06-FlexE interface commands | 292.07 KB |
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
FlexE logical interface view
# Set the expected bandwidth of FlexE 1/0/1:1 to 1000 kbps.
[Sysname] interface flexe 1/0/1:1
[Sysname-FlexE1/0/1:1] bandwidth 1000
bind interface
Use bind interface to add a FlexE physical interface to a FlexE group interface.
Use undo bind interface to remove a FlexE physical interface from a FlexE group interface.
bind interface interface-type interface-number phy-number number
undo bind interface interface-type interface-number
No FlexE physical interfaces exist in a FlexE group interface.
FlexE group interface view
interface-type interface-number: Specifies a FlexE physical interface by its type and number.
phy-number number: Specifies the PHY number of the FlexE physical interface, in the range of 1 to 254.
When you add a FlexE physical interface to a FlexE group interface, follow these restrictions and guidelines:
· You can add a FlexE physical interface only to a FlexE group interface.
· For correct communication between FlexE physical interfaces at both of the ends of a link, you must add the FlexE physical interfaces to the same FlexE group interface. Make sure the FlexE physical interfaces have the same PHY number.
· You can repeat this command to add multiple FlexE physical interfaces to a FlexE group interface. Make sure the PHY number for each FlexE physical interfaces is unique in a FlexE group interface.
· You can bind only four FlexE physical interfaces on the same chip (for example, FlexE physical interfaces 1 through 4 or 5 through 8) to a FlexE group interface. The device will prompt a notification if you bind interfaces on different chips.
If the bandwidth or timeslots of a FlexE physical interface have been bound to a FlexE logical interface, you cannot the following tasks:
· Remove the FlexE physical interface from the FlexE group interface.
· Change the PHY number of the FlexE physical interface.
# Add FlexE-100G 1/0/1 to FlexE-group 1/0/1 and set the PHY number of the FlexE physical interface to 2.
[Sysname] interface flexe-group 1/0/1
[Sysname-FlexE-Group1/0/1] bind interface flexe-hundredgig 1/0/1 phy-number 2
client
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
A FlexE logical interface does not suppress broadcast traffic.
ratio: Specifies the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the FlexE logical interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the broadcast-suppression command can suppress broadcast storms on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain broadcast command and the broadcast-suppression command on an interface.
The configured suppression threshold value in pps or kbps might be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the broadcast suppression threshold to 10000 kbps on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] broadcast-suppression kbps 10000
The actual value is 10048 on port FlexE1/0/1:1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip supports only step 64.
multicast-suppression
unicast-suppression
client
Use client to set the client ID for a FlexE logical interface to be created and create the FlexE logical interface in a FlexE group interface.
Use undo client to restore the default.
client client-id { bandwidth { bandwidth-value } | bind interface interface-type interface-number timeslot timeslot-list }
undo client client-id [ bandwidth | bind interface interface-type interface-number ]
No FlexE logical interfaces exist in a FlexE group interface.
client-id: Specifies the client ID of the FlexE group interface to be created, in the range of 1 to 65534. The interface number of the FlexE logical interface is in the form of FlexE-group-interface-number:client-ID.
bandwidth { bandwidth-value }: Specifies the bandwidth of the FlexE logical interface directly.
· bandwidth-value: Specifies the bandwidth, in GB. The value range is 5 to 4194303, and the step is 5.
bind interface interface-type interface-number timeslot timeslot-list: Specifies the bandwidth of the FlexE logical interface based on timeslots. You can bind timeslots of a FlexE physical interface to the FlexE logical interface. The bandwidth of the FlexE logical interface is timeslot-count × 5 GB.
· interface-type interface-number: Specifies the FlexE physical interface by it type and number.
· timeslot-list: Specifies a comma-separated list of timeslot items. Each item specifies a timeslot by its ID or a range of timeslots in the form of start_timeslot-end_timeslot. For example, 1,3-5. The maximum length of the timeslot list is 31 characters.
