
The following table describes the interface specifications of the RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS interface module.
Table 196 RT-XMIM-1POS, RT-XMIM-2POS, and RT-XMIM-4POS interface specifications
Item
RT-XMIM-1POS
RT-XMIM-2POS
RT-XMIM-4POS
Interface standard
Interface quantity
1
2
4
Connector type
SFP/LC
Interface speed
155.52 Mbps,  622.08 Mbps
CAUTION
CAUTION:
When the RT-XMIM-2POS or RT-XMIM-4POS interface module is configured to operate in STM-4/OC-12 POS mode, only the interface marked 0 on the front panel is available, while the other interfaces are not available.
The T-XMIM-1POS, RT-XMIM-2POS, and RT-XMIM-4POS front panels are as shown in the following figure.
Figure 161 RT-XMIM-1POS front panel
Figure 162 RT-XMIM-2POS front panel
Figure 163 RT-XMIM-4POS front panel
The following table describes the LEDs on the front panel.
Table 197 RT-XMIM-1POS/RT-XMIM-2POS/RT-XMIM-4POS LED description
LED
Status
ACT/ALM
Steady green
A link is present on the port.
Flashing green
The interface is receiving or sending data.
Steady yellow
A transceiver module has been installed in the interface, while an alarm is present on the interface.
Off
No transceiver module has been installed in the interface.
RUN
Steady green
Steady yellow
Off
For more information about the transceiver modules, optical fibers, and connection methods, see "Fiber port.”
E1 interface modules
·     RT-XMIM-2E1
·     RT-XMIM-4E1
·     RT-XMIM-8E1
RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1
Introduction
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 is a 2/4/8-port XMIM module that can operate in channelized E1 (CE1/PRI) mode or fractional E1 (E1-F) mode.
·     In channelized E1 (CE1/PRI) mode, the module can group the 31 channels in multiple ways to achieve different bundling configurations. Its primary function is to receive, transmit, and process E1 data streams while also providing CE1 access. In addition, it supports also ISDN PRI. These features enable multiple purposes to be achieved on a single module.
·     In non-channelized E1 mode, the module functions as a synchronous serial port with a data bandwidth of 2.048 Mbps and no timeslot division.
·     In fractional E1 (E1-F) mode, the module can only be bundled once (into a single channel with a speed of n × 64K, where n = 1 to 31), and does not support PRI mode.
The following table describes the interface specifications of the module.
Table 198 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface specifications
Item
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
Connector type
RJ-45
RJ-45
RJ-45
2
4
8
Interface standard
G.703
Interface speed
2.048 Mbps
Cable
E1 120-ohm balanced twisted-pair cable (2m,15m, 30m)
E1 75-ohm unbalanced coaxial cable
75-ohm 8E1 repeater cable
Operating mode
Non-channelized E1(G.703)
Supported services
Backup
Endpoint access service
ISDN PRI
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 front panels are as shown in the following figures.
Figure 164 RT-XMIM-2E1 module front panel
Figure 165 RT-XMIM-4E1 module front panel
Figure 166 RT-XMIM-8E1 module front panel
The module provides a green and a yellow LED for each interface.
Table 199 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 LED description
LED
Status
LINK/ACT (green)
Steady green
Carrier signals are received.
Flashing green
The interface is sending or receiving data.
Off
No carrier signals are received.
LP/AL (yellow)
Steady yellow
The interface is in a loopback state.
Flashing yellow
The interface does not have a cable connected, the cable is faulty, or the peer device is faulty.
Off
RUN
Steady green
Steady yellow
Off
Interface cables and the connection methods
For more information about E1 interface cables and the connection methods, see "E1 interface.”
Cables and the connection methods
Ethernet interface
Ethernet cable appearance and applicable models
Table 200 Ethernet cable appearance and applicable models
Appearance
Applicable models
1 × RJ-45 < ---- > 1 × RJ-45
SIC-4FSW
SIC-4FSWP
SIC-4GSW
DSIC-9FSW
DSIC-9FSWP
SIC-1FEA
SIC-1GEC-V2
SIC-AP220
HMIM-8GSW
HMIM-24GSW
HMIM-24GSW-PoE
HMIM-2GEE
HMIM-4GEE
HMIM-8GEE
RT-HMIM-4GEE-V2
RT-HMIM-8GEE-V2
HMIM-1E1POS
DHMIM-1DM
DHMIM-1E1POS1DM
RT-XMIM-8GEE-R
10/100 Mbps Ethernet uses category-5 twisted pair cables, and 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100BASE-T and 10BASE-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when working at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
For the pinouts of common twisted pair cables, see the following tables. (A and B represent the two ends of a cable respectively.)
Table 201 Straight-through cable pinouts
Pinout No.
A
B
1
Orange/white
Orange/white
2
Orange
Orange
3
Green/white
Green/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Green
7
Brown/white
Brown/white
8
Brown
Brown
Table 202 Crossover cable pinouts
Pinout No.
A
B
1
Orange/white
Green/white
2
Orange
Green
3
Green/white
Orange/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Orange
7
Brown/white
Brown/white
8
Brown
Brown
Strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables; otherwise, the communication quality may be affected.
Connecting an Ethernet cable
1.     Connect one end of an Ethernet cable to an Ethernet interface on the module and the other end to the Ethernet interface on the peer device. Because the Ethernet interface of the module supports MDI/MDIX autosensing, you can use a straight-through cable or crossover cable to connect the interface.
