H3C Transceiver Modules User Guide-6W119
HomeSupportTransceiver ModulesTransceiver ModulesInstall & UpgradeTransceiver ModulesH3C Transceiver Modules User Guide-6W119
Table of Contents
Related Documents
01-Text
01-Text 2.33 MB
Overview·· 1
Optical transceiver modules· 2
Data rate· 3
Transmission distance· 3
Central wavelength· 3
Fiber 3
Connector 5
Optical parameters· 7
Copper transceiver modules· 8
Data rate· 8
Transmission distance· 8
Connector 8
PoE optical transceiver modules· 9
Data rate· 9
Transmission distance· 9
Central wavelength· 10
Fiber 10
Connector 10
Optical parameters· 10
QSFP-DD modules· 11
QSFP-DD optical transceiver modules (MPO) 11
Models and specifications· 11
QSFP-DD optical transceiver modules (dual LC) 12
Models and specifications· 12
QSFP-DD copper cable· 13
Models and specifications· 13
QSFP56 modules· 14
QSFP56 optical transceiver modules (MPO) 14
Models and specifications· 14
QSFP28 modules· 15
QSFP28 optical transceiver modules (MPO) 15
Models and specifications· 15
QSFP28 optical transceiver modules (dual LC) 16
Models and specifications· 16
QSFP28 copper cable· 18
Models and specifications· 19
QSFP28 to SFP28 copper cables· 19
QSFP28 optical cables· 20
Models and specifications· 20
CFP modules· 21
100-Gigabit CFP optical transceiver modules· 21
Models and specifications· 21
40-Gigabit CFP optical transceiver modules· 22
Models and specifications· 22
CFP2 modules· 23
CFP2 optical transceiver modules (MPO) 23
Models and specifications· 23
CFP2 optical transceiver modules (dual LC) 24
Models and specifications· 24
CXP modules· 25
CXP optical transceiver modules· 25
Models and specifications· 25
CXP optical cables· 25
Models and specifications· 26
QSFP+ modules· 27
QSFP+ optical transceiver modules (MPO) 27
Models and specifications· 27
QSFP+ optical transceiver modules (dual LC) 28
Models and specifications· 28
QSFP+ copper cables· 30
Models and specifications· 30
QSFP+ to SFP+ copper cables· 30
Models and specifications· 31
QSFP+ optical cables· 31
Models and specifications· 32
SFP28 modules· 33
SFP28 optical transceiver modules· 33
Models and specifications· 33
SFP28 copper cables· 34
Models and specifications· 34
SFP28 optical cables· 35
Models and specifications· 35
SFP+ modules· 36
SFP+ optical transceiver modules (dual LC) 36
Models and specifications· 36
SFP+ optical transceiver modules (SC) 43
Models and specifications· 44
10G EPON OLT SFP+ optical transceiver modules (SC) 44
SFP+ copper transceiver modules· 46
Models and specifications· 46
SFP+ copper cables· 46
SFP+ optical cables· 47
Models and specifications· 47
XFP modules· 48
XFP optical transceiver modules (dual LC) 48
Models and specifications· 48
10G EPON OLT XFP optical transceiver modules (SC) 52
Models and specifications· 52
CX4 cables· 54
Models and specifications· 54
SFP modules· 55
2.5-Gigabit SFP optical transceiver modules· 55
Models and specifications· 55
SFP GPON ONU optical transceiver modules (SC) 56
Models and specifications· 56
SFP GPON OLT optical transceiver modules (SC) 57
Models and specifications· 57
Gigabit SFP optical transceiver modules· 58
Models and specifications· 58
622-Megabit SFP optical transceiver modules· 60
Models and specifications· 60
100-Megabit SFP optical transceiver modules· 60
Models and specifications· 61
Gigabit BIDI optical transceiver modules· 61
Models and specifications· 62
100-Megabit BIDI optical transceiver modules· 63
Models and specifications· 63
BIDI GEPON OLT optical transceiver modules (SC) 64
Models and specifications· 64
Gigabit CWDM optical transceiver modules (LC) 65
Models and specifications· 65
Gigabit SFP copper transceiver modules· 66
Models and specifications· 66
Gigabit SFP copper cables· 67
Models and specifications· 67
PoE optical transceiver modules· 68
SFP+ PoE optical transceiver modules· 68
Models and specifications· 68
SFP PoE optical transceiver modules· 69
Models and specifications· 69
Fiber PoE patch cords· 70
Models and specifications· 70
Fiber PoE pigtail 70
Models and specifications· 71
Overview
Table 1 describes transceiver modules and network cables available for H3C devices. All these transceiver modules and network cables are hot swappable.
Table 1 Transceiver modules and network cables available for H3C devices
Transceiver module and network cable type
Interface connector
Data rate
QSFP-DD module (transceiver)
Dual LC
400 Gbps
MPO
N/A
QSFP56 module
(transceiver)
MPO
200 Gbps
QSFP28 module (transceiver)
MPO/dual LC
100/50 Gbps
QSPF28 BIDI optical transceiver module
Dual LC
100 Gbps
QSFP28 copper cable
N/A
CFP module (transceiver)
Dual LC
100 Gbps
CFP2 module (transceiver)
MPO/dual LC
100 Gbps
CXP module (transceiver)
100-Gigabit CXP optical transceiver module
MPO
100 Gbps
100-Gigabit CXP optical cable
N/A
QSFP+ module (transceiver)
MPO/dual LC
40 Gbps
QSPF+ BIDI optical transceiver module
Dual LC
QSFP+ copper cable (for interconnecting QSFP+ ports)
N/A
QSFP+ to SFP+ copper cable (for connecting one 40-Gigabit QSFP+ port to four 10-Gigabit SFP+ ports)
N/A
QSFP+ optical cable
Dual LC
25 Gbps
SFP28 copper cable
N/A
SFP28 optical cable
Dual LC/SC
10 Gbps
SFP+ BIDI optical transceiver module
Dual LC
SFP+ copper cable (for interconnecting devices)
N/A
SFP+ optical cable
10-Gigabit small form-factor pluggable (XFP) module (transceiver)
Dual LC
See Table 52.
10G EPON OLT optical transceiver module
SC
See Table 54.
10-Gigabit CX4 cable (for interconnecting devices)
N/A
12 Gbps
Small form-factor pluggable (SFP) module (transceiver)
Dual LC
2.5 Gbps
1250 Mbps
622 Mbps
155 Mbps
Gigabit bi-direction (BIDI) optical transceiver module
Dual LC
1250 Mbps
100-Megabit bi-direction (BIDI) optical transceiver module
155 Mbps
SC
1250 Mbps
Gigabit GPON ONU optical transceiver module
SC
1250 Mbps
Gigabit coarse wavelength division multiplexing (CWDM) optical transceiver module
Dual LC
1250 Mbps
RJ-45
1250 Mbps
Gigabit SFP copper cable (for interconnecting devices)
N/A
1250 Mbps
IMPORTANT
IMPORTANT:
The commercial outer casing temperature range is 0°C to 70°C (32°F to 158°F) and industrial outer casing temperature range is –40°C to +85°C (–40°F to +185°F) for H3C transceiver modules. The commercial temperature range is applicable to all transceiver modules except for transceiver modules marked with * and transceiver modules with special temperature requirements specified in this document. An abnormal outer casing temperature might reduce the performance, signal transmission quality, and link status of the transceiver module, and even damage the transceiver module.
·     The available transceiver modules and network cables vary by device models and are subject to change over time. For the most up-to-date list of transceiver modules and network cables, contact your H3C sales representative or technical support engineer.
·     For information about the transceiver modules and network cables available for each device model, see the installation guides.
Optical modules transmit signals over optical fibers. Optical transmission features low loss and is fit for long distance transmission.
H3C devices support optical module models of different specifications. You can choose optical modules as needed for data transmission over optical fibers.
The optical modules include optical transmitters, optical receivers, transceivers, and transponders.
H3C devices support transceivers. Transceivers are mainly used for optical-to-electrical and electrical-to-optical conversions and provide the following functions: optical power control, modulation transmission, signal probe, IV conversion, and limiting amplifier and decision regeneration. In addition, transceivers provide some other functions, such as counterfeit-prevention query and TX-disable. Common form factors for transceiver modules include QSFP-DD, QSFP56, QSFP28, CFP, CFP2, CXP, QSFP+, SFP28, SFP+, and SFP.
Data rate
Data rate is the number of bits transmitted per second. The unit of measure for data rate is Mbps (Megabits per second) or Gbps (Gigabits per second). Optical transceiver modules available for H3C devices mainly provide the following levels of data rates: 400 Gbps, 200 Gbps, 100 Gbps, 50 Gbps, 40 Gbps, 32 Gbps, 25 Gbps, 16 Gbps, 10 Gbps, 8 Gbps, 4 Gbps, 2.5 Gbps, 2 Gbps, 1 Gbps, 622 Mbps, 155 Mbps, and 100 Mbps.
The transmission distance of optical transceiver modules is divided into short and long-range types. A distance of 2 km (1.24 miles) and below is generally considered as short-range type. 10 km (6.21 miles) is considered as long-range type.
Transmission distances provided by optical transceiver modules are mainly limited by certain loss and dispersion suffered during the transmission of optical signals over optical fibers.
·     Loss is the optical energy loss due to the absorption, dispersion and leakage over the media when light travels through optical fibers. This loss increases in direct ratio to transmission distance.
·     Dispersion happens mainly because electromagnetic waves of different wavelengths travel at different rates over the same medium, causing different wave components of optical signals to reach the receiving end early or late as the transmission distance increases, which in turn causes impulse broadening, making the signal values indistinguishable.
To meet different transmission distance requirements, choose optical transceiver modules according to actual networking conditions.
Central wavelength
Central wavelength represents the wave band used for optical signal transmission. At present, there are mainly three central wavelengths for common optical transceiver modules: 850 nm, 1310 nm, and 1550 nm, respectively representing three wavebands.
·     The 850 nm wave band is mainly used for short-reach transmission.
·     The 1310 nm and 1550 nm wave bands are mainly used for middle- and long-reach transmission.
Fiber
Fiber types
Fibers are classified as multimode fibers and single-mode fibers.
·     Multimode fibers
Multimode fibers (MMFs) have thicker fiber cores and can transport light in multiple modes. However, the inter-mode dispersion is greater and worsens as the transmission distance increases.
