- 02-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 11-HH3C-TRANSCEIVER-INFO-MIB | 105.50 KB |
About this MIB
Use this MIB to obtain information about transceiver modules, including vendor information and physical transmission characteristics.
MIB file name
hh3c-transceiver-info.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTransceiver(70)
Tabular objects
hh3cTransceiverInfoTable
About this table
Use this table to obtain information about transceiver modules.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTransceiverHardwareType (1.3.6.1.4.1.25506.2.70.1.1.1.1) |
read-only |
OCTET STRING |
Standard MIB values. |
Hardware type of the transceiver module, such as single mode (SM). |
As per the MIB. |
hh3cTransceiverType (1.3.6.1.4.1.25506.2.70.1.1.1.2) |
read-only |
OCTET STRING |
Type of the transceiver module, such as SFP. |
As per the MIB. |
hh3cTransceiverWaveLength (1.3.6.1.4.1.25506.2.70.1.1.1.3) |
read-only |
Integer32 |
Wavelength of the transceiver module, in nm. |
As per the MIB. |
hh3cTransceiverVendorName (1.3.6.1.4.1.25506.2.70.1.1.1.4) |
read-only |
OCTET STRING |
Vendor name of the transceiver module. |
As per the MIB. |
hh3cTransceiverSerialNumber (1.3.6.1.4.1.25506.2.70.1.1.1.5) |
read-only |
OCTET STRING |
Serial number of the transceiver module. |
As per the MIB. |
hh3cTransceiverFiberDiameterType (1.3.6.1.4.1.25506.2.70.1.1.1.6) |
read-only |
INTEGER |
fiber9(1), |
Fiber diameter for the transceiver module, in microns (μm). |
As per the MIB. |
hh3cTransceiverTransferDistance (1.3.6.1.4.1.25506.2.70.1.1.1.7) |
read-only |
Integer32 |
Maximum transmission distance of the transceiver module, in meters. |
As per the MIB. |
hh3cTransceiverDiagnostic (1.3.6.1.4.1.25506.2.70.1.1.1.8) |
read-only |
TruthValue |
true(1), |
Whether the transceiver module supports digital diagnosis. |
As per the MIB. |
hh3cTransceiverCurTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.9) |
read-only |
Integer32 |
Current transmit power of the transceiver module, in dBm, accurate to 0.01 dBm. |
The object returns 2147483647 when read if the device does not support this parameter. |
hh3cTransceiverMaxTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.10) |
read-only |
Integer32 |
Maximum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm. |
hh3cTransceiverMinTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.11) |
read-only |
Integer32 |
Minimum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm. |
hh3cTransceiverCurRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.12) |
read-only |
Integer32 |
Current receive power in dBm of the transceiver module, accurate to 0.01 dBm. |
hh3cTransceiverMaxRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.13) |
read-only |
Integer32 |
Maximum receive power of the transceiver module, in dBm, accurate to 0.01 dBm. |
hh3cTransceiverMinRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.14) |
read-only |
Integer32 |
Minimum receive power of the transceiver module, in dBm, accurate to 0.01 dBm. |
hh3cTransceiverTemperature (1.3.6.1.4.1.25506.2.70.1.1.1.15) |
read-only |
Integer32 |
Current temperature of the transceiver module, in °C. |
As per the MIB. |
hh3cTransceiverVoltage (1.3.6.1.4.1.25506.2.70.1.1.1.16) |
read-only |
Integer32 |
Current voltage of the transceiver module, in V, accurate to 0.01 V. |
As per the MIB. |
hh3cTransceiverBiasCurrent (1.3.6.1.4.1.25506.2.70.1.1.1.17) |
read-only |
Integer32 |
Current bias current of the transceiver module, in mA, accurate to 0.01 mA. |
As per the MIB. |
hh3cTransceiverTempHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.18) |
read-only |
Integer32 |
High temperature alarm threshold in °C, accurate to 0.001 °C , for example, 49120 representing 49.120 °C |
As per the MIB. |
hh3cTransceiverTempLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.19) |
read-only |
Integer32 |
Low temperature alarm threshold in °C, accurate to 0.001 °C |
As per the MIB. |
hh3cTransceiverTempHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.20) |
read-only |
Integer32 |
High temperature warning threshold in °C, accurate to 0.001 °C |
As per the MIB. |
hh3cTransceiverTempLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.21) |
read-only |