2.     Check the status of the LED of the Ethernet interface after power-on. For the status of the LED, see the relevant part in this manual.
Fiber port
Appearances and applicable models of transceiver modules and optical fibers
Optical interfaces must work with SFP or SFP+ transceiver modules and optical fibers with LC connectors. For more information about interface module and transceiver module compatibility, see H3C MSR Router Series Transceiver Module Compatibility Matrix.
Connecting an optical fiber
CAUTION
CAUTION:
·     Never stare into an open optical Ethernet interface, because invisible rays may be emitted from the optical Ethernet interface.
·     Cover the dust cover if no optical fiber connector is connected to the optical Ethernet interface.
To connect an optical fiber:
1.     Insert the transceiver module to the interface on the interface module or service module.
2.     Identify the Rx and Tx ports on the transceiver module. Plug the LC connector at one end of one fiber cable into the Rx port of the router and the LC connector at the other end into the Tx port of the peer device. Plug the LC connector at one end of another fiber cable into the Tx port of the router and the LC connector at the other end to the Rx port of the peer device.
3.     View the LINK LED after connection.
¡     If the LED is on, the optical fiber link is present.
¡     If the LED is off, no link is present. This may be because the TX and Rx port of the optical fiber are not connected correctly. In this case, connect the optical fiber again.
E1 interface
To verify the impedance value of the E1 cable, view the label on the cable. The label location in Figure 167 is for illustration only.
Figure 167 E1 cable label
E1 cable appearance and applicable models
Table 203 E1 cable appearance and applicable models
Cable
Appearance
Applicable models
1-port E1 75-ohm cable
图一 1端口E1 75欧姆电缆
1 × D15 < ---- > 2 × BNC
SIC-E1-F
SIC-1EPRI
MIM-1E1
MIM-1E1-F
MIM-2E1
MIM-2E1-F
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
MIM-1VE1
MIM-2VE1
HMIM-1VE1
HMIM-2VE1
1-port E1 120-ohm cable
图二   1端口E1 120欧姆电缆
1 × D15 < ---- > 1 × RJ-45
MIM-1E1
MIM-1E1-F
MIM-2E1
MIM-2E1-F
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
MIM-1VE1
MIM-2VE1
HMIM-1VE1
HMIM-2VE1
1-port E1 120-ohm cable (2 m, 15 m, 30 m)-RJ-45
RT-HMIM-2E1-V3
RT-HMIM-4E1-V3
RT-HMIM-8E1-V3
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
2-port E1 75-ohm cable
图三  2端口E1 75欧姆电缆
1 × D15 < ---- > 4 × BNC
SIC-2E1-F
4-port E1 75-ohm cable
图四  4端口E1 75欧姆电缆
1 × D25 < ---- > 4 × D15
MIM-4E1
MIM-4E1-F
HMIM-4E1
HMIM-4E1-F
4-port E1 120-ohm cable
图五  4端口E1 120欧姆电缆
MIM-4E1
MIM-4E1-F
HMIM-4E1
HMIM-4E1-F
8-port E1 75-ohm cable
1 × D68 < ---- > 16 × BNC
MIM-8E1
MIM-8E1-F
HMIM-8E1
HMIM-8E1-F
1-port E1 75-ohm cable-RJ-45
RT-HMIM-2E1-V3
RT-HMIM-4E1-V3
RT-HMIM-8E1-V3
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
RT-XMIM-2E1
RT-XMIM-4E1
RT-XMIM-8E1
图六  75欧姆中继电缆
1 × BNC < ---- > 1 × BNC
Use as needed
Coaxial connector
图七  同轴连接器
Use as needed
Impedance converter
图八 阻抗转换器
2 × BNC < ---- > 1 × RJ-45
Use as needed
Dual inline package switch
E1 / E1-F / VE1 interface module provides a dual inline package (DIP) switch. The DIP switch setting defines the interface impedance and the grounding method.
Table 204 DIP switch-to-interface map
DIP switch
E1 interface
Applicable models
S1
Interface 0
MIM-1E1
MIM-1E1-F
MIM-2E1
MIM-2E1-F
MIM-4E1
MIM-4E1-F
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
SIC-1VE1
MIM-1VE1
MIM-2VE1
HMIM-1VE1
HMIM-2VE1
S2
Interface1
MIM-1E1
MIM-1E1-F
MIM-2E1
MIM-2E1-F
MIM-4E1
MIM-4E1-F
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
MIM-2VE1
HMIM-2VE1
S3
Interface2
MIM-4E1
MIM-4E1-F
HMIM-4E1
HMIM-4E1-F
S4
Interface3
MIM-4E1
MIM-4E1-F
HMIM-4E1
HMIM-4E1-F
By default, all DIP switches are ON, and the E1 interface impedance is 70 ohms, as shown in the following figure:
Figure 168 Default DIP switch settings
H3C recommends that you use the DIP switch as follows: When the interface is connected to a 70-ohm cable, turn on switches BIT1 through 8; when the interface is connected to a 120-ohm cable, turn off switches BIT1 through 8. Description for DIP switch settings is shown in the following table:
Table 205 Description for DIP switch settings
DIP
Configuration of 75-ohm impedance
Configuration of 120-ohm impedance
1BIT
75-ohm/120-ohm selection switch
ON
Off
2BIT
ON
Off
3BIT
ON
Off
4BIT
ON
Off
5BIT
ON
Off
6BIT
RxRing grounding mode selection switch
Off: RxRing is grounded via capacitance.
ON: RxRing is grounded directly.
