08-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10008-Layer 3 - IP Routing
01-BGP4-MIB
01-BGP4-MIB 100.17 KB
BGP4-MIB
About this MIB
This document contains MIB and Trap features compliant with RFC 4273.
MIB file name
rfc4273-bgp4.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).bgp(15)
Scalar objects
bgpVersion
Object (OID)
Access
Value range
Implementation
bgpVersion (1.3.6.1.2.1.15.1)
read-only
OCTET STRING
OCTET STRING (1..255)
Supported BGP version numbers.
As per the MIB.
bgpLocalAs
Object (OID)
Access
Value range
Implementation
bgpLocalAs (1.3.6.1.2.1.15.2)
read-only
Integer32
Integer32(-2147483648..2147483647)
Local AS number.
The value range for a 4-ocet AS number is 1 to 4294967295. If the AS number is greater than 2147483647, MIB displays a negative value.
bgpIdentifier
Object (OID)
Access
Value range
Implementation
bgpIdentifier (1.3.6.1.2.1.15.4)
read-only
IpAddress
OCTET STRING (4)
BGP identifier of the local device.
As per the MIB.
Tabular objects
bgpPeerTable
About this table
This table contains BGP peer configuration and statistics information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is bgpPeerRemoteAddr.
Object (OID)
Access
Value range
Implementation
bgpPeerIdentifier (1.3.6.1.2.1.15.3.1.1)
read-only
IpAddress
OCTET STRING (4)
BGP identifier of the peer.
As per the MIB.
bgpPeerState (1.3.6.1.2.1.15.3.1.2)
read-only
INTEGER
idle(1),
connect(2),
active(3),
opensent(4),
openconfirm(5),
established(6)
Peer connection state.
As per the MIB.
bgpPeerAdminStatus (1.3.6.1.2.1.15.3.1.3)
read-write
INTEGER
stop(1),
start(2)
Expected peer connection state.
As per the MIB.
bgpPeerNegotiatedVersion (1.3.6.1.2.1.15.3.1.4)
read-only
Integer32
Integer32(0..255)
Negotiated BGP version number.
As per the MIB.
bgpPeerLocalAddr (1.3.6.1.2.1.15.3.1.5)
read-only
IpAddress
OCTET STRING (4)
Local IP address of the peer connection.
As per the MIB.
bgpPeerLocalPort (1.3.6.1.2.1.15.3.1.6)
read-only
Integer32
Integer32(0..65535)
Local port number of the peer connection.
As per the MIB.
bgpPeerRemoteAddr (1.3.6.1.2.1.15.3.1.7)
read-only
IpAddress
OCTET STRING (4)
Remote IP address of the peer connection.
As per the MIB.
bgpPeerRemotePort (1.3.6.1.2.1.15.3.1.8)
read-only
Integer32
Integer32(0..65535)
Remote port number of the peer connection.
As per the MIB.
bgpPeerRemoteAs (1.3.6.1.2.1.15.3.1.9)
read-only
Integer32
AS number of the peer.
bgpPeerInUpdates (1.3.6.1.2.1.15.3.1.10)
read-only
Counter32
INTEGER(0..4294967295)
Number of update messages received from the peer.
As per the MIB.
bgpPeerOutUpdates (1.3.6.1.2.1.15.3.1.11)
read-only
Counter32
Number of update messages sent to the peer.
As per the MIB.
bgpPeerInTotalMessages (1.3.6.1.2.1.15.3.1.12)
read-only
Counter32
Number of packets received from the peer.
As per the MIB.
bgpPeerOutTotalMessages (1.3.6.1.2.1.15.3.1.13)
read-only
Counter32
Number of packets sent to the peer.
As per the MIB.
bgpPeerLastError (1.3.6.1.2.1.15.3.1.14)
read-only
OCTET STRING
OCTET STRING(2)
Error code and subcode for the most recent peer connection error.
As per the MIB.
bgpPeerFsmEstablishedTransitions (1.3.6.1.2.1.15.3.1.15)
read-only
Counter32
Number of times that the peer entered established state.