Multimode fibers can be classified into multiple grades according to their diameters and modal bandwidth. For more information, see Table 2. The modal bandwidth of a multimode fiber is determined by the expression the modulation frequency of the maximum modulation frequency pulse that can pass a fiber × the fiber length. The modal bandwidth is a comprehensive index reflecting the optical characteristics of a multimode fiber.
International Telecommunication Union (ITU) defines multimode fiber types in its G series standards. The commonly-used multimode fiber is defined in the ITU G.651 standard. The G.651-compliant fiber transmits light at the wavelength range 800 nm to 900 nm or 1200 nm to 1350 nm.
Table 2 Multimode fiber grades
Fiber mode
Fiber grade
Fiber diameter (μm)
Modal bandwidth at 850 nm (MHz*km)
Multimode fiber
OM1
62.5/125
200
OM2
50/125
500
OM3
50/125
2000
OM4
50/125
4700
Other factors that influence the transmission distance of multimode fibers include interface type, central wavelength, and fiber grade. For more information, see Table 3.
Table 3 Multimode fiber specifications
Interface type
Central wavelength (nm)
Fiber grade
1000BASE-SX
850
OM1
< 275 m (902.23 ft)
OM2
< 550 m (1804.46 ft)
10GBASE-SR
850
OM1
< 33 m (108.27 ft)
OM2
< 82 m (269.03 ft)
OM3
< 300 m (984.25 ft)
OM4
< 400 m (1312.34 ft)
40GBASE-CSR4
850
OM3
< 300 m (984.25 ft)
OM4
40GBASE-SR4
850
OM3
< 70 m (229.66 ft)
OM4
< 100 m (328.08 ft)
100GBASE-eSR4
850
OM4
< 300 m (984.25 ft)
100GBASE-SR4
850
OM3
< 70 m (229.66 ft)
OM4
< 100 m (328.08 ft)
200GBASE-SR4
850
OM3
< 70 m (229.66 ft)
OM4
< 100 m (328.08 ft)
400GBASE-SR8
850
OM3
< 70 m (229.66 ft)
OM4
< 100 m (328.08 ft)
25GBASE-SR
850
OM3
< 70 m (229.66 ft)
OM4
< 100 m (328.08 ft)
·     Single-mode fibers
Single-mode fibers (SMFs) have a small core size, typically 9 μm or 10 μm, and can transmit light in only one mode. Single-mode fibers suffer little inter-mode dispersion and are suitable for long-reach communication.  Single-mode fibers transmit light at the central wavelength of 1310 nm or 1550 nm.
Telecommunication Industries Alliance (TIA)/Electronic Industries Alliance (EIA) defines that single-mode fibers use yellow outer jackets with the mark "SM".
ITU defines single-mode fiber types in its G series standards. The mostly-commonly used single-mode fibers are defined in ITU G.652 and G.655 standards. Table 4 describes features of the G.652 and G.655-compliant fibers.
Table 4 Features of G.652 and G.655-compliant fibers
Single-mode fiber type
Wavelength (nm)
Features
Applications
G.652-compliant fiber (standard single-mode fiber)
·     1260 to 1360
·     1530 to 1565
Zero dispersion at 1310 nm.
Connecting transceiver modules with a central wavelength of 1310 nm or 1550 nm.
G.655-compliant fiber (non-zero dispersion shifted fiber)
1530 to 1565
Near-zero dispersion around 1550 nm.
For 1550-nm wavelength-division multiplexing (WDM) transmissions.
Fiber diameter
Fiber diameter is generally expressed as core diameter/cladding diameter, in μm. For example, 9/125 μm means the fiber core diameter is 9 μm and the fiber cladding diameter is 125 μm.
For the H3C devices, the following fiber diameters are recommended:
·     G.652 standard single-mode fiber—9/125 μm.
·     G.655 single-mode fiber—9/125 μm.
·     G.651 standard multimode fiber—50/125 μm or 62.5/125 μm.
Connector
CAUTION
CAUTION:
Cover the connector with a dust cap when it is not connected to any optical fiber.
Connectors connect transceiver modules to the corresponding transmission media. The optical transceiver modules available for H3C devices use the following types of connectors:
·     Subscriber connector standard connector (SC).
Figure 1 SC connector
·     Lucent connector or local connector (LC).
Figure 2 LC connector
·     Multi-fiber Push On connector (MPO).
Figure 3 MPO connector
H3C transceiver modules use only female MPO connectors, which have guide holes in the end face.
MPO connectors are classified as the following types based on the polish type:
¡     Physical contact (PC)—End face polished flat.
¡     Angle-polished contact (APC)—End face polished with an angle, typically 8°.
MPO connectors are available with 12 fibers, 16 fibers, or 24 fibers:
¡     12-fiber MPO connector
Figure 4 End face of a 12-fiber connector
¡     16-fiber MPO connector
Figure 5 End face of a 16-fiber connector
¡     24-fiber MPO connector
Figure 6 End face of a 24-fiber connector
Optical parameters
CAUTION
CAUTION:
The average transmit power of a long-haul optical transceiver module is greater than the saturated optical power. Be careful about the length of the optical fiber you use to make sure the actual receive power reaching the optical transceiver module is less than its saturated optical power. Otherwise, the optical transceiver module might be damaged.
Average transmit and receive power ranges are provided for transceiver modules in this guide.
Transmit power
Transmit power is the power at which the transmitter of an optical transceiver module transmits optical signals, in dBm.
Receive power
Receive power is the power at which the receiver of an optical transceiver module receives optical signals, in dBm.
Receiving sensitivity
Receiving sensitivity is the minimum optical power that is needed at the receiving end for the optical module to receive optical signals at a given data rate and bit error rate, in dBm. The higher the data rate is, the worse the receiving sensitivity is, the greater the minimum receive power is. A greater receive power has higher requirements on the receiving components of the optical module.
Saturated optical power
Saturated optical power (also known as optical saturation) is the maximum receive power at a given data rate and bit error rate range (10-10 to 10-12), in dBm.
Saturated photocurrent occurs if a fiber probe is irradiated by intensive light. When this occurs, it takes the probe some time to recover. In this case, the receiving sensitivity worsens and the received signals may be decided incorrectly, causing bit errors. This will probably damage the receiving probe. Therefore, when you perform operations, try to maintain a normal saturated optical power level.
Copper transceiver modules, also called RJ-45 modules, transmit electrical signals over twisted pair cables and do not provide conversion between electrical and optical signals. Compared with optical fibers, twisted pair cables provide a short transmission distance, suitable only for small-scale networking environments.
You can use copper transceiver modules to connect two fiber ports over a network cable.
H3C devices support SFP and SFP+ copper transceiver modules.
Data rate
Data rate refers to the number of bits transmitted per second. Data rates of copper transceiver modules are typically measured in Mbps or Gbps.
10 Gbps, 1250 Mbps, and 100 Mbps copper transceiver modules are available for H3C devices.
Through UTP cables, electrical signals can be transmitted over a distance of 100 m (328.08 ft) only. This is because electrical signals attenuate during transmission through the UTP cables.
Attenuation refers to the dissipation of the power of a transmitted signal as it travels over a cable. Attenuation occurs because signal transmission suffers certain resistance from the cable, which weakens the electrical signals as they travel over the cable. When signals are transmitted over a very long distance, signal strength decreases very significantly, causing the signal-to-noise ratio to drop below the accepted level. This makes it impossible to distinguish between signals and noise, resulting in decision errors.
To transmit signals over a short distance, use copper transceiver modules only.
Connector
RJ-45 (Registered Jack-45) twisted pair connectors are used as the connectors for copper transceiver modules. Figure 7 shows the appearance of an RJ-45 connector.
Figure 7 RJ-45 connector
Table 5 RJ-45 GE connector pin assignment
Pin
Signal
Function
1
MX_0+
Data transmit/receive
2
MX_0-
3
MX_1+
4
MX_2+
5
MX_2-
6
MX_1-
7
MX_3+
8
MX_3-
PoE optical transceiver modules are typically used to connect photoelectric hybrid cables to photoelectric hybrid ports (for example, PSFP or PSFP+ ports) on optical switches in a hybrid fiber and copper scheme. Compared with common transceiver modules, PoE optical transceiver modules can transmit both data and power over photoelectric hybrid cables. Such a transmission mode features longer transmission distance, which is suitable for large-scale networking environments.
H3C devices support SFP and SFP+ PoE optical transceiver modules.
Data rate
Data rate refers to the number of bits transmitted per second. Data rates of PoE optical transceiver modules are typically measured in Mbps or Gbps.
10 Gbps, 5000 Mbps, 2500 Mbps, and 1250 Mbps PoE optical transceiver modules are available for H3C devices.
The transmission distance of PoE optical transceiver modules is divided into short and long-range types. A distance of 2 km (1.24 miles) and below is generally considered as short-range type. 10 km (6.21 miles) is considered as long-range type.
Transmission distances provided by PoE optical transceiver modules are limited by the following factors:
·     Certain loss and dispersion suffered during the transmission of optical signals over optical fibers in photoelectric hybrid cables.
¡     Loss is the optical energy loss due to the absorption, dispersion and leakage over the media when light travels through optical fibers. This loss increases in direct ratio to transmission distance.
¡     Dispersion happens mainly because electromagnetic waves of different wavelengths travel at different rates over the same medium, causing different wave components of optical signals to reach the receiving end early or late as the transmission distance increases, which in turn causes impulse broadening, making the signal values indistinguishable.
·     Power of the power supply ports on the optical switch. A longer transmission distance indicates more power consumption for the powered devices and larger power for the power supply ports.
·     Cable impedance. A longer transmission distance indicates larger cable impedance and larger power for the power supply ports.
·     Total power consumption of the remote powered devices (PDs) and wireless APs and PDs that connect to the remote PDs.
Choose compatible PoE optical transceiver modules and photoelectric hybrid cables as required.
Central wavelength
Central wavelength represents the wave band used for optical signal transmission. At present, PoE optical transceiver modules available for H3C devices use the 1310 nm wave band.
Fiber
PoE optical transceiver modules available for H3C devices use SMFs. For more information, see "Fiber."
Connector
CAUTION
CAUTION:
·     Cover the connector with a dust cap when it is not connected to any optical fiber.
·     You can insert only Power Ethernet Lucent connectors (PELC) into PoE optical transceiver modules.