N/A
7BIT
RxShield grounding mode selection switch
N/A
ON: RxShield is grounded.
Off: RxShield is not grounded.
8BIT
SxShield grounding mode selection switch
N/A
Off: RxShield is grounded via capacitance
ON: RxShield is grounded directly.
Connecting a 1/2/8-port E1 75-ohm cable (D15/D68 <----> BNC)
CAUTION
CAUTION:
Make sure you insert the cable into the right interface so as to avoid damages to the interface module or the chassis.
·     If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows:
a.     Connect the D15/D68 connector of the E1 75-ohm cable to the D15/D68 interface of the interface module and fasten the bolts to fix the cable.
b.     The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure 169 Connect an E1 75-ohm cable
·     If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure 170 Connect an E1 75-ohm cable
·     If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure 171 Connect an impedance converter
Connecting a 4-port E1 75-ohm cable (D25 <----> D15)
1.     Connect the D25 connector of the 4-port E1 75-ohm cable to the D25 interface of the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four D15 connectors. Connect them to the D15 interfaces on the remote device as needed.
Figure 172 Connect an 4-port E1 75-ohm cable
Connecting a 1-port E1 120-ohm cable (D15 <----> RJ-45)
1.     Connect the D15 connector of the E1 120-ohm cable to the D15 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides one or multiple RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure 173 Connecting an E1 120-ohm cable
Connecting a 4-port E1 120-ohm cable (D25 <----> D15)
1.     Connect the D25 connector of the 4-port E1 120-ohm cable to the D25 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four D15 connectors. Connect them to the D15 interface on the remote device as needed.
Figure 174 Connecting a 4-port E1 120-ohm cable
T1 interface
CAUTION
CAUTION:
To avoid damages to the interface module or the chassis, make sure you insert the cable into the right interface.
T1 cable appearance and applicable models
Table 206 T1 cable appearance and applicable models
Cable
Appearance
Applicable models
1-port T1 cable (100- ohm standard shielded cable)
SIC-T1-F
MIM-2T1
MIM-4T1-F
HMIM-2T1
HMIM-4T1-F
SIC-1VT1
SIC-1VE1T1
MIM-1VT1
MIM-2VT1
HMIM-1VT1
HMIM-2VT1
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
RJ-45 connector
图十八 RJ45连接器
Use as needed
Connecting a 1-port T1 cable
The two ends of the 1-port T1 cable are RJ-45 connectors. Connect one end of the cable to the T1 connector (RJ-45) of the interface module and the other end of the cable to the T1 connector (RJ-45) on the remote device.
Connecting a 4/8-port T1 cable
·     Connect the D68 connector of the 4/8-port T1 cable to the D68 interface on the interface module and fasten the bolts to fix the cable.
·     The other end of the cable provides four or eight RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
E3/T3 interface
E3/T3 cable appearance and applicable models
Table 207 E3/T3 cable appearance and applicable models
Cable
Appearance
Applicable models
E3/T3 interface cable
1 × BNS < ---- > 1 × SMB
MIM-1CE3
HMIM-1CE3
Connecting the cable
1.     Connect the SMB connector of an E3/T3 cable to the Tx port on the interface module and the other end to the Rx port on the device to be connected.
2.     Connect the SMB connector of another E3/T3 cable to the Rx port of interface module and the other end to the Tx port on the device to be connected;
3.     Check the LINK LED on the module panel. It is off when fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Appearance and applicable models of synchronous/asynchronous serial port cables
Table 208 Appearance and applicable models of synchronous/asynchronous serial port cables
Cable
Appearance
Applicable models
V.24 DTE cable
1 × D25 (male) < ---- > 1 × D28
SIC-1SAE
SIC-2SAE
SIC-4SAE
MIM-2SAE
MIM-4SAE
MIM-8SAE
HMIM-2SAE
HMIM-4SAE
HMIM-8SAE
RT-HMIM-4SAE-V2
RT-HMIM-8SAE-V2
V.24 DCE cable
1 × D25 (female) < ---- > 1 × D28
V.35 DTE cable
1 × D28 < ---- > 1 × D34 (male)
V.35 DCE cable
1 × D28 < ---- > 1 × D34 (female)
X.21 DTE cable
1 × D15 (male) < ---- > 1 × D28
X.21 DCE cable
1 × D15 (female) < ---- > 1 × D28
RS-449 DTE cable
1 × D28 < ---- > 1 × D37 (male)
RS-449 DCE cable
1 × D28 < ---- > 1 × D37 (female)
RS-530 DTE cable
RS-530 DCE cable
1.     Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2.     Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3.     If the WAN uses DDN line, connect the cable to the port of CSU/DSU.
4.     Check the LINK LED on the SAE panel.
·     If the LED is on, a link is present.
·     If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Appearance and applicable models of asynchronous serial port cables
Table 209 Appearance and applicable models of asynchronous serial port cables
Cable
Appearance
Applicable models
8-port asynchronous serial port adapter cable
图九 8端口异步串口转接电缆
1 × D60 < ---- > 8 × RJ-45 (female)
SIC-8AS
4-port asynchronous serial port adapter cable
图十  4端口异步串口转接电缆
1 × D28 < ---- > 4 × RJ-45 (female)
SIC-16AS
Serial server cable
MIM-8ASE
MIM-16ASE
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
Dumb terminal adapter cable
图十一  哑终端转接电缆
1 × RJ-45 (female) < ---- > 1 × RJ-45 (male)
MIM-8ASE
MIM-16ASE
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
AUX cable
图十二  AUX电缆
1 × D25 & 1 × D9 < ---- > 1 × RJ-45
MIM-8ASE
MIM-16ASE
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
图十九 哑终端转接器
1 × D25 < ---- > 1 × RJ-45
MIM-8ASE
MIM-16ASE
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
Console cable
1 × DB-9 < ---- > 1 × RJ-45
SIC-AP220
SIC-AP320
Connecting a SIC-8AS/SIC-16AS interface module
To connect the SIC-8AS interface module, connect the D60 connector of the 8-port asynchronous serial port adapter cable to the SIC-8AS interface module.
