| 00-Preface | 101.12 KB |
Preface
This document provides information about troubleshooting common BRAS service issues.
· Audience
Audience
· Network planners.
· Network administrators working with the routers.
Statements
This documentation is not restricted to specific software and hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
This documentation describes general technical information, some of which might not be applicable to your routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