As per the MIB.
bgpPeerFsmEstablishedTime (1.3.6.1.2.1.15.3.1.16)
read-only
Gauge32
Time elapsed since the peer entered established state most recently.
As per the MIB.
bgpPeerConnectRetryInterval (1.3.6.1.2.1.15.3.1.17)
read-write
Integer32
Integer32(1..65535)
Peer connection retry timer.
As per the MIB.
bgpPeerHoldTime (1.3.6.1.2.1.15.3.1.18)
read-only
Integer32
Integer32 (0 | 3..65535)
Hold timer negotiated with the peer.
As per the MIB.
bgpPeerKeepAlive (1.3.6.1.2.1.15.3.1.19)
read-only
Integer32
Integer32 (0 | 1..21845)
Keepalive timer negotiated with the peer.
As per the MIB.
bgpPeerHoldTimeConfigured (1.3.6.1.2.1.15.3.1.20)
read-write
Integer32
Hold timer configured for the peer.
The value of this object cannot be 0.
bgpPeerKeepAliveConfigured (1.3.6.1.2.1.15.3.1.21)
read-write
Integer32
Keepalive timer configured for the peer.
bgpPeerMinASOriginationInterval (1.3.6.1.2.1.15.3.1.22)
read-write
Integer32
Integer32(1..65535)
Interval for sending the same route to the peer.
Value range: 0 to 600.
This object displays 0 if the value is set to 0.
bgpPeerMinRouteAdvertisementInterval (1.3.6.1.2.1.15.3.1.23)
read-write
Integer32
Integer32(1..65535)
bgpPeerInUpdateElapsedTime (1.3.6.1.2.1.15.3.1.24)
read-only
Gauge32
Time elapsed since the most recent update message was received from the peer.
As per the MIB.
bgpPathAttrTable
About this table
This table is obsolete. It contains BGP route path information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are bgpPathAttrDestNetwork and bgpPathAttrPeer.
Object (OID)
Access
Value range
Implementation
bgpPathAttrPeer (1.3.6.1.2.1.15.5.1.1)
read-only
IpAddress
OCTET STRING (4)
IP address of the peer from which the route was learned.
As per the MIB.
bgpPathAttrDestNetwork (1.3.6.1.2.1.15.5.1.2)
read-only
IpAddress
OCTET STRING (4)
Destination network address.
As per the MIB.
bgpPathAttrOrigin (1.3.6.1.2.1.15.5.1.3)
read-only
INTEGER
igp(1),
egp(2),
incomplete(3)
Ultimate origin of the path information.
As per the MIB.
bgpPathAttrASPath (1.3.6.1.2.1.15.5.1.4)
read-only
OCTET STRING
OCTET STRING (2..255)
The set of ASs that must be traversed to reach the network.
As per the MIB.
bgpPathAttrNextHop (1.3.6.1.2.1.15.5.1.5)
read-only
IpAddress
OCTET STRING (4)
Address of the border router for the destination network.
As per the MIB.
bgpPathAttrInterASMetric (1.3.6.1.2.1.15.5.1.6)
read-only
Integer32
Standard MIB values.
Optional inter-AS metric.
As per the MIB.
bgp4PathAttrTable
About this table
This table contains BGP route attribute information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are bgp4PathAttrIpAddrPrefix, bgp4PathAttrIpAddrPrefixLen, and bgp4PathAttrPeer.
Object (OID)
Access
Value range
Implementation
bgp4PathAttrPeer (1.3.6.1.2.1.15.6.1.1)
read-only
IpAddress
OCTET STRING (4)
As per the MIB.
bgp4PathAttrIpAddrPrefixLen (1.3.6.1.2.1.15.6.1.2)
read-only
Integer32
Integer32 (0..32)
Route prefix mask.
As per the MIB.
bgp4PathAttrIpAddrPrefix (1.3.6.1.2.1.15.6.1.3)
read-only
IpAddress
OCTET STRING (4)
Route prefix.
As per the MIB.
bgp4PathAttrOrigin (1.3.6.1.2.1.15.6.1.4)
read-only
INTEGER
igp(1),
egp(2),
incomplete(3)
As per the MIB.
bgp4PathAttrASPathSegment (1.3.6.1.2.1.15.6.1.5)
read-only
OCTET STRING
Sequence of AS path segments.
