- 02-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 06-HH3C-LSW-DEV-ADM-MIB | 118.44 KB |
About this MIB
Use this MIB to obtain basic device information about chassis, slots, CPUs, and ports.
MIB file name
hh3c-lsw-dev-adm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswDeviceAdmin(18)
Scalar objects
hh3cLswSysIpAddr
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1) |
read-only |
IpAddress |
Standard MIB values. |
IP address of a VLAN interface. |
As per the MIB. |
hh3cLswSysIpMask
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2) |
read-only |
IpAddress |
Subnet mask for the system IP address. |
As per the MIB. |
hh3cLswSysCpuRatio
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3) |
read-only |
Integer32 |
Integer32 (0..100) |
Real-time CPU usage on the card in 1-minute intervals. For distributed devices in IRF mode, this object indicates the real-time CPU usage on the active MPU in the system. |
As per the MIB. |
hh3cLswSysVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4) |
read-only |
DisplayString |
OCTET STRING (1..64) |
Version of the system. For distributed devices in IRF mode, this object indicates the version of the active MPU in the system. |
As per the MIB. |
hh3cLswSysTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5) |
read-write |
DateAndTime |
OCTET STRING (8 | 11) |
System time of the device. For distributed devices in IRF mode, this object indicates the system time of the active MPU in the system. |
Supports only the read operation on the non-default MDC. |
hh3cLswSysPhyMemory
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Physical memory space of the device, in bytes. For distributed devices, this object indicates the physical memory space of the active MPU in the system. |
As per the MIB. |
hh3cLswSysMemory
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14) |
read-only |
Unsigned32 |
System memory space, in bytes. For distributed devices, this object indicates the system memory space of the active MPU in the system. |
As per the MIB. |
hh3cLswSysMemoryUsed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15) |
read-only |
Unsigned32 |
Used system memory, in bytes. For distributed devices, this object indicates the used system memory on the active MPU in the system. |
As per the MIB. |
hh3cLswSysMemoryRatio
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16) |
read-only |
Unsigned32 |
Unsigned32 (0..100) |
Percentage of the used system memory on the device. For distributed devices, this object indicates the percentage of the used system memory on the active MPU in the system. |
As per the MIB. |
hh3cLswSysPhyMemRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18) |
read-only |
CounterBasedGauge64 |
As per the MIB. |
hh3cLswSysMemRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19) |
read-only |
As per the MIB. |
hh3cLswSysMemUsedRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20) |
read-only |
As per the MIB. |
Tabular objects
hh3cLswFrameTable
About this table
This table contains chassis-level information about devices.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cLswFrameIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswFrameIndex (1.3.6.1.4.1.25506.8.35.18.4.2.1.1) |
read-only |
Integer32 |
Integer32 (-2147483648..2147483647) |
Chassis index. |
As per the MIB. |
hh3cLswFrameDesc (1.3.6.1.4.1.25506.8.35.18.4.2.1.3) |
read-write |
DisplayString |
OCTET STRING (0..64) |
Description of the chassis. |
hh3cLswSlotNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.4) |
read-only |
Integer32 |
Number of slots in the current chassis. |
As per the MIB. |
hh3cLswFrameAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.2.1.5) |
read-only |
INTEGER |
normal(1), |
Chassis status. |
As per the MIB. |
hh3cLswFrameSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.6) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
Serial number of the chassis. |
As per the MIB. |
hh3cLswSlotTable
About this table
This table contains card information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSlotIndex (1.3.6.1.4.1.25506.8.35.18.4.3.1.1) |
read-only |
Integer32 |
Card index. |
As per the MIB. |
hh3cLswSlotType (1.3.6.1.4.1.25506.8.35.18.4.3.1.2) |
read-only |
Integer32 |
Card type. |
Implementation varies by product. |
hh3cLswSlotDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.3) |
read-write |
DisplayString |
Description of the card. |
hh3cLswSlotCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.4) |
read-only |
Integer32 |
CPU usage on the card. |
As per the MIB. |
hh3cLswSlotPcbVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.5) |
read-only |
DisplayString |
Hardware version of the card. |
As per the MIB. |
hh3cLswSlotSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.6) |
read-only |
DisplayString |
Software version of the card. |
As per the MIB. |