To connect the SIC-16AS interface module, connect the D28 connector of the 4-port asynchronous serial port adapter cable to the SIC-16AS interface module, which allows up to four such cables.
Choose the cable connection type according to the remote device type:
·     If the remote device is a network device with a console port, connect the console port to the RJ-45 interface of the asynchronous serial port adapter cable by using a serial server cable. The sequence is shown in the following figure:
Figure 175 Connecting a network device
·     If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the asynchronous serial port adapter cable. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a D25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure 176 Connecting the dumb terminal device
·     If the interface of the remote device, usually a modem, is a D25/D9 interface, use the AUX cable to connect the asynchronous serial port adapter cable to the interface:
Figure 177 Connecting a modem
Connecting a MIM-8ASE/MIM-16ASE/HMIM-8ASE/HMIM-16ASE/RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 interface module
WARNING
WARNING!
To avoid damage to the device and the ports, do not plug or unplug the MIM-8ASE/MIM-16ASE module interface cable when the router is powered on.
CAUTION
CAUTION:
·     If the remote device is a network device with a console port, connect the console port to the RJ-45 interface of the interface module by using a serial server cable. The sequence is shown in the following figure:
Figure 178 Connecting a network device
·     If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the interface module. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a D25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure 179 Connecting a bank dumb terminal device
·     If the interface of the remote device, usually a modem, is a D25/D9 interface, use the AUX cable to connect the RJ-45 interface on the interface module. The sequence is shown in the following figure:
Figure 180 Connecting a modem
Connecting a SIC-AP220/SIC-AP320 WLAN interface module
To connect the interface module to a configuration terminal (for example, a PC) through the serial console cable:
1.     Connect the DB-9 female connector of the console cable to the serial port of the PC
2.     Connect the RJ-45 connector to the console port on the module.
To disconnect the console cable, remove the RJ-45 connector end first.
Appearance and applicable models of the magnetic-core telephone cable
Table 210 Appearance and applicable models of magnetic-core telephone cable
Cable
Appearance
Applicable models
Magnetic-core telephone cable
图十三  带磁环的电话线
1 × RJ-11 < ---- > 1 × RJ-11
SIC-1ADSL
SIC-1ADSL-I
SIC-1BS
SIC-2BS
SIC-1FXS
SIC-1FXO
SIC-2FXS
SIC-2FXO
SIC-2FXS1FXO
DSIC-4FXS1FXO
SIC-1AM
SIC-2AM
MIM-4FXS
MIM-4FXO
MIM-16FXS
MIM-8FXS8FXO
HMIM-4FXS
HMIM-4FXO
HMIM-16FXS
HMIM-8FXS8FXO
HMIM-6AM
HMIM-6FCM
Connecting an ADSL/FXS/FXO/AM/FCM interface module
1.     Connect one end of the magnetic-core telephone cable to the RJ-11 or RJ-45 interface of the interface module.
2.     Connect the other end of the magnetic-core telephone cable to the remote device interface.
Connecting a BS/BU interface module cable
1.     If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the magnetic-core telephone cable to the RJ-45 interface of the SIC-1BS interface module. Connect the other end of the magnetic-core telephone cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure 181 Connecting the U interface cable to the SIC-1BS interface module
2.     If the service provider provides an ISDN S/T interface cable, directly connect the cable to the RJ-45 interface of the SIC-1BS interface module.
Figure 182 Connecting the S/T interface cable to the SIC-1BS interface module
E&M interface
E&M interface appearance and the applicable model
MIM-4E&M and FIC-4E&M modules support Bell I, II, III, V switches, and 2-wire & 4-wire voice signals.
As a best practice, use Bell V 4-wire voice signal to communicate with the router in practice.
The sequence of E&M RJ-45 pins is shown in the following figure, numbered 1 to 8 from left to right:
Figure 183 Sequence of RJ-45 pins
Table 211 Pinouts of E&M interface cable (Bell V 4-wire)
E&M interface
RJ-45 Pin
Signal
Signal direction
1
2
E
IN
3
RING0
IN
4
RING1
OUT
5
TIP1
OUT
6
TIP0
IN
7
M
OUT
8
SG
Ground
Because the 4E&M modules cannot determine the interface types (Bell I/II/III/V), cable types (2-wire or 4-wire), and pinouts (E/M/Tx/Rx) of the peer switch, you must prepare the interface cables of the 4E&M modules according to the on-site conditions. To ensure the EMC of the router, install a ferrite core near the connector of the E&M module interface cable at the router side.
The connection method
BSV/BSE interface
BSV/BSE interface cable appearance and applicable models
Table 212 BSV/BSE interface cable appearance and applicable models
Cable
Appearance
Applicable models
ISDN S/T interface standard cable
SIC-1BSV
SIC-2BSV
ISDN S/T interface crossover cable
图十一  哑终端转接电缆
SIC-1BSV
SIC-2BSV
Connecting a SIC-1BSV / SIC-2BSV / MIM-4BSV interface module cable
BSV interface supports the User and Network operating modes. The BSV interface works in User mode when connecting to an ISDN network, or works in Network mode when connecting to TE devices such as the digital telephones or the BSV interfaces working in User mode.
