11-Network Management and Monitoring Command Reference
HomeSupportResource CenterSwitchesS6530X SeriesS6530X SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S6530X Switch Series Command References-R8108Pxx-6W10011-Network Management and Monitoring Command Reference
19-VCF fabric commands
19-VCF fabric commands 78.45 KB
VCF fabric commands
display vcf-fabric role
Use display vcf-fabric role to display the role of the device in the VCF fabric.
Use this command to display the default role and the current role of the device in the VCF fabric. To change the current role of the device, use the vcf-fabric role command.
# Display the role of the device in the VCF fabric.
<System> display vcf-fabric role
Default role: leaf
Current role: leaf
Default role
Default role of the device:
Current role
Current role of the device:
vcf-fabric role
display vcf-fabric topology
Use display vcf-fabric topology to display VCF fabric topology information.
This command displays VCF fabric topology information only when it is executed on the master spine node.
Before you display VCF fabric topology information, make sure VCF fabric topology discovery and automated underlay network deployment are enabled.
# Display VCF fabric topology information.
<Sysname> display vcf-fabric topology
                                  Topology Information
* indicates the master spine role among all spines
SpineIP            Interface                      Link LeafIP              Status
*10.11.113.51     Ten-GigabitEthernet1/0/1       Up   10.11.113.52       Deploying
                  Ten-GigabitEthernet1/0/2       Down --                   --
                  Ten-GigabitEthernet1/0/3       Down --                   --
                  Ten-GigabitEthernet1/0/4       Down --                   --
                  Ten-GigabitEthernet1/0/5       Up   10.11.113.53       Deploying
                  Ten-GigabitEthernet1/0/6       Down --                   --
                  Ten-GigabitEthernet1/0/7       Down --                   --
                  Ten-GigabitEthernet1/0/8       Down --                   --
SpineIP
IPv4 address of the management Ethernet interface on the spine node. This field displays an asterisk (*) before the IP address if the device is the master spine node.
Interface through which the spine node connects to a leaf node.
If the device is a master spine node, all interfaces on the device are displayed.
Link
Physical link state of the interface.
LeafIP
IPv4 address of the interface through which a leaf node connects to the spine node.
Status
Status of automated underlay network deployment on the leaf node.
This field displays two hyphens (--) if automated underlay network deployment is not started.
This field displays Deploying if automated underlay network deployment is in progress.
vcf-fabric underlay autoconfigure
vcf-fabric topology enable
display vcf-fabric underlay autoconfigure
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network deployment.
Before you execute this command, make sure automated underlay network deployment is enabled.
# Display information about automated underlay network deployment.
<Sysname> display vcf-fabric underlay autoconfigure
success command:
          system
          clock timezone beijing add 08:00:00
          system
          lldp global enable
          lldp compliance cdp
          system
          ospf 1
          graceful-restart ietf
          area 0.0.0.0
          system
          interface LoopBack0
          system
          l2vpn enable
          system
          vxlan tunnel arp-learning disable
          system
          stp global enable
          system
          ntp-service enable
          ntp-service unicast-peer 172.16.1.136
          system
          netconf soap https enable
          restful https enable
          system
          info-center loghost 172.16.1.136
          system
          local-user aaa
          password ******
          service-type https
          system
          line vty 0 63
          authentication-mode scheme
          system
          bgp 100
          graceful-restart
          address-family l2vpn evpn
          system
          system
          neutron
          rabbit user openstack
          rabbit password ******
          rabbit host ip 172.16.1.136
          restful user aaa password ******
          vpn-target 1:1 export-extcommunity
          vsi-mac 789c-2f5f-0200
          network-type distributed-vxlan
          proxy-arp enable
          l2agent enable
          l3agent enable
          system
          snmp-agent
          snmp-agent packet max-size 4096
          snmp-agent community read public
          snmp-agent community write private
          snmp-agent sys-info version all
Uplink interface:
Downlink interface:
AP-side interfaces:
Loopback0 IP allocation:
        Device_MAC         Loopback_IP       Management_IP     State
        a43c-adae-0400     200.1.1.6         172.16.1.193      Up
        a43c-9aa7-0100     200.1.1.4         172.16.1.152      Up
Loopback1 IP allocation:
        a43c-adae-0400     100.1.1.6         172.16.1.193      Up
        a43c-9aa7-0100     100.1.1.4         172.16.1.152      Up
Aggregation configuration:
        AggrID: 7
        interface: Ten-GigabitEthernet1/0/5
        interface: Ten-GigabitEthernet1/0/6
IRF allocation:
        Self Bridge Mac: a43c-adae-0400
        IRF Status: Yes
        Member List: [1, 2]
BGP peer configuration:
        Device_MAC: 265b-208d-0300
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_MAC: 1ea6-06a4-0500
        Device_role:spine
        BGP peer list:
                200.1.4.4
                200.1.4.7
        Device_MAC: 1ead-aed1-0600
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_role:spine
        BGP peer list:
                200.1.4.4
                200.1.4.7
        Device_role:leaf
        BGP peer list:
                200.1.4.5
success command
Commands that have been successfully executed during automated underlay network deployment.
