08-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10008-Layer 3 - IP Routing
06-OSPF-MIB
06-OSPF-MIB 188.01 KB
OSPF-MIB
About this MIB
This document contains MIB and Trap features compliant with RFC 4750.
MIB file name
rfc4750-ospf.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14)
Scalar objects
ospfRouterId
Object (OID)
Access
Value range
Implementation
ospfRouterId (1.3.6.1.2.1.14.1.1)
read-write
RouterID
OCTET STRING (4)
Router ID that uniquely identifies a router in an AS.
Supports only the read operation.
ospfAdminStat
Object (OID)
Access
Value range
Implementation
ospfAdminStat (1.3.6.1.2.1.14.1.2)
read-write
Status
INTEGER{
enabled(1), disabled(2)
OSPF administrative state of the router. Enabled indicates at least one OSPF interface exists. Disabled indicates no OSPF interface exists.
ospfVersionNumber
Object (OID)
Access
Value range
Implementation
ospfVersionNumber (1.3.6.1.2.1.14.1.3)
read-only
INTEGER
version2 (2)
Version number (2).
As per the MIB.
ospfAreaBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfAreaBdrRtrStatus (1.3.6.1.2.1.14.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the router is an ABR.
As per the MIB.
ospfASBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfASBdrRtrStatus (1.3.6.1.2.1.14.1.5)
read-write
TruthValue
true(1),
false(2)
Whether the router is an ASBR.
ospfExternLsaCount
Object (OID)
Access
Value range
Implementation
ospfExternLsaCount (1.3.6.1.2.1.14.1.6)
read-only
Gauge32
INTEGER(0..4294967295)
Number of Type-5 LSAs.
As per the MIB.
ospfExternLsaCksumSum
Object (OID)
Access
Value range
Implementation
ospfExternLsaCksumSum (1.3.6.1.2.1.14.1.7)
read-only
Integer32
Standard MIB values.
Sum of checksums in Type-5 LSAs.
As per the MIB.
ospfTOSSupport
Object (OID)
Access
Value range
Implementation
ospfTOSSupport (1.3.6.1.2.1.14.1.8)
read-write
TruthValue
true(1),
false(2)
Whether ToS is supported.
ospfOriginateNewLsas
Object (OID)
Access
Value range
Implementation
ospfOriginateNewLsas (1.3.6.1.2.1.14.1.9)
read-only
Counter32
Number of new LSAs that have been originated. This number is incremented each time the router originates a new LSA.
As per the MIB.
ospfRxNewLsas
Object (OID)
Access
Value range
Implementation
ospfRxNewLsas (1.3.6.1.2.1.14.1.10)
read-only
Counter32
Number of newly received LSAs, excluding self-originated LSAs.
As per the MIB.
ospfExtLsdbLimit
Object (OID)
Access
Value range
Implementation
ospfExtLsdbLimit (1.3.6.1.2.1.14.1.11)
read-write
Integer32
Integer32(-1..'7FFFFFFF'h)
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit.
The value takes -1, or is in the range of 1 to 1000000.
ospfMulticastExtensions
Object (OID)
Access
Value range
Implementation
ospfMulticastExtensions (1.3.6.1.2.1.14.1.12)
read-write
Integer32
Whether the router is multicast capable. Bit 0 indicates intra-area multicast; bit 1 indicates inter-area multicast; bit 2 indicates inter-AS multicast. The value can be 0, 1, 3, 5, and 7. The default value is 0.
ospfExitOverflowInterval
Object (OID)
Access
Value range
Implementation
ospfExitOverflowInterval (1.3.6.1.2.1.14.1.13)
read-write
PositiveInteger
Integer32(0..'7FFFFFFF'h)
Time that the router takes to leave the OverflowState. 0 indicates the router does not leave the OverflowState until it is restarted.
As per the MIB.
ospfDemandExtensions
Object (OID)
Access
Value range
Implementation
ospfDemandExtensions (1.3.6.1.2.1.14.1.14)
read-write
TruthValue
true(1),
false(2)
Support for demand routing.
ospfRFC1583Compatibility
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.15)
read-write
TruthValue
true(1),
false(2)
Compatibility with RFC 1583.
When compatibility is enabled, only cost will be used when choosing among multiple ASE LSAs advertising the same destination.
When compatibility is disabled, preference will be used first.
As per the MIB.
ospfOpaqueLsaSupport
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.16)
read-only
TruthValue
true(1),
false(2)
Support for Opaque LSAs.
