- 02-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 08-HH3C-LswTRAP-MIB | 299.51 KB |
hh3cCpuUsageSevereNotification
hh3cCpuUsageSevereRecoverNotification
hh3cCpuUsageMinorRecoverNotification
hh3cMemoryUsageEarlyWarningNotification
hh3cMemoryUsageEarlyWarningRecoverNotification
hh3cMemoryUsageMinorNotification
hh3cMemoryUsageMinorRecoverNotification
hh3cMemoryUsageSevereNotification
hh3cMemoryUsageSevereRecoverNotification
hh3cMemoryUsageCriticalNotification
hh3cMemoryUsageCriticalRecoverNotification
HH3C-LswTRAP-MIB
About this MIB
This MIB contains information about notifications for state change of cards and resources on the device.
MIB file name
hh3c-splat-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswTrapMib(12)
Scalar objects
hh3csLswTrapCpuCoreInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapCpuCoreInfo (1.3.6.1.4.1.25506.8.35.12.2.1) |
accessible-for-notify |
SnmpAdminString |
OCTET STRING (0..255) |
CPU core information in CPU notifications. |
As per the MIB. |
hh3csLswTrapProcessCpuInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapProcessCpuInfo (1.3.6.1.4.1.25506.8.35.12.2.1) |
SnmpAdminString |
Process information in CPU notifications. |
As per the MIB. |
hh3csLswTrapProcessMemoryInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapProcessMemoryInfo (1.3.6.1.4.1.25506.8.35.12.2.3) |
SnmpAdminString |
Memory information in CPU notifications. |
As per the MIB. |
hh3csLswTrapSlubInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapSlubInfo (1.3.6.1.4.1.25506.8.35.12.2.4) |
SnmpAdminString |
Slub information in CPU notifications. |
As per the MIB. |
hh3cLswTrapCpuUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswTrapCpuUsage (1.3.6.1.4.1.25506.8.35.12.2.5) |
SnmpAdminString |
CPU usage information in CPU notifications. |
As per the MIB. |
hh3cLswTrapCoreProcessInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswTrapCoreProcessInfo (1.3.6.1.4.1.25506.8.35.12.2.6) |
SnmpAdminString |
Core process information in CPU notifications. |
As per the MIB. |
hh3cLswCoreTrapUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCoreTrapUsage (1.3.6.1.4.1.25506.8.35.12.2.7) |
Unsigned32 |
Standard MIB values. |
CPU usage in the most recent 30 minutes. |
As per the MIB. |
hh3cBoardAvailablePower
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBoardAvailablePower (1.3.6.1.4.1.25506.8.35.12.2.8) |
Integer32 |
Available power. |
As per the MIB. |
hh3cBoardRequiredPower
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBoardRequiredPower (1.3.6.1.4.1.25506.8.35.12.2.9) |
Integer32 |
Required power. |
As per the MIB. |
hh3cLswAlarmInPortInNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswAlarmInPortInNum (1.3.6.1.4.1.25506.8.35.12.2.10) |
Unsigned32 |
Number of alarm in ports. |
As per the MIB. |
hh3cHeartbeatTimeoutSeconds
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cHeartbeatTimeoutSeconds (1.3.6.1.4.1.25506.8.35.12.2.19) |
Unsigned32 |
Heartbeat timeout, in seconds. |
As per the MIB. |
Notifications
This section contains the HH3C-LswTRAP-MIB notifications.
hh3cpowerfailure
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.1 |
Failure of a power supply |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.2(hh3cPowerNormal) |
ON |
This notification is generated when a power supply fails or a new power supply is inserted into the device.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.9.1.2.1.1 (hh3cDevMPowerNum) |
Power supply ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.9.1.13 (hh3cDevMFirstTrapTime) |
Timestamp of the notification. |
N |
TimeTicks |
Recommended action
To resolve the issue:
1. Verify that the power supply is installed correctly.
2. If the issue persists, contact H3C Support.
hh3cPowerNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.2 |
Recovery of a power supply from a fault |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a power supply recovers from an abnormal state.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Power supply ID. |
Y |
Integer32 |
N |
TimeTicks |
Recommended action
hh3cPowerRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.5 |
Removal of a power supply |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.23 (hh3cPowerInserted) |
ON |
This notification is generated when a power supply is removed from the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Power supply ID. |
Y |
Integer32 |
Recommended action
1. Verify that a power supply is removed from the device.
¡ If the power supply is removed from the device, no action is required.