Choose the cable connection type according to the operating mode:
·     When the BSV interface works in User mode, choose the connection method according to the type of the cable provided by the service provider:
¡     If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the standard ISDN S/T interface cable to the RJ-45 interface of the BSV interface module. Connect the other end of the standard ISDN S/T interface cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure 184 Connecting a service provider U interface cable to a BSV interface module
¡     If the service provider provides an ISDN S/T interface cable, directly connect the service provider cable to the BSV interface.
Figure 185 Connecting a service provider S/T interface cable to a BSV interface module
·     When the BSV interface works in Network mode, you must use an ISDN S/T interface crossover cable to connect the BSV interface to a TE device such as a digital telephone or a BSV interface working in User mode:
Connect the RJ-45 connector (male) of the ISDN S/T interface crossover cable to the RJ-45 interface on the BSV interface module. Connect the RJ-45 interface (female) of the standard ISDN S/T interface cable to one end of the standard ISDN S/T interface cable. Connect the S/T interface on the TE device to the other end of the standard ISDN S/T interface cable.
Figure 186 Connecting a TE device to a BSV interface module
3G interface
Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Table 213 Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Antenna and cable
Appearance
Applicable models
Antenna
TZD-EW618-04_页面_1_图像_0003
SIC-3G-CDMA
SIC-3G-TD
SIC-3G-HSPA
AUX cable
图十二  AUX电缆
Table 214 The detailed specifications for the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Item
Frequency scope
824-960 MHz / 1710-2170 MHz
Voltage standing wave ratio
≤ 2
Input impedance
50 ohms
Gain
1.5 dBi
Polarization type
Vertical
Maximum input power
10 W
TNC-Male
Lightning protection
Direct current grounding
Height
153 mm (6.02 in)
Weight
26 g (0.92 oz)
Length
None
Color
Black
Operating temperature
–30 °C to +60 °C (–22°F to +140°F)
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
1.     To install an antenna, adjust the angle of the antenna to 180º.
2.     Fasten the antenna onto the antenna port that has a MAIN mark. Avoid over-tightening. Make sure the antenna is vertical to the ground or ceiling to achieve the optimal coverage.
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface debug antenna
To debug and test the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA, connect the RJ-45 interface of the AUX cable to the Diag Port interface and connect the D25/D9 connector to a peer device, which is usually a PC.
4G interface
Appearance and applicable models of 4G antennas and extension cables
Table 215 Appearance and applicable models of the 4G antennas and extension cables
Antenna and cable
Appearance
Applicable models
4G antenna
SIC-4G-LTE-M
4G antenna
SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK
4G antenna
RT-SIC-4G-CAT6
4G antenna extension cable
cid:image005.jpg@01D68CDF.2C973130
RT-SIC-4G-CAT6
Table 216 Antenna specifications
Item
Specification
SIC-4G-LTE-M
RT-SIC-4G-CAT6
Frequency scope
698 to 960 MHz
1.71 to 2.7 GHz
791 to 960 MHz
1710 to 2690 MHz
617 to 960 MHz
1400 to 1612 MHz
1710 to 2170 MHz
2300 to 2700 MHz
3300 to 3800 MHz
4400 to 5000 MHz
5150 to 5850 MHz
2.5
≤ 3.5
≤ 4
Input impedance
50 ohms
50 ohms
50 ohms
Gain
2 dBi
791 to 960 MHz @ 3.1 dBi
1710 to 2690 MHz @ 7.2dBi
617 to 960 MHz/0.59 dBi
1400 to 1612 MHz/1.87 dBi
1710 to 2170 MHz/3.74 dBi
2300 to 2700 MHz/3.51 dBi
3300 to 3800 MHz/3.7 dBi
4400 to 5000 MHz/4.0 dBi
5150 to 5850 MHz/4.87 dBi
Polarization type
Vertical
Vertical
Vertical
Maximum input power
5 W
1 W
1 W
TNC
SMA
SMA, male
Height
21.4 cm (8.43 in)
16.6 cm (6.54 in)
20.3 cm (7.99 in)
Weight
50.5 g (1.78 oz)
22 g (0.78 oz)
19.63 g (0.69 oz)
Color
Black
Black
Black
–40°C to +85°C (–40°F to +185°F)
–10°C to +60°C (14°F to 140°F)
–20°C to +60°C (–4°F to +140°F)
Table 217 4G antenna extension cable specifications for the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK module
Item
Specification
Frequency scope
698 to 960 MHz
1710 to 2700 MHz
≤ 2.0
Input impedance
50 ohms
Gain
2.0 dBi
Polarization type
Vertical
SMA
Height
16.4 ± 0.2 cm (6.46 ± 0.08 in)
Weight
134 ± 5 g (4.73 ± 0.18 oz)
Color
Black
Cable length
200 ± 2 cm (78.74 ± 0.79 in)
–40°C to +60°C (–40°F to +140°F)
Table 218 4G antenna extension cable specifications for the RT-SIC-4G-CAT6 module
Item
Specification
Frequency range
DC to 6 GHz
≤ 5
Input impedance
50 ohms
Cable type
RG-174
Max input power
1 W
SMA
Cable length
3000 mm (118.11 in)
Weight
65.3 g (2.30 oz)
Color
Black
Installing a 4G antenna for the SIC-4G-LTE-M, SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, SIC-D4G-CNDE-SJK, or RT-SIC-4G-CAT6 module
1.     Change the angle of the antenna orientation from vertical to horizontal.
2.     Fasten the antenna onto the antenna port. Avoid over-tightening.
Change the antenna orientation to vertical to achieve better signal coverage.