PoE optical transceiver modules available for H3C devices use PELC connectors. With conductive terminals, a PELC connector can provide high-speed and long-range data transmission and supply power for remote devices. As shown in Figure 8, the parts marked in small red square boxes are conductive terminals.
Figure 8 PELC connector
Optical parameters
The optical parameters are the same for PoE optical transceiver modules and common optical transceiver modules. For more information, see "Optical parameters."
QSFP-DD modules
Figure 9 QSFP-DD optical transceiver module (MPO)
QSFP-DD optical transceiver modules (MPO) provide a transmission rate of 400 Gbps.
Table 6 Specifications for QSFP-DD optical transceiver modules (MPO) (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
Modal bandwidth (MHz*km)
QSFPDD-400G-SR8-MM850
850
MMF
50/125
16
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Table 7 Specifications for QSFP-DD optical transceiver modules (MPO) (2)
Model
Connector
Optical parameters (dBm)
Transmit power
Receive power
MPO (APC polished, 16-fiber)
–6.5 to +4
–8.4 to +4
Figure 10 QSFP-DD optical transceiver module (dual LC)
QSFP-DD optical transceiver modules (dual LC) provide a transmission rate of 400 Gbps.
Table 8 Specifications for QSFP-DD optical transceiver modules (dual LC) (1)
Model
Fiber mode
Fiber diameter (µm)
QSFPDD-400G-FR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
2 km (1.24 miles)
QSFPDD-400G-LR4-WDM1300-DC
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
6 km (3.73 miles, complying with the IEEE802.3cu standard)
10 km (6.21 miles, complying with the 100G Lambda MSA standard)
QSFPDD-400G-LR8-WDM1300
Four lanes:
·     1273.54
·     1277.89
·     1282.26
·     1286.66
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
10 km (6.21 miles)
Table 9 Specifications for QSFP-DD optical transceiver modules (dual LC) (2)
Model
Transmit power
Receive power
–3.3 to +3.5
–7.3 to +3.5
–2.7 to +5.1
–6.8 to +5.1
–2.8 to +5.3
–7.2 to +5.3
The transmit power and receive power provided in Table 9 are average values of the four lanes.
Figure 11 QSFP-DD copper cable
Table 10 Specifications for QSFP-DD copper cables
Model
Length
Data rate
QSFPDD-400G-D-CAB-2M
2 m (6.56 ft)
400 Gbps
QSFP56 modules
Figure 12 QSFP56 optical transceiver module (MPO)
QSFP56 optical transceiver modules (MPO) provide a transmission rate of 200 Gbps and use an MPO connector.
Table 11 Specifications for QSFP56 optical transceiver modules (MPO) (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
QSFP56-200G-SR4-MM850
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Table 12 Specifications for QSFP56 optical transceiver modules (MPO) (2)
Model
Connector
Transmit power
Receive power
MPO (PC polished, 12-fiber)
–6.5 to +4
–8.4 to +4
QSFP28 modules
Figure 13 QSFP28 optical transceiver module (MPO)
QSFP28 optical transceiver modules (MPO) provide a transmission rate of 100 Gbps and use an MPO connector.
Table 13 Specifications for QSFP28 optical transceiver modules (MPO) (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
QSFP-100G-SR4-MM850
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SR4-MM850-H
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SR4-MM850-B-CM
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SR4-MM850-CM
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SR4-MM850-A
850
MMF
50/125
8
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-eSR4-MM850
850
MMF
50/125
8
4700
300 m (984.25 ft)
QSFP-100G-PSM4-SM1310
1310
SMF
9/125
8
N/A
0.5 km (0.31 miles)
Table 14 Specifications for QSFP28 optical transceiver modules (MPO) (2)
Model
Connector
Transmit power
Receive power
QSFP-100G-SR4-MM850
–8.4 to +2.4
–10.3 to +2.4
–8.4 to +2.4
–10.3 to +2.4
–2 to +2.4
–10.3 to +2.4
–8.4 to +2.4
–10.3 to +2.4
–8.4 to +2.4
–10.3 to +2.4
–8.4 to +2.4
–10.3 to +2.4
MPO (APC polished, 12-fiber)
–9.4 to +2
–12.66 to +2
Figure 14 QSFP28 optical transceiver module (dual LC)
QSFP28 optical transceiver modules (dual LC) in Table 15 and Table 16 provide a transmission rate of 100 Gbps and 50 Gbps, respectively. The QSFP28 optical transceiver modules use a dual LC connector.
Table 15 Specifications for QSFP28 optical transceiver modules (dual LC) (1)
Model
Fiber mode
Fiber diameter (µm)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
40 km (24.86 miles)
QSFP-100G-ER4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
40 km (24.86 miles)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4-WDM1300-A
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
2 km (1.24 miles)
QSFP-100G-ZR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
N/A
80 km (49.71 miles)
QSFP-100G-CWDM4-SM1300-A
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
2 km (1.24 miles)
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
MMF
50/125
2000
75 m (246.06 ft)
4700
100 m (328.08 ft)
QSFP-100G-BIDI-MM850
(end of sale)
Four lanes:
·     855
·     908
MMF
50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Table 16 Specifications for QSFP28 optical transceiver modules (dual LC) (2)
Model
Fiber mode
Fiber diameter (µm)
QSFP-50G-LR-SM1311
1311
SMF
9/125
N/A
10 km (6.2 miles)
QSFP-50G-ER-SM1311
1311
SMF
9/125
N/A
40 km (24.86 miles)
Table 17 Specifications for QSFP28 optical transceiver modules (dual LC) (3)
Model
Transmit power (average)
Receive power (average)
+0.5 to +4.5 per lane
–20.5 to –1.9 per lane
–2.9 to +2.9 per lane
–20.9 to –3.5 per lane
–4.3 to +4.5 per lane
–10.6 to +4.5 per lane
–6.5 to +2.5 per lane
–11.5 to +2.5 per lane
+2 to +6.5 per lane
–28 to –7 per lane
–7.5 to +2.4 per lane
–9.5 to +2.4 per lane
–6 to +4 per lane
–7.9 to +4 per lane
QSFP-50G-LR-SM1311
–4.5 to +4.2 per lane
–10.8 to +4.2 per lane
QSFP-50G-ER-SM1311
+0.4 to +6.6 per lane
–17.6 to –3.4 per lane
·     The operating outer casing temperature of a QSFP-100G-BIDI-MM850 transceiver module is in the range of 10°C to 60°C (50°F to 140°F). The performance, signal transmitting and receiving capability, and link status of the transceiver module deteriorate when the outer casing temperature is out of this range.
·     To use the QSFP-100G-ER4L-WDM1300 transceiver module to transmit data over a distance of 40 km (24.86 miles), you must enable FEC on the traffic transmitting and receiving ports. If FEC is not enabled on the peer ports, the transmission distance can only reach a maximum of 30 km (18.64 miles).
QSFP28 copper cable
Figure 15 QSFP28 copper cable
Table 18 Specifications for QSFP28 copper cables
Model
Length
Data rate
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
100 Gbps
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-3M-CM
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
A QSFP28 to SFP28 copper cable has a QSFP28 module at one end and four SFP28 modules at the other end.
Figure 16 QSFP28 to SFP28 copper cable
JG329A_HP X242 40G QSFP to 4x10G SFP+ 1m Direct Attach Copper Splitter Cable.png
Table 19 Specifications for QSFP28 to SFP28 copper cables
Model
Length
Data rate
Remarks
QSFP-100G-4SFP-25G-CAB-1M
1 m (3.28 ft)
100 Gbps
Used for connecting one 100G QSFP28 port to four 25G SFP28 ports.
QSFP-100G-4SFP-25G-CAB-3M
3 m (9.84 ft)
QSFP-100G-4SFP-25G-CAB-3M-CM
3 m (9.84 ft)
QSFP-100G-4SFP-25G-CAB-5M
5 m (16.40 ft)
QSFP-100G-4SFP-25G-CAB-5M-CM
5 m (16.40 ft)
Figure 17 QSFP28 optical cable
Table 20 Specifications for QSFP28 optical cables
Model
Length
Data rate
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
100 Gbps
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
CFP modules
Figure 18 100-Gigabit/40-Gigabit CFP optical transceiver module
100-Gigabit CFP optical transceiver modules provide a transmission rate of 100 Gbps and use LC connectors.
Table 21 Specifications for 100-Gigabit CFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (µm)
CFP-100G-LR4-WDM1300 (end of sale)
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
10 km (6.21 miles)
CFP-100G-LR4-WDM1300-A
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
10 km (6.21 miles)
CFP-100G-ER4-WDM1300
(end of sale)
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
40 km (24.86 miles)
Table 22 Specifications for 100-Gigabit CFP optical transceiver modules (2)
Model
–4.3 to +4.5
–10.6 to +4.5
–4.3 to +4.5
–10.6 to +4.5
–2.9 to +2.9
–20.9 to +4.5
See Figure 18 for a view of the 40-Gigabit CFP optical transceiver module.
40-Gigabit CFP optical transceiver modules provide a transmission rate of 40 Gbps and use a dual LC connector.
Table 23 Specifications for 40-Gigabit CFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (µm)
CFP-40G-LR4-SM1310 (end of sale)
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
10 km (6.21 miles)
CFP-40G-ER4-WDM1300 (end of sale)
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
40 km (24.86 miles)
Table 24 Specifications for 40-Gigabit CFP optical transceiver modules (2)
Model
CFP-40G-LR4-SM1310
–4 to +3
–11.5 to +3
CFP-40G-ER4-WDM1300
–2.7 to +4.5
–21 to –4.5
CFP2 modules
Figure 19 CFP2 optical transceiver module (MPO)
CFP2 optical transceiver modules (MPO) provide a transmission rate of 100 Gbps and use an MPO connector.
Table 25 Specifications for CFP2 optical transceiver modules (MPO) (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
CFP2-100G-SR10-MM850
850
MMF
50/125
20
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
Table 26 Specifications for CFP2 optical transceiver modules (MPO) (2)
Model
Connector
Transmit power
Receive power
MPO (PC polished, 24-fiber)
–7.6 to +2.4
–9.5 to +2.4
Figure 20 CFP2 optical transceiver module (dual LC)
CFP2 optical transceiver modules (dual LC) provide a transmission rate of 100 Gbps and use a dual LC connector.