As per the MIB.
bgp4PathAttrNextHop (1.3.6.1.2.1.15.6.1.6)
read-only
IpAddress
OCTET STRING (4)
Next hop of the route.
As per the MIB.
bgp4PathAttrMultiExitDisc (1.3.6.1.2.1.15.6.1.7)
read-only
Integer32
Integer32(-1..2147483647)
MED value.
The object returns 2147483647 when the actual value is in the range of 2147483647 to 4294967295.
bgp4PathAttrLocalPref (1.3.6.1.2.1.15.6.1.8)
read-only
Integer32
Local preference.
bgp4PathAttrAtomicAggregate (1.3.6.1.2.1.15.6.1.9)
read-only
INTEGER
lessSpecificRouteNotSelected(1), lessSpecificRouteSelected(2)
Atomic aggregate attribute.
As per the MIB.
bgp4PathAttrAggregatorAS (1.3.6.1.2.1.15.6.1.10)
read-only
Integer32
AS number of the last device that performed route aggregation.
bgp4PathAttrAggregatorAddr (1.3.6.1.2.1.15.6.1.11)
read-only
IpAddress
OCTET STRING (4)
IP address of the last device that performed route aggregation.
As per the MIB.
bgp4PathAttrCalcLocalPref (1.3.6.1.2.1.15.6.1.12)
read-only
Integer32
Local preference calculated by the receiving device for an advertised route.
bgp4PathAttrBest (1.3.6.1.2.1.15.6.1.13)
read-only
INTEGER
false(1), true(2)
Whether the route is the optimal route.
As per the MIB.
bgp4PathAttrUnknown (1.3.6.1.2.1.15.6.1.14)
read-only
OCTET STRING
OCTET STRING (0..255)
Route attributes that cannot be identified.
As per the MIB.
Notifications
bgpEstablishedNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.15.0.1
A peer enters established state.
Recovery
ON
A notification sent when BGP FSM enters established state.
Status control
ON
CLI: Use the snmp-agent trap enable bgp command or the snmp-agent trap enable bgp peer-established command.
OFF
CLI: Use the undo snmp-agent trap enable bgp command or the undo snmp-agent trap enable bgp peer-established command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.15.3.1.7 (bgpPeerRemoteAddr)
No
IpAddress
1.3.6.1.2.1.15.3.1.14 (bgpPeerLastError)
No
DisplayString
OCTET STRING (2)
1.3.6.1.2.1.15.3.1.2 (bgpPeerState)
No
INTEGER
idle(1)
connect(2)
active(3)
opensent(4)
openconfirm(5)
established(6)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
bgpBackwardTransNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.15.0.2
A peer enters a lower numbered state.
Recovery
Warning
ON
A notification sent when BGP FSM enters a lower numbered state.
Status control
ON
CLI: Use the snmp-agent trap enable bgp command or the snmp-agent trap enable bgp peer-backward-transition command.
OFF
CLI: Use the undo snmp-agent trap enable bgp command or the undo snmp-agent trap enable bgp peer-backward-transition command.
Objects
OID (object name)
Index
Value range
No
IpAddress
OCTET STRING (4)
No
DisplayString
OCTET STRING (2)
No
INTEGER
idle(1)
connect(2)
active(3)
opensent(4)
openconfirm(5)
established(6)
Recommended action
To resolve the issue:
1.     Verify that the notification is triggered by link state changes.
2.     If the issue persists, contact H3C Support.
bgpEstablished
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.15.7.1
Recovery
ON
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
DisplayString
OCTET STRING (2)
No
INTEGER
idle(1)
connect(2)
active(3)
opensent(4)
openconfirm(5)
established(6)
Recommended action
bgpBackwardTransition
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.15.7.2
Error
Warning
ON
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
DisplayString
OCTET STRING (2)
No
INTEGER
idle(1)
connect(2)
active(3)
opensent(4)
openconfirm(5)
established(6)
Recommended action
To resolve this issue:
