- 12-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-802.1X commands
- 04-MAC authentication commands
- 05-Portal commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-Group domain VPN commands
- 14-SSH commands
- 15-SSL commands
- 16-SSL VPN commands
- 17-ASPF commands
- 18-APR commands
- 19-mGRE commands
- 20-Session management commands
- 21-Connection limit commands
- 22-Object group commands
- 23-Object policy commands
- 24-Attack detection and prevention commands
- 25-IP source guard commands
- 26-ARP attack protection commands
- 27-ND attack defense commands
- 28-uRPF commands
- 29-Crypto engine commands
- 30-FIPS commands
04-MAC authentication commands | 146.51 KB |
display mac-authentication connection
mac-authentication access-user log enable
mac-authentication carry user-ip
mac-authentication critical vlan
mac-authentication critical-voice-vlan
mac-authentication guest-vlan auth-period
mac-authentication host-mode multi-vlan
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer auth-delay
mac-authentication user-name-format
reset mac-authentication access-user
reset mac-authentication critical-vlan
reset mac-authentication guest-vlan
reset mac-authentication statistics
This feature is supported only on the Layer 2 Ethernet ports on Ethernet switching modules.
Use display mac-authentication to display MAC authentication settings and statistics.
interface interface-type interface-number: Specifies a port by its type and number. If the specified port is not enabled with MAC authentication, this command displays only global MAC authentication information.
If you do not specify any parameters, this command displays all MAC authentication information including the global settings, port-specific settings, MAC authentication statistics, and online user statistics.
# Display all MAC authentication settings and statistics.
MAC authentication : Enabled
User name format : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
Username : mac
Password : Not configured
Offline detect period : 300 s
Quiet period : 60 s
Server timeout : 100 s
Authentication domain : Not configured, use default domain
Online MAC-auth wired users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
0001-0000-0001 100 GigabitEthernet1/0/2 21
0001-0000-0003 12 GigabitEthernet1/0/4 301
GigabitEthernet1/0/1 is link-up
Carry User-IP : Disabled
Auth-delay timer : Enabled
Auth-delay period : 60 s
Guest VLAN : 100
Guest VLAN auth-period : 150 s
Critical VLAN : Not configured
Critical voice VLAN : Disabled
Host mode : Multiple VLAN
Max online users : 256
Authentication attempts : successful 2, failed 3
Current online users : 1
MAC address Auth state
0001-0000-0001 Unauthenticated
MAC authentication |
Whether MAC authentication is enabled globally. |
User name format |
User account type: MAC-based or shared. · If MAC-based accounts are used, this field displays the format settings for the username. For example, MAC address in lowercase(xx-xx-xx-xx-xx-xx) indicates that the MAC address is in six-section format, and letters are in lower case. · If a shared account is used, this field displays Fixed account. |
Username |
Username for MAC authentication. · If MAC-based accounts are used, this field displays mac. The device uses the MAC address of each user as the username and password for MAC authentication. · If a shared account is used, this field displays the username of the shared account for MAC authentication users. By default, the username is mac. |
Password |
Password for MAC authentication. · If MAC-based accounts are used or if a shared account is used but no password is configured, this field displays Not configured. · If a shared account is used and a password is configured, this field displays a string of asterisks (******). |
Offline detect period |
Offline detect timer. |
Quiet period |
Quiet timer. |
Server timeout |
Server timeout timer. |
Authentication domain |
MAC authentication domain specified in system view. If no authentication domain is specified in system view, this field displays Not configured, use default domain. |
Online MAC-auth wired users |
Number of wired online MAC authentication users, including users that have passed MAC authentication and users that are performing MAC authentication. |
Online MAC-auth wireless users |
Number of wireless online MAC authentication users, including users that have passed MAC authentication and users that are performing MAC authentication. |
Silent MAC users |
Information about silent MAC addresses. |
MAC address |
Silent MAC address. |
VLAN ID |
ID of the VLAN to which the silent MAC address belongs. |
From port |
Name of the port that marks the MAC address as a silent MAC address. |
Port index |
Index of the port that marks the MAC address as a silent MAC address. |
GigabitEthernet1/0/1 is link-up |
Status of the link on GigabitEthernet 1/0/1. In this example, the link is up. |
Whether MAC authentication is enabled on the port. |
Carry User-IP |
Whether user IP addresses are included in MAC authentication requests. |
MAC authentication domain specified for the port. |
Auth-delay timer |
Whether MAC authentication delay is enabled on the port. |
Auth-delay period |
MAC authentication delay timer. |
Re-auth server-unreachable |
