- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-VLAN commands
- 05-MVRP commands
- 06-VLAN mapping commands
- 07-VLAN termination commands
- 08-Loop detection commands
- 09-Spanning tree commands
- 10-LLDP commands
- 11-PFC commands
- 12-Service loopback group commands
- 13-Cut-through Layer 2 forwarding commands
| 03-M-LAG commands | 274.13 KB |
display m-lag consistency-check status
m-lag auto-recovery reload-delay
m-lag consistency-check disable
m-lag peer-link mac-address hold
m-lag mad exclude logical-interfaces
reset m-lag troubleshooting history
M-LAG commands
Use display m-lag consistency to display information about the configuration consistency check done by M-LAG.
display m-lag consistency { type1 | type2 } { global | interface interface-type interface-number }
type1: Specifies type 1 configuration consistency check.
type2: Specifies type 2 configuration consistency check.
global: Specifies global information.
interface interface-type interface-number: Specifies an M-LAG interface by its type and number.
This command displays configuration details for the M-LAG member devices when type 1 or type 2 setting inconsistencies are detected. For more information about type 1 or type 2 configuration, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
The device does not check the invalid VLANs for inconsistency during global or interface-specific type 2 configuration consistency check.
This command displays the following fields only when VLAN or VLAN interface inconsistencies are detected during global type 2 configuration consistency check:
· Vlan-int(shutdown).
· Vlan-int(IPv4).
· Vlan-int(IPv6).
· Vlan-int(VRRPv4).
# Display global information about type 1 configuration consistency check.
<Sysname> display m-lag consistency type1 global
Configuration Local Peer
Link type Access Trunk
PVID 10 20
Global STP Enabled Disabled
STP mode MSTP RSTP
MST region abc def
Revision level 100 200
MSTI(VLANs) 1(1,64,127,190,316,379,442, 1(2,4,61,121,261,291,362)
505,568,631)
STP-enabled VLANs 10,12,14,16,18 20,22,24,26,28
# Display global information about type 2 configuration consistency check.
<Sysname> display m-lag consistency type2 global
VLANs 1,3,5,7,9 2,4,6,8,10
Vlan-int 10,12,14,17,22,33 11,19,23,27,47
Vlan-int(shutdown) 100,103,107,200,301 200,261,290,333,465
Vlan-int(IPv4) 1019(192.168.1.1/29) -
Vlan-int(IPv6) 40(fc00:0:0:102:0:0:0:1/64) -
Vlan-int(VRRPv4) 100(192.168.100.1/24) -
Global BPDU guard Enabled Disabled
MAC aging time 100s No-aging
Psec load sharing Local Odd-MAC
Psec MAC move state Enabled Disabled
Psec MAC move mode Port All
802.1X auth method Chap Pap
MAC auth method Chap Pap
VSI name vpna
VNI 10
Gateway interface VSI-interface1
VSI name vpnb vpnb
VNI 20 30
VSI interface 1 1
MAC address 1-1-1 2-2-2
IPv4 address 192.168.0.1/24 192.168.0.2/24
IPv6 address 1::1/64 1::2/64
Physical state UP DOWN
Protocol state UP DOWN
VSI interface 2 2
MAC address 1-1-1 2-2-3
IPv4 address 192.168.1.1/24 192.168.1.2/24
IPv6 address 2::2/64 2::2/128
# Display information about type 1 configuration consistency check on M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag consistency type1 interface bridge-aggregation 1
LAGG mode Static Dynamic
PVID 10 20
# Display information about type 2 configuration consistency check on M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag consistency type2 interface bridge-aggregation 1
LACP select speed Enabled Disabled
LAGG ignore speed Enabled Disabled
Root guard Enabled Disabled
Psec port mode Autolearn Mac-else-userlogin-secure-ext
Dot1x critical VSI vpna vpnb
Dot1x handshake Enabled Disabled
Dot1x multi-trigger Enabled Disabled
Dot1x uni-trigger Enabled Disabled
MAC crt microseg 1 2
MAC critical VSI vpna vpnb
MAC URL user logoff Enabled Disabled
MAC with dot1x Enabled Disabled
Web auth-fail VLAN 1 2
The module module failed the check. Cannot obtain configuration. |
Configuration consistency check failed for the displayed module because of the failure to obtain the configuration for that module. |
Configuration |
Configuration item. |
Local |
Local configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a local configuration, this field is empty. |
Peer |
Peer configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a peer configuration, this field is empty. |
Link type |
Link type of the M-LAG peer-link interface: · Access. · Hybrid. · Trunk. |
PVID |
PVID of the M-LAG peer-link interface. |
MSTI(VLANs) |
VLAN-to-MSTI mappings. This field displays Inconsistent if inconsistent VLAN-to-MSTI mappings are detected and M-LAG cannot obtain VLAN-to-MSTI mappings. |
VLANs |
VLANs permitted by an interface. The system checks tagged VLANs before untagged VLANs. |
Vlan-int |
VLAN interface. |
Vlan-int(shutdown) |
VLAN interfaces that were administratively shut down. |
Vlan-int(IPv4) |
IPv4 address of the VLAN interface. |
Vlan-int(IPv6) |
IPv6 address of the VLAN interface. |
Vlan-int(VRRPv4) |
Virtual IPv4 address of the VRRP group on a VLAN interface on the VRRP master. |
MAC aging time |
MAC aging timer in seconds. This field displays No-aging if MAC address entries do not age out. |
Psec load sharing |
This field is not supported in the current version. Authentication load sharing mode for users on port security-enabled M-LAG interfaces: · Centralized—The primary M-LAG member device authenticates users. · Local—Each M-LAG member device authenticates their local users. · Odd-MAC—The local M-LAG member device authenticates odd-MAC users on all M-LAG interfaces of the M-LAG system. · Even-MAC—The local M-LAG member device authenticates even-MAC users on all M-LAG interfaces of the M-LAG system. |
Psec MAC move state |
State of the MAC move feature: · Enabled. · Disabled. |
Psec MAC move mode |
Port security MAC move mode: · Port—Allows an authenticated online user to move between ports on the device. · VLAN—Allows an authenticated online user to move between VLANs on a trunk or hybrid port. · All—Allows an authenticated online user to move between ports on the device or VLANs on a trunk or hybrid port. |
802.1X auth method |
This field is not supported in the current version. 802.1X authentication method: · Chap—Performs EAP termination and uses CHAP to communicate with the RADIUS server. · Eap—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server. · Pap—Performs EAP termination and uses PAP to communicate with the RADIUS server. |
MAC auth method |
This field is not supported in the current version. MAC authentication method: · Chap—CHAP authentication. · Pap—PAP authentication. |
VSI name |
Name of the VSI that has ACs on an M-LAG interface. |
VNI |
VXLAN ID of the VSI. |
Gateway interface |
VSI interface associated with the VSI. |
VSI interface |
VSI interface number. |
MAC address |
MAC address of the VSI interface. |
IPv4 address |
IPv4 address of the VSI interface. |
IPv6 address |
IPv6 address of the VSI interface. |
Physical state |
Physical link state of the VSI interface: · ADM—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—The interface is both administratively and physically up. |
Protocol state |
Data link layer state of the VSI interface: · DOWN—The data link layer protocol is down. · UP—The data link layer protocol is up. |
LAGG mode |
Link aggregation mode: · Static—Static aggregation. · Dynamic—Dynamic aggregation. |
STP |
Enabling state of the spanning tree feature on the M-LAG interface. Options: · Enabled. · Disabled. |
LACP select speed |
Whether the M-LAG interface uses port speed as the prioritized criterion for reference port selection: · Enabled. · Disabled. |
LAGG ignore speed |
Whether the M-LAG interface ignores port speed in setting the aggregation states of member ports: · Enabled. · Disabled. |
Root guard |
Enabling state of root guard on the interface: · Enabled. · Disabled. |
Psec port mode |
This field is not supported in the current version. Available port security modes: · Autolearn · Mac-authentication · Mac-else-userlogin-secure · Mac-else-userlogin-secure-ext · Secure · Userlogin · Userlogin-secure · Userlogin-secure-ext · Userlogin-secure-or-mac · Userlogin-secure-or-mac-ext · Userlogin-withoui |
Dot1x critical VSI |
This field is not supported in the current version. Name of the 802.1X critical VSI. |
Dot1x handshake |
This field is not supported in the current version. Whether the 802.1X online user handshake feature is enabled: · Enabled. · Disabled. |
Dot1x multi-trigger |
This field is not supported in the current version. Whether the 802.1X multicast trigger feature is enabled: · Enabled. · Disabled. |
Dot1x uni-trigger |
This field is not supported in the current version. Whether the 802.1X unicast trigger feature is enabled: · Enabled. · Disabled. |
MAC crt microseg |
This field is not supported in the current version. ID of the MAC authentication critical microsegment. |
MAC critical VSI |
This field is not supported in the current version. Name of the MAC authentication critical VSI. |
MAC URL user logoff |
This field is not supported in the current version. Whether the device logs off MAC authentication users that have been assigned authorization URLs and have not passed authentication on the port when the first user is assigned to the critical microsegment: · Enabled. · Disabled. |
MAC with dot1x |
This field is not supported in the current version. State of parallel processing of MAC authentication and 802.1X authentication: · Enabled. · Disabled. |
Web auth-fail VLAN |
This field is not supported in the current version. The Auth-Fail VLAN for Web authentication. |
Use display m-lag consistency-check status to display the configuration consistency check status.
