H3C IE4320 Industrial Switch Series Hardware Information and Specifications-6W100
HomeSupportResource CenterSwitchesIE Series Industrial Ethernet SwitchesIE4320 SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C IE4320 Industrial Switch Series Hardware Information and Specifications-6W100
01-Text
01-Text 3.64 MB
1 Product models and technical specifications
Product models
This document is applicable to the IE4320 industrial switch series. Table1-1 describes the IE4320 industrial switch models.
Table1-1 IE4320 industrial switch models
Subseries
Switch model
IE4320S rack mounting industrial switch series
IE4320S-26S
IE4320S-50S
IE4320 DIN-rail mounting industrial switch series
IE4320-6P
IE4320-6P-AC
IE4320-12P
IE4320-12P-UPWR
IE4320-20P
IE4320 TSN DIN-rail mounting industrial switch series
IE4320-10S
IE4320-10S-UPWR
IE4320 rack mounting industrial switch series
IE4320-28F
IE4320-28P
IE4320-28P-S
IE4320-28S
IE4320-28S-HPWR
IE4320-28S-PS1
IE4320-52P
IE4320-52S
IE4320 M12 rack mounting industrial switch series
IE4320-12P-PWR-M
IE4320-12P-PWR-M-NAT
The IE4320-28P switch model includes switches with the LS-IE4320-28P and LS-IE4320-28P-K product codes. Information described for the IE4320-28P switch model applies to the switches with the LS-IE4320-28P or LS-IE4320-28P-K product code.
Technical specifications
Table1-2 Technical specifications for the IE4320S rack mounting industrial switches
Item
IE4320S-26S
IE4320S-50S
Dimensions (H × W × D)
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in)
Weight
6.5 kg (14.33 lb)
6.5 kg (14.33 lb)
Console port
1 × serial console port
10/100/1000BASE-T autosensing Ethernet port
24
48
SFP+ port
2
2
Power supply slot
2, in the rear panel
Input voltage
PSR75-12A power supply:
·     Rated voltage range:
¡     100 to 240 VAC @ 50 or 60 Hz
¡     240 VDC
·     Max voltage range:
¡     90 to 290 VAC @ 47 to 63 Hz
¡     180 to 320 VDC
Power consumption (static)
·     Single power input: 18 W
·     Dual power inputs: 20 W
Power consumption (fully configured)
·     Single power input: 30 W
·     Dual power inputs: 37 W
·     Single power input: 41 W
·     Dual power inputs: 43 W
Melting current of power supply fuse
3.15 A/250 V
Operating altitude
–60 to +5000 m (–196.85 to +16404.20 ft)
The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from Tmax@0m.
Operating temperature
0°C to 50°C (32°F to 122°F)
Operating humidity
5% RH to 95% RH, noncondensing
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-3 Technical specifications for the IE4320 rack mounting industrial switches (1)
Item
Non-PoE switch model
IE4320-28P
IE4320-28S
IE4320-28S-PS1
IE4320-28P-S
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
4 kg (8.82 lb)
4 kg (8.82 lb)
4 kg (8.82 lb)
4 kg (8.82 lb)
Console port
1
1
1
1
USB port
1
1
1
1
24 (The eight highest-numbered 10/100/1000BASE-T autosensing Ethernet ports and eight their corresponding lowest-numbered SFP ports form combo interfaces.)
24 (The eight highest-numbered 10/100/1000BASE-T autosensing Ethernet ports and their corresponding SFP ports form combo interfaces.)
24
SFP port
12
8
8
4
SFP+ port
N/A
4
4
N/A
Alarm input (DI)
The system detects exceptions of the connected device based on the input voltage changes on the alarm input connection.
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
·     Max. input current: 8 mA
Alarm output (DO)
Uses a relay for output, with a current carrying capacity of 1A @ 24 VDC
The relay outputs alarms by opening or closing the contact.
DIP switch
Supported. For more information, see "DIP switches."
Input voltage
·     Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz
·     Max voltage range: 90 to 264 VAC @ 47 to 63 Hz
·     AC input:
¡     Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz
¡     Max voltage range: 90 to 264 VAC @ 47 to 63 Hz
·     DC input:
¡     Rated voltage range: 24 to 48 VDC
¡     Max voltage range: 24 to 48 VDC
·     Single AC input: 14 W
·     Dual AC inputs: 15 W
·     Single AC input: 13 W
·     Single DC input: 16 W
·     AC + DC inputs: 20 W
·     Single AC input: 28 W
·     Dual AC inputs: 30 W
·     Single AC input: 30 W
·     Dual AC inputs: 32 W
·     Single DC input: 29 W
·     AC + DC inputs: 36 W
2 A/250 V
Operating altitude
–25°C to +55°C (–13°F to +131°F)
Operating humidity
Ingress protection rating
IP40
IP40
IP30
IP40
Pollution degree
Degree 2.