hh3cLswSubslotNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.7) |
read-only |
Integer32 |
Number of subcards. |
As per the MIB. |
hh3cLswSlotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.8) |
read-only |
INTEGER |
not-install(1), normal(2), fault(3), forbidden(4) |
Administrative status of the card. |
As per the MIB. |
hh3cLswSlotOperStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.9) |
read-write |
INTEGER |
disable(1), enable(2), reset(3), test(4) |
Operation status of the card. |
Supports only reset. Supports only the read operation on the non-default MDC. |
hh3cLswSlotPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.10) |
read-only |
Unsigned32 |
Physical memory space of the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.11) |
read-only |
Unsigned32 |
System memory space of the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.3.1.12) |
read-only |
Unsigned32 |
Used system memory on the card, in bytes. The memory is a 32-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.13) |
read-only |
Unsigned32 |
Percentage of the system used memory on the card, in bytes. |
As per the MIB. |
hh3cLswSlotTemperature (1.3.6.1.4.1.25506.8.35.18.4.3.1.14) |
read-only |
Integer32 |
Temperature of the card. |
Not supported |
hh3cLswSlotPktBufFree (1.3.6.1.4.1.25506.8.35.18.4.3.1.15) |
read-only |
Integer32 |
Number of free packet buffers on the card. |
As per the MIB. |
hh3cLswSlotPktBufInit (1.3.6.1.4.1.25506.8.35.18.4.3.1.16) |
read-only |
Integer32 |
Number of packet buffers on the card. |
As per the MIB. |
hh3cLswSlotPktBufMin (1.3.6.1.4.1.25506.8.35.18.4.3.1.17) |
read-only |
Integer32 |
Minimum number of packet buffers on the card. |
As per the MIB. |
hh3cLswSlotPktBufMiss (1.3.6.1.4.1.25506.8.35.18.4.3.1.18) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Packet loss counting in packet buffers on the card. |
As per the MIB. |
hh3cLswSlotRunTime (1.3.6.1.4.1.25506.8.35.18.4.3.1.19) |
read-only |
DisplayString |
Running time of the card. |
As per the MIB. |
hh3cLswSlotMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.20) |
read-only |
Counter64 |
System memory space of the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotPhyMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.21) |
read-only |
Counter64 |
Physical memory space of the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotMemUsedRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.22) |
read-only |
Counter64 |
Used system memory on the card, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswSlotModelDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.23) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Description of the extended module in the slot. |
As per the MIB. |
hh3cLswSlotPktBufThreshold (1.3.6.1.4.1.25506.8.35.18.4.3.1.24) |
read-write |
Integer32 |
Integer32 (1..100) |
Threshold for the number of packet buffers on the card. |
As per the MIB. |
hh3cLswSlotSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.25) |
read-only |
SnmpAdminString |
Serial number of the card. |
As per the MIB. |
hh3cLswSubslotTable
About this table
This table contains subcard information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswSubslotIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswSubslotIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.1) |
read-only |
Integer32 |
Subcard index. |
As per the MIB. |
hh3cLswSubslotType (1.3.6.1.4.1.25506.8.35.18.4.4.1.2) |
read-only |
Integer32 |
Subcard type. |
hh3cLswSubslotPortNum (1.3.6.1.4.1.25506.8.35.18.4.4.1.3) |
read-only |
Integer32 |
Port number of the subcard. |
As per the MIB. |
hh3cLswSubslotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.4.1.4) |
read-only |
INTEGER |
not-install(1), |
Status of the subacard. |
As per the MIB. |
hh3cLswSubslotFirstIfIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.5) |
read-only |
Integer32 |
Index of the first physical port on the subcard. |
Supports only Ethernet ports. |
hh3cLswSubslotSerialNumber(1.3.6.1.4.1.25506.8.35.18.4.4.1.6) |
read-only |
SnmpAdminString |
Serial number of the subcard. |
As per the MIB. |
hh3cLswPortTable
About this table
This table contains port information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswPortIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.1) |
read-only |
Integer32 |
Port index. |
As per the MIB. |
hh3cLswPortType (1.3.6.1.4.1.25506.8.35.18.4.5.1.2) |
read-only |
Integer32 |
Port type. |
hh3cLswPortIfIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.3) |
read-only |
Integer32 |
Index of the interface attached to the port. |
As per the MIB. |
Hh3cLswPortIsPlugged (1.3.6.1.4.1.25506.8.35.18.4.5.1.4) |
read-only |
INTEGER |
unplugged(0), |
Connection status of the port. |
As per the MIB. |
hh3cLswFabricTable
About this table
This table contains fabric module channel information.