# Display the configuration consistency check status.
<Sysname> display m-lag consistency-check status
Global Consistency Check Configuration
Local status : Enabled Peer status : Enabled
Local check mode : Strict Peer check mode : Strict
Consistency Check on Modules
Module Type1 Type2
LAGG Check Check
VLAN Check Check
STP Check Check
MAC Not Check Check
L2VPN Not Check Check
PORTSEC Not Check Check
DOT1X Not Check Check
MACA Not Check Check
WEBAUTH Not Check Check
Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
M-LAG IF M-LAG group ID Check Result Inconsistency modules
BAGG4 4 SUCCESS -
Local status |
Status of configuration consistency check at the local end: · Enabled. · Disabled. |
Peer status |
Status of configuration consistency check at the peer end: · Enabled. · Disabled. |
Local check mode |
Configuration consistency check mode at the local end: · Loose. · Strict. |
Peer check mode |
Configuration consistency check mode at the peer end: · Loose. · Strict. |
Module |
Feature module name. |
Type1 |
Whether M-LAG checks the module for a type 1 configuration inconsistency: · Check. · Not Check. |
Type2 |
Whether M-LAG checks the module for a type 2 configuration inconsistency: · Check. · Not Check. |
Global consistency check result |
Result of global configuration consistency check: · FAILURE. · SUCCESS. |
Inconsistent global modules |
Modules that failed global configuration consistency check. If the check succeeded, this field displays a hyphen (-). |
M-LAG IF |
Abbreviated name of the M-LAG interface. |
M-LAG group ID |
ID of the M-LAG group. |
Check result |
Result of the interface configuration consistency check: · FAILURE. · SUCCESS. |
Inconsistency modules |
Modules that failed interface configuration consistency check. If the check succeeded, this field displays a hyphen (-). |
display m-lag drcp statistics
Use display m-lag drcp statistics to display DRCPDU statistics.
display m-lag drcp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 aggregate interface or VXLAN tunnel interface by its type and number. If you do not specify this option, the command displays the DRCPDU statistics about the M-LAG peer-link interface and all M-LAG interfaces.
# Display DRCPDU statistics.
<Sysname> display m-lag drcp statistics
* indicates the port is the peer-link interface.
Interface type:
BAGG -- Bridge-Aggregation, Tun -- Tunnel
Interface State Sent Received(Normal/Error/Unknown)
*BAGG3 UP 30 26/0/0
BAGG4 UP 29 26/0/0
# Display DRCPDU statistics about Bridge-Aggregation 4.
<Sysname> display m-lag drcp statistics interface bridge-aggregation 4
Interface type:
Interface : BAGG4
State : UP
Sent : 31
Received (Normal/Error/Unknown): 28/0/0
Last received packet information:
Source MAC address: 3cd4-437d-0300
Time: 2019/09/11 09:19:58
Action: Accept
Abbreviated interface name. The name of the M-LAG peer-link interface is prefixed with an asterisk (*). |
State |
Physical state of the interface: · UP. · DOWN. |
Sent |
Number of sent DRCPDUs. |
Received (Normal/Error/Unknown) |
Numbers of received normal, error, and unrecognized DRCPDUs. |
Last received packet information |
Information about the most recently received DRCPDU. |
Time |
Date and time when the DRCPDU was received, in the YYYY/MM/DD hh:mm:ss format. |
Action |
Action taken on the DRCPDU: · Accept. · Drop. If the DRCPDU was dropped, this field also displays the reason for dropping the DRCPDU. Possible reasons: · Incorrect incoming port. · Incorrect packet type. · Incorrect packet version. · Incorrect packet length. · Packets from local device. · Local M-LAG interface not configured. · System MAC inconsistency. · System priority inconsistency. · Incorrect system number. · Incorrect sequence number. · Failed authentication. · Other error. |
reset m-lag drcp statistics
display m-lag keepalive
Use display m-lag keepalive to display M-LAG keepalive packet statistics.
# Display M-LAG keepalive packet statistics.
<Sysname> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 135642 s 501 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 10.0.0.2
Time: 2019/09/11 09:21:51
Action: Accept
M-LAG keepalive parameters:
Destination IP address: 10.0.0.2
Source IP address: 10.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : vpn1
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
Neighbor keepalive link status (cause) |
State of the M-LAG peer: · Unknown—No M-LAG peer is detected because the destination IP address of keepalive packets is not specified. · Up—The M-LAG peer is up. · Down—The M-LAG peer is down. Cause of the keepalive link down event: · M-LAG system init—M-LAG system initialization. · Local IP not configured—The local end does not have source and destination IP address settings for the keepalive link. · Local Tx failed—Packet transmission failed on the local end. · Local Rx timeout—Packet reception timed out on the local end. · Peer Rx timeout—Packet reception timed out on the peer end. |
Neighbor is alive for |
Time period for which the M-LAG peer has been up. |
Last received keepalive packet information |
Information about the most recently received keepalive packet. |
Time |
Date and time when the keepalive packet was received, in the YYYY/MM/DD hh:mm:ss format. If the device has not received any keepalive packets, this field displays N/A. |
Action |
Action taken on the keepalive packet: · Accept. · Drop. If the keepalive packet was dropped, this field also displays the reason for dropping the packet. Possible reasons: · Incorrect packet type. · M-LAG system init. · Invalid packet Interval. · Incorrect packet length. · System MAC inconsistency. · System priority inconsistency. · Incorrect system number. · Incorrect sequence number. · Failed authentication. |
Destination IP address |
Destination IP address of keepalive packets sent by the device. |
Source IP address |
Source IP address of keepalive packets sent by the device. |
Keepalive UDP port |
Destination UDP port of keepalive packets. |
Keepalive VPN name |
VPN instance for keepalive packets. If no VPN instance is configured for keepalive packets, this field displays N/A. |
Keepalive interval |
Interval at which the device sends keepalive packets. |
Keepalive timeout |
Keepalive timeout timer. |
Keepalive hold time |
Keepalive hold timer setting. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of an M-LAG peer link down event. |
m-lag keepalive{ ip | ipv6 }
m-lag keepalive hold-time
m-lag keepalive interval
display m-lag mad verbose
Use display m-lag mad verbose to display detailed M-LAG MAD information.