As per the MIB.
ospfReferenceBandwidth
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.17)
read-write
Unsigned32
Reference bandwidth in Kb/s for calculating the interface cost.
When the value is divided by 1000, the decimal number will be ignored.
ospfRestartSupport
Object (OID)
Access
Value range
Implementation
ospfRestartSupport
(1.3.6.1.2.1.14.1.18)
read-write
INTEGER
none (1),
plannedOnly (2),
plannedAndUnplanned (3)
Support for GR.
If the value changes from 1 to 2 or 3, IETF GR is supported.
If the value changes between 2 and 3, the original GR type remains unchanged.
ospfRestartInterval
Object (OID)
Access
Value range
Implementation
ospfRestartInterval
(1.3.6.1.2.1.14.1.19)
read-write
Integer32
Integer32(1..1800)
Graceful restart timeout interval.
Value range: 40 to 1800.
ospfRestartStrictLsaChecking
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.20)
read-write
TruthValue
true(1),
false(2)
Whether the strict LSA checking capability is enabled for GR.
As per the MIB.
ospfRestartStatus
Object (OID)
Access
Value range
Implementation
ospfRestartStatus
(1.3.6.1.2.1.14.1.21)
read-only
INTEGER
notRestarting (1),
plannedRestart (2),
unplannedRestart (3)
Graceful restart state.
As per the MIB.
ospfRestartAge
Object (OID)
Access
Value range
Implementation
ospfRestartAge
(1.3.6.1.2.1.14.1.22)
read-only
Unsigned32
Remaining time for the current graceful restart
As per the MIB.
ospfRestartExitReason
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.23)
read-only
INTEGER
none (1),
inProgress (2),
completed (3),
timedOut (4),
topologyChanged (5)
GR exit reason.
As per the MIB.
ospfAsLsaCount
Object (OID)
Access
Value range
Implementation
ospfAsLsaCount
(1.3.6.1.2.1.14.1.24)
read-only
Gauge32
Number of AS-scope LSAs.
As per the MIB.
ospfAsLsaCksumSum
Object (OID)
Access
Value range
Implementation
ospfAsLsaCksumSum
(1.3.6.1.2.1.14.1.25)
read-only
Unsigned32
Sum of AS-scope LSA checksums.
As per the MIB.
ospfStubRouterSupport
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.26)
read-only
TruthValue
true(1),
false(2)
Support for stub router.
As per the MIB.
ospfStubRouterAdvertisement
Object (OID)
Access
Value range
Implementation
ospfStubRouterAdvertisement(1.3.6.1.2.1.14.1.27)
read-write
INTEGER
doNotAdvertise (1),
advertise(2)
Whether to advertise stub router LSAs.
As per the MIB.
ospfDiscontinuityTime
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.14.1.28)
read-only
TimeStamp
TimeTicks
Most recent system startup time.
As per the MIB.
Tabular objects
ospfAreaTable
About this table
This table contains parameter and statistics information about each area on the device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ospfAreaId.
Object (OID)
Access
Value range
Implementation
ospfAreaId (1.3.6.1.2.1.14.2.1.1)
read-only
AreaID
OCTET STRING (4)
Area ID, a 32-bit integer that uniquely identifies an area.
As per the MIB.
ospfAuthType (1.3.6.1.2.1.14.2.1.2)
read-create
OspfAuthenticationType
none (0),
simplePassword (1),
md5 (2)
Authentication type.
ospfImportAsExtern (1.3.6.1.2.1.14.2.1.3)
read-create
INTEGER
importExternal(1),
importNoExternal (2), importNssa (3)
Area type, stub, NSSA, or common area.
ospfSpfRuns (1.3.6.1.2.1.14.2.1.4)
read-only
Counter32
Time of route calculations in the area.
As per the MIB.
ospfAreaBdrRtrCount (1.3.6.1.2.1.14.2.1.5)
read-only
Gauge32
Number of reachable ABRs in the area.
As per the MIB.
ospfAsBdrRtrCount (1.3.6.1.2.1.14.2.1.6)
read-only
Gauge32
Number of reachable ASBRs in the area.
As per the MIB.
ospfAreaLsaCount (1.3.6.1.2.1.14.2.1.7)
read-only
Gauge32
Number of LSAs in the LSDB of the area.
As per the MIB.
ospfAreaLsaCksumSum (1.3.6.1.2.1.14.2.1.8)
read-only
Integer32
Sum of the checksums of the LSAs in the area.