Connecting a 4G antenna extension cable for the SIC-4G-LTE-M, SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, SIC-D4G-CNDE-SJK, or RT-SIC-4G-CAT6 module
1.     Fasten the SMA connector onto the antenna port on the module.
2.     Attach the magnetic cradle on the other end of the extension cable to the rack.
Connecting a 4G antenna extension cable for the RT-SIC-4G-CAT6 module
1.     Fasten the SMA connector of the cable onto the antenna port on the module.
2.     Connect the SMA female connector at the other end of the cable to the rod antenna. Place the antenna to a location near outdoors.
Installing a 4G interface debugging antenna
A 4G interface module has a Mini USB port to connect to the peer device through the USB console cable for third-party software to debug the 4G interface module. When the interface module is operating correctly, you do not need to connect the USB console cable.
To debug a 4G interface module, connect the port at one end of the USB console cable to the peer device (PC), and connect the other end to the Mini USB port on the interface module.
5G interface
Appearance and applicable models of stick antennas and antenna extension cables
Table 219 Appearance and applicable models of the antennas and extension cables
Name
Appearance
Applicable models
Stick antenna A
cid:image004.jpg@01D68CDF.2C973130
RT-SIC-5G
RT-SIC-5G-CN
Stick antenna B
RT-SIC-5G
RT-SIC-5G-CN
3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base)
RT-SIC-5G
RT-SIC-5G-CN
1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base)
RT-SIC-5G
RT-SIC-5G-CN
10 cm (3.94 in) cable
RT-SIC-5G
RT-SIC-5G-CN
5 m (16.40 ft)/10 m (32.81 ft) antenna extension cable
RT-SIC-5G
RT-SIC-5G-CN
Antenna bracket
RT-SIC-5G
RT-SIC-5G-CN
Table 220 Stick antenna A specifications
Item
Frequency range
698 to 960 MHz
1710 to 2170 MHz
2300 to 2700 MHz
3300 to 3800 MHz
4400 to 5000 MHz
5150 to 5850 MHz
≤ 4
Input impedance
50 ohms
Gain
617 MHz to 960 MHz, 0.59 dBi
1710 MHz to 2170 MHz, 3.74 dBi
2300 MHz to 2700 MHz, 3.51 dBi
3300 MHz to 3800 MHz, 3.7 dBi
4400 MHz to 5000 MHz, 4.0 dBi
5150 MHz to 5850 MHz, 4.87 dBi
Polarization type
Vertical
Maximum input power
1 W
SMA male
Height
203 mm (7.99 in)
Weight
19.63 g (0.69 oz)
Color
Black
–20 °C to +65 °C (–4°F to +149°F)
Table 221 Stick antenna B specifications
Item
Frequency range
0.6 to 6 GHz
≤ 6
Input impedance
50 ohms
Gain (max.)
2.74 dBi @ 0.617 to 0.96 GHz
1.01 dBi @ 1.4 to 1.612 GHz
4.48 dBi @ 1.71 to 2.17 GHz
3.98 dBi @ 2.3 to 2.7 GHz
4.74 dBi @ 3.3 to 4.0 GHz
5.50 dBi @ 4.0 to 5.0 GHz
5.82 dBi @ 5.15 to 5.85 GHz
Polarization type
Vertical
Maximum input power
1 W
SMA male
Height
17.6 cm (6.93 in)
Weight
20 g (0.71 oz)
Color
Black
–20°C to +70°C (–4°F to +158°F)
Table 222 3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 5
Input impedance
50 ohms
Cable type
RG-174
Max input power
1 W
SMA
Cable length
3000 mm (118.11 in)
Weight
65.3 g (2.30 oz)
Color
Black
Table 223 1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.7
Input impedance
50 ohms
Cable type
RG-174
SMA
Cable length
1 m (3.28 ft)
Weight
202 g (7.13 oz)
Color
Black
Table 224 10 cm (3.94 in) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.2 @ (3 GHz)
≤ 1.4 @ (3 to 6 GHz)
Input impedance
50 ohms
Cable type
RG-174
SMA
Cable length
10 cm (3.94 in)
Color
Black
Table 225 5 m (16.40 ft) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
< 1.2 @ (0.3 to 2.4 GHz)
< 1.4 @ (5 to 6 GHz)
Input impedance
50 ohms
Cable type
RG8
SMA
Cable length
5 m (16.40 ft)
Color
White
Table 226 10 m (32.81 ft) antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 1.2 @ (2.4 GHz)
≤ 1.5 @ (5 to 6 GHz)
Input impedance
50 ohms
Cable type
RG8
SMA
Cable length
10 m (32.81 ft)
Color
White
Connection method of stick antennas and antenna extension cables
Different antenna configuration schemes and installation methods are used depending on the required antenna extension cable length and application scenario. For more information, see H3C MSR 5G SIC Modules SIM Card, Antenna, and Antenna Extension Cable Installation Guides.