The switch is for indoor use only.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-4 Technical specifications for the IE4320 rack mounting industrial switches (2)
Item
IE4320-28F
IE4320-52P
IE4320-52S
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in)
Weight
5 kg (11.02 lb)
5 kg (11.02 lb)
5 kg (11.02 lb)
Console port
1
1
1
USB port
1
1
1
8
48
48
SFP port
24 (The eight highest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
4
N/A
SFP+ port
4
N/A
4
Alarm input (DI)
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
Alarm output (DO)
DIP switch
Input voltage
·     Single AC input: 16 W
·     Dual AC inputs: 17 W
·     Single AC input: 20 W
·     Dual AC inputs: 21 W
·     Single AC input: 44 W
·     Dual AC inputs: 46 W
·     Single AC input: 41 W
·     Dual AC inputs: 42 W
·     Single AC input: 43 W
·     Dual AC inputs: 44 W
10 A/250 V
Operating altitude
Operating humidity
IP40
Pollution degree
Degree 2.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-5 Technical specifications for the IE4320 rack mounting industrial switches (3)
Item
PoE switch model
IE4320-28S-HPWR
Weight
4 kg (8.82 lb)
Console port
1
USB port
1
24 (The 8 lowest-numbered ports support PoE++ power supply and the 16 highest-numbered ports support PoE+ power supply.)
SFP+ port
4
Alarm input (DI)
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
Alarm output (DO)
DIP switch
Input voltage
·     Rated voltage range: 53 to 57 VDC
·     Max voltage range: 53 to 57 VDC
Max PoE power per port
·     Ports 1 to 8: 60 W
·     Ports 9 to 24: 30 W
Total PoE power
·     Single DC input: 160 W
·     Dual DC inputs: 360 W
·     Single DC input: 17 W
·     Dual DC inputs: 19 W
Power consumption (fully configured, including PoE power consumption)
·     Single DC input: 198 W
·     Dual DC inputs: 415 W
10 A/250 V
Operating altitude
Operating humidity
IP40
Pollution degree
Degree 2.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-6 Technical specifications for the IE4320 DIN-rail mounting industrial switches
Item
IE4320-6P-AC
IE4320-6P
IE4320-12P
IE4320-20P
IE4320-12P-UPWR
150 × 44 × 130 mm (5.91 × 1.73 × 5.12 in)
150 × 84 × 130 mm (5.91 × 3.31 × 5.12 in)
Weight
1 kg (2.20 lb)
1 kg (2.20 lb)
1 kg (2.20 lb)
1.6 kg (3.53 lb)
1 kg (2.20 lb)
Console port
1
1
1
1
1
4
4
8
16
8 (support PoE power supply)
SFP port
2
2
4
4
4
Alarm input (DI)
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
Alarm output (DO)
DIP switch
Input voltage
·     Max voltage range: 85 to 264 VAC @ 45 to 65 Hz
·     Rated voltage range: 24 to 48 VDC
·     Max voltage range: 24 to 48 VDC
N/A
N/A
N/A
N/A
Ports 1 to 8: 60 W
Total PoE power
N/A
N/A
N/A
N/A
7 W
8 W
8 W
9 W
·     Single DC input: 13 W
·     Dual DC inputs: 15 W
10 W
11 W
17 W
19 W
·     Single DC input: 205 W
·     Dual DC inputs: 420 W
3.15 A/250 V
Operating altitude
Operating humidity
IP40
IP40
IP40
IP40
IP40
Pollution degree
Degree 2.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-7 Technical specifications for the IE4320 TSN DIN-rail mounting industrial switches
Item
IE4320-10S
IE4320-10S-UPWR
Weight
1 kg (2.20 lb)
1 kg (2.20 lb)
Console port
1
1
8
SFP+ port
2
2
Alarm input (DI)
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
Alarm output (DO)
DIP switch
Input voltage
N/A
Ports 1 to 8: 60 W
Total PoE power
N/A
·     Single DC input: 10 W
·     Dual DC inputs: 11 W
·     Single DC input: 11 W
·     Dual DC inputs: 12 W
·     Single DC input: 15 W
·     Dual DC inputs: 16 W
·     Single DC input: 200 W
·     Dual DC inputs: 400 W
3.15 A/250 V
Operating altitude
–25°C to +60°C (–13°F to +140°F)
Operating humidity
IP40
Pollution degree
Degree 2.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
Table1-8 Technical specifications for IE4320 M12 rack mounting industrial switches
Item
IE4320-12P-PWR-M/IE4320-12P-PWR-M-NAT
43.6 × 440 × 200 mm (1.72 × 17.32 × 7.87 in)
Weight
4.5 kg (9.92 lb)
Console port
1
12 (The eight lowest-numbered ports support PoE power supply.)