# Display detailed M-LAG MAD information.
<Sysname> display m-lag mad verbose
M-LAG MAD DOWN state : No
Restore delay : 30 s
Remaining restore delay: -
M-LAG MAD default action: DOWN
M-LAG MAD DOWN persistence: Disabled
Excluding logical interfaces: Disabled
Port configuration for M-LAG MAD DOWN action:
Included ports(user-configured):
Bridge-Aggregation1
HundredGigE1/0/5(ineffective)
Included ports(system-configured):
Member interfaces of M-LAG Bridge-Aggregation3:
HundredGigE 1/0/3
Excluded ports(user-configured):
Bridge-Aggregation2
HundredGigE1/0/4
Excluded ports(system-configured):
Management interfaces:
M-GigabitEthernet0/0/0
M-LAG interfaces:
Bridge-Aggregation4
Peer-link interface:
Bridge-Aggregation3
Member interfaces of peer-link interface Bridge-Aggregation3:
HundredGigE1/0/1
HundredGigE1/0/2
Table 5 Command output
M-LAG MAD DOWN state |
Whether the network interfaces on the device are in M-LAG MAD DOWN state: · Yes—The device has network interfaces placed in M-LAG MAD DOWN state. · No—No network interfaces are in M-LAG MAD DOWN state. If this field displays Yes, check the M-LAG peer link for the link down issue to remove multi-active collision. |
Restore delay |
Data restoration interval, in seconds. |
Remaining restore delay |
The remaining time (in seconds) before the data restoration interval expires. If the data restoration interval has not started, this field displays a hyphen (-). |
M-LAG MAD default action |
Default action to take on network interfaces when the M-LAG system splits: · DOWN—Shut down interfaces and place them in M-LAG MAD DOWN state. · NONE—M-LAG MAD does not take action on interfaces. |
M-LAG MAD DOWN persistence |
M-LAG MAD DOWN state persistence: · Enabled—The M-LAG member device does not bring up the network interfaces in M-LAG MAD DOWN state when its role changes from secondary to primary. · Disabled—The M-LAG member device brings up the network interfaces in M-LAG MAD DOWN state when its role changes from secondary to primary. |
Excluding logical interfaces |
Whether all logical interfaces are excluded from the shutdown action by M-LAG MAD: · Enabled. · Disabled. |
Included ports(user-configured) |
Network interfaces manually configured to be shut down by M-LAG MAD when the M-LAG system splits. An interface entry will be marked as ineffective if the system does not allow the specified interface to be shut down by M-LAG MAD. M-LAG MAD will not shut down interfaces in ineffective entries when the M-LAG system splits. The following are interfaces not allowed to be shut down by M-LAG MAD: · Interfaces automatically excluded from being shut down by M-LAG MAD. · Interfaces manually or automatically excluded from being shut down by IRF MAD. · Interfaces used for special purposes. |
Included ports(system-configured) |
Network interfaces automatically set by the system to shut down by M-LAG MAD when the M-LAG system splits. Aggregation member ports of M-LAG interfaces are in this category of interfaces. |
Excluded ports(user-configured) |
Network interfaces manually configured to not be shut down by M-LAG MAD. An interface entry will be marked as ineffective if the specified interface is in the list of ports excluded by the system from the M-LAG MAD shutdown action. In this situation, the manual configuration does not take effect. |
Excluded ports(system-configured) |
Network interfaces set by the system to not shut down by M-LAG MAD, including: · Management interfaces. · M-LAG interfaces. · M-LAG peer-link interface. · Aggregation member interfaces if a Layer 2 aggregate interface is used as the M-LAG peer-link interface. |
m-lag mad default-action
m-lag mad exclude interface
m-lag mad include interface
m-lag mad persistent
display m-lag role
Use display m-lag role to display M-LAG role information.
display m-lag role
# Display M-LAG role information.
<Sysname> display m-lag role
Effective role information
Factors Local Peer
Effective role Primary Secondary
Initial role None None
MAD DOWN state Yes Yes
Health level 0 0
Role priority 32768 32768
Bridge MAC 3cd4-3ce1-0200 3cd4-437d-0300
Effective role trigger: Peer link calculation
Effective role reason: Bridge MAC
Configured role information
Factors Local Peer
Configured role Primary Secondary
Table 6 Command output
Factors |
Factors used in role calculation. |
Local |
Local configuration. |
Peer |
Peer configuration. |
Effective role |
Effective device role: · None. · Primary. · Secondary. |
Status of M-LAG interfaces |
The status of all M-LAG interfaces: · Down—All M-LAG interfaces are down. · UP—One or more M-LAG interfaces are up. |
Initial role |
Device role before role calculation: · None. · Primary. · Secondary. |
MAD DOWN state |
Whether there were interfaces in M-LAG MAD DOWN state during role calculation: · Yes. · No. This field displays N/A if no peer exists. |
Health level |
Health level of the device during role calculation. The member device with a lower value is healthier. This field displays N/A if no peer exists. |
Effective role trigger |
Why effective role calculation was triggered: · M-LAG system init—M-LAG system initialization. · Peer link calculation—The local device role was calculated over the M-LAG peer link. · Peer link down and role calculation over keepalive link—The M-LAG peer link went down, and the local device role was calculated over the keepalive link. · Peer link and keepalive link down—Both the M-LAG peer link and the keepalive link went down. · Peer link and keepalive link down. All local M-LAG interfaces down—Both the M-LAG peer link and the keepalive link went down, and all local M-LAG interfaces went down. |
Effective role reason |
Factor that determined the effective device role: · No peer existed. In this situation, a hyphen (-) is displayed. · Status of M-LAG interfaces. · Single None role. One M-LAG member device had the None role, and the other M-LAG member device had the Primary role. · MAD status. · Health level. · Role priority. · Bridge MAC. |
Configured role |
Manually assigned device role: · None. · Primary. · Secondary. |
m-lag role priority
display m-lag summary
Use display m-lag summary to display summary information about the M-LAG peer-link interface and M-LAG interfaces.
# Display summary information about the M-LAG peer-link interface and M-LAG interfaces. In this example, global configuration consistency check was successful.
<Sysname> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG3
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG4 4 UP UP -
Table 7 Command output
Peer-link interface |
Abbreviated name of the M-LAG peer-link interface. |
Peer-link interface state (cause) |
State of the M-LAG peer-link interface: · UP. · DOWN. If the local M-LAG peer-link interface is down, this field also displays the cause of the down state. Possible down reasons: · Aggregate interface down—The aggregate interface that acts as the peer-link interface is down. · Tunnel interface down—The tunnel interface that acts as the peer-link interface is down. · No correct DRCPDUs received—The interface has not received correct DRCPDUs. |
Keepalive link state (cause) |
State of the keepalive link: · UP. · DOWN. Cause of the keepalive link down event: · M-LAG system init—M-LAG system initialization. · Local IP not configured—The local end does not have source and destination IP address settings for the keepalive link. · Local Tx failed—Packet transmission failed on the local end. · Local Rx timeout—Packet reception timed out on the local end. · Peer Rx timeout—Packet reception timed out on the peer end. |
M-LAG interface information |
Information about M-LAG interfaces. |
M-LAG IF |
Name of the M-LAG interface. |
M-LAG group |
Local state (cause) |
State of the M-LAG interface: · UP. · DOWN. If the M-LAG interface is down, this field also displays the cause of the down state: · A—The aggregate interface went down. · B—The peer M-LAG interface did not exist. · C—Configuration consistency check failed. |
Peer state |
State of the peer M-LAG interface: · UP. · DOWN—No peer M-LAG interface exists or the peer M-LAG interface is down. · UNKNOWN—The state of the peer M-LAG interface is unknown when the M-LAG peer link is down. |
Remaining down time (s) |
Remaining time (in seconds) during which the M-LAG interface will stay in M-LAG MAD DOWN state. If the M-LAG interface is not in M-LAG MAD DOWN state, this field displays a hyphen (-). |
display m-lag system
Use display m-lag system to display the M-LAG system settings.
# Display the M-LAG system settings.
<Sysname> display m-lag system
System information
Local system number: 1 Peer system number: 2
Local system MAC: 0001-0001-0001 Peer system MAC: 0001-0001-0001
Local system priority: 123 Peer system priority: 123
Local bridge MAC: 3cd4-3ce1-0200 Peer bridge MAC: 3cd4-437d-0300
Local effective role: Primary Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: Yes
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 30 -
Consistency-check delay Disabled 15 -
Standalone delay Disabled - -
Role to None delay Disabled 60 -
Table 8 Command output
Local system number |
Local M-LAG system number. If the parameter is not configured, this field displays N/A. |
Peer system number |
Peer M-LAG system number. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local system MAC |
Local M-LAG system MAC address. If the parameter is not configured, this field displays N/A. |
Peer system MAC |
Peer M-LAG system MAC address. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local system priority |
Local M-LAG system priority. If the parameter is not configured, this field displays N/A. |
Peer system priority |
Peer M-LAG system priority. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local bridge MAC |
Local bridge MAC address. |
Peer bridge MAC |
Peer bridge MAC address. If the peer does not exist, this field displays N/A. |
Local effective role |
Effective role of the local device: · None. · Primary. · Secondary. |
Peer effective role |
Effective role of the peer device: · None. · Primary. · Secondary. |
Health level |
Health level of the device. The member device with a lower value is healthier. |
Standalone mode on split |
Whether M-LAG standalone mode is enabled: · Enabled. · Disabled. |
In standalone state |
Whether the device is in M-LAG standalone mode: · Yes. · No. |
Timer |
Timer type: · Auto recovery—Reload delay timer. · Restore delay—Data restoration interval. · Consistency check delay—Configuration consistency check delay timer. · Standalone delay—Delay that the device must wait before changing to M-LAG standalone mode. · Role to None delay—Delay that the device must wait before setting its role to None. |
State |
State of the timer: · Enabled. · Disabled. |
Value (s) |
Value of the timer, in seconds. |
Remaining time (s) |
Remaining time of the timer, in seconds. If the timer has not started, this field displays a hyphen (-). |
display m-lag troubleshooting
Use display m-lag troubleshooting to display M-LAG troubleshooting information.
display m-lag troubleshooting [ m-lag-interface | peer-link | keepalive ] [ history ] [ count ]
m-lag-interface: Displays information for M-LAG interface troubleshooting.
peer-link: Displays information for M-LAG peer-link interface troubleshooting.
keepalive: Displays information for keepalive link troubleshooting.
history: Displays troubleshooting records. If you do not specify this keyword, the command displays current troubleshooting information.
count: Specifies the number of events to display, in the range of 1 to 200. If you do not specify this argument, the command displays the most recent 20 events.