GPS interface
Appearance and applicable models of the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK interface module GPS antenna
Table 227 Appearance and applicable models of the 4G interface module GPS antenna
Antenna
Appearance
Applicable models
GPS antenna
SIC-4G-CNDE
SIC-D4G-CNDE
SIC-4G-CNDE-SJK
SIC-D4G-CNDE-SJK
Table 228 Antenna specifications
Item
Specification
Frequency scope
1575.42 ± 3 MHz
≤ 1.92
Input impedance
50 ohms
Gain
1.5 dBic Typ
Echo return loss
10 dB Min
SMA
Extension cable length
5 m (16.40 ft)
Extension cable type
RG-174 Coaxial Cable
Color
Black
–30°C to +80°C (–22°F to +176°F)
Connecting an antenna extension cable
1.     Fasten the SMA connector onto the GPS antenna port on the module.
2.     Put the other end of the extension cable outdoor to achieve better signal coverage.
GNSS interface
Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Table 229 Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Antenna
Appearance
Applicable models
GNSS antenna
RT-SIC-4G-CAT6
Table 230 RT-SIC-4G-CAT6 module GNSS antenna specifications
Item
Specification
Frequency scope
·     1561±3 MHz
·     1575.42±3 MHz
·     1602±0.5 MHz
Operating mode
·     GPS
·     GLONASS
·     BDS
·     Galileo
Input impedance
50 ohms
Gain
–2.91 dBic Typ
SMA male
5 m (16.40 ft)
RG-174 coaxial cable
Color
Black
Connecting a GNSS antenna
1.     Fasten the SMA male connector of the antenna extension cable onto the GNSS antenna port on the module.
2.     Connect the other end of the extension cable to the antenna. Place the antenna outdoors for better signal receipt.
WLAN interface
Appearance and applicable models of the WLAN interface module antenna
Table 231 Appearance and applicable models of the WLAN interface module antenna
Antenna
Appearance
Applicable models
天线渲染图
SIC-AP220
SIC-AP320
Connecting a WLAN interface module antenna
1.     Unfold the antenna.
2.     Attach the antenna to the antenna connector on the interface module. To avoid damage, do not over-tighten the antenna.
3.     Fold the antenna to a 90-degree angle so that it is vertical to the ground or ceiling to achieve optimal coverage.
An interface can operate in bridge or route link mode. You can use the port link-mode command to change the link mode of an interface. Interfaces that operate in bridge mode are called Layer 2 interfaces. Interfaces that operate in route mode are called Layer 3 interfaces.
Some interfaces on Ethernet switching modules and interface modules can operate only as Layer 3 interfaces, as shown in Table 232. Some interfaces operate as Layer 2 interfaces by default but can be changed to Layer 3 interfaces by using the port link-mode command, as shown in Table 233.
IMPORTANT
IMPORTANT:
·     Interfaces on the SIC-4GSW interface module can operate only in route link mode (Layer 3 interface mode) when the interface module is installed on an MSR3600-28-G-DP or MSR3600-51-G-DP router.
·     By default, the nine Ethernet interfaces on the DSIC-9FSW and DSIC-9FSWP interface modules operate in bridge mode. You can execute the port link-mode command to change the operating mode of any four interfaces to route. The remaining five interfaces can operate only in bridge mode.
·     When the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, or DSIC-9FSWP interface module is installed on an MSR2600-10 or MSR2600-17 router, you can change the operating mode of any two interfaces to route. The remaining interfaces can operate only in bridge mode.
·     When the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, or DSIC-9FSWP interface module is installed on other routers than MSR2600-10 and MSR2600-17 routers, you can change the operating mode of any four interfaces to route. The remaining interfaces can operate only in bridge mode.