As per the MIB.
ospfAreaSummary (1.3.6.1.2.1.14.2.1.9)
read-create
INTEGER
noAreaSummary (1),
sendAreaSummary (2)
Whether to send summary LSAs to stub and NSSA areas.
Supports only the read and write operations.
ospfAreaStatus (1.3.6.1.2.1.14.2.1.10)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Area state.
ospfAreaNssaTranslatorRole
(1.3.6.1.2.1.14.2.1.11)
read-create
INTEGER
always (1),
candidate (2)
Ability of the NSSA ABR to translate Type-7 LSAs into Type-5 LSAs.
ospfAreaNssaTranslatorState
(1.3.6.1.2.1.14.2.1.12)
read-only
INTEGER
enabled (1),
elected (2),
disabled (3)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
As per the MIB.
ospfAreaNssaTranslatorStabilityInterval(1.3.6.1.2.1.14.2.1.13)
read-create
PositiveInteger
Time for the elected translator to continue to perform translation.
Value range: 0 to 900.
ospfAreaNssaTranslatorEvents (1.3.6.1.2.1.14.2.1.14)
read-only
Counter32
Number of translator state changes.
As per the MIB.
ospfStubAreaTable
About this table
This table contains cost information that is advertised to a stub area.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfStubAreaId and ospfStubTOS.
Object (OID)
Access
Value range
Implementation
ospfStubAreaId (1.3.6.1.2.1.14.3.1.1)
read-only
AreaID
OCTET STRING (4)
Area ID, a 32-bit integer that uniquely identifies a stub area.
As per the MIB.
ospfStubTOS (1.3.6.1.2.1.14.3.1.2)
read-only
TOSType
Integer32 (0..30)
Type of Service associated with the cost.
As per the MIB.
ospfStubMetric (1.3.6.1.2.1.14.3.1.3)
read-create
BigMetric
Integer32(0..'FFFFFF'h)
Default cost of generated default LSAs, including Type-3 and Type-7 LSAs.
Value range: 0 to 16777214.
ospfStubStatus (1.3.6.1.2.1.14.3.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Area state.
ospfStubMetricType (1.3.6.1.2.1.14.3.1.5)
read-create
INTEGER
ospfMetric (1),
comparableCost (2),
nonComparable (3)
Cost type.
ospfLsdbTable
About this table
This table contains OSPF LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfLsdbAreaId, ospfLsdbType, ospfLsdbLsid, and ospfLsdbRouterId.
Object (OID)
Access
Value range
Implementation
ospfLsdbAreaId (1.3.6.1.2.1.14.4.1.1)
read-only
AreaID
OCTET STRING (4)
ID of the area from which the LSA was received.
As per the MIB.
ospfLsdbType (1.3.6.1.2.1.14.4.1.2)
read-only
INTEGER
routerLink (1),
networkLink (2),
summaryLink (3),
asSummaryLink (4),
asExternalLink (5),
multicastLink (6), nssaExternalLink (7),
areaOpaqueLink (10)
LSA type.
Type-5 LSAs are not displayed.
As per the MIB.
ospfLsdbLsid (1.3.6.1.2.1.14.4.1.3)
read-only
IpAddress
OCTET STRING (4)
LS ID
As per the MIB.
ospfLsdbRouterId (1.3.6.1.2.1.14.4.1.4)
read-only
RouterID
OCTET STRING (4)
Router ID of the LSA originator.
As per the MIB.
ospfLsdbSequence (1.3.6.1.2.1.14.4.1.5)
read-only
Integer32
LSA sequence number.
As per the MIB.
ospfLsdbAge (1.3.6.1.2.1.14.4.1.6)
read-only
Integer32
LSA age.
As per the MIB.
ospfLsdbChecksum (1.3.6.1.2.1.14.4.1.7)
read-only
Integer32
Checksum of the complete contents of the LSA except the age field.
As per the MIB.
ospfLsdbAdvertisement (1.3.6.1.2.1.14.4.1.8)
read-only
OCTET STRING
OCTET STRING (1..65535)
Complete LSA information, including the LSA header.
As per the MIB.
ospfHostTable
About this table
This table contains host route information on the device.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfHostIpAddress and ospfHostTOS.
Object (OID)
Access
Value range
Implementation
ospfHostIpAddress (1.3.6.1.2.1.14.6.1.1)
read-only
IpAddress
OCTET STRING (4)
IP address of the host route.
As per the MIB.
ospfHostTOS (1.3.6.1.2.1.14.6.1.2)
read-only
TOSType
Integer32 (0..30)
Type of Service.