If you do not specify the m-lag-interface, peer-link, or keepalive keyword, this command displays information for troubleshooting M-LAG interfaces, the M-LAG peer-link interface, and the keepalive link.
# Display M-LAG troubleshooting records.
<Sysname> display m-lag troubleshooting history
Total: 3
Time Event description
2019-09-10 14:13:53.103 Peer-link interface BAGG10 went down because the
peer-link interface role of the interface was removed.
Please reconfigure an interface as the peer-link interface.
2019-09-10 14:23:53.102 Keepalive link went down because the peer keepalive
timeout timer expired. Please check the keepalive
packet transmission and reception status at the two
ends.
2019-09-10 14:53:53.103 Local M-LAG interface state of BAGG1024 in M-LAG group 1024
changed to down because the aggregate interface went
down. Please check the aggregate link status.
Table 9 Command output
Total |
Total number of M-LAG system failure records. |
Time |
Date and time when the failure occurred, in YYYY-MM-DD HH:MM:SS.MS format. |
Event description |
Description of the failure event. For information about pee-link interface failure events, see Table 10. For information about keepalive link failure events, see Table 11. For information about M-LAG interface failure events, see Table 12. |
Table 10 Possible peer-link interface failure events
Event |
Peer-link interface interface-name went down because the aggregate interface went down. Please check the aggregate link status. |
Peer-link interface interface-name went down because the tunnel interface went down. Please check the tunnel link status. |
Peer-link interface interface-name went down because no DRCPDUs were received. Please check the DRCPDU transmission and reception status at the two ends. |
Peer-link interface interface-name went down because the peer failed to receive DRCPDUs. Please check the DRCPDU transmission and reception status at the two ends. |
Peer-link interface interface-name went down because the peer-link interface role of the interface was removed. Please reconfigure an interface as the peer-link interface. |
Table 11 Possible keepalive link failure events
Event |
Keepalive link went down because keepalive parameters were not configured. Please configure keepalive parameters. |
Keepalive link went down because the device failed to send keepalive packets. Please check Layer 3 reachability to the peer. |
Keepalive link went down because the local keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends. |
Keepalive link went down because the peer keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends. |
Table 12 Possible M-LAG interface failure events
Event |
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because the aggregate interface went down. Please check the aggregate link status. |
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because no peer M-LAG interface was detected. Please check peer M-LAG interface configuration. |
Local M-LAG interface state of interface-name in M-LAG group group-id changed to down because of configuration consistency check failure. Please check the type 1 configuration of the peer devices for inconsistencies. |
Local M-LAG interface state of interface-name changed to down because it was removed from M-LAG group group-id. Please reconfigure the M-LAG interface settings as needed. |
display m-lag verbose
Use display m-lag verbose to display detailed information about the M-LAG peer-link interface and M-LAG interfaces.
display m-lag verbose [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an M-LAG interface or the M-LAG peer-link interface by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about the M-LAG peer-link interface and all M-LAG interfaces.
If the specified interface is not the M-LAG peer-link interface or an M-LAG interface, no information is displayed.
# Display detailed information about M-LAG interface Bridge-Aggregation 1.
<Sysname> display m-lag verbose interface bridge-aggregation 1
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
G -- Port_Sync, H -- Expired
M-LAG interface/M-LAG group ID: BAGG1/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Peer M-LAG interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Local M-LAG interface LACP priority: Config=200, Effective=200
Peer M-LAG interface LACP priority: Config=200, Effective=200
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/1 (260), HGE1/0/2 (261)
Peer Selected ports indexes: 260, 261
# Display detailed information about M-LAG peer-link interface Bridge-Aggregation 2.
<Sysname> display m-lag verbose interface bridge-aggregation 2
Peer-link interface/Peer-link interface ID: BAGG2/1
State: UP
Cause: -
Local Selected ports (index): HGE1/0/1 (258), HGE1/0/2 (259)
Peer Selected ports indexes: 258, 259
Table 13 Command output
Flags |
DRCP state flags. The flag field is one byte long, represented by ABCDEFGH from the lowest bit to the highest bit. A letter is displayed when its bit is 1 and is not displayed when its bit is 0. · A—Indicates whether DRCP is enabled on the local device. 1 indicates enabled. 0 indicates disabled. · B—Indicates whether DRCP is enabled on the M-LAG peer. 1 indicates enabled. 0 indicates disabled. · C—Indicates whether DRCP is enabled on a third M-LAG member device. 1 indicates enabled. 0 indicates disabled. · D—Indicates whether the local M-LAG peer-link interface has determined that DRCP is enabled on the M-LAG peer. 1 indicates yes. 0 indicates no. · E—Indicates the DRCP timeout timer. 1 indicates the short timeout timer. 0 indicates the long timeout timer. · F—Indicates whether the local M-LAG peer-link interface permits the packets that contain the negotiated gateway conversation IDs. 1 indicates yes. 0 indicates no. · G—Indicates whether the local M-LAG peer-link interface permits the packets that contain the negotiated port conversation IDs. 1 indicates yes. 0 indicates no. · H—Indicates whether the local DRCPDU receive machine is in default or expired state. 1 indicates yes. 0 indicates no. |
Peer-link interface ID |
M-LAG interface |
M-LAG group ID |
Local M-LAG interface state |
State of the local M-LAG interface: · UP—The M-LAG interface is up if it has Selected ports in its aggregation group. · DOWN—The M-LAG interface is down if it does not have Selected ports in its aggregation group. |
Peer M-LAG interface state |
State of the peer M-LAG interface: · UP—The M-LAG interface is up if it has Selected ports in its aggregation group. · DOWN—The M-LAG interface is down if it does not have Selected ports in its aggregation group. · UNKNOWN—The state of the peer M-LAG interface is unknown when the M-LAG peer link is down. |
M-LAG group state |
State of the M-LAG group: · UP—The M-LAG group is up if it contains a minimum of one member M-LAG interface in UP state. · DOWN—The M-LAG group is down if it all its member M-LAG interfaces are in DOWN state. |
Local M-LAG interface down cause |
Cause of the down state of the local M-LAG interface. If the local M-LAG interface is up, this field displays a hyphen (-). |
Remaining M-LAG DOWN time |
State |
State of the M-LAG peer-link interface. |
Cause |
Cause of the down state of the M-LAG peer-link interface. If the M-LAG peer-link interface is up, this field displays a hyphen (-). Possible down state causes: · No correct DRCPDUs received—The interface has not received correct DRCPDUs. · Aggregate interface down—The aggregate interface that acts as the peer-link interface went down. · Tunnel interface down—The tunnel interface that acts as the peer-link interface went down. · No correct DRCPDUs received by peer—The peer end has not received correct DRCPDUs. |
Local M-LAG interface LACP MAC |
System MAC address information for the LACPDUs sent out of the local M-LAG interface. |
Peer M-LAG interface LACP MAC |
System MAC address information for the LACPDUs sent out of the peer M-LAG interface. |
Local M-LAG interface LACP priority |
System priority information for the LACPDUs sent out of the local M-LAG interface. |
Peer M-LAG interface LACP priority |
System priority information for the LACPDUs sent out of the peer M-LAG interface. |
Config |
Configured value. |
Effective |
Effective value. |
Local DRCP flags |
Local DRCP state flags. If all bits are set to 0, this field displays Unknown. |
Peer DRCP flags |
Peer DRCP state flags. If all bits are set to 0 or no peer exists, this field displays Unknown. |
Local Selected ports (index) |
Abbreviated name of the Selected ports in the local aggregation group and their port indexes. |
Peer Selected ports indexes |
Port indexes of the Selected ports in the peer aggregation group. |
display m-lag virtual-ip
Use display m-lag virtual-ip to display M-LAG virtual IP addresses.
display m-lag virtual-ip [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a VLAN interface or loopback interface by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about all M-LAG virtual IP addresses.