Alarm input (DI)
·     State:
¡     1: +13 to +30 V
¡     0: 30 to + 3 V
Alarm output (DO)
Input voltage
·     Rated voltage: 110 VDC
·     Max voltage range: 66 to 160 VDC
Ports 1 to 8: 30 W
Total PoE power
125 W
12 W
165 W
10 A/250 V
Operating altitude
Operating humidity
IP54
Pollution degree
Degree 2.
Safety compliance
UL60950-1
EN60950-1
IEC60950-1
GB4943.1
UL62368-1
EN62368-1
IEC62368-1
DIP switches
Some switch models provide DIP switches to enable or disable corresponding features.
Table1-9 DIP switch descriptions
Switch model
DIP switch 1
DIP switch 2
DIP switch 3
DIP switch 4
IE4320-10S
IE4320-10S-UPWR
Enables or disables flow control on all ports
Enables or disables broadcast suppression on all ports
Reserved
Enables or disables RRPP on ports 9 and 10
IE4320-28F
IE4320-28P
IE4320-28P-S
IE4320-28S
IE4320-28S-PS1
IE4320-28S-HPWR
Enables or disables link aggregation on ports 25 and 26
Enables or disables RRPP on ports 27 and 28
IE4320-52P
IE4320-52S
Enables or disables link aggregation on ports 49 and 50
Enables or disables RRPP on ports 51 and 52
IE4320-6P
IE4320-6P-AC
Reserved
Enables or disables RRPP on ports 5 and 6
IE4320-12P
IE4320-12P-UPWR
Enables or disables link aggregation on ports 9 and 10
Enables or disables RRPP on ports 11 and 12
IE4320-20P
Enables or disables link aggregation on ports 17 and 18
Enables or disables RRPP on ports 19 and 20
When DIP switch 1 is on, flow control is enabled on all ports. When DIP switch 1 is off, the status of the flow control feature depends on the configuration. For more information about flow control, see Ethernet interface configuration in the configuration guides for the switch.
When DIP switch 2 is on, broadcast suppression is enabled on all ports. When DIP switch 2 is off, the status of the broadcast suppression feature depends on the configuration. For more information about broadcast suppression, see Ethernet interface configuration in the configuration guides for the switch.
When DIP switch 3 is on, the system creates Layer 2 aggregation group 1 and adds the two uplink Ethernet ports to the group. When DIP switch 3 is off, the status of the link aggregation feature depends on the configuration. For more information about Layer 2 link aggregation, see Ethernet link aggregation configuration in the configuration guides for the switch.
When DIP switch 4 is on, RRPP is enabled. When DIP switch 4 is off, the status of the RRPP feature depends on the configuration. For more information, see RRPP configuration in the configuration guides for the switch.
2 Chassis views
IE4320S-26S
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) Power supply 1 status LED (PWR1)
(4) Power supply 2 status LED (PWR2)
(5) System status LED (SYS)
(6) Console port
(7) SFP+ port LED
(8) SFP+ port
Figure2-2 Rear panel
(1) Grounding screw
(2) Removable power supply 1
(3) Removable power supply 2
The IE4320S-26S switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-2, two PSR75-12A AC power supplies are installed.
IE4320S-50S
Figure2-3 Front panel
(6) Console port
(7) SFP+ port LED
(8) SFP+ port
Figure2-4 Rear panel
(1) Grounding screw
The IE4320S-50S switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-4, two PSR75-12A AC power supplies are installed.