Action taken when no server is reachable for MAC reauthentication: · Logoff—Logs off online MAC authentication users. · Online—Keeps MAC authenticated users online. |
Guest VLAN |
MAC authentication guest VLAN configured on the port. If no MAC authentication guest VLAN is configured, this field displays Not configured. |
Guest VLAN auth-period |
Authentication interval for users in the MAC authentication guest VLAN on the port. |
Critical VLAN |
MAC authentication critical VLAN configured on the port. If no MAC authentication critical VLAN is configured, this field displays Not configured. |
Critical voice VLAN |
Whether the MAC authentication critical voice VLAN feature is enabled on the port. |
Host mode |
· If multi-VLAN mode is enabled, this field displays Multiple VLAN. · If multi-VLAN mode is disabled, this field displays Single VLAN. |
Max online users |
Maximum number of concurrent online users allowed on the port. |
Authentication attempts: successful 1, failed 0 |
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts. |
MAC address |
MAC address of the online user. |
Auth state |
User status: · Authenticated—The user has passed MAC authentication. · Unauthenticated—The user failed MAC authentication. |
Use display mac-authentication connection to display information about online MAC authentication users.
In standalone mode:
display mac-authentication connection [ interface interface-type interface-number | slot slot-number | user-mac mac-addr | user-name user-name ]
In IRF mode:
display mac-authentication connection [ chassis chassis-number slot slot-number | interface interface-type interface-number | user-mac mac-addr | user-name user-name ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays information about online MAC authentication users for all ports.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about online MAC authentication users for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about online MAC authentication users for all cards. (In IRF mode.)
user-mac mac-address: Specifies an online MAC authentication user by its MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an online MAC authentication user, this command displays online user information for all MAC authentication users.
user-name user-name: Specifies an online MAC authentication user by its username. The user name is a case-sensitive string of 1 to 55 characters, and it can include the domain name. If you do not specify an online MAC authentication user, this command displays online user information for all MAC authentication users.
(In standalone mode.) If you do not specify any parameters, this command displays information about online MAC authentication users for all cards.
(In IRF mode.) If you do not specify any parameters, this command displays information about online MAC authentication users for all cards.
# (In standalone mode.) Display all online MAC authentication user information.
Total connections: 1
Slot ID: 0
Username: ias
Authentication domain: h3c
Initial VLAN: 1
Session timeout period: 2 s
Online from: 2013/03/02 13:14:15
Online duration: 0h 2m 15s
# (In IRF mode.) Display all online MAC authentication user information.
Chassis ID: 1
Slot ID: 0
Username: ias
Initial VLAN: 1
Total connections |
Total number of online MAC authentication users. |
User MAC address |
MAC address of the user. |
Access interface |
Interface through which the user accesses the device. |
MAC authentication domain to which the user belongs. |
IPv4 address |
IPv4 address of the user. If no user IPv4 address is available, this field is not displayed. |
IPv6 address |
IPv6 address of the user. If no user IPv6 address is available, this field is not displayed. |
Initial VLAN |
VLAN that holds the user before MAC authentication. |
Authorization untagged VLAN |
Untagged VLAN authorized to the user. |
Authorization tagged VLAN |
Tagged VLAN authorized to the user. |
Authorization VLAN |
Authorization ACL number/name |
Number or name of the ACL authorized to the user. If no ACL is authorized, this field displays N/A. If ACL authorization fails, this field displays (NOT effective) after the ACL number or name. |
Authorization user profile |
User profile authorized to the user. |
Authorization CAR |
Authorization CAR attributes assigned by the server. · Average input rate—Average rate of inbound traffic in bps. · Average output rate—Average rate of outbound traffic in bps. If no authorization CAR attributes are assigned, this field displays N/A. |
Authorization URL |
URL authorized to the user. |
Termination action |
Action attribute assigned by the server to terminate the user session: · Default—Logs off the online authenticated user when the session timeout timer expires. · Radius-request—Reauthenticates the online user when the session timeout timer expires. If the device performs local authentication, this field displays N/A. |
Session timeout period |
Session timeout timer assigned by the server. If the device performs local authentication, this field displays N/A. |
Online from |
Time from which the MAC authentication user came online. |
Online duration |
Online duration of the MAC authentication user. |
mac-authentication
Use mac-authentication to enable MAC authentication globally or on a port.
