| 00-Perface | 30.57 KB |
Preface
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C Intelligent Management Center (IMC).
Conventions
GUI conventions
| Convention | Description |
| Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window opens; click OK. |
| > | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
| An alert that calls attention to important information that if not understood or followed can result in personal injury. | |
| An alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software. | |
| An alert that calls attention to essential information. | |
| NOTE: | An alert that contains additional or supplementary information. |
| An alert that provides helpful information. |
Documentation feedback
We appreciate your comments.
 Login
Login