Table 27 Specifications for CFP2 optical transceiver modules (dual LC) (1)
Model
Fiber mode
Fiber diameter (µm)
CFP2-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
10 km (6.21 miles)
CFP2-100G/112G-LR4-WDM1300
(end of sale)
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
10 km (6.21 miles)
CFP2-100G-ER4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
9/125
40 km (24.86 miles)
Table 28 Specifications for CFP2 optical transceiver modules (dual LC) (2)
Model
–4.3 to +4.5
–10.6 to +4.5
–4.3 to +4.5
–10.6 to +4.5
–2.7 to +2.9
–20.9 to +4.5
CXP modules
Figure 21 CXP optical transceiver module
CXP optical transceiver modules provide a transmission rate of 100 Gbps and use an MPO connector.
Table 29 Specifications for CXP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
CXP-100G-SR10-MM850
(end of sale)
850
MMF
50/125
20
2000
100 m (328.08 ft)
CXP-100G-SR10-MM850-A (end of sale)
850
MMF
50/125
20
2000
100 m (328.08 ft)
Table 30 Specifications for CXP optical transceiver modules (2)
Model
Connector
Transmit power
Receive power
CXP-100G-SR10-MM850
–7.6 to +2.4
–9.5 to +2.4
–7.6 to +2.4
–9.5 to +2.4
CXP optical cables
Figure 22 CXP optical cable
Table 31 Specifications for CXP optical cables
Model
Length
Transmission rate
CXP-CXP-AOC-30M (end of sale)
30 m (98.43 ft)
100 Gbps
CXP-CXP-AOC-10M (end of sale)
10 m (32.81 ft)
QSFP+ modules
Figure 23 QSFP+ optical transceiver module (MPO)
QSFP+ optical transceiver modules (MPO) provide a transmission rate of 40 Gbps and use an MPO connector.
Table 32 Specifications for QSFP+ optical transceiver modules (MPO) (1)
Model
Fiber mode
Fiber diameter (µm)
Fiber cores
QSFP-40G-SR4-MM850
850
MMF
50/125
8
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-SR4-MM850-H
850
MMF
50/125
8
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-SR4-MM850-CM
850
MMF
50/125
8
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-SR4-MM850-NDDM (end of sale)
850
MMF
50/125
8
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
MMF
50/125
8
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
QSFP-40G-CSR4-MM850-H
850
MMF
50/125
8
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
QSFP-40G-CSR4-MM850-NDDM (end of sale)
850
MMF
50/125
8
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
QSFP-40G-IR4-PSM1310 (end of sale)
1310
SMF
9/125
8
N/A
1.4 km (0.87 miles)
QSFP-40G-LR4-PSM1310
1310
SMF
9/125
8
N/A
10 km (6.21 miles)
QSFP-40G-LR4-PSM1310-A
1310
SMF
9/125
8
N/A
10 km (6.21 miles)
Table 33 Specifications for QSFP+ optical transceiver modules (MPO) (2)
Model
Connector
Transmit power
Receive power
QSFP-40G-SR4-MM850
–7.6 to 0
–9.5 to +2.4
–7.6 to +2.4
–9.5 to +2.4
–7.6 to 0
–9.5 to +2.4
–7.6 to 0
–9.5 to +2.4
QSFP-40G-CSR4-MM850
–7.6 to 0
–9.9 to +2.4
–7.6 to +2.4
–9.9 to +2.4
–7.6 to 0
–9.9 to +2.4
–6 to +0.5
–11.5 to +2.3
–8.2 to +1.5
–12.6 to +1.5
–8.2 to +1.5
–12.6 to +1.5
The 40G QSFP+ ports of the QSFP-40G-SR4-MM850, QSFP-40G-SR4-MM850-H, QSFP-40G-SR4-MM850-CM, QSFP-40G-SR4-MM850-NDDM, QSFP-40G-CSR4-MM850, QSFP-40G-CSR4-MM850-H, QSFP-40G-CSR4-MM850-NDDM, QSFP-40G-IR4-PSM1310, QSFP-40G-LR4-PSM1310, and QSFP-40G-LR4-PSM1310-A optical transceiver modules can be split into four channels. You can connect a 40G QSFP+ port to four 10G SFP+ ports. The QSFP+ optical transceiver module and SFP+ optical transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type.
Figure 24 QSFP+ optical transceiver module (dual LC)
QSFP+ optical transceiver modules (dual LC) provide a transmission rate of 40 Gbps and use a dual LC connector.
Table 34 Specifications for QSFP+ transceiver modules (dual LC) (1)
Model
Fiber mode
Fiber diameter (µm)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
2 km (1.24 miles)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
40 km (24.86 miles)
QSFP-40G-LX4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
MMF
50/125
2000
150 m (492.13 ft)
4700
QSFP-40G-BIDI-SR-MM850
Two lanes:
·     850
·     900
MMF
50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM1310 (end of sale)
Two lanes:
·     1271
·     1291
·     1311
·     1331
MMF
50/125
2000
140 m (459.32 ft)
4700
160 m (524.93 ft)
QSFP-40G-BIDI-WDM850
Two lanes:
·     850
·     880
·     910
·     940
MMF
50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
Table 35 Specifications for QSFP+ transceiver modules (dual LC) (2)
Model
–7 to +2.3
–13.7 to +2.3
–10 to +2.3
–11.5 to +2.3
–2.7 to +4.5
–21.2 to –4.5
–5 to +3.5
–10.5 to +3.5
–4 to +5
–6 to +5
–7 to +4.3
–10 to +4.3
–7.6 to +3
–9 to +3
·     The operating outer casing temperature of a QSFP-40G-BIDI-SR-MM850 transceiver module is in the range of 10°C to 70°C (50°F to 158°F). The performance, signal transmitting and receiving capability, and link status of the transceiver module deteriorate when the outer casing temperature is out of this range.
·     The display transceiver diagnosis command displays the current values of the digital diagnosis parameters on transceiver modules. However, if you use this command for a port in which a QSFP-40G-BIDI-SR-MM850 transceiver module is installed, the transmit and receive power of the transceiver module will not be displayed.
·     In the scenario where optical distribution frames (ODFs) are used, the transmission line from a QSFP-40G-LX4-WDM1300 transceiver module can pass through only one ODF if the ODFs use MPO interfaces and can pass through two ODFs if the ODFs use LC interfaces.
QSFP+ copper cables
Figure 25 QSFP+ copper cable
Table 36 Specifications for QSFP+ copper cables
Model
Length
Data rate
Remarks
LSWM1QSTK0
1 m (3.28 ft)
40 Gbps
QSFP+ copper cable
Used for interconnecting 40-Gigabit QSFP+ ports
LSWM1QSTK1
3 m (9.84 ft)
QSFP-40G-3M-CM
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
QSFP-40G-5M-CM
5 m (16.40 ft)
One end of a QSFP+ to SFP+ copper cable provides a QSFP+ module, and the other end provides four SFP+ modules.
Figure 26 QSFP+ to SFP+ copper cable
Table 37 Specifications for QSFP+ to SFP+ copper cables
Model
Length
Data rate
Cable type
Remarks
LSWM1QSTK3
1 m (3.28 ft)
40 Gbps
40G QSFP+ to 4 x 10G SFP+ copper cable
Used for connecting a 40-Gigabit QSFP+ port to four 10-Gigabit SFP+ ports
LSWM1QSTK4
3 m (9.84 ft)
QSFP-40G-4SFP-10G-CAB-3M-CM
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
QSFP-40G-4SFP-10G-CAB-5M-CM
5 m (16.40 ft)
Figure 27 QSFP+ optical cable
Table 38 Specifications for QSFP+ optical cables
Model
Length
Data rate
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
40 Gbps
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-7M-H
7 m (22.97 ft)
QSFP-40G-D-AOC-7M-CM
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-10M-H
10 m (32.81 ft)
QSFP-40G-D-AOC-10M-CM
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
QSFP-40G-D-AOC-20M-H
20 m (65.62 ft)
QSFP-40G-D-AOC-20M-CM
20 m (65.62 ft)
SFP28 modules
Figure 28 SFP28 optical transceiver module
SFP28 optical transceiver modules provide a transmission rate of 25 Gbps and use a dual LC connector.
Table 39 Specifications for SFP28 transceiver modules (1)
Model
Fiber mode
Fiber diameter (µm)
SFP-25G-SR-MM850
850
MMF
50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-SR-MM850-H
850
MMF
50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
*SFP-25G-LR-SM1310-I
1310
SMF
9/125
N/A
10 km (6.21 miles)
SFP-25G-CSR-MM850
850
MMF
50/125
2000
200 m (656.17 ft)
> 3500
300 m (984.25 ft)
> 5500
400 m (1312.34 ft)
Table 40 Specifications for SFP28 transceiver modules (2)
Model
Transmit power
Receive power
SFP-25G-SR-MM850
–8.4 to +2.4
–10.3 to +2.4
SFP-25G-SR-MM850-H
–8.4 to +2.4
–10.3 to +2.4
SFP-25G-LR-SM1310
–7 to +2
–13.3 to +2
–7 to +2
–13.3 to +2
SFP-25G-CSR-MM850
–6.4 to +2.4
–10.3 to +2.4
SFP28 copper cables
Figure 29 SFP28 copper cable
07-SFP+电缆
Table 41 Specifications for SFP28 copper cables
Model
Length
Data rate
SFP-25G-D-CAB-1M
1 m (3.28 ft)
25 Gbps
SFP-25G-D-CAB-1M-A
1 m (3.28 ft)
SFP-25G-D-CAB-2M-A
2 m (6.56 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-3M-CM
3 m (9.84 ft)
SFP-25G-D-CAB-3M-A
3 m (9.84 ft)
SFP-25G-D-CAB-4M-A
4 m (13.12 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP-25G-D-CAB-5M-A
5 m (16.40 ft)
SFP-25G-D-ACC-7M
7 m (22.97 ft)
SFP-25G-D-ACC-10M
10 m (32.81 ft)
Figure 30 SFP28 optical cable
Table 42 Specifications for SFP28 optical cables
Model
Length
Data rate
SFP-25G-D-AOC-3M
3 m (9.84 ft)
25 Gbps
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-5M-H
5 m (16.40 ft)
SFP-25G-D-AOC-5M-DG
5 m (16.40 ft)
SFP-25G-D-AOC-5M-DT
(end of sale)
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-7M-H
7 m (22.97 ft)
SFP-25G-D-AOC-7M-DG
7 m (22.97 ft)
SFP-25G-D-AOC-7M-DT
(end of sale)
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-10M-H
10 m (32.81 ft)
SFP-25G-D-AOC-10M-DG
10 m (32.81 ft)
SFP-25G-D-AOC-10M-DT
(end of sale)
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
SFP-25G-D-AOC-20M-H
20 m (65.62 ft)
SFP-25G-D-AOC-20M-DG
20 m (65.62 ft)
SFP-25G-D-AOC-20M-DT
(end of sale)
20 m (65.62 ft)
SFP+ modules
Figure 31 SFP+ optical transceiver module (dual LC)
SFP+ optical transceiver modules (dual LC) use a dual LC connector.
