- 02-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 13-POWER-ETHERNET-MIB | 65.06 KB |
POWER-ETHERNET-MIB
About this MIB
Use this MIB to query for and manage Power Source Equipment (PSE) working.
MIB file name
rfc3621-power-ethernet.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).powerEthernetMIB(105)
Tabular objects
pethPsePortTable
About this table
Use this table to obtain and control the power characteristics of power Ethernet ports on a PSE.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pethPsePortGroupIndex (1.3.6.1.2.1.105.1.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
PSE port group index. |
As per the MIB. |
pethPsePortIndex (1.3.6.1.2.1.105.1.1.1.2) |
not-accessible |
Integer32 |
PSE port index. |
As per the MIB. |
pethPsePortAdminEnable (1.3.6.1.2.1.105.1.1.1.3) |
read-write |
TruthValue |
true(1), |
Whether the port can provide the PSE functions. |
As per the MIB. |
pethPsePortPowerPairsControlAbility (1.3.6.1.2.1.105.1.1.1.4) |
read-only |
TruthValue |
true(1), |
Capability of controlling the power pairs functionality to switch pins for sourcing power. |
As per the MIB. |
pethPsePortPowerPairs (1.3.6.1.2.1.105.1.1.1.5) |
read-write |
INTEGER |
signal(1), |
Pairs in use. |
As per the MIB. If the value of pethPsePortPowerPairsControl is true, this object is writable. A value of signal(1) means that the signal pairs (1, 2, 3, 6) only are in use. A value of spare(2) means that the spare pairs (4, 5, 7, 8) only are in use. |
pethPsePortDetectionStatus (1.3.6.1.2.1.105.1.1.1.6) |
read-only |
INTEGER |
disabled(1), |
Operational status of the port PD detection. |
As per the MIB. |
pethPsePortPowerPriority (1.3.6.1.2.1.105.1.1.1.7) |
read-write |
INTEGER |
critical(1), |
PSE port power priority. |
As per the MIB. |
pethPsePortMPSAbsentCounter (1.3.6.1.2.1.105.1.1.1.8) |
read-only |
Counter32 |
Standard MIB values |
This counter is incremented when the PSE state diagram transitions directly from the POWER_ON state to the IDLE state due to tmpdo_timer_done being asserted. |
As per the MIB. |
pethPsePortType (1.3.6.1.2.1.105.1.1.1.9) |
read-write |
SnmpAdminString |
OCTET STRING (0..255) |
Type of powered device connected to the port. |
As per the MIB. A zero-length octet string is not supported. |
pethPsePortPowerClassifications (1.3.6.1.2.1.105.1.1.1.10) |
read-only |
INTEGER |
class0(1), |
Class of the powered device by its power consumption. |
As per the MIB. This object takes effect only when the PD is being powered. |
pethPsePortInvalidSignatureCounter (1.3.6.1.2.1.105.1.1.1.11) |
read-only |
Counter32 |
This counter is incremented when the PSE state diagram enters the SIGNATURE_INVALID state. |
As per the MIB. |
pethPsePortPowerDeniedCounter (1.3.6.1.2.1.105.1.1.1.12) |
read-only |
Counter32 |
This counter is incremented when the PSE state diagram enters the POWER_DENIED state. |
As per the MIB. |
pethPsePortOverLoadCounter (1.3.6.1.2.1.105.1.1.1.13) |
read-only |
Counter32 |
This counter is incremented when the PSE state diagram enters the ERROR_DELAY_OVER state. |
As per the MIB. |
pethPsePortShortCounter (1.3.6.1.2.1.105.1.1.1.14) |
read-only |
Counter32 |
This counter is incremented when the PSE state diagram enters the ERROR_DELAY_SHORT state. |
As per the MIB. |
pethMainPseTable
About this table
Use this table to obtain and control attributes of the main power source on a PSE device.
This table is not supported on non-default MDCs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is pethMainPseGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pethMainPseGroupIndex (1.3.6.1.2.1.105.1.3.1.1.1) |
not-accessible |
Integer32 |
Index of the group to which a power Ethernet PSE is connected. |
As per the MIB. |
pethMainPsePower (1.3.6.1.2.1.105.1.3.1.1.2) |
read-only |
Gauge32 |
Gauge32 (1..65535) |
Nominal power of the PSE, in watts. |
As per the MIB. |
pethMainPseOperStatus (1.3.6.1.2.1.105.1.3.1.1.3) |
read-only |
INTEGER |
on(1), |
Operational status of the main PSE. |
As per the MIB. |
pethMainPseConsumptionPower (1.3.6.1.2.1.105.1.3.1.1.4) |
read-only |
Gauge32 |
PSE power usage in watts. |
As per the MIB. |
pethMainPseUsageThreshold (1.3.6.1.2.1.105.1.3.1.1.5) |
read-write |
Integer32 |
Integer32 (1..99) |
PSE power usage threshold. |
As per the MIB. |
pethNotificationControlTable
About this table
Use this table to control and obtain PSE notifications.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is pethNotificationControlGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pethNotificationControlGroupIndex (1.3.6.1.2.1.105.1.4.1.1.1) |
not-accessible |
Integer32 |
Index of the notification control group. |
As per the MIB. |
pethNotificationControlEnable (1.3.6.1.2.1.105.1.4.1.1.2) |
read-write |
INTEGER |
true(1), |
Whether or not to enable notifications. |
As per the MIB. |
Notifications
This section contains the POWER-ETHERNET-MIB notifications.
pethPsePortOnOffNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.105.0.1 |
PSE port status change |
Informational |
N/A |
N/A |
ON |
This notification indicates if a PSE port is delivering or not power to the PD. It is generated when a PSE port changes its status except in the searching mode. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus) |
PD detection status of a PSE port |
N |
INTEGER |
disabled(1) searching(2) deliveringPower(3) fault(4) test(5) otherFault(6) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
pethMainPowerUsageOnNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.105.0.2 |
PSE power usage threshold reached |
Error |
Minor |
1.3.6.1.2.1.105.0.3(pethMainPowerUsageOffNotification) |
ON |
This notification is generated when the PSE power usage reaches the threshold. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.105.1.3.1.1.4 (pethMainPseConsumptionPower) |
PSE power usage |
N |
Gauge32 |
0..4294967295 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.105.0.3 |
PSE power usage dropped below the threshold |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the PSE power usage falls below the threshold. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
PSE power consumption |
N |
Gauge32 |
0..4294967295 |
Recommended action