# Display all M-LAG virtual IP addresses.
<Sysname> display m-lag virtual-ip
Interface IP address MAC address Effective State
Vlan2 10.10.10.10/24 0001-0001-0001 ACTIVE
10.10.20.10/24 0001-0001-0002 STANDBY
Loop1 1::20/124 0001-0001-0003 STANDBY
1::10/124 0001-0001-0004 ACTIVE
Table 14 Command output
Abbreviated name of the interface. |
IP address |
Virtual IP address. |
MAC address |
Virtual MAC address. |
Effective State |
State of the virtual IP address: · ACTIVE—The virtual IPv4 address is available on the local device. · STANDBY—The virtual IPv4 address is not available on the local device. |
m-lag authentication key
Use m-lag authentication key to enable M-LAG packet authentication and configure an authentication key.
Use undo m-lag authentication key to disable M-LAG packet authentication.
m-lag authentication key { simple | cipher } string
M-LAG packet authentication is disabled.
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the authentication key specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
To prevent DRCPDU and keepalive packet tampering from causing link flapping, enable M-LAG packet authentication on M-LAG member devices. With this feature enabled, M-LAG member devices compute a message digest by using an authentication key for each outgoing DRCPDU or keepalive packet and insert the message digest into the packet. When receiving a DRCPDU or keepalive packet, an M-LAG member device computes a message digest and compares it with the message digest in the packet. If the message digests match, the packet passes authentication. If the message digests do not match, the device drops the packet.
For successful authentication, configure the same authentication key for the M-LAG member devices.
# Enable M-LAG packet authentication and configure the authentication key as abcdefg.
[Sysname] m-lag authentication key simple abcdefg
Use m-lag auto-recovery reload-delay to enable M-LAG system auto-recovery and set the reload delay timer.
Use undo m-lag auto-recovery reload-delay to restore the default.
m-lag auto-recovery reload-delay delay-value
M-LAG system auto-recovery is disabled and the reload delay timer is not set.
delay-value: Specifies a reload delay in the range of 240 to 3600 seconds.
If only one M-LAG member device recovers after the entire M-LAG system reboots, auto-recovery enables that member device to remove its M-LAG interfaces from the M-LAG DOWN interface list.
· If that member device has up M-LAG interfaces, it takes over the primary role when the reload delay timer expires and forwards traffic.
· If that member device does not have up M-LAG interfaces, it is stuck in the None role and does not forward traffic.
If auto-recovery is disabled, that M-LAG member device will be stuck in the None role with all its M-LAG interfaces being M-LAG DOWN after it recovers.
If both M-LAG member devices recover and have up M-LAG interfaces after the entire M-LAG system reboots, active-active situation might occur if both M-LAG peer link and keepalive links were down when the reload delay timer expires. If this rare situation occurs, examine the M-LAG peer link and keepalive links and restore them.
To avoid incorrect role preemption, make sure the reload delay timer is longer than the amount of time required for the device to restart.
# Enable M-LAG system auto-recovery and set the reload delay timer to 245 seconds.
[Sysname] m-lag auto-recovery reload-delay 245
display m-lag role
Use m-lag consistency-check disable to disable M-LAG from performing configuration consistency check.
Use undo m-lag consistency-check disable to enable M-LAG to perform configuration consistency check.
M-LAG performs configuration consistency check.
To ensure that the M-LAG system can operate correctly, M-LAG by default performs configuration consistency check when the M-LAG system is set up.
Configuration consistency check might fail when you upgrade the M-LAG member devices in an M-LAG system. To prevent the M-LAG system from falsely shutting down M-LAG interfaces, you can temporarily disable configuration consistency check.
You must make sure the M-LAG member devices use the same setting for configuration consistency check.
# Disable M-LAG from performing configuration consistency check.
[Sysname] m-lag consistency-check disable
m-lag consistency-check mode
Use m-lag consistency-check mode to set the mode of configuration consistency check.
Use undo m-lag consistency-check mode to restore the default.
m-lag consistency-check mode { loose | strict }
Configuration consistency check uses strict mode.
loose: Specifies loose mode.
strict: Specifies strict mode.
The device handles configuration inconsistency depending on the mode of configuration consistency check.
· For type 1 configuration inconsistency:
¡ The device generates log messages if loose mode is enabled.
¡ The device shuts down M-LAG interfaces and generates log messages if strict mode is enabled.
· For type 2 configuration inconsistency, the device only generates log messages, whether strict or loose mode is enabled.
# Enable the loose mode of configuration consistency check.
[Sysname] m-lag consistency-check mode loose
m-lag drcp period short
Use m-lag drcp period short to enable the short DRCP timeout timer (3 seconds) on the peer-link interface or an M-LAG interface.
Use undo m-lag drcp period to restore the default.
An aggregate interface uses the long DRCP timeout timer (90 seconds).
This command takes effect only on the peer-link interface or an M-LAG interface.
DRCP uses a timeout mechanism to specify the amount of time that a peer-link interface or M-LAG interface must wait to receive DRCPDUs before it determines that the peer interface is down. This timeout mechanism provides the following timer options:
· Short DRCP timeout timer, which is fixed at 3 seconds. If this timer is used, the peer interface sends one DRCPDU every second.
· Long DRCP timeout timer, which is fixed at 90 seconds. If this timer is used, the peer interface sends one DRCPDU every 30 seconds.
Short DRCP timeout timer enables the M-LAG member devices to detect a peer interface down event more quickly than the long DRCP timeout timer. However, this benefit is at the expense of bandwidth and system resources.
To avoid traffic interruption, disable the short DRCP timeout timer before an M-LAG process restart.
# Enable the short DRCP timeout timer on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] m-lag drcp period short
Use m-lag peer-link mac-address hold to enable the peer-link interface to retain MAC address entries for single-homed devices.
Use undo m-lag peer-link mac-address hold to disable the peer-link interface from retaining MAC address entries for single-homed devices.
The peer-link interface does not retain MAC address entries for single-homed devices when the devices go down.
When an M-LAG member device detects that the link to a single-homed device goes down, the peer-link interface takes the following actions:
· Deletes the MAC address entries for the single-homed device.
· Sends a message to the peer peer-link interface for it to delete the affected MAC address entries.
If the link to a single-homed device flaps constantly, the peer-link interface repeatedly deletes and adds MAC address entries for the device. This situation increases floods of unicast traffic destined for the single-homed device.
To reduce flood traffic, enable the peer-link interface to retain MAC address entries for single-homed devices. After the links to single-homed devices go down, the affected MAC address entries age out on expiration of the MAC aging timer instead of being deleted immediately. The timer is set by using the mac-address timer command. For more information about this command, see MAC address table commands in Layer 2—LAN Switching Command Reference.
# Enable the peer-link interface to retain MAC address entries for single-homed devices.
[Sysname] m-lag peer-link mac-address hold
mac-address timer
m-lag keepalive { ip | ipv6 }
Use m-lag keepalive { ip | ipv6 } to configure M-LAG keepalive packet parameters.
Use undo m-lag keepalive { ip | ipv6 } to restore the default.
m-lag keepalive { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | udp-port udp-number | vpn-instance vpn-instance-name ] *
No keepalive packet parameters are configured.
ip: Specifies IPv4 addresses.
ipv6: Specifies IPv6 addresses.
destination: Specifies an IP address of the M-LAG peer as the destination IP address of keepalive packets.
source: Specifies a local IP address as the source IP address of keepalive packets. If you do not specify a source IP address, the IP address of the outgoing interface is used.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
udp-port udp-number: Specifies the destination UDP port of keepalive packets. The value range for the udp-number argument is 1 to 65535. If you do not specify a UDP port number, 6400 is used.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the keepalive packets belong to the public network, do not specify a VPN instance.
The device accepts only keepalive packets that are sourced from the specified destination IP address. The keepalive link goes down if the device receives keepalive packets sourced from any other IP addresses.
Make sure the M-LAG member devices in an M-LAG system use the same keepalive destination UDP port.
# Specify the destination and source IP addresses of keepalive packets as 192.168.68.125 and 192.168.68.100, respectively.
[Sysname] m-lag keepalive ip destination 192.168.68.125 source 192.168.68.100
Use m-lag keepalive hold-time to set the keepalive hold timer.
Use undo m-lag keepalive hold-time to restore the default.
m-lag keepalive hold-time value
The keepalive hold timer is 3 seconds.
value: Specifies a timer value in the range of 3 to 10 seconds.