Use undo mac-authentication to disable MAC authentication globally or on a port.
mac-authentication
MAC authentication is disabled globally or on any port.
To use MAC authentication on a port, you must enable the feature both globally and on the port.
# Enable MAC authentication globally.
[Sysname] mac-authentication
# Enable MAC authentication on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication
Use mac-authentication access-user log enable to enable MAC authentication user logging.
Use undo mac-authentication access-user log enable to disable MAC authentication user logging.
MAC authentication user logging is disabled.
failed-login: Logs MAC authentication user login failures.
logoff: Logs MAC authentication user logoffs.
successful-login: Logs successful MAC authentication user logins.
To prevent excessive MAC authentication user log entries, use this feature only if you need to analyze abnormal MAC authentication user logins or logouts.
If you do not specify any parameters, this command enables all types of MAC authentication user logs.
# Enable logging MAC authentication user login failures.
info-center source maca logfile deny (Network Management and Monitoring Command Reference)
Use mac-authentication carry user-ip to include user IP addresses in MAC authentication requests sent to an IMC server.
Use undo mac-authentication carry user-ip to restore the default.
mac-authentication carry user-ip [ exclude-ip acl acl-number ]
A MAC authentication request does not include the user IP address.
exclude-ip: Specifies an ACL-based filter to identify source IP addresses that can or cannot trigger MAC authentication.
acl acl-number: Specifies a basic ACL. The value range for the acl-number argument is 2000 to 2999.
IMPORTANT: This command can only operate in conjunction with an IMC server. |
To avoid IP conflicts that result from changes to static IP addresses, use this command on a port that has MAC authentication users with static IP addresses.
This command adds user IP addresses to the MAC authentication requests sent to the authentication server. When MAC authentication is triggered for a user, the device checks the user's IP address for invalidity.
· If the IP address is valid, the device sends a MAC authentication request with the IP address included.
· If the IP address is not a valid host IP address or the triggering packet does not contain an IP address, the device does not initiate MAC authentication.
· If the packet is a DHCP packet with a source IP address of all zeros, the device sends a MAC authentication request without including the IP address. In this case, the IMC server does not examine the user IP address when it performs authentication.
Upon receipt of the authentication request that includes a user's IP address, the IMC server compares the user's IP and MAC addresses with its IP-MAC mappings.
· If an exact match is found or if no match is found, the user passes MAC authentication. In the latter case, the server creates an IP-MAC mapping for the user.
· If a mapping is found for the MAC address but the IP addresses do not match, the user fails the MAC authentication.
If the user host is configured with IPv6, the device might receive packets that contain an IPv6 link-local address, which starts with fe80. MAC authentication failure or incorrect MAC-IP binding will occur if this address is used in MAC authentication. To avoid these issues, configure an ACL to exclude the IPv6 IP addresses that start with fe80.
When you configure the ACL, follow these guidelines:
· The specified ACL number represents an IPv4 ACL and an IPv6 ACL with the same number. For example, if the ACL number is 2000, you specify both IPv4 ACL 2000 and IPv6 ACL 2000. The IPv4 ACL and the IPv6 ACL will be used to process IPv4 packets and IPv6 packets, respectively.
· Use permit rules to identify source IP addresses that are valid for MAC authentication. Use deny rules to identify source IP addresses that cannot trigger MAC authentication.
· In the rules, only the action keyword (permit or deny) and the source IP match criteria can take effect.
· As a best practice, configure a deny rule to exclude the IPv6 IP addresses that start with fe80 from triggering MAC authentication.
· If you configure permit rules, add a deny all rule at the bottom of the ACL.