As per the MIB.
ospfHostMetric (1.3.6.1.2.1.14.6.1.3)
read-create
Metric
Integer32(0..'FFFF'h)
Host route cost.
Value range: 1 to 65535.
ospfHostStatus (1.3.6.1.2.1.14.6.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Host route state.
ospfHostAreaID (1.3.6.1.2.1.14.6.1.5)
read-only
AreaID
OCTET STRING (4)
ID of the area to which the host route belongs.
As per the MIB.
ospfHostCfgAreaID
(1.3.6.1.2.1.14.6.1.6)
read-create
AreaID
OCTET STRING (4)
Configured area ID of the host route.
ospfIfTable
About this table
This table contains OSPF interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfIfIpAddress and ospfAddressLessIf.
Object (OID)
Access
Value range
Implementation
ospfIfIpAddress (1.3.6.1.2.1.14.7.1.1)
read-only
IpAddress
OCTET STRING (4)
Interface IP address.
As per the MIB.
ospfAddressLessIf (1.3.6.1.2.1.14.7.1.2)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Used to distinguish interface instances with addresses configured and those without addresses configured.
As per the MIB.
ospfIfAreaId (1.3.6.1.2.1.14.7.1.3)
read-create
AreaID
OCTET STRING (4)
Area ID.
ospfIfType (1.3.6.1.2.1.14.7.1.4)
read-create
INTEGER
broadcast(1),
nbma (2),
pointToPoint (3),
pointToMultipoint (5)
OSPF interface type.
Loopback interfaces do not support the write operation.
ospfIfAdminStat (1.3.6.1.2.1.14.7.1.5)
read-create
Status
INTEGER{
Administrative state of the OSPF interface. It is enabled when the interface is active and disabled when the interface is in other state.
ospfIfRtrPriority (1.3.6.1.2.1.14.7.1.6)
read-create
DesignatedRouterPriority
Integer32(0..'FF'h)
Interface priority.
ospfIfTransitDelay (1.3.6.1.2.1.14.7.1.7)
read-create
UpToMaxAge
Integer32(0..3600)
Delay time interval.
Value range: 1 to 3600.
ospfIfRetransInterval (1.3.6.1.2.1.14.7.1.8)
read-create
UpToMaxAge
Integer32(0..3600)
Retransmission interval.
ospfIfHelloInterval (1.3.6.1.2.1.14.7.1.9)
read-create
HelloRange
Integer32(1..'FFFF'h)
Hello interval.
Supports only the read and write operations. Loopback interfaces do not support the write operation.
ospfIfRtrDeadInterval (1.3.6.1.2.1.14.7.1.10)
read-create
PositiveInteger
Dead interval.
Value range: 1 to 2147483647.
ospfIfPollInterval (1.3.6.1.2.1.14.7.1.11)
read-create
PositiveInteger
Poll interval.
ospfIfState (1.3.6.1.2.1.14.7.1.12)
read-only
INTEGER
down (1),
loopback(2),
waiting(3),
pointToPoint (4),
designatedRouter(5),
backupDesignatedRouter (6),
otherDesignatedRouter (7)
Interface state.
As per the MIB.
ospfIfDesignatedRouter (1.3.6.1.2.1.14.7.1.13)
read-only
IpAddress
OCTET STRING (4)
DR address.
As per the MIB.
ospfIfBackupDesignatedRouter (1.3.6.1.2.1.14.7.1.14)
read-only
IpAddress
OCTET STRING (4)
BDR address.
As per the MIB.
ospfIfEvents (1.3.6.1.2.1.14.7.1.15)
read-only
Counter32
Number of interface state changes.
As per the MIB.
ospfIfAuthKey (1.3.6.1.2.1.14.7.1.16)
read-create
OCTET STRING
OCTET STRING (0..256)
Authentication key.
ospfIfStatus (1.3.6.1.2.1.14.7.1.17)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfIfMulticastForwarding (1.3.6.1.2.1.14.7.1.18)
read-create
INTEGER
blocked(1),
multicast(2),
unicast (3)
Multicast forwarding way on the interface.
ospfIfDemand (1.3.6.1.2.1.14.7.1.19)
read-create
TruthValue
true(1),
false(2)
Whether the interface performs demand routing.
ospfIfAuthType (1.3.6.1.2.1.14.7.1.20)
read-create
none (0),
simplePassword (1),
md5 (2)
ospfIfLsaCount
(1.3.6.1.2.1.14.7.1.21)
read-only
Gauge32
Number of Type-9 LSAs.