Uplink interface
Uplink interfaces of the device.
Downlink interface
Downlink interfaces of the device.
IP addresses assigned to Loopback 0.
IP addresses assigned to Loopback 1.
Information about Layer 2 aggregation groups.
IRF allocation
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device.
Information about BGP peers of the device.
BGP peer information on all spine and leaf nodes is displayed only when this command is executed on the master spine node in a spine-aggregate-leaf VCF fabric.
display vcf-fabric underlay template-version
Use display vcf-fabric underlay template-version to display the supported version and the current version of the template file for automated VCF fabric deployment.
The version format of a template file for automated VCF fabric deployment is x.y. Only the x part is examined during a version compatibility check. For successful automated deployment, make sure x in the version of the template file to be used is not greater than x in the supported version.
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment is not started.
<Sysname> display vcf-fabric underlay template-version
Supported template version: 14.0
Current template version: Not available
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment has finished.
Current template version: 14.0
Supported version of the template file for automated VCF fabric deployment.
Current version of the template file for automated VCF fabric deployment.
This field displays Not available if automated VCF fabric deployment has not started.
This field displays None if automated VCF fabric deployment has finished but the template file does not contain a version number.
vcf-fabric role
Use vcf-fabric role to specify the role of the device.
Use undo vcf-fabric role to restore the default.
vcf-fabric role { access | aggr | leaf | spine }
The device is a leaf node.
Neutron view
access: Specifies the access node.
aggr: Specifies the aggregate node.
leaf: Specifies the leaf node.
spine: Specifies the spine node.
If you change the role of the device, the new role takes effect after the device restarts.
# Specify the device as a spine node.
[Sysname] vcf-fabric role spine
vcf-fabric spine-role master
Use vcf-fabric spine-role master to specify the device as a master spine node.
Use undo vcf-fabric spine-role master to restore the default.
The device is not a master spine node.
You must execute this command on a spine node.
When multiple spines nodes exist in the VCF fabric, you must specify a device as the master spine node to collect the topology for the entire VCF fabric.
For the new role to take effect, you must restart the automated underlay network deployment. To restart the automated underlay network deployment, execute the undo vcf-fabric underlay autoconfigure command and then the vcf-fabric underlay autoconfigure command.
# Specify the device as a master spine.
[Sysname] vcf-fabric spine-role master
For this configuration to take effect, you must execute the undo vcf-fabric underlay autoconfigure and vcf-fabric underlay autoconfigure commands in sequence.
vcf-fabric role
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network deployment.
Use undo vcf-fabric underlay autoconfigure to cancel automated underlay network deployment.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network deployment.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file ending with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
If you re-execute this command after automated underlay network deployment is cancelled, the spine node will assign different IP addresses to loopback interfaces on leaf nodes. Thus, the leaf nodes will go offline and come online again.
# Specify template file vxlan_leaf.template for automated underlay network deployment.
[Sysname] vcf-fabric underlay autoconfigure vxlan_leaf.template
vcf-fabric underlay netconf-username
Use vcf-fabric underlay netconf-username to set the NETCONF username.
Use undo vcf-fabric underlay netconf-username to restore the default.
vcf-fabric underlay netconf-username username
The device uses the NETCONF username defined in the template file for automated VCF fabric deployment.
username: Specifies the username used by the spine device to collect the global topology through NETCONF, a case-sensitive string of 1 to 63 characters.
This command is available on spine nodes.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF username on the spine node.
Make sure all devices in the underlay network use the same username and password for NETCONF session establishment.
# Set the NETCONF username to aaa.
[Sysname] vcf-fabric underlay netconf-username aaa
vcf-fabric underlay netconf-password
Use vcf-fabric underlay netconf-password to set the NETCONF password.
Use undo vcf-fabric netconf-underlay password to restore the default.
vcf-fabric underlay netconf-password { cipher | simple } string
undo vcf-fabric underlay netconf-password
The device uses the NETCONF password defined in the template file for automated VCF fabric deployment.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. Its plaintext form is a string of 1 to 63 characters. Its encrypted form is a string of 1 to 127 characters.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF password on the spine node.
# Set the NETCONF password to aaa in plaintext form.
[Sysname] vcf-fabric underlay netconf-password simple aaa
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network deployment.
Use undo vcf-fabric underlay pause to continue automated underlay network deployment.
Automated underlay network deployment is not paused.
You can use this command to pause automated underlay network deployment if the device is in the process of automated underlay network deployment.
# Pause automated underlay network deployment.
[Sysname] vcf-fabric underlay pause
  • Become a Partner
  • Partner Resources