IE4320-6P
Figure2-5 Front panel
(1) Power supply status LED (PWR2)
(2) Diag LED (Diag)
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) 10/100/1000BASE-T autosensing Ethernet port
(5) SFP port
(6) SFP port LED
(7) Alarm LED (Alarm)
(8) Power supply status LED (PWR1)
Figure2-6 Top panel
(1) Alarm input connection (DI)
(2) Alarm output connection (DO)
(3) DC power receptacle 2 (PWR2)
(4) DC power receptacle 1 (PWR1)
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-6P-AC
Figure2-7 Front panel
(1) Diag LED (Diag)
(4) SFP port
(5) SFP port LED
(6) Alarm LED (Alarm)
(7) Power supply status LED (PWR)
Figure2-8 Top panel
(3) AC power receptacle
(4) DIP switch
(5) Console port
(6) Grounding screw
IE4320-12P
Figure2-9 Front panel
(2) Diag LED (Diag)
(5) SFP port
(6) SFP port LED
Figure2-10 Top panel
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-12P-UPWR
Figure2-11 Front panel
(2) Diag LED (Diag)
(5) SFP port
(6) SFP port LED
Figure2-12 Top panel
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-20P
Figure2-13 Front panel
(2) Diag LED (Diag)
(5) Alarm LED (Alarm)
(6) Power supply status LED (PWR1)
(7) SFP port
(8) SFP port LED
Figure2-14 Top panel
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-10S
Figure2-15 Front panel
(2) Diag LED (Diag)
(5) SFP+ port
(6) SFP+ port LED
Figure2-16 Top panel
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-10S-UPWR
Figure2-17 Front panel
(2) Diag LED (Diag)
(5) SFP+ port
(6) SFP+ port LED
Figure2-18 Top panel
(5) DIP switch
(6) Console port
(7) Grounding screw
IE4320-28P
Figure2-19 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(8) Power supply status LED (PWR2)
(9) Power supply status LED (PWR1)
(10) SFP port LED
(11) SFP port
Figure2-20 Rear panel
(1) Alarm output connection (DO)
(2) Alarm input connection (DI)
(3) AC power receptacle 1
(4) AC power receptacle 2
(5) Grounding screw
The IE4320-28P switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
IE4320-28P-S
Figure2-21 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(10) SFP port
(11) SFP port LED
Figure2-22 Rear panel
(5) Grounding screw
The IE4320-28P-S switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
IE4320-28S
Figure2-23 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(9) SFP+ port
(10) Power supply status LED (PWR1)
(11) SFP+ port LED
(12) SFP port LED
(13) SFP port
Figure2-24 Rear panel
(5) Grounding screw
The IE4320-28S switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
IE4320-28F
Figure2-25 Front panel
(1) SFP port
(2) SFP port LED
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(10) SFP+ port
(11) SFP+ port LED
(12) 10/100/1000BASE-T autosensing Ethernet port
(13) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-26 Rear panel
(5) Grounding screw
The IE4320-28F switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
IE4320-28S-HPWR
Figure2-27 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(9) SFP+ port
(11) SFP+ port LED
Figure2-28 Rear panel
(1) Grounding screw
(3) Alarm input connection (DI)
(5) DC power receptacle 2
The IE4320-28S-HPWR switch supports dual DC power feeds. You can use two H3C DG-240-55XX industrial power supplies connected in parallel to achieve load sharing for high power requirements. For more information, see Table1-5.
IE4320-28S-PS1
Figure2-29 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(8) AC power supply status LED (AC PWR)
(9) SFP+ port
(10) DC power supply status LED (DC PWR)
(11) SFP+ port LED
(12) SFP port LED
(13) SFP port
Figure2-30 Rear panel
(1) DC power receptacle
(5) Grounding screw
The IE4320-28S-PS1 switch has one fixed AC power receptacle and one fixed DC power receptacle on the rear panel. One power receptacle can meet the power requirement of the switch. You can use both of the power receptacles for redundancy.
IE4320-52P
Figure2-31 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(10) SFP port
(11) SFP port LED
Figure2-32 Rear panel
(5) Grounding screw
The IE4320-52P switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
IE4320-52S
Figure2-33 Front panel
(3) Console port
(4) USB port
(5) DIP switch
(6) Diag LED
(7) Alarm LED
(10) SFP+ port
(11) SFP+ port LED
Figure2-34 Rear panel
(5) Grounding screw
The IE4320-52S switch has two fixed AC power receptacles on the rear panel. One AC power receptacle can meet the power requirement of the switch. You can use both of the AC power receptacles for redundancy.
