08-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10008-Layer 3 - IP Routing
03-HH3C-ISIS-MIB
03-HH3C-ISIS-MIB 59.54 KB
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs by using the hh3cIsisSysInstance node.
MIB file name
hh3c-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIsis(59)
Global objects
hh3cIsisSysInstance
Object (OID)
Access
Value range
Implementation
hh3cIsisSysInstance (1.3.6.1.4.1.25506.2.59.1.1.1.1.1)
read-only
Integer32
Integer32 (1..65535)
Process node.
As per the MIB.
hh3cIsisCircIndex
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIndex
(1.3.6.1.4.1.25506.2.59.1.3.1.1.1)
not-accessible
Unsigned32
Unsigned32(1..100)
Interface index node.
As per the MIB.
hh3cIsisCircIfIndex
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIfIndex
(1.3.6.1.4.1.25506.2.59.1.3.1.1.2)
read-only
Integer32
As per the MIB.
isisNotificationSysLevelIndex
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex)
System level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
isisNotificationCircIfIndex
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex)
Interface index.
No
Unsigned32
Unsigned32(1..2147483647)
isisPduLspId
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId)
LSP ID.
No
IsisLinkStatePDUID
OCTET STRING (8)
hh3cIsisAdjProtoType
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.59.1.2.1.1
(hh3cIsisAdjProtoType)
Protocol type.
No
INTEGER
ipv4(1)
ipv6(1)
hh3cIsisAdjProtoState
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.59.1.2.1.2
 (hh3cIsisAdjProtoState)
Neighbor state.
No
INTEGER
down (1)
initializing (2)
up (3)
ifName
OID (object name)
Index
Value range
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name.
No
DisplayString
OCTET STRING(0..255)
Tabular objects
hh3cIsisSysTable
About this table
This table contains information about all IS-IS process IDs.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIsisSysInstance.
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Process node.
As per the MIB.
hh3cIsisCircTable
About this table
This table contains information about all interfaces enabled with IS-IS.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIsisSysInstance and hh3cIsisCircIndex.
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIndex
not-accessible
Unsigned32
Unsigned32(1..100)
As per the MIB.
hh3cIsisCircIfIndex
read-only
Integer32
As per the MIB.
Notifications
hh3cIsisAdjacencyProtocolChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.59.0.1
Address family state change
Informational
Informational
ON
This notification is generated when a change in address family has occurred.
Status control
ON
CLI: Use the snmp-agent trap enable isis adjacency-protocol-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis adjacency-protocol-change command.
Objects
OID (object name)
Index
Value range
System level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
LSP ID.
No
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.6.3.1.2
(hh3cIsisProtoState)
IP protocol state.
No
INTEGER
ipv4up (1)
ipv4down (2)
ipv6up (3)
ipv6down(4)
Interface name.
No
DisplayString
Recommended action
Check whether the address family change is normal. If the issue persists, please contact the H3C technical support.