This table does not support the read operation only on the default MDC.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswFabricChannelIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswFabricChannelIndex (1.3.6.1.4.1.25506.8.35.18.4.7.1.1) |
not-accessible |
Integer32 |
Channel index. |
As per the MIB. |
hh3cLswFabricUtilIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.2) |
read-only |
Integer32 |
Ingress utilization of the channel. |
As per the MIB. |
hh3cLswFabricUtilOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.3) |
read-only |
Integer32 |
Egress utilization of the channel. |
As per the MIB. |
hh3cLswFabricPeakIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.4) |
read-only |
Integer32 |
Peak ingress utilization of the channel. |
As per the MIB. |
hh3cLswFabricPeakInTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.5) |
read-only |
DateAndTime |
Time at which peak ingress utilization of the channel is present. |
As per the MIB. |
hh3cLswFabricPeakOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.6) |
read-only |
Integer32 |
Peak egress utilization of the channel. |
As per the MIB. |
hh3cLswFabricPeakOutTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.7) |
read-only |
DateAndTime |
Time at which peak egress utilization of the channel is present. |
As per the MIB. |
hh3cLswExtendModelTable
About this table
This table contains extended module information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cLswExtendModelIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswExtendModelIndex (1.3.6.1.4.1.25506.8.35.18.4.9.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Extended module index. |
As per the MIB. |
hh3cLswExtendModelDesc (1.3.6.1.4.1.25506.8.35.18.4.9.1.2) |
read-only |
DisplayString |
Description of the Extended module. |
As per the MIB. |
hh3cLswCpuTable
About this table
This table contains CPU information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswCpuIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCpuIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.1) |
not-accessible |
PhysicalIndex |
Integer32 (0..2147483647) |
CPU index. |
As per the MIB. |
hh3cLswCpuEntityIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.2) |
read-only |
Integer32 |
Index of the CPU entity. |
As per the MIB. |
hh3cLswCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.3) |
read-only |
Unsigned32 |
Real-time CPU usage on the host. |
As per the MIB. |
hh3cLswCpuSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.10.1.4) |
read-only |
DisplayString |
CPU software version. |
As per the MIB. |
hh3cLswCpuAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.5) |
read-only |
INTEGER |
notInstall(1), |
CPU status. |
As per the MIB. |
hh3cLswCpuOperStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.6) |
read-write |
INTEGER |
disable(1), |
Operation status of the CPU. |
Supports reset only on the active CPU. Supports the read operation only on the non-default MDC. |
hh3cLswCpuPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.7) |
read-only |
Counter64 |
Physical memory space of the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.8) |
read-only |
Counter64 |
System memory space of the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.9) |
read-only |
Counter64 |
Used memory on the node, in bytes. The memory is a 64-bit wide memory. |
As per the MIB. |
hh3cLswCpuMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.10) |
read-only |
Unsigned32 |
Percentage of the used memory on the node. |
As per the MIB. |
hh3cLswCpuMemoryFree (1.3.6.1.4.1.25506.8.35.18.4.10.1.14) |
read-only |
Free memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryFreeRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.15) |
read-only |
Unsigned32 |
Percentage of the free memory. |
As per the MIB. |
hh3cLswCpuMemoryHighTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.16) |
read-only |
Total high memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryHighFree (1.3.6.1.4.1.25506.8.35.18.4.10.1.17) |
read-only |
Free high memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryLowTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.18) |
read-only |
Total low memory size, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryLowFree (1.3.6.1.4.1.25506.8.35.18.4.10.1.19) |
read-only |
Free low memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryVmallocTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.20) |
read-only |