¡ If the power supply is not removed from the device, verify that the power supply is installed correctly.
hh3cfanfailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.6 |
Failure of a fan tray |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.7(hh3cFanNormal) |
ON |
This notification is generated when a fan tray fails.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.9.1.1.1.1 (hh3cDevMFanNum) |
Fan tray ID. |
Y |
Integer32 |
Recommended action
1. Verify that the fan tray is installed correctly.
hh3cFanNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.7 |
Recovery of a fan tray from a fault. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a fan tray recovers from a fault.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Fan tray ID. |
Y |
Integer32 |
Recommended action
hh3cBoardRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.8 |
Removal of a card |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.9(hh3cBoardInserted) |
ON |
This notification is generated when a card is removed from the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.18.4.2.1.1 (hh3cLswFrameIndex) |
Chassis ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cLswSlotIndex) |
Slot ID. |
Y |
Integer32 |
Recommended action
1. Verify that the card is removed from the device.
¡ If the card is removed from the device, no action is required.
¡ If the card is not removed from the device, verify that the card is installed correctly.
hh3cBoardInserted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.9 |
Insertion of a card |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a card is inserted into the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
Recommended action
hh3cBoardFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.10 |
Failure or startup of a card |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.11(hh3cBoardNormal) |
ON |
This notification is generated when a card is starting up or a fault occurs on the card.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Member ID of the device |
Y |
Integer32 |
Slot ID |
Y |
Integer32 |
Recommended action
1. Verify that the card is installed correctly.
2. If the issue persists after 24 hours, contact H3C Support.
hh3cBoardNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.11 |
Initialization completion of a card |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a card completes initialization.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
Recommended action
hh3cSubcardRemove
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.12 |
Removal of a subcard |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.13(hh3cSubcardInsert) |
ON |
This notification is generated when a subcard is removed from the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Integer32 |
Slot ID |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.4.1.1 (hh3cLswSubslotIndex) |
Subslot ID |
Y |
Integer32 |
Recommended action
1. Verify that the subcard is removed from the device.
¡ If the subcard is removed from the device, no action is required.
¡ If the subcard is not removed from the device, verify that the subcard is installed correctly.
hh3cSubcardInsert
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.13 |
Insertion of a subcard |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a subcard is inserted into the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
Subslot ID. |
Y |
Integer32 |
Recommended action
No action is required.
hh3cPowerInserted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.23 |
Insertion of a power supply |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a power supply is inserted into the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Power supply ID. |
Y |
Integer32 |
Recommended action
hh3cCpuRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.25 |
Removal of a non-default CPU |
Error |
Minor |
N/A |
ON |
This notification is generated when a non-default CPU subcard is removed from the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.1 (hh3cLswCpuIndex) |
CPU ID. |
Y |
Integer32 |
Recommended action
1. Verify that the non-default CPU is removed from the device.
¡ If the non-default CPU is removed from the device, no action is required.
¡ If the non-default CPU is not removed from the device, verify that the non-default CPU is installed correctly.
hh3cCpuFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.26 |
Failure or startup of a non-default CPU |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.27(hh3cCpuNormal) |
ON |
This notification is generated when a non-default CPU is starting up or a fault occurs on it.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