Use this command to set the client ID for a FlexE logical interface to be created and create the FlexE logical interface in a FlexE group interface. The interface number of the FlexE logical interface is in the format of FlexE-group-interface-number:client ID. For example, after you execute the client-id 10 command in the view of FlexE-Group 1/0/1, the device creates FlexE logical interface FlexE1/0/1:10 in which 10 is the client ID.
You can set the bandwidth of a FlexE logical interface in bandwidth or timeslot configuration mode set by using the flexe config-mode command in system view.
· If the bandwidth configuration mode is bandwidth mode, you can only use the client client-id bandwidth command to set the bandwidth of the FlexE logical interface.
· If the bandwidth configuration mode is timeslot mode, you can only use the client client-id binding interface interface-type interface-number timeslot timeslot-list command to set the bandwidth of FlexE logical interfaces.
For correct communication between FlexE logical interfaces at both ends of a link, you must perform the following tasks:
· Create a FlexE group interface at both of the devices.
· Set the same client ID for the two FlexE group interfaces.
# Create FlexE logical interface FlexE1/0/1:10 and set its bandwidth to 10 GB.
[Sysname-FlexE-Group1/0/1] client 10 bandwidth 10
bind interface
flexe config-mode
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
FlexE-50-100G interface view
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
This command and the link-delay command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
As a best practice, do not enable the dampening function on an interface with MSTP or Smart Link enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command, MIB, or Web is always down.
# Enable interface dampening on FlexE-Fifty-HundredGigE2/2/1.
[Sysname] interface flexe-fifty-hundredgige 2/2/1
[Sysname-FlexE-Fifty-HundredGig2/2/1] dampening
display interface
link-delay
default
Use default to restore the default settings for an interface.
default
FlexE physical interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network. |
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] default
description
The description of an interface is the interface name plus Interface (for example, FlexE1/0/1:1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Configure the description of FlexE logical interface FlexE 1/0/1:1 as lan-interface.
[Sysname-FlexE1/0/1:1] description lan-interface
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument represents the interface number. The subnumber argument represents the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display information about Layer 3 FlexE logical interface FlexE1/0/2:1.
<Sysname> display interface flexe 1/0/2:1
FlexE2/2/1:1
Current state: DOWN
Line protocol state: DOWN
Description: FlexE2/2/1:1 Interface
Bandwidth: 5000000 kbps
FlexE group: FlexE-Group2/2/1
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 542b-de0e-0a01
IPv6 packet frame type: Ethernet II, hardware address: 542b-de0e-0a01
Media type is not sure, port hardware type is no connector
Port priority: 0
Link speed type is autonegotiation, link duplex type is force link
Flow-control is not enabled
The maximum frame length is 9964
Last link flapping: Never
Last hardware down reason: -
Current system time:2022-12-01 15:01:25
Last time when physical state changed to up:-
Last time when physical state changed to down:2022-12-01 14:57:48
Peak input rate: 0 bytes/sec, at 2022-12-01 14:57:52
Peak output rate: 0 bytes/sec, at 2022-12-01 14:57:52
Last 5 seconds input: 0 packets/sec 0 bytes/sec -%
Last 5 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (normal): 0 packets, - bytes
Output: 0 output errors, - underruns, 0 buffer failures
0 lost carrier, - no carrier
# Display information about FlexE-group interface FlexE-Group 5/1/1.
<Sysname> display interface flexe-group 5/1/1
FlexE-Group5/1/1
Current state: UP
Description: FlexE-Group5/1/1 Interface
FlexE group information:
IF_INDEX: 0x10006
Bandwidth configuration mode: Bandwidth
Group number: 1
Total bandwidth: 100 Gbps
Valid bandwidth: 0 Gbps
TX overhead: group number 1; Calendar: A
RX overhead: group number 1; Calendar: B
FlexE PHY information:
FlexE-50-100G5/1/6:
Phy Number: 1
Status: Normal
TX overhead: PHY number 1
RX overhead: PHY number 1
TX-Time-Slot Configuration:
1 1 1 1 1
1 1 1 1 1
1 1 1 1 1
1 1 1 1 1
RX-Time-Slot Configuration:
1 1 1 1 1
1 1 1 1 1
1 1 1 1 1
1 1 1 1 0
# Display information about FlexE physical interface FlexE-50-100G 1/0/1.
<Sysname> display interface flexe-50-100g 1/0/1
FlexE-50-100G1/0/1
Current state: DOWN
Description: FlexE-50-100G1/0/1 Interface
Bandwidth: 50000000 kbps
FlexE group: FlexE-Group1/0/1
Bound FlexE logical interface hosting clock service: FlexE1/0/1
Current system time:2017-10-27 15:10:03
Last time when physical state changed to down:2017-10-27 14:56:38
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Bandwidth |
Expected bandwidth of the interface. |
FlexE group |
FlexE group interface to which the FlexE physical interface belongs. |
Current system time |
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS format. |
Last time when physical state changed to up |
Last time when physical state of the interface changed to up. A hyphen (-) indicates that the physical state of the interface has not changed to up. |
Last time when physical state changed to down |
Last time when physical state of the interface changed to down. A hyphen (-) indicates that the physical state of the interface has not changed to down. |
# Display brief information about all interfaces.
Protocol: (s) - spoofing
50-100GE2/1/1 UP UP --
FlexE-Group2/1/3 UP -- --
FlexE2/1/3:1 UP UP 44.12.1.1 toMER2_slice1
FlexE2/1/3:1.1 UP UP 44.12.1.5 toMER2_slice1
# Display brief information about FlexE1/0/2:1, including the complete description of the interface.
<Sysname>display interface FlexE 1/1/2:1 brief description
FlexE2/1/5:1 UP UP 45.11.1.1 aaaaaa
# Display information about interfaces in DOWN state and the causes.
Interface Link Cause
50-100GE2/1/2 DOWN Not connected
FlexE-Group2/2/1 DOWN Not connected
FlexE2/2/1:1 DOWN Not connected
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. This field displays two hyphens (--) if the device does not support displays the data link layer protocol status of the interface. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down. · DOWN (Loopback detection down)—The loopback detection module has detected loops. · DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). · Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · Standby—The interface is a backup interface in standby state. |
reset counters interface
flexe config-mode
Use flexe config-mode to set the bandwidth configuration mode of FlexE logical interfaces.
Use undo flexe config-mode to restore the default.
flexe config-mode slot slot-number subslot subslot-number { bandwidth | timeslot }
undo flexe config-mode slot slot-number subslot subslot-number
The bandwidth mode is used. You can flexibly set the bandwidth of FlexE logical interfaces.
slot slot-number: Specifies a card by its slot number.
subslot subslot-number: Specifies a subcard by its slot number.
bandwidth: Specifies the bandwidth mode as the bandwidth configuration mode of FlexE logical interfaces. In this mode, you can flexibly set the bandwidth of a FlexE logical interface.
timeslot: Specifies the timeslot mode as the bandwidth configuration mode of FlexE logical interfaces. In this mode, you can allocate bandwidth to a FlexE logical interface through specifying timeslots with the specified granularity.
You can configure bandwidth for a FlexE logical interface flexibly or through specifying timeslots with the specified granularity.
· You can set the bandwidth configuration mode for FlexE logical interfaces to bandwidth mode. You can only use the client client-id bandwidth command to set the bandwidth of the FlexE logical interface. In this mode, you can set different bandwidth for FlexE logical interfaces at both ends.
· When the bandwidth configuration mode is configured as timeslot, you can only execute the client client-id binding interface interface-type interface-number timeslot timeslot-list command to specify timeslots for a FlexE logical interface. The bandwidth of the FlexE logical interface is the number of timeslots multiplied by the timeslot granularity. In this mode, two FlexE logical interfaces interconnected must be bound to the same FlexE physical interfaces.
If you already set the bandwidth of a FlexE logical interface by using the client command, you cannot change the bandwidth configuration mode by using this command.
# Set the bandwidth configuration mode to timeslot mode for FlexE logical interfaces.
[Sysname] flexe config-mode slot 1 subslot 1 timeslot
client
flexe min-bandwidth-percent
Use flexe min-bandwidth-percent to set the minimum available bandwidth percentage of a FlexE logical interface.