As per the MIB.
ospfIfLsaCksumSum
(1.3.6.1.2.1.14.7.1.22)
read-only
Unsigned32
Sum of checksums in Type-9 LSAs.
As per the MIB.
ospfIfDesignatedRouterId
(1.3.6.1.2.1.14.7.1.23)
read-only
RouterID
OCTET STRING (4)
Router ID of the DR.
As per the MIB.
ospfIfBackupDesignatedRouterId(1.3.6.1.2.1.14.7.1.24)
read-only
RouterID
OCTET STRING (4)
Router ID of the BDR.
As per the MIB.
ospfIfMetricTable
About this table
This table contains information about costs to be advertised for a specific interface at various service types.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfIfMetricIpAddress and ospfIfMetricAddressLessIf.
Object (OID)
Access
Value range
Implementation
ospfIfMetricIpAddress (1.3.6.1.2.1.14.8.1.1)
read-only
IpAddress
OCTET STRING (4)
IP address of the OSPF interface.
As per the MIB.
ospfIfMetricAddressLessIf (1.3.6.1.2.1.14.8.1.2)
read-only
As per the MIB.
ospfIfMetricTOS (1.3.6.1.2.1.14.8.1.3)
read-only
TOSType
Integer32 (0..30)
ToS cost being used.
As per the MIB.
ospfIfMetricValue (1.3.6.1.2.1.14.8.1.4)
read-create
Metric
Interface cost.
Value range for a loopback interface: 0 to 65535.
Value range for other interfaces: 1 to 65535.
ospfIfMetricStatus (1.3.6.1.2.1.14.8.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfVirtIfTable
About this table
This table contains OSPF virtual interface information of the router.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfVirtIfAreaId and ospfVirtIfNeighbor.
Object (OID)
Access
Value range
Implementation
ospfVirtIfAreaId (1.3.6.1.2.1.14.9.1.1)
read-only
AreaID
OCTET STRING (4)
ID of the area to which the virtual link belongs.
As per the MIB.
ospfVirtIfNeighbor (1.3.6.1.2.1.14.9.1.2)
read-only
RouterID
OCTET STRING (4)
Router ID of the virtual neighbor.
As per the MIB.
ospfVirtIfTransitDelay (1.3.6.1.2.1.14.9.1.3)
read-create
UpToMaxAge
Integer32(0..3600)
Delay interval.
ospfVirtIfRetransInterval (1.3.6.1.2.1.14.9.1.4)
read-create
UpToMaxAge
Integer32(0..3600)
ospfVirtIfHelloInterval (1.3.6.1.2.1.14.9.1.5)
read-create
HelloRange
Hello interval.
Value range: 1 to 8192.
ospfVirtIfRtrDeadInterval (1.3.6.1.2.1.14.9.1.6)
read-create
PositiveInteger
Dead interval.
Value range: 1 to 32768.
ospfVirtIfState (1.3.6.1.2.1.14.9.1.7)
read-only
INTEGER
down (1), pointToPoint (4)
OSPF virtual interface state.
As per the MIB.
ospfVirtIfEvents (1.3.6.1.2.1.14.9.1.8)
read-only
Counter32
Number of state changes on the interface.
As per the MIB.
ospfVirtIfAuthKey (1.3.6.1.2.1.14.9.1.9)
read-create
OCTET STRING
Authentication key.
ospfVirtIfStatus (1.3.6.1.2.1.14.9.1.10)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfVirtIfAuthType (1.3.6.1.2.1.14.9.1.11)
read-create
none (0),
simplePassword (1),
md5 (2)
ospfVirtIfLsaCount
(1.3.6.1.2.1.14.9.1.12)
read-only
Gauge32
As per the MIB.
ospfVirtIfLsaCksumSum
(1.3.6.1.2.1.14.9.1.13)
read-only
Unsigned32
As per the MIB.
ospfNbrTable
About this table
This table contains information about non-virtual neighbors of the local OSPF router.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfNbrIpAddr and ospfNbrAddressLessIndex.
Object (OID)
Access
Value range
Implementation
ospfNbrIpAddr (1.3.6.1.2.1.14.10.1.1)
read-only
IpAddress
OCTET STRING (4)
Neighbor IP address.
As per the MIB.
ospfNbrAddressLessIndex (1.3.6.1.2.1.14.10.1.2)
read-only
Set to 0 on an interface having an IP address, and set to the value of interface index in the Internet Standard MIB on an interface having no IP address.