Recommended action
1. Verify that the non-default CPU is installed correctly.
hh3cCpuNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.27 |
Initialization completion of a non-default CPU |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a non-default CPU completes initialization.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
Recommended action
hh3cPowerIncompatible
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.28 |
Incompatibility of a power supply with the device |
Error |
Major |
ON |
This notification is generated when a power supply is not compatible with the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Power supply ID. |
Y |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.29 |
Severe CPU usage alarm |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.30(hh3cCpuUsageSevereRecoverNotification) |
ON |
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageSevereThreshold. This notification is sent at intervals of 60 seconds until the alarm is cleared.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.3 (hh3cLswCpuRatio) |
CPU usage. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.11 (hh3cLswCpuUsageMinorThreshold) |
Minor CPU usage threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.12 (hh3cLswCpuUsageSevereThreshold) |
Severe CPU usage threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.13 (hh3cLswCpuUsageRecoverThreshold) |
CPU usage recovery threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.12.2.1 (hh3csLswTrapCpuCoreInfo) |
CPU core usage (top1). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top1) |
CPU core usage (top2). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top2) |
CPU core usage (top3). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top3) |
CPU core usage (top4). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top4) |
CPU core usage (top5). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top5) |
1.3.6.1.4.1.25506.8.35.12.2.2 (hh3csLswTrapProcessCpuInfo) |
Process usage (top1). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top1) |
Process usage (top2). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top2) |
Process usage (top3). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio-top3) |
Process usage (top4). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top4) |
Process usage (top5). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top5) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.30 |
Clearance of a severe CPU usage alarm |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageSevereThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
CPU usage. |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
hh3cCpuUsageMinorNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.31 |
Minor CPU usage alarm |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.1.32(hh3cCpuUsageMinorRecoverNotification) |
ON |
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageMinorThreshold. This notification is sent at intervals of 300 seconds until the alarm is cleared.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
CPU usage. |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
CPU core usage (top5) |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
Potential risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.32 |
Minor CPU usage alarm clearance |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageMinorThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
CPU usage. |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.33 |
Memory usage early warning alarm |
Informational |
N/A |
1.3.6.1.4.1.25506.8.35.12.1.34(hh3cMemoryUsageEarlyWarningRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageEarlyWarningThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.8 (hh3cLswCpuMemory) |
Total memory size. |
N |
CounterBasedGauge64 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.14 (hh3cLswCpuMemoryFree) |
Free memory size. |
N |
1.3.6.1.4.1.25506.8.35.18.4.10.1.15 (hh3cLswCpuMemoryFreeRadio) |
Free memory ratio. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.16 (hh3cLswCpuMemoryHighTotal) |
Total high memory size |
N |
1.3.6.1.4.1.25506.8.35.18.4.10.1.17 (hh3cLswCpuMemoryHighFree) |
Free high memory size. |
N |
1.3.6.1.4.1.25506.8.35.18.4.10.1.18 (hh3cLswCpuMemoryLowTotal) |
Total low memory size. |
N |
1.3.6.1.4.1.25506.8.35.18.4.10.1.19 (hh3cLswCpuMemoryLowFree) |
Free low memory size. |
N |
1.3.6.1.4.1.25506.8.35.18.4.10.1.26 (hh3cLswCpuMemorySecureThreshold) |
Sufficient memory threshold. |
N |
Unsigned32 |
1 to 100, in percentage |
1.3.6.1.4.1.25506.8.35.18.4.10.1.27 (hh3cLswCpuMemoryEarlyWarningThreshold) |
Early-warning memory threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.28 (hh3cLswCpuMemoryNormalThreshold) |
Normal state memory threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.29 (hh3cLswCpuMemoryMinorThreshold) |
Minor memory threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.30 (hh3cLswCpuMemorySevereThreshold) |
Severe memory threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.31 (hh3cLswCpuMemoryCriticalThreshold) |
Critical memory threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.32 (hh3cLswCpuMemoryCurrentState) |
Current memory state. |
N |
INTEGER |
secure(1), earlywarning(2), normal(3), minor(4), severe(5), critical(6) |
1.3.6.1.4.1.25506.8.35.18.4.10.1.33 (hh3cLswCpuMemoryUsageThreshold) |
Memory usage threshold. |
N |
1.3.6.1.4.1.25506.8.35.12.2.3 (hh3csLswTrapProcessMemoryInfo) |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top1) |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top2) |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top3) |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top4) |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top5) |
1.3.6.1.4.1.25506.8.35.12.2.4 (hh3csLswTrapSlubInfo) |
Slub information (top 1). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top1) |
Slub information (top 2). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top2) |
Slub information (top 3). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top3) |
Slub information (top 4). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top4) |
Slub information (top 5). |
N |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top5) |
Recommended action
Potentical risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.34 |
Memory usage early warning alarm clearance |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSecureThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
Total high memory size. |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.35 |