Table 43 Specifications for SFP+ optical transceiver modules (dual LC) (1)
Model
Fiber mode
Fiber diameter (µm)
Data rate
SFP-XG-SX-MM850-A
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-B (end of sale)
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
100 m (328.08 ft)
500
25 m (82.02 ft)
400
20 m (65.62 ft)
62.5/125
200
10 m (32.81 ft)
160
8 m (26.25 ft)
SFP-XG-SX-MM850-D
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-F1 (end of sale)
850
MMF
50/125
4700
400 m (1312.34 ft)
10.31 Gbps
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX220-MM1310 (end of sale)
1310
MMF
50/125
1500
220 m (721.78 ft)
10.31 Gbps
500
220 m (721.78 ft)
400
100 m (328.08 ft)
62.5/125
200
220 m (721.78 ft)
160
220 m (721.78 ft)
SFP-XG-LX-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
10.31 Gbps
SFP-XG-LX-SM1310-D
1310
SMF
9/125
N/A
10 km (6.21 miles)
10.31 Gbps
SFP-XG-LX-SM1310-S
1310
SMF
9/125
N/A
10 km (6.21 miles)
10.31 Gbps
SFP-XG-LX-SM1310-CM
1310
SMF
9/125
10 km (6.21 miles)
10.31 Gbps
SFP-XG-LX-SM1310-E
1310
SMF
9/125
N/A
10 km (6.21 miles)
10.31 Gbps
SFP-XG-LH40-SM1550
1550
SMF
9/125
N/A
40 km (24.86 miles)
10.31 Gbps
SFP-XG-LH40-SM1550-D
1550
SMF
9/125
N/A
40 km (24.86 miles)
10.31 Gbps
SFP-XG-LH80-SM1550
1550
SMF
9/125
N/A
80 km (49.71 miles)
10.31 Gbps
SFP-XG-LH80-SM1550-D
1550
SMF
9/125
N/A
80 km (49.71 miles)
10.31 Gbps
SFP-FC-8G-SW-MM850
850
MMF
62.5/125
200
150 m (492.13 ft)
2.125 Gbps
70 m (229.66 ft)
4.25 Gbps
21 m (68.90 ft)
8.5 Gbps
50/125
500
300 m (984.25 ft)
2.125 Gbps
150 m (492.13 ft)
4.25 Gbps
50 m (164.04 ft)
8.5 Gbps
2000
500 m (1640.42 ft)
2.125 Gbps
380 m (1246.72 ft)
4.25 Gbps
150 m (492.13 ft)
8.5 Gbps
4700
N/A
2.125 Gbps
400 m (1312.34 ft)
4.25 Gbps
190 m (623.36 ft)
8.5 Gbps
SFP-FC-8G-SW-MM850-CM
850
MMF
62.5/125
200
150 m (492.13 ft)
2.125 Gbps
70 m (229.66 ft)
4.25 Gbps
21 m (68.90 ft)
8.5 Gbps
50/125
500
300 m (984.25 ft)
2.125 Gbps
150 m (492.13 ft)
4.25 Gbps
50 m (164.04 ft)
8.5 Gbps
2000
500 m (1640.42 ft)
2.125 Gbps
380 m (1246.72 ft)
4.25 Gbps
150 m (492.13 ft)
8.5 Gbps
4700
N/A
2.125 Gbps
400 m (1312.34 ft)
4.25 Gbps
190 m (623.36 ft)
8.5 Gbps
SFP-FC-8G-LW-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
2.125 Gbps
4.25 Gbps
8.5 Gbps
SFP-FC-16G-SW-MM850
850
MMF
62.5/125
200
70 m (229.66 ft)
4.25 Gbps
21 m (68.90 ft)
8.5 Gbps
15 m (49.21 ft)
14.025 Gbps
50/125
500
150 m (492.13 ft)
4.25 Gbps
50 m (164.04 ft)
8.5 Gbps
35 m (114.83 ft)
14.025 Gbps
2000
380 m (1246.72 ft)
4.25 Gbps
150 m (492.13 ft)
8.5 Gbps
100 m (328.08 ft)
14.025 Gbps
4700
400 m (1312.33 ft)
4.25 Gbps
190 m (623.36 ft)
8.5 Gbps
125 m (410.11 ft)
14.025 Gbps
SFP-FC-16G-SW-MM850-CM
850
MMF
62.5/125
200
70 m (229.66 ft)
4.25 Gbps
21 m (68.90 ft)
8.5 Gbps
15 m (49.21 ft)
14.025 Gbps
50/125
500
150 m (492.13 ft)
4.25 Gbps
50 m (164.04 ft)
8.5 Gbps
35 m (114.83 ft)
14.025 Gbps
2000
380 m (1246.72 ft)
4.25 Gbps
150 m (492.13 ft)
8.5 Gbps
100 m (328.08 ft)
14.025 Gbps
4700
400 m (1312.33 ft)
4.25 Gbps
190 m (623.36 ft)
8.5 Gbps
125 m (410.11 ft)
14.025 Gbps
SFP-FC-16G-LW-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
4.25 Gbps
8.5 Gbps
14.025 Gbps
SFP-FC-16G-LW-SM1310-CM
1310
SMF
9/125
N/A
10 km (6.21 miles)
4.25 Gbps
8.5 Gbps
14.025 Gbps
SFP-FC-32G-SW-MM850
850
MMF
62.5/125
200
21 m (68.90 ft)
8.5 Gbps
15 m (49.21 ft)
14.025 Gbps
N/A
28.05 Gbps
50/125
500
50 m (164.04 ft)
8.5 Gbps
35 m (114.83 ft)
14.025 Gbps
20 m (65.62 ft)
28.05 Gbps
2000
150 m (492.13 ft)
8.5 Gbps
100 m (328.08 ft)
14.025 Gbps
70 m (229.66 ft)
28.05 Gbps
4700
190 m (623.36 ft)
8.5 Gbps
125 m (410.11 ft)
14.025 Gbps
100 m (328.08 ft)
28.05 Gbps
SFP-FC-32G-SW-MM850-CM
850
MMF
62.5/125
200
21 m (68.90 ft)
8.5 Gbps
15 m (49.21 ft)
14.025 Gbps
N/A
28.05 Gbps
50/125
500
50 m (164.04 ft)
8.5 Gbps
35 m (114.83 ft)
14.025 Gbps
20 m (65.62 ft)
28.05 Gbps
2000
150 m (492.13 ft)
8.5 Gbps
100 m (328.08 ft)
14.025 Gbps
70 m (229.66 ft)
28.05 Gbps
4700
190 m (623.36 ft)
8.5 Gbps
125 m (410.11 ft)
14.025 Gbps
100 m (328.08 ft)
28.05 Gbps
SFP-XG-LH80-Tunable
(end of sale)
1547.75
SMF
9/125
N/A
80 km (49.71 miles)
9.95 to 11.3 Gbps
*SFP-XG-CPRI-IR-SM1310
1310
SMF
9/125
N/A
1.4 km (0.87 miles)
4.91 to 10.31 Gbps
*SFP-XG-CPRI-LR-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
4.91 to 10.31 Gbps
SFP-XG-LX-SM1270-BIDI
Transmitting end (TX): 1270
Receiving end (RX): 1330
SMF
9/125
N/A
10 km (6.21 miles)
10.31Gbps
SFP-XG-LX-SM1270-BIDI-S
SMF
9/125
N/A
10 km (6.21 miles)
10.31Gbps
SFP-XG-LX-SM1330-BIDI
Transmitting end (TX): 1330
Receiving end (RX): 1270
SMF
9/125
N/A
10 km (6.21 miles)
10.31Gbps
SFP-XG-LX-SM1330-BIDI-S
SMF
9/125
N/A
10 km (6.21 miles)
10.31Gbps
SFP-XG-LH40-SM1270-BIDI
SMF
9/125
N/A
40 km (24.86 miles)
10.31Gbps
SFP-XG-LH40-SM1330-BIDI
SMF
9/125
N/A
40 km (24.86 miles)
10.31Gbps
SFP-XG-LH80-SM1490-BIDI
Transmitting end (TX): 1490
Receiving end (RX): 1550
SMF
9/125
N/A
80 km (49.71 miles)
10.31Gbps
SFP-XG-LH80-SM1550-BIDI
Transmitting end (TX): 1550
Receiving end (RX): 1490
SMF
9/125
N/A
80 km (49.71 miles)
10.31Gbps
·     BIDI optical transceiver modules use different central wavelengths in transmit and receive directions, in order to implement bidirectional transmission of optical signals over the same fiber.
·     You must use the SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules in pairs.