Integer32 |
Low temperature warning threshold in °C, accurate to 0.001 °C |
As per the MIB. |
hh3cTransceiverVccHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.22) |
read-only |
Integer32 |
High voltage alarm threshold in µV, accurate to 0.01 µV. |
As per the MIB. This object returns 0 when read if the transceiver module does not support this parameter. |
hh3cTransceiverVccLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.23) |
read-only |
Integer32 |
Low voltage alarm threshold in µV, accurate to 0.01 µV. |
hh3cTransceiverVccHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.24) |
read-only |
Integer32 |
High voltage warning threshold in µV, accurate to 0.01 µV. |
hh3cTransceiverVccLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.25) |
read-only |
Integer32 |
Low voltage warning threshold in mV, accurate to 0.01 µV. |
hh3cTransceiverBiasHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.26) |
read-only |
Integer32 |
High bias current alarm threshold in µA. |
hh3cTransceiverBiasLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.27) |
read-only |
Integer32 |
Low bias current alarm threshold in µA. |
hh3cTransceiverBiasHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.28) |
read-only |
Integer32 |
High bias current warning threshold in µA. |
hh3cTransceiverBiasLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.29) |
read-only |
Integer32 |
Low bias current warning threshold in µA. |
hh3cTransceiverPwrOutHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.30) |
read-only |
Integer32 |
High transmit power alarm threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverPwrOutLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.31) |
read-only |
Integer32 |
Low transmit power alarm threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverPwrOutHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.32) |
read-only |
Integer32 |
High transmit power warning threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverPwrOutLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.33) |
read-only |
Integer32 |
Low transmit power warning threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverRcvPwrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.34) |
read-only |
Integer32 |
High receive power alarm threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverRcvPwrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.35) |
read-only |
Integer32 |
Low receive power alarm threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverRcvPwrHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.36) |
read-only |
Integer32 |
High receive power warning threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverRcvPwrLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.37) |
read-only |
Integer32 |
Low receive power warning threshold in µW, accurate to 0.1 µW. |
hh3cTransceiverErrors (1.3.6.1.4.1.25506.2.70.1.1.1.38) |
read-only |
BITS |
BITS { Unused(20-31) |
Error information about the transceiver module. |
As per the MIB. |
hh3cTransceiverVendorOUI (1.3.6.1.4.1.25506.2.70.1.1.1.39) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Vendor OUI of the transceiver module. |
As per the MIB. |
hh3cTransceiverRevisionNumber (1.3.6.1.4.1.25506.2.70.1.1.1.40) |
read-only |
SnmpAdminString |
Revision number of the transceiver module. |
As per the MIB. |
hh3cTransceiverFrequency (1.3.6.1.4.1.25506.2.70.1.1.1.41) |
read-only |
Integer32 |
Frequency of the current ITU channel, in THz, accurate to 0.01 THz. |
As per the MIB. |
hh3cTransceiverActiveITUChannel (1.3.6.1.4.1.25506.2.70.1.1.1.42) |
read-write |
Unsigned32 |
Unsigned32 (1.. 4294967295) |
Index of the current ITU channel. |
As per the MIB. |
hh3cTransceiverCurWaveErr (1.3.6.1.4.1.25506.2.70.1.1.1.43) |
read-only |
Integer32 |
Wavelength offset of the current ITU channel, in nm, accurate to 0.001 nm. |
As per the MIB. |
hh3cTransceiverWaveErrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.44) |
read-only |
Integer32 |
High wavelength offset alarm threshold for the current ITU channel, in nm, accurate to 0.001 nm.. |
As per the MIB. |
hh3cTransceiverWaveErrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.45) |
read-only |
Integer32 |