Minor memory usage alarm |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.36(hh3cMemoryUsageMinorRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cLswCpuMemoryMinorThreshold. The notification is sent at intervals of 12 hours until the alarm condition is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
Sufficient memory threshold |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
The issue needs to be reviewed to determine whether action is necessary.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.36 |
Minor memory usage notification clearance |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cLswCpuMemoryNormalThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Slub information (top 4) |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.37 |
Severe memory usage alarm |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.38(hh3cMemoryUsageSevereRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageSevereThreshold. This notification is sent at intervals of 3 hours until the alarm is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
The issue has significant impact on services. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.38 |
Severe memory usage alarm clearance |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageMinorThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.39 |
Critical memory usage alarm |
Error |
Critical |
1.3.6.1.4.1.25506.8.35.12.1.40(hh3cMemoryUsageCriticalRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageCriticalThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
The issue puts the system assets and services at risk. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.40 |
Critical memory usage alarm clearance |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSevereThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
N |
Free memory size. |
N |
N |
Unsigned32 |
N |
N |
N |
N |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
INTEGER |
N |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
Recommended action
hh3cCoreUsageNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.1 |
CPU core usage alarm |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.10(hh3cCoreUsageSevereRecoveryNotification) |
ON |
This notification is generated when the amount of core usage increases to or above the hh3cLswCoreThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
CPU ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.1 (hh3cLswCoreIndex) |
CPU core ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.7 (hh3cLswCoreTrapUsage) |
CPU core usage in the most recent 30 minutes. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.5 (hh3cLswCoreThreshold) |
CPU core usage threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.12.2.5 (hh3cLswTrapCpuUsage) |
CPU usage during the most recent 5 seconds, 1 minute, 5 minutes. |
N |
SnmpAdminString |
1.3.6.1.4.1.25506.8.35.12.2.6 (hh3cLswTrapCoreProcessInfo) |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
N |
SnmpAdminString |
1.3.6.1.4.1.25506.8.35.18.4.15.1.7 (hh3cLswCoreMinorThreshold) |
Minor CPU core usage threshold. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.8 (hh3cLswCoreRecoveryThreshold) |
CPU core normal state threshold. |
N |
Unsigned32 |
Recommended action
hh3cBoardPowerNotEnough
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.2 |
Power insufficiency for a card |
Error |
Major |
N/A |
ON |
This notification is generated when the power provided for a card is not enough.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.8 (hh3cBoardAvailablePower) |
Available power. |
N |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.9 (hh3cBoardRequiredPower) |
Required power. |
N |
Integer32 |
Recommended action
Replace the power supplies with high-power ones.
hh3cAlarmInPortIn
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.3 |
Electrical level state received on an alarm input port inconsistent with that configured for the port. |
Informational |
N/A |
1.3.6.1.4.1.25506.8.35.12.3.0.4(hh3cAlarmInPortRecover) |
ON |
This notification is generated when the electrical level state received on an alarm input port is inconsistent with that configured for the port.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.10 (hh3cLswAlarmInPortInNum) |
Alarm input port number. |
N |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.4 |
Electrical level state received on an alarm input port become consistent with that configured for the port |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the electrical level state received on an alarm input port becomes consistent with that configured for the port.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer32 |
Slot ID. |
Y |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.9 (hh3cLswAlarmInPortInNum) |
N |
Integer32 |
Recommended action
hh3cLoadFinished
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.20 |
A card finished loading of the image file. |
Informational |
N/A |
N/A |
ON |
This notification is generated when a card finishes loading of the image file.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.18.4.2.1.1(hh3cLswFrameIndex) |
Chassis ID. |
Y |
Integer |
Slot ID. |
Y |
Integer |
hh3cBootImageUpdated
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.24 |
Startup software images updated. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the startup software images are updated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer |
Slot ID. |
Y |
Integer |
Recommended action
hh3cRequestLoading
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.18 |
Image loading request received. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the loading service end receives an image loading request.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer |
Slot ID. |
Y |
Integer |
Recommended action
hh3cBoardHeartbeatTimeout
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.46 |
Heartbeat between the MPU and a card timed out. |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.47(hh3cBoardHeartbeatResume) |
ON |
This notification is generated when the heartbeat between the MPU and a card times out.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer |
Slot ID. |
Y |
Integer |
CPU ID. |
Y |
Integer |
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cHeartbeatTimeoutSeconds) |
N |
Integer |
Recommended action
Check the connection between the MPU and the card.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.47 |
Heartbeat between the MPU and a card resumed. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the heartbeat between the MPU and a card resumes.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Y |
Integer |
Slot ID. |
Y |
Integer |
CPU ID. |
Y |
Integer |
Recommended action