Table 44 Specifications for SFP+ optical transceiver modules (dual LC) (2)
Model
Transmit power
Receive power
SFP-XG-SX-MM850-A
–7.3 to –1
–9.9 to +0.5
SFP-XG-SX-MM850-B
–7.3 to –1
–9.9 to +0.5
SFP-XG-SX-MM850-D
–7.3 to –1
–9.9 to +0.5
SFP-XG-SX-MM850-S
–7.3 to –1
–9.9 to +0.5
SFP-XG-SX-MM850-E
–7.3 to –1
–9.9 to +0.5
SFP-XG-SX-MM850-F1
–7.3 to –1
–9.9 to +0.5
SFP-XG-LX220-MM1310
–6.5 to +0.5
–6.5 to +1.5
SFP-XG-LX-SM1310
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LX-SM1310-D
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LX-SM1310-S
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LX-SM1310-CM
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LX-SM1310-E
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LH40-SM1550
–4.7 to +4
–15.8 to –1
–4.7 to +4
–15.8 to –1
SFP-XG-LH80-SM1550
0 to +4
–24 to –7
0 to +4
–24 to –7
SFP-FC-8G-SW-MM850
–10 to 0 (2.125 Gbps)
–13.1 to 0 (2.125 Gbps)
–9 to 0 (4.25 Gbps)
–12.1 to 0 (4.25 Gbps)
–8.2 to 0 (8.5 Gbps)
–11.2 to 0 (8.5 Gbps)
SFP-FC-8G-LW-SM1310
–9.5 to –3 (2.125 Gbps)
–18.2 to –3 (2.125 Gbps)
–8.4 to –1 (4.25 Gbps)
–15.4 to –1 (4.25 Gbps)
–8.4 to +0.5 (8.5 Gbps)
–13.8 to +0.5 (8.5 Gbps)
SFP-FC-16G-SW-MM850
–9 to 0 (4.25 Gbps)
–7.8 to 0 (14.025 Gbps)
–10.5 to 0 (14.025 Gbps)
–9 to 0 (4.25 Gbps)
–5 to +2 (14.025 Gbps)
–12 to +2 (14.025 Gbps)
SFP-FC-32G-SW-MM850
–6.2 to +2 (28.05 Gbps)
–10.2 to +2 (28.05 Gbps)
SFP-XG-LH80-Tunable
–1 to +3
–24 to –7
–8.2 to +0.5
–14.4 to +0.5
–8.2 to +0.5
–14.4 to +0.5
-8.2 to -0.5
–14.4 to +0.5
-8.2 to -0.5
–14.4 to +0.5
-8.2 to -0.5
–14.4 to +0.5
-8.2 to -0.5
–14.4 to +0.5
0 to +5
–15 to +0.5
0 to +5
–15 to +0.5
0 to +4
–23 to –6
–1 to +3
–23 to –6
·     A mode conditioning patch cord is required when you use OM1 or OM2 fiber types on an SFP-XG-LX220-MM1310. No mode conditioning patch cords are required for OM3 fiber types. For more information about mode conditioning patch cords, see the IEEE 802.3 standard.
·     The SFP-XG-LH80-Tunable module supports wavelength adjustment. Cold-starting of the module takes a longer time (usually not exceeding 90 seconds) than other SFP+ modules.
Figure 32 SFP+ optical transceiver module (SC)
Table 45 Specifications for SFP+ optical transceiver modules (SC) (1)
Model
Fiber mode
Fiber diameter (µm)
SFP-XG-PR30-U-SM1270
·     Transmitting end (TX): 1270
·     Receiving end (RX): 1577.5
SMF
9/125
20 km (12.43 miles)
SFP-XG-PRX30-U-SM1310
·     Transmitting end (TX): 1310
SMF
9/125
20 km (12.43 miles)
Table 46 Specifications for SFP+ optical transceiver modules (SC) (2)
Model
Data rate (Gbps)
Receiving end (RX)
Transmit power
Receive power
10.3125
10.3125
+4 to +9
–10 to –28.5
1.25
10.3125
+0.62 to +5.62
–10 to –28.5
A 10G EPON OLT SFP+ optical transceiver module uses an SC connector.
Figure 33 10G EPON OLT SFP+ optical transceiver module (SC)
Table 47 Specifications for 10G EPON OLT SFP+ optical transceiver modules (SC) (1)
Model
Fiber mode
Fiber diameter (µm)
SFP-XG-PR30-D-SM1577-A (end of sale)
·     Tx/Rx rate—10.3125 Gbps
¡     Tx: 1577.5
¡     Rx: 1270
·     Tx/Rx rate—1.25 Gbps
¡     Tx:  1490
¡     Rx: 1310
SMF
9/125
20 km (12.43 miles)
SFP-XG-PR30-D-SM1577-C
¡     Tx: 1577.5
¡     Rx: 1270
¡     Tx:  1490
¡     Rx: 1310
SMF
9/125
20 km (12.43 miles)
SFP-XG-PR40-D-SM1577-A (end of sale)
¡     Tx: 1577.5
¡     Rx: 1270
¡     Tx: 1490
¡     Rx: 1310
SMF
9/125
20 km (12.43 miles)
SFP-XG-PR40-D-SM1577-C
¡     Tx: 1577.5
¡     Rx: 1270
¡     Tx: 1490
¡     Rx: 1310
SMF
9/125
20 km (12.43 miles)
Table 48 Specifications for 10G EPON OLT SFP+ optical transceiver modules (SC) (2)
Model
Data rate (Gbps)
Tx
Rx
Tx power
Rx power
10.3125
10.3125
+2 to +5
–6 to –28
1.25
1.25
+3 to +7
–9.38 to –29.78
10.3125
10.3125
+2 to +5
–6 to –28
1.25
1.25
+3 to +7
–9.38 to –29.78
10.3125
10.3125
+5 to +9
–9 to –29
1.25
1.25
+4 to +10
–12 to –32
10.3125
10.3125
+5 to +9
–9 to –29
1.25
1.25
+4 to +10
–12 to –31
The optical power budget is 29 dBm for the SFP-XG-PR30-D-SM1577-A and SFP-XG-PR30-D-SM1577-C transceiver modules and 33 dBm for the SFP-XG-PR40-D-SM1577-A and SFP-XG-PR40-D-SM1577-C transceiver modules.
Figure 34 SFP+ copper transceiver module
Table 49 SFP+ copper transceiver module specifications
Model
Data rate
Cable type
Connector type
SFP-10GE-T
30 m (98.43 ft)
10 Gbps
Category 6a STP or Category 7 STP
RJ-45
100 m (328.08 ft)
1000/100 Mbps
Category 5e UTP/STP
Support for data rate autonegotiation of depends on the device model.
SFP+ copper cables
Figure 35 SFP+ copper cable
07-SFP+电缆
Table 50 Specifications for SFP+ copper cables
Model
Length
Data rate
LSWM1STK
0.65 m (2.13 ft)
10.31 Gbps
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
SFP-XG-CAB-3M-CM
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
LSTM1STK-S
5 m (16.40 ft)
SFP-XG-CAB-5M-CM
5 m (16.40 ft)
LSTM2STK
7 m (22.97 ft)
SFP+ optical cables
Figure 36 SFP+ optical cable
Table 51 Specifications for SFP+ optical cables
Model
Length
Data rate
SFP-XG-D-AOC-7M
7 m (22.97 ft)
10.31 Gbps
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
XFP modules
Figure 37 XFP optical transceiver module (dual LC)
Table 52 Specifications for XFP optical transceiver modules (dual LC) (1)
Model
Data rate (Gbps)
Fiber mode
Fiber diameter (µm)
XFP-SX-MM850
850
9.95 to 10.31
MMF
50/125
4700
400 m (1312.34 ft)
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
XFP-SX-MM850-D
850
9.95 to 10.31
MMF
50/125
4700
400 m (1312.34 ft)
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
XFP-LX-SM1310
1310
9.95 to 10.31
SMF
9/125
N/A
10 km (6.21 miles)
XFP-LX-SM1310-D
1310
9.95 to 10.31
SMF
9/125
N/A
10 km (6.21 miles)
XFP-POS-LH10-SM1310
1310
9.95 to 11.3
SMF
9/125
N/A
10 km (6.21 miles)
XFP-LH40-SM1550 (end of sale)
1550
9.95 to 10.7
SMF
9/125
N/A
40 km (24.86 miles)
XFP-LH40-SM1550-D
1550
9.95 to 10.7
SMF
9/125
N/A
40 km (24.86 miles)
XFP-LH40-SM1550-F1
1550
9.95 to 10.7
SMF
9/125
N/A
40 km (24.86 miles)
XFP-LH80-SM1550
1550
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LH80-SM1550-D
1550
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1530.33 (end of sale)
1530.33
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1531.12 (end of sale)
1531.12
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1531.90 (end of sale)
1531.90
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1532.68 (end of sale)
1532.68
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1534.25 (end of sale)
1534.25
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1535.04 (end of sale)
1535.04
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1535.82 (end of sale)
1535.82
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1536.61 (end of sale)
1536.61
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1538.19 (end of sale)
1538.19
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1538.98 (end of sale)
1538.98
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1539.77 (end of sale)
1539.77
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1540.56 (end of sale)
1540.56
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1542.14 (end of sale)
1542.14
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1542.94 (end of sale)
1542.94
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1543.73 (end of sale)
1543.73
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1544.53 (end of sale)
1544.53
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1546.12 (end of sale)
1546.12
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1546.92 (end of sale)
1546.92
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1547.72 (end of sale)
1547.72
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1548.51 (end of sale)
1548.51
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1550.12 (end of sale)
1550.12
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1550.92 (end of sale)
1550.92
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1551.72 (end of sale)
1551.72
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1552.52 (end of sale)
1552.52
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1554.13 (end of sale)
1554.13
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1554.94 (end of sale)
1554.94
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1555.75 (end of sale)
1555.75
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1556.55 (end of sale)
1556.55
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1558.17 (end of sale)
1558.17
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1558.98 (end of sale)
1558.98