As per the MIB.
ospfNbrRtrId (1.3.6.1.2.1.14.10.1.3)
read-only
RouterID
OCTET STRING (4)
Router ID of the neighbor.
As per the MIB.
ospfNbrOptions (1.3.6.1.2.1.14.10.1.4)
read-only
Integer32
Option field of the neighbor.
As per the MIB.
ospfNbrPriority (1.3.6.1.2.1.14.10.1.5)
read-create
Integer32(0..'FF'h)
Priority of the neighbor.
Supports only the read and write operations. NBMA neighbors support only the write operations.
ospfNbrState (1.3.6.1.2.1.14.10.1.6)
read-only
INTEGER
down (1),
attempt (2),
init (3),
twoWay (4),
exchangeStart (5),
exchange (6),
loading (7),
full (8)
State of the relationship with the neighbor.
As per the MIB.
ospfNbrEvents (1.3.6.1.2.1.14.10.1.7)
read-only
Counter32
Number of neighbor state changes.
As per the MIB.
ospfNbrLsRetransQLen (1.3.6.1.2.1.14.10.1.8)
read-only
Gauge32
Retransmission queue length.
As per the MIB.
ospfNbmaNbrStatus (1.3.6.1.2.1.14.10.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfNbmaNbrPermanence (1.3.6.1.2.1.14.10.1.10)
read-only
INTEGER
dynamic(1),
permanent(2)
Entry status.
The values dynamic and permanent refer to how the neighbor became known.
As per the MIB.
ospfNbrHelloSuppressed (1.3.6.1.2.1.14.10.1.11)
read-only
TruthValue
true(1),
false(2)
Whether hello packets are being suppressed to the neighbor.
As per the MIB.
ospfNbrRestartHelperStatus
(1.3.6.1.2.1.14.10.1.12)
read-only
INTEGER
notHelping(1),
helping (2)
Whether the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfNbrRestartHelperAge
(1.3.6.1.2.1.14.10.1.13)
read-only
Unsigned32
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfNbrRestartHelperExitReason(1.3.6.1.2.1.14.10.1.14)
read-only
INTEGER
none (1),inProgress (2),completed (3),timedOut (4),topologyChanged (5)
GR helper exit reason.
As per the MIB.
ospfVirtNbrTable
About this table
This table contains information about all virtual neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfVirtNbrArea and ospfVirtNbrRtrId.
Object (OID)
Access
Value range
Implementation
ospfVirtNbrArea (1.3.6.1.2.1.14.11.1.1)
read-only
AreaID
OCTET STRING (4)
Transit area identifier.
As per the MIB.
ospfVirtNbrRtrId (1.3.6.1.2.1.14.11.1.2)
read-only
RouterID
OCTET STRING (4)
A 32-bit integer that uniquely identifies the neighboring router in the AS.
As per the MIB.
ospfVirtNbrIpAddr (1.3.6.1.2.1.14.11.1.3)
read-only
IpAddress
OCTET STRING (4)
IP address of the virtual neighbor.
As per the MIB.
ospfVirtNbrOptions (1.3.6.1.2.1.14.11.1.4)
read-only
Integer32
As per the MIB.
ospfVirtNbrState (1.3.6.1.2.1.14.11.1.5)
read-only
INTEGER
down (1),                    attempt (2),                 init (3),                   twoWay (4),                    exchangeStart (5),                   exchange (6),                   loading (7),                   full (8)
State of the virtual neighbor relationship.
As per the MIB.
ospfVirtNbrEvents (1.3.6.1.2.1.14.11.1.6)
read-only
Counter32
Number of virtual link state changes.
As per the MIB.
ospfVirtNbrLsRetransQLen (1.3.6.1.2.1.14.11.1.7)
read-only
Gauge32
As per the MIB.
ospfVirtNbrHelloSuppressed (1.3.6.1.2.1.14.11.1.8)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
ospfVirtNbrRestartHelperStatus (1.3.6.1.2.1.14.11.1.9)
read-only
INTEGER
notHelping(1),                             helping (2)
As per the MIB.
ospfVirtNbrRestartHelperAge(1.3.6.1.2.1.14.11.1.10)
read-only
Unsigned32
As per the MIB.
ospfVirtNbrRestartHelperExitReason (1.3.6.1.2.1.14.11.1.11)
read-only
INTEGER
none(1),
inProgress(2),
completed (3),
timedOut (4),
topologyChanged (5)
As per the MIB.
ospfExtLsdbTable
About this table
This table contains information about the LSDB of external LSAs for the OSPF process.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfExtLsdbType, ospfExtLsdbLsid, and ospfExtLsdbRouterId.