Figure2-35 Front panel
(1) Grounding screw
(2) DC power receptacle
(3) Power supply status LED (PWR1)
(4) Power supply status LED (PWR2)
(5) PoE status LED
(6) 10/100/1000BASE-T autosensing Ethernet port LED
(7) 10/100/1000BASE-T autosensing Ethernet port
(8) Alarm input/output connection (DI/DO)
(9) Console port
(10) Alarm LED
(11) Diag LED
Figure2-36 Rear panel
3 Removable components and compatibility matrixes
Only IE4320S rack mounting industrial switches use removable power supplies. Table3-1 describes the power supplies available for the switch.
Table3-1 Compatibility matrix between switches and removable power supplies
Power supply model
Item
Specification
Remarks
PSR75-12A
Rated input voltage range
·     AC: 100 to 240 VAC @ 50 or 60 Hz
·     DC: 240 VDC
For more information about the power supply, see H3C PSR75-12A Power Module User Manual.
Max input voltage range
·     AC: 90 to 290 VAC @ 47 to 63 Hz
·     DC: 180 to 320 VDC
Max power
75 W
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item
Specification
Connector type
·     IE4320-12P-PWR-M/IE4320-12P-PWR-M-NAT: M12 (A-CODE)
·     Other switch models: RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local terminal (PC for example) running a terminal emulation program.
Available switch models
All switch models
USB port
Table4-2 USB port specifications
Item
Specification
USB2.0
Compliant standard
OHC
480 Mbps for uploading and downloading data
Services
Used to access the file system on the flash of the switch, for example, to upload or download image files and configuration files.
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from all vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
SFP port
Table4-3 SFP port specifications
Item
Specification
SFP
Compatible transceiver modules/cables
·     GE SFP transceiver modules or cables in Table4-5
·     FE SFP transceiver modules in Table4-4
·     IE4320 DIN-rail mounting industrial switches
·     IE4320 rack mounting industrial switches except for the IE4320-28S-HPWR and IE4320-52S
·     Only SFP ports 17 to 24 on the IE4320-28F, IE4320-28P, IE4320-28P-S, IE4320-28S, or IE4320-28S-PS1 switch support FE SFP transceiver modules.
·     To use transceiver modules with a maximum transmission distance greater than or equal to 40 km (24.86 miles), make sure the ambient temperature does not exceed 40°C (104°F).
Table4-4 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber diameter (µm)
Max transmission distance
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table4-5 GE SFP transceiver modules and cables available for the SFP ports
GE SFP transceiver module and cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP fiber transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX10-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-I
1310
LC
Single-mode, 9/125
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-I
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and network cables for the switch.
·     The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide.
SFP+ port
Table4-6 SFP+ port specifications
Item
Specification
SFP+
·     10GE SFP+ transceiver modules or cables in Table4-7, Table4-8, and Table4-9
·     IE4320S rack mounting industrial switches
·     IE4320 TSN DIN-rail mounting industrial switches
·     IE4320 rack mounting industrial switches except for the IE4320-28P, IE4320-28P-S, and IE4320-52P
·     The IE4320-10S and IE4320-10S-UPWR switches do not support LSTM1STK cables.
Table4-7 10GE SFP+ transceiver modules available for the SFP+ ports
Connector
Fiber diameter (µm)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules and SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-8 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table4-9 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
Cable length
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 SFP+ cable
(1) Connector
(2) Pull latch
10/100/1000BASE-T Ethernet port
Table4-10 10/100/1000BASE-T Ethernet port specifications
Item
Specification
Connector type
Rate and duplex mode
·     10 Mbps, half/full-duplex
·     100 Mbps, half/full-duplex
·     1000 Mbps, full-duplex
Auto MDI/MDI-X
Supported
Transmission medium and max transmission distance
100 m (328.08 ft) over category-5 or above twisted pair cable
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
All switch models.
The 10/100/1000BASE-T Ethernet ports on an IE4320-12P-PWR-M or IE4320-12P-PWR-M-NAT switch use M12 (A-CODE) connectors. The 10/100/1000BASE-T Ethernet ports on the other switch models use RJ-45 connectors.
Combo interface
Table4-11 Combo interface specifications
Item
Specification
Combo
The IE4320-28F, IE4320-28P, IE4320-28S, and IE4320-28S-PS1 switches each provide eight combo interfaces on the front panel.
A combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time.
LEDs
System status LED
Only the IE4320S rack mounting industrial switches each provide a system status LED on the front panel to indicate the operating status of the switch.
Table4-12 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed power-on self test (POST) or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Removable power supply status LED
Only the IE4320S rack mounting industrial switches each provide two power supply slots at the rear. For each power supply, the switch provides a power supply status LED on the front panel.
Table4-13 Description for removable power supply status LEDs
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or no power is input to the power supply.