Do not use this command in conjunction with the mac-authentication guest-vlan command on a port. The device cannot perform MAC authentication for a user once that user is added to the MAC authentication guest VLAN.
# Include user IP addresses in MAC authentication requests on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication carry user-ip
# Include user IP addresses in MAC authentication requests on GigabitEthernet 1/0/1 and deny users that use IPv6 link-local addresses from performing MAC authentication on the port.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule deny source fe80:0::0:0 16
[Sysname-GigabitEthernet1/0/1] mac-authentication carry user-ip exclude-ip acl 2000
mac-authentication
Use mac-authentication critical vlan to configure a MAC authentication critical VLAN on a port.
Use undo mac-authentication critical vlan to restore the default.
No MAC authentication critical VLAN exists on a port.
critical-vlan-id: Specifies a VLAN as the MAC authentication critical VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
The MAC authentication critical VLAN accommodates users that have failed MAC authentication because all the servers in their ISP domains are unreachable. Users in the critical VLAN can access network resources in the critical VLAN.
You cannot specify a VLAN as both a super VLAN and a MAC authentication critical VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN.
Before you delete a VLAN that has been set as a MAC authentication critical VLAN, use the undo mac-authentication critical vlan command to remove the critical VLAN configuration.
# Configure VLAN 100 as the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication critical vlan 100
Use mac-authentication critical-voice-vlan to enable the MAC authentication critical voice VLAN feature on a port.
Use undo mac-authentication critical-voice-vlan to disable the MAC authentication critical voice VLAN feature on a port.
The MAC authentication critical voice VLAN feature is disabled on a port.
The MAC authentication critical voice VLAN on a port accommodates MAC authentication voice users that have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
Before you enable the MAC authentication critical voice VLAN feature on the port, make sure the following requirements are met:
· The port is configured with the voice VLAN.
To configure a voice VLAN on a port, use the voice-vlan enable command (see Layer 2—LAN Switching Command Reference).
· LLDP is enabled both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP commands, see Layer 2—LAN Switching Command Reference.
· A MAC authentication critical VLAN is configured on the port. This setting ensures that a voice user is assigned to the critical VLAN if it has failed authentication for unreachability of RADIUS servers before the device recognizes it as a voice user. If a MAC authentication critical VLAN is not available, the voice user might be logged off instead.
# Enable the MAC authentication critical voice VLAN feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication critical-voice-vlan
lldp enable (Layer 2—LAN Switching Command Reference)
lldp global enable (Layer 2—LAN Switching Command Reference)
voice-vlan enable (Layer 2—LAN Switching Command Reference)
mac-authentication domain
Use mac-authentication domain to specify a global or port-specific authentication domain.
Use undo mac-authentication domain to restore the default.
The system default authentication domain is used. For more information about the default authentication domain, see the domain default enable command in "AAA commands."
domain-name: Specifies the name of an ISP domain, a case-insensitive string of 1 to 255 characters.
The global authentication domain applies to all MAC authentication-enabled ports. An authentication domain specified in Layer 2 Ethernet interface view applies only to the port. You can specify different authentication domains on different ports.
A port chooses an authentication domain for MAC authentication users in the following order:
1. Authentication domain specified on the port.
2. Global authentication domain specified in system view.
3. Default authentication domain.
# Specify ISP domain domain1 as the global MAC authentication domain.
# Specify ISP domain aabbcc as the MAC authentication domain on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication domain aabbcc
Use mac-authentication guest-vlan to configure a MAC authentication guest VLAN on a port.
Use undo mac-authentication guest-vlan to restore the default.
No MAC authentication guest VLAN exists on a port.
guest-vlan-id: Specifies a VLAN as the MAC authentication guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
The MAC authentication guest VLAN accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VLAN accommodates users with invalid passwords entered. You can deploy a limited set of network resources in the MAC authentication guest VLAN. For example, a software server for downloading software and system patches.
You cannot specify a VLAN as both a super VLAN and a MAC authentication guest VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
Before you delete a VLAN that has been set as a MAC authentication guest VLAN, use the undo mac-authentication guest-vlan command to remove the guest VLAN configuration.