Object (OID)
Access
Value range
Implementation
ospfExtLsdbType (1.3.6.1.2.1.14.12.1.1)
read-only
INTEGER
asExternalLink(5)
LSA type.
As per the MIB.
ospfExtLsdbLsid (1.3.6.1.2.1.14.12.1.2)
read-only
IpAddress
OCTET STRING (4)
LS ID, an LS type specific field containing either a router ID or an IP address.
As per the MIB.
ospfExtLsdbRouterId (1.3.6.1.2.1.14.12.1.3)
read-only
RouterID
OCTET STRING (4)
A 32-bit number that uniquely identifies the originating router in the AS.
As per the MIB.
ospfExtLsdbSequence (1.3.6.1.2.1.14.12.1.4)
read-only
Integer32
Sequence number.
As per the MIB.
ospfExtLsdbAge (1.3.6.1.2.1.14.12.1.5)
read-only
Integer32
Age of the LSA.
As per the MIB.
ospfExtLsdbChecksum (1.3.6.1.2.1.14.12.1.6)
read-only
Integer32
Checksum of the complete contents of the LSA, except the age field.
As per the MIB.
ospfExtLsdbAdvertisement (1.3.6.1.2.1.14.12.1.7)
read-only
OCTET STRING
OCTET STRING (36)
Complete LSA information.
As per the MIB.
ospfAreaAggregateTable
About this table
This table contains information about configured summary routes.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfAreaAggregateAreaID, ospfAreaAggregateLsdbType, ospfAreaAggregateNet, and ospfAreaAggregateMask.
Object (OID)
Access
Value range
Implementation
ospfAreaAggregateAreaID (1.3.6.1.2.1.14.14.1.1)
read-only
AreaID
OCTET STRING (4)
Area where the summary route resides.
As per the MIB.
ospfAreaAggregateLsdbType (1.3.6.1.2.1.14.14.1.2)
read-only
INTEGER
summaryLink(3),                  nssaExternalLink (7)
Summary route type.
As per the MIB.
ospfAreaAggregateNet (1.3.6.1.2.1.14.14.1.3)
read-only
IpAddress
OCTET STRING (4)
Network address.
As per the MIB.
ospfAreaAggregateMask (1.3.6.1.2.1.14.14.1.4)
read-only
IpAddress
OCTET STRING (4)
Subnet mask.
As per the MIB.
ospfAreaAggregateStatus (1.3.6.1.2.1.14.14.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfAreaAggregateEffect (1.3.6.1.2.1.14.14.1.6)
read-create
INTEGER
advertiseMatching (1),                  doNotAdvertiseMatching (2)
Whether subnets are included in the summary route.
ospfAreaAggregateExtRouteTag(1.3.6.1.2.1.14.14.1.7)
read-create
Unsigned32
External route tag in Type-7 LSAs.
Supports only the read and write operations. nssaExternalLink supports only the write operation.
ospfLocalLsdbTable
About this table
This table contains all local LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfLocalLsdbIpAddress, ospfLocalLsdbAddressLessIf, ospfLocalLsdbType, ospfLocalLsdbLsid, and ospfLocalLsdbRouterId.
Object (OID)
Access
Value range
Implementation
ospfLocalLsdbIpAddress (1.3.6.1.2.1.14.17.1.1)
not-accessible
IpAddress
OCTET STRING (4)
IP address of the interface that received the LSA.
As per the MIB.
ospfLocalLsdbAddressLessIf (1.3.6.1.2.1.14.17.1.2)
not-accessible
Index of the interface that received the LSA.
As per the MIB.
ospfLocalLsdbType (1.3.6.1.2.1.14.17.1.3)
not-accessible
INTEGER
localOpaqueLink (9)
LSA type.
As per the MIB.
ospfLocalLsdbLsid (1.3.6.1.2.1.14.17.1.4)
not-accessible
IpAddress
OCTET STRING (4)
LS ID.
As per the MIB.
ospfLocalLsdbRouterId (1.3.6.1.2.1.14.17.1.5)
not-accessible
RouterID
OCTET STRING (4)
As per the MIB.
ospfLocalLsdbSequence (1.3.6.1.2.1.14.17.1.6)
read-only
Integer32
As per the MIB.
ospfLocalLsdbAge
(1.3.6.1.2.1.14.17.1.7)
read-only
Integer32
LSA age in seconds.