IMPORTANT: For the M-LAG member device to correctly determine the cause of a peer link down event, make sure the keepalive hold timer is longer than the keepalive interval and is shorter than the keepalive timeout timer. |
The keepalive hold timer starts when the peer link goes down. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of a peer link down event.
· If the device receives keepalive packets from the M-LAG peer before the timer expires, the peer link is down because the peer link fails.
· If the device does not receive keepalive packets from the M-LAG peer before the timer expires, the peer link is down because the peer M-LAG device fails.
If you use M-LAG and VRRP together, make sure the keepalive hold timer is shorter than the interval at which the VRRP master sends VRRP advertisements. Violation of this restriction might cause a VRRP master/backup switchover to occur before peer link failure is confirmed. To set the interval at which the VRRP master sends VRRP advertisements, use the vrrp vrid timer advertise command. For more information about this command, see High Availability Command Reference.
# Set the keepalive hold timer to 5 seconds.
[Sysname] m-lag keepalive hold-time 5
vrrp vrid timer advertise (High Availability Command Reference)
Use m-lag keepalive interval to set the M-LAG keepalive interval and timeout timer.
Use undo m-lag keepalive interval to restore the default.
m-lag keepalive interval interval [ timeout timeout ]
The M-LAG keepalive interval is 1000 milliseconds, and the M-LAG keepalive timeout timer is 5 seconds.
interval interval: Specifies the keepalive interval, in the range of 100 to 10000 milliseconds.
timeout timeout: Specifies the keepalive timeout timer, in the range of 3 to 20 seconds. The local keepalive timeout timer must be two times the keepalive interval of the peer at minimum.
The device sends keepalive packets at the specified interval to its M-LAG peer. If the device has not received a keepalive packet from the M-LAG peer before the keepalive timeout timer expires, the device determines that the keepalive link is down.
You must configure the same M-LAG keepalive interval on the M-LAG member devices in an M-LAG system.
# Set the M-LAG keepalive interval and timeout timer to 2000 milliseconds and 6 seconds, respectively.
[Sysname] m-lag keepalive interval 2000 timeout 6
Changing the keepalive interval might cause system setup failure. Continue? [Y/N]:y
Use m-lag mad default-action to configure the default M-LAG MAD action to take on network interfaces on the secondary M-LAG member device when the M-LAG system splits.
Use undo m-lag mad default-action to restore the default.
m-lag mad default-action { down | none }
M-LAG MAD shuts down network interfaces on the secondary M-LAG member device.
down: Sets the action to M-LAG MAD DOWN. M-LAG MAD will shut down all network interfaces on the secondary M-LAG member device when the M-LAG system splits, except the interfaces excluded manually or by the system.
none: Sets the M-LAG MAD action to NONE. M-LAG MAD will not shut down any network interfaces when the M-LAG system splits, except the interfaces configured manually or by the system to be shut down by M-LAG MAD.
In most network environments, use the M-LAG MAD DOWN action in conjunction with the m-lag mad exclude interface command.
· The M-LAG MAD DOWN action helps avoid network issues caused by multi-active collision, which occurs if the M-LAG peer link goes down while the keepalive link is up.
· The m-lag mad exclude interface command enables you to exclude special-purpose interfaces, for example, interfaces used in M-LAG for M-LAG keepalive detection.
This configuration method is inefficient if a large number of interfaces on the secondary M-LAG member must be retained in up state after the M-LAG system splits. For example, if you use a VXLAN tunnel as the M-LAG peer link in an EVPN environment, you must retain a large number of logical interfaces in up state. These logical interfaces include VLAN, aggregate, loopback, tunnel, and VSI interfaces.
In these situations, use the following method to configure M-LAG MAD:
· Set the default M-LAG MAD action to NONE.
· Execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD, in addition to those already automatically specified by the system.
The M-LAG MAD DOWN action will not take effect on the following interfaces:
· Interfaces automatically or manually excluded from being shut down by M-LAG MAD.
· Interfaces used for special purposes, including:
¡ Interfaces placed in a loopback test by using the loopback command.
¡ Interfaces assigned to a service loopback group by using the port service-loopback group command.
¡ Interfaces assigned to remote source groups as reflector ports for traffic mirroring by using the mirroring-group reflector-port command.
¡ Fiber interfaces placed in up state by using the port-up mode command.
# Configure M-LAG MAD to shut down all network interfaces except excluded interfaces when the M-LAG system splits.
[Sysname] m-lag mad default-action down
loopback (Interface Command Reference)
mirroring-group reflector-port (Network Management and Monitoring Command Reference)
port up-mode (Interface Command Reference)
Use m-lag mad exclude interface to exclude an interface from the shutdown action by M-LAG MAD.
Use undo m-lag mad exclude interface to enable M-LAG MAD to shut down an interface when a multi-active collision is detected.
m-lag mad exclude interface interface-type interface-number
undo m-lag mad exclude interface interface-type interface-number
M-LAG MAD shuts down all network interfaces on the secondary M-LAG member device when it detects a multi-active collision, except for the automatically excluded interfaces.
When M-LAG MAD detects a multi-active collision, M-LAG sets all network interfaces on the secondary M-LAG device to M-LAG MAD DOWN state, except for the following interfaces:
· Network interfaces manually configured to not shut down by M-LAG MAD.
· Network interfaces set by the system to not shut down by M-LAG MAD, including:
¡ M-LAG peer-link interface.
¡ Aggregation member interfaces if a Layer 2 aggregate interface is used as the M-LAG peer-link interface.
¡ M-LAG interfaces.
¡ Management interfaces.
You must exclude the following interfaces from the shutdown action by M-LAG MAD:
· For correct keepalive detection, exclude the interfaces used for keepalive detection from the shutdown action.
· For M-LAG member devices to synchronize ARP entries, exclude the VLAN interfaces of the VLANs to which the M-LAG interfaces and M-LAG peer-link interfaces belong from the shutdown action.
# Exclude HundredGigE 1/0/1 from the shutdown action by M-LAG MAD.
[Sysname] m-lag mad exclude interface hundredgige 1/0/1
display fib (Layer 3—IP Services Command Reference)
display ip routing-table (Layer 3—IP Services Command Reference)
Use m-lag mad exclude logical-interfaces to exclude all logical interfaces from the shutdown action by M-LAG MAD.
Use undo m-lag mad exclude logical-interfaces to restore the default.
When a VXLAN tunnel is used as the M-LAG peer link on an EVPN M-LAG system, you must retain a large number of logical interfaces (for example, VLAN, aggregate, loopback, tunnel, and VSI interfaces) in up state. To simplify configuration, you can exclude all logical interfaces from the shutdown action by M-LAG MAD.
The m-lag mad exclude interface and m-lag mad include interface commands take precedence over the m-lag mad exclude logical-interfaces command.
# Exclude all logical interfaces from the shutdown action by M-LAG MAD.
[Sysname] m-lag mad exclude logical-interfaces
Use m-lag mad include interface to add an interface to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits.
Use undo m-lag mad include interface to remove a network interface from the user-configured list of included ports.
m-lag mad include interface interface-type interface-number
undo m-lag mad include interface interface-type interface-number
The user-configured included port list does not contain any ports.
This command is typically used when the default M-LAG MAD action is set to NONE. In this situation, M-LAG MAD does not shut down the network interfaces on the secondary M-LAG member device when the M-LAG system splits. To avoid network issues caused by multi-active collision, add network interfaces to the user-configured include port list if they are not in the system-configured included port list. M-LAG MAD on the secondary M-LAG member device will shut down the interfaces in the system-configured and user-configured included port lists when the M-LAG system splits.
For example, if you use a VXLAN tunnel as the M-LAG peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, VLAN, aggregate, loopback, tunnel, and VSI interfaces) in up state. To improve configuration efficiency, you can set the default M-LAG MAD action to NONE and add interfaces to the user-configured include port list.
· Network interfaces automatically or manually excluded from being shut down by M-LAG MAD. To identify these interfaces, execute the display m-lag mad verbose command.
· Network interfaces used for special purposes, including:
# Configure M-LAG MAD to shut down Bridge-Aggregation 1 on the secondary M-LAG member device when the M-LAG system splits.
[Sysname] m-lag mad include interface bridge-aggregation 1
Use m-lag mad persistent to enable M-LAG MAD DOWN state persistence.
Use undo m-lag mad persistent to disable M-LAG MAD DOWN state persistence.
The secondary M-LAG member device brings up interfaces in M-LAG MAD DOWN state when its role changes to primary.