Total vmalloc memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryVmallocUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.21) |
read-only |
Used vmalloc memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryVmallocChunk (1.3.6.1.4.1.25506.8.35.18.4.10.1.22) |
read-only |
Number of chunks for the vmalloc memory. |
As per the MIB. |
hh3cLswCpuMemoryCommitLimit (1.3.6.1.4.1.25506.8.35.18.4.10.1.23) |
read-only |
Memory size that can be allocated to the system, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryCommittedAs (1.3.6.1.4.1.25506.8.35.18.4.10.1.24) |
read-only |
Committed_As memory, in bytes. |
As per the MIB. |
hh3cLswCpuMemoryThresholdUnit (1.3.6.1.4.1.25506.8.35.18.4.10.1.25) |
read-write |
INTEGER |
inMB(1), inPercentage(2) |
Unit of memory thresholds. |
As per the MIB. |
hh3cLswCpuMemorySecureThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.26) |
read-write |
Unsigned32 |
Sufficient-memory threshold for the memory. |
As per the MIB. |
hh3cLswCpuMemoryEarlyWarningThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.27) |
read-write |
Unsigned32 |
Early-warning threshold for the memory. |
As per the MIB. |
hh3cLswCpuMemoryNormalThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.28) |
read-write |
Unsigned32 |
Normal state threshold for the memory. |
As per the MIB. |
hh3cLswCpuMemoryMinorThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.29) |
read-write |
Unsigned32 |
Minor memory alarm threshold. |
As per the MIB. |
hh3cLswCpuMemorySevereThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.30) |
read-write |
Unsigned32 |
Major memory alarm threshold. |
As per the MIB. |
hh3cLswCpuMemoryCriticalThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.31) |
read-write |
Unsigned32 |
Critical memory alarm threshold. |
As per the MIB. |
hh3cLswCpuMemoryCurrentState (1.3.6.1.4.1.25506.8.35.18.4.10.1.32) |
read-only |
INTEGER |
secure(1), earlywarning(2), normal(3), minor(4), severe(5), critical(6) |
Current memory status. |
As per the MIB. |
hh3cLswPowerTable
About this table
This table contains power supply information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswPowerIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswPowerIndex (1.3.6.1.4.1.25506.8.35.18.4.11.1.1) |
read-only |
Integer32 |
Power supply index. |
As per the MIB. |
hh3cLswPowerSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.11.1.2) |
read-only |
SnmpAdminString |
Serial number of the power supply. |
As per the MIB. |
hh3cLswFanTable
About this table
This table contains fan information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswFanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswFanIndex (1.3.6.1.4.1.25506.8.35.18.4.12.1.1) |
read-only |
Integer32 |
Fan index. |
As per the MIB. |
hh3cLswFanSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.12.1.2) |
read-only |
SnmpAdminString |
Serial number of the fan. |
As per the MIB. |
hh3cLswTransceiverTable
About this table
This table contains transceiver module information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswTransceiverIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswTransceiverIndex (1.3.6.1.4.1.25506.8.35.18.4.13.1.1) |
read-only |
Integer32 |
Transceiver module index. |
As per the MIB. |
hh3cLswTransceiverSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.13.1.2) |
read-only |
SnmpAdminString |
Serial number of the transceiver module. |
As per the MIB. |
hh3cLswCoreTable
About this table
This table contains CPU core information.
Support for this table varies by product.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswCpuIndex, and hh3cLswCoreIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCoreIndex (1.3.6.1.4.1.25506.8.35.18.4.15.1.1) |
read-only |
Integer32 |
CPU core index. |
As per the MIB. |
hh3cLswCoreUsageInLast5Sec (1.3.6.1.4.1.25506.8.35.18.4.15.1.2) |
read-only |
Unsigned32 |
CPU core usage in the most recent 5-second interval. |
As per the MIB. |
hh3cLswCoreUsageInLast1Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.3) |
read-only |
Unsigned32 |
CPU core usage in the most recent 1-minute interval. |
As per the MIB. |
hh3cLswCoreUsageInLast5Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.4) |
read-only |
Unsigned32 |
CPU core usage in the most recent 5-minute interval. |
As per the MIB. |
hh3cLswCoreThreshold (1.3.6.1.4.1.25506.8.35.18.4.15.1.5) |
read-write |
Unsigned32 |
CPU core alarm threshold. |
As per the MIB. |
hh3cLswCoreState (1.3.6.1.4.1.25506.8.35.18.4.15.1.6) |
read-only |
INTEGER |
normal(1), |
CPU core status. |
As per the MIB. |