As per the MIB.
ospfLocalLsdbChecksum
(1.3.6.1.2.1.14.17.1.8)
read-only
Integer32
LSA checksum.
As per the MIB.
ospfLocalLsdbAdvertisement
(1.3.6.1.2.1.14.17.1.9)
read-only
OCTET STRING
As per the MIB.
ospfVirtLocalLsdbTable
About this table
This table contains local LSDB information for all virtual links.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfVirtLocalLsdbTransitArea, ospfVirtLocalLsdbNeighbor, ospfVirtLocalLsdbType, ospfVirtLocalLsdbLsid, and ospfVirtLocalLsdbRouterId.
Object (OID)
Access
Value range
Implementation
ospfVirtLocalLsdbTransitArea (1.3.6.1.2.1.14.18.1.1)
not-accessible
AreaID
OCTET STRING (4)
Transit area that the virtual link traverses.
As per the MIB.
ospfVirtLocalLsdbNeighbor (1.3.6.1.2.1.14.18.1.2)
not-accessible
RouterID
OCTET STRING (4)
As per the MIB.
ospfVirtLocalLsdbType (1.3.6.1.2.1.14.18.1.3)
not-accessible
INTEGER
localOpaqueLink (9)
LSA type.
As per the MIB.
ospfVirtLocalLsdbLsid (1.3.6.1.2.1.14.18.1.4)
not-accessible
IpAddress
OCTET STRING (4)
LS ID.
As per the MIB.
ospfVirtLocalLsdbRouterId (1.3.6.1.2.1.14.18.1.5)
not-accessible
RouterID
OCTET STRING (4)
As per the MIB.
ospfVirtLocalLsdbSequence (1.3.6.1.2.1.14.18.1.6)
read-only
Integer32
As per the MIB.
ospfVirtLocalLsdbAge (1.3.6.1.2.1.14.18.1.7)
read-only
Integer32
LSA age in seconds.
As per the MIB.
ospfVirtLocalLsdbChecksum (1.3.6.1.2.1.14.18.1.8)
read-only
Integer32
LSA checksum.
As per the MIB.
ospfVirtLocalLsdbAdvertisement (1.3.6.1.2.1.14.18.1.9)
read-only
OCTET STRING
As per the MIB.
ospfAsLsdbTable
About this table
This table contains information about LSDB information of an AS.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfAsLsdbType, ospfAsLsdbLsid, and ospfAsLsdbRouterId.
Object (OID)
Access
Value range
Implementation
ospfAsLsdbType (1.3.6.1.2.1.14.19.1.1)
not-accessible
INTEGER
asExternalLink (5),                     asOpaqueLink   (11)
LSA type.
As per the MIB.
ospfAsLsdbLsid (1.3.6.1.2.1.14.19.1.2)
not-accessible
IpAddress
OCTET STRING (4)
LS ID.
As per the MIB.
ospfAsLsdbRouterId (1.3.6.1.2.1.14.19.1.3)
not-accessible
RouterID
OCTET STRING (4)
As per the MIB.
ospfAsLsdbSequence (1.3.6.1.2.1.14.19.1.4)
read-only
Integer32
As per the MIB.
ospfAsLsdbAge (1.3.6.1.2.1.14.19.1.5)
read-only
Integer32
LSA age in seconds.
As per the MIB.
ospfAsLsdbChecksum (1.3.6.1.2.1.14.19.1.6)
read-only
Integer32
LSA checksum.
As per the MIB.
ospfAsLsdbAdvertisement (1.3.6.1.2.1.14.19.1.7)
read-only
OCTET STRING
As per the MIB.
ospfAreaLsaCountTable
About this table
This table contains LSA statistics information of all areas and types.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfAreaLsaCountAreaId and ospfAreaLsaCountLsaType.
Object (OID)
Access
Value range
Implementation
ospfAreaLsaCountAreaId (1.3.6.1.2.1.14.20.1.1)
not-accessible
AreaID
OCTET STRING (4)
Area ID.
As per the MIB.
ospfAreaLsaCountLsaType (1.3.6.1.2.1.14.20.1.2)
not-accessible
INTEGER
routerLink (1),                          networkLink (2),                          summaryLink (3),                          asSummaryLink (4),                         multicastLink (6),                       nssaExternalLink (7),                          areaOpaqueLink (10)
LSA type.
As per the MIB.
ospfAreaLsaCountNumber (1.3.6.1.2.1.14.20.1.3)
read-only
Gauge32
Number of LSAs of the specified type in the specified area.
As per the MIB.