Off
No power supply is installed in the power supply slot.
Fixed power supply status LED
All IE4320 industrial switches except the IE4320S-26S and IE4320S-50S switches use fixed power supply status LEDs to indicate the power input status. Table4-14 provides the description of the fixed power supply status LEDs on the switch.
Table4-14 Description for the fixed power supply status LEDs on the switch
Switch model
LED mark
Status
IE4320-28F
IE4320-28P
IE4320-28P-S
IE4320-28S
IE4320-52P
IE4320-52S
PWR1/PWR2
Steady green
Normal AC power input
Off
Abnormal or no AC power input
IE4320-6P-AC
PWR
Steady green
Off
IE4320-6P
IE4320-10S
IE4320-10S-UPWR
IE4320-12P
IE4320-12P-UPWR
IE4320-12P-PWR-M
IE4320-20P
IE4320-28S-HPWR
PWR1/PWR2
Steady green
Normal DC power input
Off
Abnormal or no DC power input
IE4320-28S-PS1
DC PWR
Steady green
Off
AC PWR
Steady green
Off
The IE4320-12P-PWR-M switch provides a built-in power adapter. The compatible power cord contains two DC input circuits for redundancy.
Table4-15 Description for the power supply status LED on the IE4320-12P-PWR-M switch
LED mark
Status
PWR1/PWR2
PWR1: Steady green
PWR2: Steady green
PWR1: Off
Active DC power input failure has occurred or no power input.
PWR2: Off
Standby DC power input failure has occurred or no power input.
PoE status LED
Only the IE4320-12P-PWR-M and IE4320-12P-PWR-M-NAT switches provide a PoE status LED to indicate the PoE power supply status.
Table4-16 PoE status LED description
LED mark
Status
PoE+
Steady yellow
PoE is enabled on the Ethernet port.
Off
PoE is disabled on the Ethernet port.
Alarm LED
All IE4320 industrial switches except the IE4320S-26S and IE4320S-50S switches each provide an alarm input connection and can detect changes of the digital input voltage. When the digital input voltage exceeds the acceptable range, the system uses the alarm LED to indicate the exception.
Table4-17 Alarm LED description
LED mark
Status
Alarm
Steady red
A digital input exception has been detected.
Off
No exception has been detected.
Diag LED
All IE4320 industrial switches except the IE4320S-26S and IE4320S-50S switches each provide a Diag LED on the front panel to indicate the system operating status.
Table4-18 Diag LED description
LED mark
Status
Diag
Steady red
The switch has failed the POST, or an alarm condition such as MAC chip overtemperature has occurred.
Off
The switch has passed the POST and is operating correctly.
Table4-19 10/100/1000BASE-T autosensing Ethernet port LED description for non-PoE switch models
Switch model
LED
Status
IE4320S-26S
IE4320S-50S
IE4320-28P
IE4320-28P-S
IE4320-28S
IE4320-28F
IE4320-28S-PS1
IE4320-52P
IE4320-52S
Green LED
Steady on
A link is present on the port.
Flashing
The port is sending or receiving data.
Off
No link is present on the port.
IE4320-6P
IE4320-6P-AC
IE4320-10S
IE4320-12P
IE4320-20P
Green LED
Steady on
A link is present on the port and the port is operating at 1000 Mbps.
Flashing
The port is sending or receiving data at 1000 Mbps.
Off
No 1000 Mbps link is present on the port.
Yellow LED
Steady on
A link is present on the port and the port is operating at 10/100 Mbps.
Flashing
The port is sending or receiving data at 10/100 Mbps.
Off
No 10/100 Mbps link is present on the port.
Table4-20 10/100/1000BASE-T autosensing Ethernet port LED description for PoE switch models
Switch model
LED
Status
IE4320-28S-HPWR
IE4320-10S-UPWR
IE4320-12P-UPWR
IE4320-12P-PWR-M
Green LED
Steady on
The port is operating at 10/100/1000 Mbps.
Flashing
The port is sending or receiving data at 10/100/1000 Mbps.
Off
No link is present on the port or the link has failed.
Yellow LED
Steady on
The port is connected to a PD and PoE power supply is normal.
Flashing
The port is connected to a PD but PoE power supply is abnormal.
Off
The port is not connected to a PD or PoE is not enabled on the port.
SFP/SFP+ port LED
Table4-21 SFP/SFP+ port LED description
Status
Steady green
Flashing green
Off
  • Become a Partner
  • Partner Resources