# Configure VLAN 100 as the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan 100
Use mac-authentication guest-vlan auth-period to set the interval at which the device authenticates users in the MAC authentication guest VLAN.
Use undo mac-authentication guest-vlan auth-period to restore the default.
The device authenticates users in the MAC authentication guest VLAN every 30 seconds.
period-value: Specifies the authentication interval for users in the MAC authentication guest VLAN. The value range is 1 to 3600, in seconds.
# Set the authentication interval to 150 seconds for users in the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan auth-period 150
Use mac-authentication host-mode multi-vlan to enable MAC authentication multi-VLAN mode on a port.
Use undo mac-authentication host-mode to restore the default.
MAC authentication multi-VLAN mode is disabled on a port. When the port receives a packet sourced from an authenticated MAC address in a VLAN not matching the existing MAC-VLAN mapping, the device logs off and reauthenticates the user.
The MAC authentication multi-VLAN mode prevents an authenticated online user from service interruption caused by VLAN changes on a port. When the port receives a packet sourced from the user in a VLAN not matching the existing MAC-VLAN mapping, the device neither logs off the user nor reauthenticates the user. The device creates a new MAC-VLAN mapping for the user, and traffic transmission is not interrupted. The original MAC-VLAN mapping for the user remains on the device until it dynamically ages out. As a best practice, configure this feature on hybrid or trunk ports.
This feature improves transmission of data that is vulnerable to delay and interference. It is typically applicable to IP phone users.
# Enable MAC authentication multi-VLAN mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication host-mode multi-vlan
mac-authentication max-user
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication users on a port.
Use undo mac-authentication max-user to restore the default.
The default is 4294967295.
max-number: Sets the maximum number of concurrent MAC authentication users on the port. The value range for this argument is 1 to 4294967295.
Set the maximum number of concurrent MAC authentication users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent MAC authentication users.
# Configure GigabitEthernet 1/0/1 to support a maximum of 32 concurrent MAC authentication users.
[Sysname-GigabitEthernet1/0/1] mac-authentication max-user 32
Use mac-authentication re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo mac-authentication re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online MAC authentication users if no server is reachable for MAC reauthentication.
The keep-online feature keeps authenticated MAC authentication users online when no server is reachable for MAC reauthentication.
# Enable the keep-online feature for authenticated MAC authentication users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication re-authenticate server-unreachable keep-online
Use mac-authentication timer to configure a MAC authentication timer.
Use undo mac-authentication timer to restore the default of a MAC authentication timer.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
undo mac-authentication timer { offline-detect | quiet | server-timeout }
The following MAC authentication timers apply:
· The offline detect timer is 300 seconds.
· The quiet timer is 60 seconds.
· The server timeout timer is 100 seconds.
offline-detect offline-detect-value: Sets the offline detect timer in seconds, in the range of 60 to 65535.
quiet quiet-value: Sets the quiet timer in seconds, in the range of 1 to 3600.
server-timeout server-timeout-value: Sets the server timeout timer in seconds, in the range of 100 to 300.
MAC authentication uses the following timers:
· Offline detect timer—Sets the interval that the device waits for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user.
· Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
· Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user cannot access the network.
# Set the server timeout timer to 150 seconds.
Use mac-authentication timer auth-delay to enable MAC authentication delay and set the delay time.
Use undo mac-authentication timer auth-delay to restore the default.
mac-authentication timer auth-delay time
MAC authentication delay is disabled. MAC authentication starts immediately after it is triggered by a user packet.
time: Sets the delay time for MAC authentication in seconds. The value range is 1 to 180.
When both 802.1X authentication and MAC authentication are enabled on a port, you can delay MAC authentication so that 802.1X authentication is preferentially triggered. If no 802.1X authentication is triggered or if 802.1X authentication fails within the delay period, the port continues to process MAC authentication.
Do not set the port security mode to mac-else-userlogin-secure or mac-else-userlogin-secure-ext when you want to use MAC authentication delay. The delay does not take effect on a port in either of the two modes. For more information about port security modes, see "Port security commands."
# Enable MAC authentication delay on interface GigabitEthernet 1/0/1 and set the delay time to 10 seconds.
[Sysname-GigabitEthernet1/0/1] mac-authentication timer auth-delay 10
port-security port-mode
Use mac-authentication user-name-format to configure the type of user accounts for MAC authentication users.