Low wavelength offset alarm threshold for the current ITU channel, in nm, accurate to 0.001 nm. |
As per the MIB. |
hh3cTransceiverCurFreqErr (1.3.6.1.4.1.25506.2.70.1.1.1.46) |
read-only |
Integer32 |
Frequency offset of the current ITU channel, in GHz, accurate to 0.1 GHz. |
As per the MIB. |
hh3cTransceiverFreqErrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.47) |
read-only |
Integer32 |
High frequency offset alarm threshold for the current ITU channel, in GHz, accurate to 0.1 GHz. |
As per the MIB. |
hh3cTransceiverFreqErrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.48) |
read-only |
Integer32 |
Low frequency offset alarm threshold for the current ITU channel, in GHz, accurate to 0.1 GHz. |
As per the MIB. |
hh3cTransceiverPartNumber (1.3.6.1.4.1.25506.2.70.1.1.1.49) |
read-only |
OCTET STRING |
Part number of the transceiver module. |
As per the MIB. |
hh3cTransceiverProductCode (1.3.6.1.4.1.25506.2.70.1.1.1.50) |
read-only |
OCTET STRING |
Product code of the transceiver module. |
As per the MIB. |
hh3cTransceiverOriginalSN (1.3.6.1.4.1.25506.2.70.1.1.1.51) |
read-only |
OCTET STRING |
Original serial number of the transceiver module. |
As per the MIB. |
hh3cTransceiverChannelTable
About this table
Use this table to obtain statistics about channels of a transceiver module.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex and hh3cTransceiverChannelIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTransceiverChannelIndex (1.3.6.1.4.1.25506.2.70.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Transceiver module channel index. |
As per the MIB. |
hh3cTransceiverChannelCurTXPower (1.3.6.1.4.1.25506.2.70.1.2.1.2) |
read-only |
Integer32 |
Current transmit power in dBm, accurate to 0.01 dBm. |
This object returns 2147483647 when read if this parameter is not supported. |
hh3cTransceiverChannelCurRXPower (1.3.6.1.4.1.25506.2.70.1.2.1.3) |
read-only |
Integer32 |
Current receiver power in dBm, accurate to 0.01 dBm. |
hh3cTransceiverChannelTemperature (1.3.6.1.4.1.25506.2.70.1.2.1.4) |
read-only |
Integer32 |
Current temperature in °C. |
hh3cTransceiverChannelBiasCurrent (1.3.6.1.4.1.25506.2.70.1.2.1.5) |
read-only |
Integer32 |
Current bias current in mA, accurate to 0.01 mA. |
hh3cTransceiverChannelBiasHiAm (1.3.6.1.4.1.25506.2.70.1.2.1.6) |
read-only |
Integer32 |
As per the MIB. |
hh3cTransceiverChannelBiasLoAm (1.3.6.1.4.1.25506.2.70.1.2.1.7) |
read-only |
Integer32 |
As per the MIB. |
hh3cTransceiverChannelTXPwrHiAm (1.3.6.1.4.1.25506.2.70.1.2.1.8) |
read-only |
Integer32 |
High transmit power alarm threshold in dBm, accurate to 0.01 dBm. |
As per the MIB. |
hh3cTransceiverChannelTXPwrLoAm (1.3.6.1.4.1.25506.2.70.1.2.1.9) |
read-only |
Integer32 |
Low transmit power alarm threshold in dBm, accurate to 0.01 dBm. |
As per the MIB. |
hh3cTransceiverITUChanTable
About this table
Use this table to obtain information about ITU channels supported on the transceiver module on an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex and hh3cTransceiverITUChanIdx.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTransceiverITUChanIdx (1.3.6.1.4.1.25506.2.70.1.3.1.1) |
not-accessible |
Unsigned32 |
Index of an ITU channel on the transceiver module. |
As per the MIB. |
hh3cTransceiverITUChanFreq (1.3.6.1.4.1.25506.2.70.1.3.1.2) |
read-only |
Integer32 |
Frequency of the ITU channel, in THz, accurate to 0.01 THz. |
As per the MIB. |
hh3cTransceiverITUChanWaveLth (1.3.6.1.4.1.25506.2.70.1.3.1.3) |
read-only |
Integer32 |
Wavelength of the ITU channel, in pm. |
As per the MIB. |
hh3cTransceiverLaneTable
About this table
Use this table to obtain the transmit power and receive power of each transceiver lane.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTransceiverLaneCurTxPower (1.3.6.1.4.1.25506.2.70.1.4.1.1) |
read-only |
OCTET STRING |
Receive power of each transceiver lane, in 0.01 dBM. |
As per the MIB. |
hh3cTransceiverLaneCurRxPower (1.3.6.1.4.1.255062.70.1.4.1.2) |
read-only |
OCTET STRING |
Transmit power of each transceiver lane, in 0.01 dBM. |
As per the MIB. |
hh3cTransceiverLaneBiasCurrent (1.3.6.1.4.1.255062.70.1.4.1.3) |
read-only |
OCTET STRING |
Bias current of each transceiver lane, in 0.01 mA. |
As per the MIB. |