M-LAG MAD DOWN state persistence prevents the secondary M-LAG member device from bringing up the network interfaces in M-LAG MAD DOWN state when its role change to primary. This feature helps avoid the forwarding issues that might occur in the multi-active situation that occurs because the keepalive link goes down while the peer link is down.
# Enable M-LAG MAD DOWN state persistence.
[Sysname] m-lag mad persistent
m-lag mad restore
m-lag mad restore
Use m-lag mad restore to bring up the interfaces in M-LAG MAD DOWN state.
m-lag mad restore
Execute this command only when both the M-LAG peer link and the keepalive link are down.
You can bring up the interfaces in M-LAG MAD DOWN state on the secondary M-LAG member device for it to forward traffic if the following conditions exist:
· The primary M-LAG member device fails while the peer link is down.
· M-LAG MAD DOWN state persists on the secondary M-LAG member device.
# Bring up the interfaces in M-LAG MAD DOWN state.
[Sysname] m-lag mad restore
To avoid network issues, make sure the primary device has failed and cannot forward traffic. Continue? [Y/N]:y
m-lag restore-delay
Use m-lag restore-delay to set the data restoration interval.
Use undo m-lag restore-delay to restore the default.
m-lag restore-delay value
The data restoration interval is 30 seconds.
value: Specifies the data restoration interval, in the range of 1 to 3600 seconds.
The data restoration interval specifies the maximum amount of time for the secondary M-LAG device to synchronize data with the primary M-LAG device during M-LAG system setup. Within the data restoration interval, the secondary M-LAG device sets all network interfaces to M-LAG MAD DOWN state, except for the following interfaces:
· Management Ethernet interface.
· Interfaces excluded from the M-LAG MAD shutdown action.
When the data restoration interval expires, the secondary M-LAG device brings up all network interfaces.
To avoid packet loss and forwarding failure, increase the data restoration interval if a large amount of data is to be synchronized between the M-LAG member devices.
# Set the data restoration interval to 50 seconds.
[Sysname] m-lag restore-delay 50
m-lag role priority
Use m-lag role priority to set the M-LAG role priority of the device.
Use undo m-lag role priority to restore the default.
m-lag role priority priority-value
The M-LAG role priority of the device is 32768.
priority-value: Specifies the M-LAG role priority, in the range of 0 to 65535. The lower the value, the higher the priority.
For features that require centralized traffic processing, an M-LAG member device is assigned the primary or secondary role based on its M-LAG role priority. The secondary M-LAG device forwards the traffic of those features to the primary M-LAG device for processing. If the M-LAG member devices use the same M-LAG role priority, the member device with a lower bridge MAC address is assigned the primary role.
As a best practice to avoid network flapping, do not modify the M-LAG role priority of M-LAG member devices after the M-LAG system is established.
# Set the M-LAG role priority of the device to 66.
[Sysname] m-lag role priority 66
display m-lag role
m-lag sequence enable
Use m-lag sequence enable to enable M-LAG sequence number check.
Use undo m-lag sequence enable to disable M-LAG sequence number check.
M-LAG sequence number check is disabled.
To protect M-LAG member devices from replay attacks, enable M-LAG sequence number check for them to identify attack packets.
With this feature enabled, the M-LAG member devices insert a sequence number into each outgoing DRCPDU or keepalive packet and the sequence number increases by 1 for each sent packet. When receiving a DRCPDU or keepalive packet, the M-LAG member devices check its sequence number and drop the packet if the check result is either of the following:
· The sequence number of the packet is the same as that of a previously received packet.
· The sequence number of the packet is smaller than that of the most recently received packet.
As a best practice to improve security, use M-LAG sequence number check together with M-LAG packet authentication.
After one M-LAG member device reboots, the other M-LAG member device might receive and accept the packets that were intercepted by an attacker before the reboot. As a best practice, change the authentication key after an M-LAG member device reboots.
# Enable M-LAG sequence number check.
[Sysname] m-lag sequence enable
m-lag standalone enable
Use m-lag standalone enable to enable M-LAG standalone mode.
Use undo m-lag standalone enable to disable M-LAG standalone mode.
m-lag standalone enable [ delay delay-time ]
undo m-lag standalone enable [ delay ]
M-LAG standalone mode is disabled.
delay delay-time: Sets the delay that the device must wait before changing to M-LAG standalone mode. The value range for this delay is 0 to 3600 seconds. If you do not set this parameter, the device changes to M-LAG standalone mode without delay when both the M-LAG peer link and the keepalive link go down.
Enable M-LAG standalone mode to avoid forwarding issues in the multi-active situation that might occur after both the M-LAG peer link and the keepalive link are down.
M-LAG standalone mode helps avoid traffic forwarding issues in this multi-active situation by allowing only the member ports in the M-LAG interfaces on one member device to forward traffic.
As a best practice, enable M-LAG standalone mode on both primary and secondary M-LAG member devices.
To prevent member ports of M-LAG interfaces from flapping, set the M-LAG standalone mode delay to be longer than the time required for a device reboot.
Before you enable M-LAG standalone mode on an M-LAG member device, make sure its LACP system priority is higher than that of the remote aggregation system. This restriction ensures that the reference port is on the remote aggregation system and prevents the interfaces attached to the M-LAG system from flapping.
NOTE: An M-LAG member device changes to M-LAG standalone mode only when it detects that both the M-LAG peer link and the keepalive link are down. It does not change to M-LAG standalone mode when the peer M-LAG member device reboots. |
# Enable M-LAG standalone mode.
[Sysname] m-lag standalone enable
m-lag system-mac
Use m-lag system-mac to configure the M-LAG system MAC address.
Use undo m-lag system-mac to restore the default.
m-lag system-mac mac-address
The M-LAG system MAC address is not configured.
mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
CAUTION: Changing the M-LAG system MAC address causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
The M-LAG system MAC address uniquely identifies the M-LAG system on the network. For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them. As a best practice to avoid MAC address collision, use the bridge MAC address of one M-LAG member device as the M-LAG system MAC address.
# Configure the M-LAG system MAC address as 0001-0001-0001.
[Sysname] m-lag system-mac 1-1-1
Changing the system MAC address might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-number
Use m-lag system-number to set the M-LAG system number.
Use undo m-lag system-number to restore the default.
m-lag system-number system-number
The M-LAG system number is not set.
system-number: Specifies the M-LAG system number. Available values are 1 and 2.
CAUTION: Changing the M-LAG system number causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system.
# Set the M-LAG system number to 1.
[Sysname] m-lag system-number 1
Changing the system number might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
m-lag system-priority
Use m-lag system-priority to set the M-LAG system priority.
Use undo m-lag system-priority to restore the default.
m-lag system-priority priority
The M-LAG system priority is 32768.
priority: Specifies a priority value in the range of 0 to 65535. The lower the value, the higher the priority.
CAUTION: Changing the M-LAG system priority causes M-LAG system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
An M-LAG system uses its M-LAG system priority as the system LACP priority to communicate with the remote aggregation system.
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system.
# Set the M-LAG system priority to 64.
[Sysname] m-lag system-priority 64
Changing the system priority might flap the intra-portal link and cause M-LAG system setup failure. Continue? [Y/N]:y
[Sysname]
port m-lag group
Use port m-lag group to assign an aggregate interface to an M-LAG group.
Use undo port m-lag group to restore the default.
port m-lag group group-id
undo port m-lag
An aggregate interface does not belong to an M-LAG group.
group-id: Specifies an M-LAG group number. The value range for the group-id argument is 1 to 1024.
To use a Layer 2 aggregate interface as an M-LAG interface, you must assign it to an M-LAG group.
The device can have multiple M-LAG interfaces. However, you can assign a Layer 2 aggregate interface to only one M-LAG group.
A Layer 2 aggregate interface cannot operate as both a peer-link interface and an M-LAG interface.
# Assign Bridge-Aggregation 1 to M-LAG group 100.
[Sysname-Bridge-Aggregation1] port m-lag group 100
port m-lag peer-link
Use port m-lag peer-link to specify an aggregate interface or tunnel interface as the peer-link interface.
Use port undo m-lag peer-link to restore the default.
port m-lag peer-link port-id
undo port m-lag peer-link
An interface is not the peer-link interface.
Tunnel interface view
port-id: Specifies the peer-link interface ID, which is fixed at 1.
An M-LAG member device can have only one peer-link interface.
Make sure the bandwidth of the peer-link interface is higher than that of an M-LAG interface.
If you specify an aggregate interface as a peer-link interface, the device assigns the aggregate interface as a trunk port to all VLANs when the interface uses the default VLAN settings. If not, the device does not change the VLAN settings of the interface.