Use undo mac-authentication user-name-format to restore the default.
mac-authentication user-name-format { fixed [ account name ] [ password { cipher | simple } string ] | mac-address [ { with-hyphen [ six-section | three-section ] | without-hyphen } [ lowercase | uppercase ] ] }
Each user's MAC address is used as the username and password for MAC authentication. The MAC addresses are in hexadecimal notation without hyphens, and letters are in lower case.
fixed: Uses a shared account for all MAC authentication users.
account name: Specifies the username for the shared account. The name is a case-sensitive string of 1 to 55 characters, excluding the at sign (@). If you do not specify a username, the default name mac applies.
password: Specifies the password for the shared user account. If you do not specify a password, the shared user account does not have a password.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
mac-address: Uses MAC-based user accounts for MAC authentication users. You can also specify the format of username and password by using the following keywords:
· with-hyphen: Includes hyphens in the MAC address.
¡ six-section: Hyphenates the MAC address into six groups of two hexadecimal digits, for example, xx-xx-xx-xx-xx-xx or XX-XX-XX-XX-XX-XX.
¡ three-section: Hyphenates the MAC address into three groups of four hexadecimal digits, for example, xxxx-xxxx-xxxx or XXXX-XXXX-XXXX.
If you do not specify the six-section or three-section keyword, the MAC address is in six-section format.
· without-hyphen: Excludes hyphens from the MAC address, for example, xxxxxxxxxxxx or XXXXXXXXXXXX.
· lowercase: Specifies letters in lower case.
· uppercase: Specifies letters in upper case.
If you specify the MAC-based user account, the device uses the MAC address of a user as the username and password for MAC authentication of the user. This user account type ensures high authentication security. However, you must create on the authentication server a user account for each user, using the MAC address of the user as both the username and password.
If you specify a shared user account, the device uses the specified username and password for MAC authentication of all users. Because all MAC authentication users use a single account for authentication, you only need to create one account on the authentication server. This user account type is suitable for trusted networks.
# Configure a shared account for MAC authentication users, and set the username to abc and password to plaintext string of xyz.
# Use MAC-based user accounts for MAC authentication users. The MAC addresses must be in hexadecimal notation without hyphens, and letters are in upper case.
[Sysname] mac-authentication user-name-format mac-address without-hyphen uppercase
Use reset mac-authentication access-user to log off MAC authentication users.
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address | username username | vlan vlan-id | vsi vsi-name ]
mac mac-address: Specifies a MAC authentication user by its MAC address. The mac-address argument is in the format of H-H-H.
username username: Specifies a MAC authentication user by its name. The username argument is a case-sensitive string of 1 to 253 characters.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
vsi vsi-name: Specifies a VSI by its name. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
Use this command to log off the specified MAC authentication users and clear information about these users from the device. These users must perform MAC authentication to come online again.
With a VSI specified, this command logs off a MAC authentication user if that user has passed authentication and its authorization VSI is the specified VSI.
With a VLAN specified, this command logs off the following MAC authentication users:
· Users that have passed MAC authentication and have been assigned the specified VLAN as their authorization VLAN by the server.
· Users that stay in the specified VLAN after they have passed MAC authentication, because they have not been assigned an authorization VLAN yet.
· Users that are performing MAC authentication in the specified VLAN.
To identify the VLAN in which a user is staying, use the display mac-address command.
If you do not specify any parameters, the reset mac-authentication access-user command logs off all MAC authentication users on the device.
# Log off all MAC authentication users on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication access-user interface gigabitethernet 1/0/1
Use reset mac-authentication critical-vlan to remove users from the MAC authentication critical VLAN on a port.
reset mac-authentication critical-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
Use reset mac-authentication guest-vlan to remove users from the MAC authentication guest VLAN on a port.
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication guest VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
Use reset mac-authentication statistics to clear MAC authentication statistics.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears both global and port-specific MAC authentication statistics.
If you do not specify any parameters, this command clears all MAC authentication statistics.
# Clear MAC authentication statistics on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication statistics interface gigabitethernet 1/0/1