·     For the interface module compatibility with router models, see "Appendix B  Purchase guide."
Table 232 Ethernet interfaces that can operate only as Layer 3 interfaces
Ethernet switching module/Ethernet interface module
Interfaces that can operate only as Layer 3 interfaces
SIC-4FSW
N/A
SIC-4FSWP
N/A
DSIC-9FSW
N/A
DSIC-9FSWP
N/A
SIC-4GSW
N/A
SIC-4GSWF
N/A
SIC-1FEA
FE0
SIC-1FEF
SFP0
SIC-1GEC-V2
Combo 0 (GE0, SFP0)
HMIM-8GSW
N/A
HMIM-24GSW
N/A
HMIM-24GSW-PoE
N/A
HMIM-8GSWF
N/A
HMIM-2GEE
GE0 and GE1
HMIM-4GEE
GE0 to GE3
HMIM-8GEE
GE0 to GE7
RT-HMIM-4GEE-V2
GE0 to GE3
RT-HMIM-8GEE-V2
GE0 to GE7
HMIM-2GEF
SFP0 and SFP1
HMIM-4GEF
SFP0 to SFP3
HMIM-8GEF
SFP0 to SFP7
RT-HMIM-4GEF-V2
SFP0 to SFP3
RT-HMIM-8GEF-V2
SFP0 to SFP7
RT-HMIM-4XP
SFP+0 to SFP+3
RT-XMIM-8GEE-R
GE0 to GE7
RT-XMIM-8GEF-R
GE0 to GE7
Table 233 Ethernet interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
Interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
SIC-4FSW
FE0 to FE3
SIC-4FSWP
FE0 to FE3
DSIC-9FSW
Any four interfaces
DSIC-9FSWP
Any four interfaces
SIC-4GSW
GE0 to GE3
SIC-4GSWF
SFP0 to SFP3
SIC-1FEA
N/A
SIC-1FEF
N/A
SIC-1GEC-V2
N/A
HMIM-8GSW
GE0 to GE5, Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7)
HMIM-24GSW
GE0 to GE23
HMIM-24GSW-PoE
GE0 to GE23
HMIM-8GSWF
SFP0 to SFP3, Combo 4 (GE4, SFP4), Combo 5 (GE5, SFP5), Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7)
HMIM-2GEE
N/A
HMIM-4GEE
N/A
HMIM-8GEE
N/A
RT-HMIM-4GEE-V2
N/A
RT-HMIM-8GEE-V2
N/A
HMIM-2GEF
N/A
HMIM-4GEF
N/A
HMIM-8GEF
N/A
RT-HMIM-4GEF-V2
N/A
RT-HMIM-8GEF-V2
N/A
RT-HMIM-4XP
N/A
RT-XMIM-8GEE-R
N/A
RT-XMIM-8GEF-R
N/A
Interface module power consumption
Table 234 Interface module power consumption
Interface module model
Max power consumption
DSIC-9FSW
3.20 W
SIC-4GSW
3.80 W
SIC-4GSWF
4.20 W
SIC-1GEC-V2
0.82 W
RT-SIC-1POS-STM1
8.35 W
SIC-E1-F
0.43 W
SIC-2E1-F
0.43 W
SIC-8AS
3.35 W
SIC-16AS
0.75 W
SIC-1SAE
0.42 W
SIC-2SAE
3.35 W
SIC-4SAE
3.35 W
SIC-4RS
0.96 W
SIC-2FXS
2.00 W
SIC-2FXO
2.00 W
SIC-2FXS1FXO
2.44 W
SIC-3G-CDMA
3.40 W
SIC-3G-TD
3.40 W
SIC-3G-HSPA
3.40 W
SIC-4G-LTE-M
5.00 W
SIC-4G-CNDE
4.18 W
SIC-D4G-CNDE
6.61 W
SIC-CNDE
5.50 W
RT-SIC-4G-CAT6
4.68 W
RT-SIC-5G
7.60 W
RT-SIC-5G-CN
10.30 W
HMIM-8GSW
9.26 W
HMIM-24GSW
22.40 W
HMIM-24GSW-PoE
22.40 W
HMIM-2GEE
6.68 W
HMIM-4GEE
6.88 W
HMIM-8GEE
11.20 W
RT-HMIM-4GEE-V2
9.09 W
RT-HMIM-8GEE-V2
9.36 W
HMIM-2GEF
6.80 W
HMIM-4GEF
6.80 W
HMIM-8GEF
12.20 W
RT-HMIM-4GEF-V2
9.09 W
RT-HMIM-8GEF-V2
13.68 W
HMIM-8GSWF
10.30 W
RT-HMIM-4XP
5.12 W
HMIM-1ATM-OC3
5.80 W
HMIM-1POS
5.07 W
RT-HMIM-2POS-STM1
17.76 W
RT-HMIM-4POS-STM1/4
17.76 W
HMIM-1CPOS
10.00 W
HMIM-2CPOS
11.54 W
HMIM-1E1
4.50 W
HMIM-2E1
4.61 W
HMIM-4E1
4.71 W
HMIM-1E1-F
4.50 W
HMIM-2E1-F
4.61 W
HMIM-4E1-F
4.71 W
HMIM-8E1
4.90 W
HMIM-8E1-F
4.90 W
RT-HMIM-2E1-V3
4.34 W
RT-HMIM-4E1-V3
4.56 W
RT-HMIM-8E1-V3
4.91 W
HMIM-2T1
5.10 W
HMIM-4T1-F
5.30 W
HMIM-2E1T1
4.60 W
HMIM-4E1T1
5.65 W
HMIM-8E1T1
5.65 W
HMIM-2E1T1-F
4.60 W
HMIM-4E1T1-F
4.70 W
HMIM-8E1T1-F
4.90 W
HMIM-1CE3
11.30 W
HMIM-2SAE
6.71 W
HMIM-4SAE
6.90 W
HMIM-8SAE
7.29 W
RT-HMIM-4SAE-V2
4.19 W
RT-HMIM-8SAE-V2
4.69 W
HMIM-8ASE
3.60 W
HMIM-16ASE
4.30 W
RT-HMIM-8ASE-V2
3.00 W
RT-HMIM-16ASE-V2
3.12 W
HMIM-16FXS
21.19 W
HMIM-8FXS8FXO
15.22 W
HMIM-2VE1
10.75 W
HMIM-2VT1
10.75 W
HMIM-1VE1
9.50 W
HMIM-1VT1
9.50 W
HMIM-4FXS
6.30 W
HMIM-4FXO
3.54 W
HMIM-4E&M
7.17 W
HMIM-8E&M
7.17 W
HMIM-6AM
12.00 W
HMIM-6FCM
9.90 W
HMIM-CNDE-SJK
14.00 W
HMIM-Adapter
2.00 W
DHMIM-1DM
49.00 W
DHMIM-1E1POS1DM
58.56 W
VPM2 512
10.00 W
VPM2 256
6.12 W
VPM2 128
5.76 W
RT-XMIM-8GEE-R
8.80 W
RT-XMIM-8GEF-R
17.16 W
RT-XMIM-1POS
9.70 W
RT-XMIM-2POS
10.30 W
RT-XMIM-4POS
15.00 W
RT-XMIM-2E1
5.00 W
RT-XMIM-4E1
5.40 W
RT-XMIM-8E1
6.10 W
  • Become a Partner
  • Partner Resources