The device does not change the VLAN settings of an aggregate interface when you remove its peer-link interface role.
As a best practice to reduce the impact of interface flapping on upper-layer services, execute the link-delay command on the peer-link interface.
By default, MAC address learning is enabled on the peer-link interface. This feature is not configurable on the peer-link interface.
# Specify Bridge-Aggregation 2 as the peer-link interface.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] port m-lag peer-link 1
link-delay
mac-address mac-learning enable
port m-lag ipv6 virtual-ip
Use port m-lag ipv6 virtual-ip to assign an M-LAG virtual IPv6 address to an interface.
Use undo port m-lag ipv6 virtual-ip to restore the default.
VLAN interface view:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] [ virtual-mac mac-address ] | link-local }
undo port m-lag ipv6 virtual-ip [ ipv6-address ]
Loopback interface view:
port m-lag ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] | link-local }
VSI interface view:
No M-LAG virtual IPv6 addresses are assigned to interfaces.
VLAN interface view
VSI interface view
ipv6-address: Specifies a virtual IPv6 address. The IPv6 address must be a global unicast address.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
active: Sets the virtual IPv6 address to be available on the local device.
standby: Sets the virtual IPv6 address to be unavailable on the local device.
virtual-mac mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
link-local: Uses the specified link-local address as the virtual IPv6 address. Specify this keyword only for OSPFv3 neighbor establishment when dual-active gateways are placed on the M-LAG system.
For an M-LAG member device to act as a RADIUS client, you must assign an M-LAG virtual IPv6 address to an interface of the device as the source IPv6 address of RADIUS packets. The virtual IPv6 address must be the IPv6 address configured by using the nas-ip command.
Configure M-LAG virtual IPv6 addresses based on the user authentication load sharing mode set by using the port-security m-lag load-sharing-mode command.
· Centralized mode—Configure the same virtual IPv6 address on the M-LAG member devices, and set the state of the virtual IPv6 address to active on the primary M-LAG member device.
· Distributed mode—Configure the virtual IPv6 addresses used for local user authentication and peer user authentication on both M-LAG member devices. On each M-LAG member device, set the state of the local virtual IPv6 address to active, and set the state of the peer virtual IPv6 address to standby.
If you do not specify the active or standby keyword for a virtual IPv6 address, the address is available only on the primary M-LAG member device.
If you execute the undo port m-lag ipv6 virtual-ip command without specifying the ipv6-address argument, the command deletes all M-LAG virtual IPv6 addresses on the interface.
If the peer-link interface fails, the standby virtual IPv6 address becomes active on the primary M-LAG member device.
When you assign multiple M-LAG virtual IPv6 addresses to an interface, follow these restrictions and guidelines:
· You can assign a maximum of two virtual IPv6 addresses to an interface.
· If you configure different virtual MAC addresses for a virtual IPv6 address, the most recent configuration takes effect.
· You cannot configure the same virtual MAC address for multiple virtual IPv6 addresses.
· When you assign a virtual IPv6 address to VLAN interfaces, you must configure the same virtual MAC address for the virtual IPv6 address on both M-LAG member devices.
If you assign both virtual IPv4 and IPv6 addresses to VLAN interfaces, make sure the virtual IPv4 and IPv6 addresses that use the same virtual MAC address are in the same state on the M-LAG member devices.
# Assign M-LAG virtual IPv6 address 1::10/64 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port m-lag ipv6 virtual-ip 1::10 64 active virtual-mac 1-1-1
nas-ip (Security Command Reference)
port m-lag system-mac
Use port m-lag system-mac to configure the M-LAG system MAC address on an aggregate interface.
Use undo port m-lag system-mac to restore the default.
port m-lag system-mac mac-address
Aggregate interface view
The M-LAG system MAC address uniquely identifies the M-LAG system on the network. For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on the M-LAG interfaces in the same M-LAG group. As a best practice to avoid MAC address collision, use the bridge MAC address of one M-LAG member device as the M-LAG system MAC address.
You can configure the M-LAG system MAC address on an aggregate interface only after it is configured as an M-LAG interface.
You can configure the M-LAG system MAC address globally and in aggregate interface view. The global M-LAG system MAC address takes effect on all aggregation groups. On an aggregate interface, the interface-specific M-LAG system MAC address takes precedence over the global M-LAG system MAC address.
# Configure the M-LAG system MAC address as 0001-0001-0001 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port m-lag system-mac 1-1-1
m-lag system-mac
port m-lag system-priority
Use port m-lag system-priority to set the M-LAG system priority on an aggregate interface.
Use undo port m-lag system-priority to restore the default.
port m-lag system-priority priority
An M-LAG system uses its M-LAG system priority as the LACP system priority to communicate with the remote aggregation system.
You must configure the same M-LAG system priority for the M-LAG interfaces in the same M-LAG group.
You can configure the M-LAG system priority on an aggregate interface only after it is configured as an M-LAG interface.
You can configure the M-LAG system priority globally and in aggregate interface view. The global M-LAG system priority takes effect on all aggregation groups. On an aggregate interface, the interface-specific M-LAG system priority takes precedence over the global M-LAG system priority.
# Set the M-LAG system priority to 64 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port m-lag system-priority 64
port m-lag virtual-ip
Use port m-lag virtual-ip to assign an M-LAG virtual IPv4 address to an interface.
Use undo port m-lag virtual-ip to restore the default.
port m-lag virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ]
undo port m-lag virtual-ip [ ipv4-address ]
VSI interface view:
No M-LAG virtual IPv4 addresses are assigned to interfaces.
VLAN interface view
VSI interface view
ipv4-address: Specifies a virtual IPv4 address.
mask-length: Specifies the subnet mask length in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
active: Sets the virtual IPv4 address to be available on the local device.
standby: Sets the virtual IPv4 address to be unavailable on the local device.
For an M-LAG member device to act as a RADIUS client, you must assign an M-LAG virtual IPv4 address to an interface of the device as the source IPv4 address of RADIUS packets. The virtual IPv4 address must be the IPv4 address configured by using the nas-ip command.
Configure M-LAG virtual IPv4 addresses based on the user authentication load sharing mode set by using the port-security m-lag load-sharing-mode command.
· Centralized mode—Configure the same virtual IPv4 address on the M-LAG member devices, and set the state of the virtual IPv4 address to active on the primary M-LAG member device.
· Distributed mode—Configure the virtual IPv4 addresses used for local user authentication and peer user authentication on both M-LAG member devices. On each M-LAG member device, set the state of the local virtual IPv4 address to active, and set the state of the peer virtual IPv4 address to standby.
If you do not specify the active or standby keyword for a virtual IPv4 address, the address is available only on the primary M-LAG member device.
If you execute the undo port m-lag ipv4 virtual-ip command without specifying the ipv4-address argument, the command deletes all M-LAG virtual IPv4 addresses on the interface.
If the M-LAG peer-link interface fails, the standby virtual IPv4 address becomes active on the primary M-LAG member device.
When you assign multiple M-LAG virtual IPv4 addresses to an interface, follow these restrictions and guidelines:
· You can assign a maximum of two virtual IPv4 addresses to an interface.
· If you configure different virtual MAC addresses for a virtual IPv4 address, the most recent configuration takes effect.
· You cannot configure the same virtual MAC address for multiple virtual IPv4 addresses.
· When you assign a virtual IPv4 address to VLAN interfaces, you must configure the same virtual MAC address for the virtual IPv4 address on both M-LAG member devices.
# Assign M-LAG virtual IPv4 address 10.10.10.10/24 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port m-lag virtual-ip 10.10.10.10 24 active virtual-mac 1-1-1
reset m-lag drcp statistics
Use reset m-lag drcp statistics to clear DRCPDU statistics.
reset m-lag drcp statistics [ interface interface-list ]
interface interface-list: Specifies a space-separated list of interface items. Each item specifies an aggregate interface or a range of aggregate interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The value for interface-number2 must be greater than or equal to the value for interface-number1. The aggregate interfaces must be M-LAG interfaces or the peer-link interface. If you do not specify this option, the command clears the DRCPDU statistics about all M-LAG interfaces and the peer-link interface.
# Clear DRCPDU statistics.
<Sysname> reset m-lag drcp statistics
display m-lag drcp statistics
reset m-lag troubleshooting history
Use reset m-lag troubleshooting history to clear M-LAG troubleshooting records.
# Clear M-LAG troubleshooting records.
<Sysname> reset m-lag troubleshooting history