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1559.79 (end of sale)
1559.79
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
XFP-LX-SM1560.61 (end of sale)
1560.61
9.95 to 10.31
SMF
9/125
N/A
80 km (49.71 miles)
Table 53 Specifications for XFP optical transceiver modules (dual LC) (2)
Model
Transmit power
Receive power
XFP-SX-MM850
–7.3 to –1.08
–9.9 to –1
XFP-SX-MM850-D
–7.3 to –1.08
–9.9 to –1
XFP-LX-SM1310
–8.2 to +0.5
–14.4 to +0.5
XFP-LX-SM1310-D
–8.2 to +0.5
–14.4 to +0.5
XFP-POS-LH10-SM1310
–6 to –1
–10.3 to +0.5
XFP-LH40-SM1550
–1 to +2
–14 to –1
XFP-LH40-SM1550-D
–1 to +2
–14 to –1
XFP-LH40-SM1550-F1
–1 to +2
–14.1 to –1
XFP-LH80-SM1550
0 to +4
–24 to –7
XFP-LH80-SM1550-D
0 to +4
–24 to –7
XFP-LX-SM1530.33
–1 to +3
–24 to –7
XFP-LX-SM1531.12
–1 to +3
–24 to –7
XFP-LX-SM1531.90
–1 to +3
–24 to –7
XFP-LX-SM1532.68
–1 to +3
–24 to –7
XFP-LX-SM1534.25
–1 to +3
–24 to –7
XFP-LX-SM1535.04
–1 to +3
–24 to –7
XFP-LX-SM1535.82
–1 to +3
–24 to –7
XFP-LX-SM1536.61
–1 to +3
–24 to –7
XFP-LX-SM1538.19
–1 to +3
–24 to –7
XFP-LX-SM1538.98
–1 to +3
–24 to –7
XFP-LX-SM1539.77
–1 to +3
–24 to –7
XFP-LX-SM1540.56
–1 to +3
–24 to –7
XFP-LX-SM1542.14
–1 to +3
–24 to –7
XFP-LX-SM1542.94
–1 to +3
–24 to –7
XFP-LX-SM1543.73
–1 to +3
–24 to –7
XFP-LX-SM1544.53
–1 to +3
–24 to –7
XFP-LX-SM1546.12
–1 to +3
–24 to –7
XFP-LX-SM1546.92
–1 to +3
–24 to –7
XFP-LX-SM1547.72
–1 to +3
–24 to –7
XFP-LX-SM1548.51
–1 to +3
–24 to –7
XFP-LX-SM1550.12
–1 to +3
–24 to –7
XFP-LX-SM1550.92
–1 to +3
–24 to –7
XFP-LX-SM1551.72
–1 to +3
–24 to –7
XFP-LX-SM1552.52
–1 to +3
–24 to –7
XFP-LX-SM1554.13
–1 to +3
–24 to –7
XFP-LX-SM1554.94
–1 to +3
–24 to –7
XFP-LX-SM1555.75
–1 to +3
–24 to –7
XFP-LX-SM1556.55
–1 to +3
–24 to –7
XFP-LX-SM1558.17
–1 to +3
–24 to –7
XFP-LX-SM1558.98
–1 to +3
–24 to –7
XFP-LX-SM1559.79
–1 to +3
–24 to –7
XFP-LX-SM1560.61
–1 to +3
–24 to –7
Figure 38 10G EPON OLT XFP optical transceiver module (SC)
Table 54 Specifications for 10G EPON OLT XFP optical transceiver modules (SC) (1)
Model
Fiber mode
Fiber diameter (µm)
XFP-PR30-D-SM1577
·     Data rate of 10.3125 Gbps at both the transmitting end (TX) and receiving end (RX)
¡     TX: 1577.5
¡     RX: 1270
·     Data rate of 1.25 Gbps at both the TX and RX
¡     TX: 1490
¡     RX: 1310
SMF
9/125
20 km (12.43 miles)
XFP-PRX30-D-SM1577
·     Data rate of 10.3125 Gbps at the TX and 1.25 Gbps at the RX
¡     TX: 1577.5
¡     RX: 1310
¡     TX: 1490
¡     RX: 1310
SMF
9/125
20 km (12.43 miles)
Table 55 Specifications for 10G EPON OLT XFP optical transceiver modules (SC) (2)
Model
Data rate (Gbps)
Receiving end (RX)
Transmit power
Receive power
XFP-PR30-D-SM1577
10.3125
10.3125
+2 to +5
–6 to –28
1.25
1.25
+3 to +7
–9.38 to –29.8
XFP-PRX30-D-SM1577
10.3125
1.25
+2 to +5
–9.38 to –29.8
1.25
+3 to +7
To accurately measure the optical power of 10G EPON OLT or ONU ports, use an optical power meter specially designed for 10G EPON, for example VIAVI OLP-87 used by H3C,
CX4 cables
Figure 39 CX4 cable
09-CX4电缆
Table 56 Specifications for CX4 cables
Model
Length
Data rate
LSPM2STKA
0.5 m (1.64 ft)
12 Gbps
CX4 cable
LSPM2STKB
1 m (3.28 ft)
LSPM2STKC
3 m (9.84 ft)
SFP modules
Figure 40 2.5-Gigabit/Gigabit/622-Megabit/100-Megabit SFP optical transceiver module
2.5-Gigabit SFP optical transceiver modules use a dual LC connector.
Table 57 Specifications for 2.5-Gigabit SFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-2.5G-LX-SM1310
1310
SMF
9/125
2 km (1.24 miles)
*SFP-2.5G-LX10-SM1310-DR-I
1310
SMF
9/125
10 km (6.21 miles)
SFP-2.5G-LH15-SM1310
1310
SMF
9/125
15 km (9.32 miles)
SFP-2.5G-LH40-SM1310
(end of sale)
1310
SMF
9/125
40 km (24.86 miles)
SFP-2.5G-LH80-SM1550 (end of sale)
1550
SMF
9/125
80 km (49.71 miles)
Table 58 Specifications for 2.5-Gigabit SFP optical transceiver modules (2)
Model
Transmit power
Receive power
SFP-2.5G-LX-SM1310
–10 to –3
–18 to –3
–5 to –0.5
–14.4 to –0.5
–5 to 0
–18 to 0
–2 to +3
–27 to –9
–20 to –14
–31 to –12
Figure 41 SFP GPON ONU optical transceiver module
Gigabit GPON ONU optical transceiver modules provide a transmission rate of 1250 Mbps and use an SC connector.
Table 59 Specifications for SFP GPON ONU optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
*SFP-GPON-ONU-STICK-BP-SM1310-I
TX: 1310
RX: 1490
SMF
9/125
20 km (12.43 miles)
Table 60 Specifications for SFP GPON ONU optical transceiver modules (2)
Model
Transmission rate (Gbps)
Tx
Rx
Transmit power
Receive power
1.25
2.5
+0.5 to +5
–27 to –8
IMPORTANT
IMPORTANT:
·     The SFP-GPON-ONU-STICK-BP-SM1310-I is a Class B+ GPON ONU optical transceiver module. As a best practice, use it in pair with a Class B+ GPON OLT transceiver module.
·     The optical power budget for the SFP-GPON-ONU-STICK-BP-SM1310-I transceiver module is 28 dBm.
Figure 42 SFP GPON OLT optical transceiver module
Gigabit GPON OLT optical transceiver modules provide a transmission rate of 1250 Mbps and use an SC connector.
Table 61 Specifications for SFP GPON OLT optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
TX: 1490
RX: 1310
SMF
9/125
20 km (12.43 miles)
SFP-GPON-C+-D-SM1490
TX: 1490
RX: 1310
SMF
9/125
20 km (12.43 miles)
SFP-GPON-C++-D-SM1490
TX: 1490
RX: 1310
SMF
9/125
20 km (12.43 miles)
Table 62 Specifications for SFP GPON OLT optical transceiver modules (2)
Model
Tx
Rx
Transmit power
Receive power
SFP-GPON-B+-D-SM1490
2.5
1.25
+1.5 to +5
–8 to –28
2.5
1.25
+3 to +7
–12 to –30
2.5
1.25
+6 to +10
–12 to –33
IMPORTANT
IMPORTANT:
·     The SFP-GPON-B+-D-SM1490 is a Class B+ GPON OLT optical transceiver module. As a best practice, use it in pair with a Class B+ GPON ONU transceiver module.
·     The SFP-GPON-C+-D-SM1490 is a Class C+ GPON OLT optical transceiver module.
·     The SFP-GPON-C++-D-SM1490 is a Class C++ GPON OLT optical transceiver module.
·     The optical power budget for an SFP-GPON-B+-D-SM1490 transceiver is 28 dBm.
·     The optical power budget for an SFP-GPON-C+-D-SM1490 transceiver is 32 dBm.
·     The optical power budget for an SFP-GPON-C++-D-SM1490 transceiver is 33 dBm.
See Figure 40 for a view of the Gigabit SFP optical transceiver module.
Gigabit SFP optical transceiver modules provide a transmission rate of 1250 Mbps and use a dual LC connector.
Table 63 Specifications for Gigabit SFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-GE-SX-MM850-A
850
MMF
50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-CM
850
MMF
50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
MMF
50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
MMF
50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
SMF
9/125
N/A
10 km (6.21 miles)
MMF
50/125
500 or 400
550 m (1804.46 ft)
62.5/125
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-C
1310
SMF
9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-D
1310
SMF
9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
SMF
9/125
N/A
10 km (6.21 miles)
*SFP-GE-LX10-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
SFP-GE/FE-LX10-SM1310
1310
SMF
9/125
N/A
10 km (6.21 miles)
*SFP-GE-LH20-SM1310-I
1310
SMF
9/125
N/A
20 km (12.43 miles)
*SFP-GE-LH40-SM1310-I
1310
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-S
1310
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-S
1550
SMF
9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
SMF
9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
SMF
9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
SMF
9/125
N/A
100 km (62.14 miles)
Table 64 Specifications for Gigabit SFP optical transceiver modules (2)
Model
Transmit power
Receive power
SFP-GE-SX-MM850-A
–9.5 to 0
–17 to –3
SFP-GE-SX-MM850-CM
-9.5 to 0
-17 to –3
SFP-GE-SX-MM850-D
–9.5 to 0
–17 to –3
SFP-GE-SX-MM850-S
–9.5 to 0
–17 to –3
SFP-GE-LX-SM1310-A
–9.5 to –3
–20 to –3
SFP-GE-LX-SM1310-C
–9.5 to –3
–20 to –3
SFP-GE-LX-SM1310-D
–9.5 to –3
–20 to –3
SFP-GE-LX-SM1310-S
–9.5 to –3
–20 to –3
*SFP-GE-LX10-SM1310
–11 to –3
–19 to –3
–9.5 to –3
–22 to –3
–8 to –3
–23 to –3
–5 to 0
–23 to –3
SFP-GE-LH40-SM1310
–5 to +5
–22 to –3
–5 to +5
–22 to –3
–5 to +5
–22 to –3
SFP-GE-LH40-SM1550
–4 to +1
–21 to –3
–4 to +1
–21 to –3
SFP-GE-LH80-SM1550
–4 to +5
–22 to –3
–4 to +5
–22 to –3
SFP-GE-LH100-SM1550
0 to +5
–30 to –9
The transmission distance of the SFP-GE-LH80-SM1550 and SFP-GE-LH80-SM1550-D transceiver modules might be displayed as 70 km (43.50 miles) on H3C devices with old software versions. Devices with upgraded software versions can correctly display the distance. The actual transmission distance is 80 km (49.71 miles).
622-Megabit SFP optical transceiver modules
See Figure 40 for a view of the 622-Megabit SFP optical transceiver module.
622-Megabit SFP optical transceiver modules use a dual LC connector.
Table 65 Specifications for 622-Megabit SFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-622M-LX-SM1310
1310
SMF
9/125
15 km (9.32 miles)
SFP-622M-LH40-SM1310
1310
SMF
9/125
40 km (24.86 miles)
SFP-622M-LH80-SM1550
1550
SMF
9/125
80 km (49.71 miles)
Table 66 Specifications for 622-Megabit SFP optical transceiver modules (2)
Model
Transmit power
Receive power
SFP-622M-LX-SM1310
–15 to –8
–28 to –8
–3 to +2
–28 to –8
–3 to +2
–28 to –8
100-Megabit SFP optical transceiver modules
See Figure 40 for a view of the 100-Megabit SFP optical transceiver module.
Models and specifications
100-Megabit SFP optical transceiver modules provide a maximum transmission rate of 155 Mbps and use a dual LC connector.
Table 67 Specifications for 100-Megabit SFP optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-FE-SX-MM1310-A
1310
MMF
50/125
2 km (1.24 miles)
62.5/125
SFP-FE-SX-MM1310-GE (end of sale)
1310
MMF
50/125
2 km (1.24 miles)
62.5/125
1310
SMF
9/125
10 km (6.21 miles)
SFP-FE-LX-SM1310-A
1310
SMF
9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
SMF
9/125
15 km (9.32 miles)
*SFP-FE-BX15-U-SM1310
1310
SMF
9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
SMF
9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
SMF
9/125
80 km (49.71 miles)
Table 68 Specifications for 100-Megabit SFP optical transceiver modules (2)
Model
Transmit power
Receive power
SFP-FE-SX-MM1310-A
–19 to –14
–30 to –14
SFP-FE-SX-MM1310-GE
–20 to –14
–31.5 to –8
–15 to –8
–28 to –8
SFP-FE-LX-SM1310-A
–15 to –8
–28 to –7
SFP-FE-LX-SM1310-D
–15 to –8
–28 to –7
–15 to –8
–28 to –8
SFP-FE-LH40-SM1310
–5 to 0
–34 to –9
SFP-FE-LH80-SM1550
–5 to 0
–34 to –10
Gigabit BIDI optical transceiver modules
Figure 43 Gigabit/100-Megabit BIDI optical transceiver module
Gigabit BIDI optical transceiver modules provide a transmission rate of 1250 Mbps and use a dual LC connector.
Table 69 Specifications for Gigabit BIDI optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-GE-LX-SM1310-BIDI
·     Receiving end (RX): 1490
SMF
9/125
10 km (6.21 miles)
SFP-GE-LX-SM1310-BIDI-S
SMF
9/125
10 km (6.21 miles)
*SFP-GE-LX-SM1310-BIDI-I
SMF
9/125
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
·     Transmitting end (TX): 1490
·     Receiving end (RX): 1310
SMF
9/125
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-S
SMF
9/125
10 km (6.21 miles)
*SFP-GE-LX-SM1490-BIDI-I
SMF
9/125
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
·     Receiving end (RX): 1550
SMF
9/125
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
·     Transmitting end (TX): 1550
SMF
9/125
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
SMF
9/125
70 km (43.50 miles)
Table 70 Specifications for Gigabit BIDI optical transceiver modules (2)
Model
Transmit power
Receive power
–9 to –3
–18.7 to –3
–9 to –3
–20 to –3
–5 to 0
–23 to –3
–3 to +5
–23 to –3
·     You must use the SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules in pairs.
100-Megabit BIDI optical transceiver modules
See Figure 43 for a view of the 100-Megabit BIDI optical transceiver module.
100-Megabit BIDI optical transceiver modules provide a transmission rate of 155 Mbps and use a dual LC connector.
Table 71 Specifications for 100-Megabit BIDI optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
SFP-FE-LX-SM1310-BIDI
SMF
9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
SMF
9/125
15 km (9.32 miles)
Table 72 Specifications for 100-Megabit BIDI optical transceiver modules (2)
Model
Transmit power
Receive power
–15 to –8
–31 to –3
·     You must use the SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules in pairs.
BIDI GEPON OLT optical transceiver modules (SC)
Figure 44 BIDI GEPON OLT optical transceiver module
BIDI GEPON OLT optical transceiver modules provide a transmission rate of 1250 Mbps and use an SC connector.
Table 73 Specifications for BIDI GEPON OLT optical transceiver modules (1)
External model
Fiber mode
Fiber diameter (µm)
SFP-GE-PX10-D-SM1490-A (end of sale)
SMF
9/125
10 km (6.21 miles)
SFP-GE-PX20-D-SM1490-A (end of sale)
SMF
9/125
20 km (12.43 miles)
SFP-GE-PX20-D-SM1490-M
SMF
9/125
20 km (12.43 miles)
Table 74 Specifications for BIDI GEPON OLT optical transceiver modules (2)
External model
Connector index (dBm)
Output fiber power
Fiber saturation
–3 to +2
≤ –24
≤ –3
+2 to +7
≤ –30
≤ –10
+2 to +7
≤ –28
≤ –6
·     BIDI GEPON OLT optical transceiver module is a kind of Gigabit SFP module specially used for EPON OLT end devices. The fiber signals transmitted through SFP-GE-PX10-D-SM1490-A module can be used for only the ONU devices with a transmission distance of 10 km (6.2 miles).
·     When testing the fiber power of EPON OLT and ONU ports, please use the fiber power meter dedicated for EPON (the fiber power meter model used in H3C is JDSU OLP-57) to ensure the correctness of the test result.
Gigabit CWDM optical transceiver modules (LC)
Figure 45 Gigabit CWDM optical transceiver module
Gigabit CWDM optical transceiver modules provide a transmission rate of 1250 Mbps and use a dual LC connector.
Table 75 Specifications for Gigabit CWDM optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (µm)
SFP-GE-LH70-SM1470-CW (end of sale)
1470
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1490-CW (end of sale)
1490
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1510-CW (end of sale)
1510
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1530-CW (end of sale)
1530
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1550-CW (end of sale)
1550
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1570-CW (end of sale)
1570
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1590-CW (end of sale)
1590
SMF
9/125
70 km (43.50 miles)
SFP-GE-LH70-SM1610-CW (end of sale)
1610
SMF
9/125
70 km (43.50 miles)
Table 76 Specifications for Gigabit CWDM optical transceiver modules (2)
Model
Transmit power
Receive power
0 to +5
–23 to –3
·     Gigabit CWDM optical transceiver modules adopt the CWDM technology that uses wavelength division multiplexers to multiplex optical signals with different wavelengths for transmission over a single optical fiber, thereby saving optical fiber resources. The receiving end uses a wavelength division demultiplexer to demultiplex the multiplexed optical signals.
·     The most recent software version of H3C networking devices might display the transmission distance of the Gigabit CWDM optical transceiver module as 80 km (49.71 miles). The CWDM optical transceiver module can transmit data over 80 km (49.71 miles) when the fiber link meets the budget.
Gigabit SFP copper transceiver modules
Figure 46 Gigabit SFP copper transceiver module
Table 77 Specifications for Gigabit SFP copper transceiver modules
Model
Data rate
Connector type
SFP-GE-T
100 m (328.08 ft)
1250 Mbps
RJ-45
SFP-GE-T-CM
100 m (328.08 ft)
1250 Mbps
RJ-45
SFP-GE-T-D
100 m (328.08 ft)
1250 Mbps
RJ-45
IMPORTANT
IMPORTANT:
As a best practice, use shielded twisted pair (STP) cables for Gigabit SFP copper transceiver modules for better transmission performance.
Gigabit SFP copper cables
Figure 47 Gigabit SFP copper cable
05-SFP堆叠电缆
Table 78 Specifications for Gigabit SFP copper cables
Model
Data rate
Cable type
SFP-STACK-Kit
1.5 m (4.92 ft)
1250 Mbps
UTP/STP
SFP-STACK-Kit-S
1.5 m (4.92 ft)
1250 Mbps
UTP/STP
To transmit data and supply or receive power, use PoE optical transceiver modules together with the photoelectric hybrid cables.
Figure 48 SFP+ PoE optical transceiver module (dual PELC connectors)
SFP+ PoE optical transceiver modules use PELC connectors and provide a transmission rate of 10 Gbps, 5 Gbps, 2.5 Gbps, or 1 Gbps.
Table 79 Specifications for SFP+ PoE optical transceiver modules (1)
Model
Central wavelength (nm)
Fiber mode
Fiber diameter (μm)
*SFP-XG-POE-MR
1310
SMF
9/125
1.4 km (0.87 miles)
Table 80 Specifications for SFP+ PoE optical transceiver modules (2)
Model
Transmit power
Receive power
*SFP-XG-POE-MR
–8.2 to +0.5
–12.6 to +0.5
SFP PoE optical transceiver modules
Figure 49 SFP PoE optical transceiver module (dual PELC connectors)
SFP PoE optical transceiver modules provide a transmission rate of 1250 Mbps and use PELC connectors.
Table 81 Specifications for SFP PoE optical transceiver modules (1)
Model
Fiber mode
Fiber diameter (μm)
*SFP-GE-POE
1310
SMF
9/125
10 km (6.21 miles)
Table 82 Specifications for SFP PoE optical transceiver modules (2)
Model
Transmit power
Receive power
*SFP-GE-POE
–9 to –1
–18.7 to –3
Fiber PoE patch cords
Figure 50 Fiber PoE patch cord
Table 83 Specifications for fiber PoE patch cords
Model
Length
PoE-PELC-PELC-0.3
0.3 m (0.98 ft)
PoE-PELC-PELC-1.5
1.5 m (4.92 ft)
PoE-PELC-PELC-3.0
3.0 m (9.84 ft)
Fiber PoE pigtail
Figure 51 Fiber PoE pigtail
Table 84 Specifications for fiber PoE pigtails
Model
Length
PoE-PELC-ODF-0.4m
0.4 m (1.31 ft)
PoE-PELC-ODF-1.2m
1.2 m (3.94 ft)
  • Become a Partner
  • Partner Resources