Use undo flexe min-bandwidth-percent to restore the default.
flexe min-bandwidth-percent percent
The minimum available bandwidth percentage is 0% for a FlexE logical interface.
percent: Specifies the minimum available bandwidth percentage in the range of 1% to 100%.
If the available bandwidth percentage of the interface drops below the minimum available bandwidth percentage, the interface goes down.
If the available bandwidth percentage of the interface reaches or exceeds the minimum available bandwidth percentage, the interface comes up.
To display the minimum available bandwidth percentage of a FlexE logical interface, use the display interface command.
# Set the minimum available bandwidth percentage to 25% for FlexE logical interface FlexE 1/0/1.
[Sysname-FlexE1/0/1] flexe min-bandwidth-percent 25
display interface
flow-interval
Use flow-interval to set the statistics polling interval on a FlexE logical interface.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Specifies the statistics polling interval in seconds. The interval is in the range of 5 to 300.
After you modify the statistics polling interval on a FlexE logical interface, the collected statistics are inaccurate until two intervals after the modification. To view the accurate statistics, see the Last interval second input and Last interval second output fields in the output from the display interface command.
# Set the statistics polling interval to 100 seconds on FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] flow-interval 100
display interface
ifmonitor crc-error
Use ifmonitor crc-error to set global CRC error packet alarm parameters.
Use undo ifmonitor crc-error to restore the default.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packet alarms.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for CRC error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface.
With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the CRC error packet alarm parameters in system view and interface view.
· The configuration in system view takes effect on all interfaces. The configuration in interface view takes effect only on the current interface.
· For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
This command takes effect only when the CRC error packet alarm function is enabled by using the snmp-agent trap enable ifmonitor crc-error command.
# Globally set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms.
[Sysname] ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor giant
Use ifmonitor giant to configure global giant packet alarm parameters.
Use undo ifmonitor giant to restore the default.
ifmonitor giant slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor giant slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for giant packet alarms.
high-threshold high-value: Specifies the upper threshold for giant packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for giant packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for giant packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming giant packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming giant packets exceeds the upper threshold on the interface.
With the giant packet alarm function enabled, when the number of incoming giant packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming giant packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the giant packet alarm parameters in system view and interface view.
When you execute this command multiple times, the most recent configuration takes effect.
# Set the upper threshold to 5, lower threshold to 4, and statistics collection and comparison interval to 6 seconds for giant packet alarms.
[Sysname] ifmonitor giant high-threshold 5 low-threshold 4 interval 6
port ifmonitor giant
ifmonitor input-error
Use ifmonitor input-error to set global input error packet alarm parameters.
Use undo ifmonitor input-error to restore the default.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packet alarms.
high-threshold high-value: Specifies the upper threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for input error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of input error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of input error packets exceeds the upper threshold on the interface.
With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the input error packet alarm parameters in system view and interface view.
This command takes effect only when the input error packet alarm function is enabled by using the snmp-agent trap enable ifmonitor input-error command.
# Globally set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms.
[Sysname] ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage
Use ifmonitor input-usage to set global inbound bandwidth usage alarm parameters.
Use undo ifmonitor input-usage to restore the default.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
The upper threshold is 90% and the lower threshold is 80% for inbound bandwidth usage alarms.
high-threshold high-value: Specifies the upper threshold for inbound bandwidth usage alarms, in the range of 1% to 100%.
low-threshold low-value: Specifies the lower threshold for inbound bandwidth usage alarms, in the range of 1% to 100%.
With the inbound bandwidth usage alarm function enabled, when the inbound bandwidth usage on an interface in normal state within the statistic polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the inbound bandwidth usage on an interface in the alarm state within the statistic polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
The statistics polling interval can be set by using the flow-interval command.
You can configure the inbound bandwidth usage alarm parameters in system view and interface view.
This command takes effect only when the inbound bandwidth usage alarm function is enabled by using the snmp-agent trap enable ifmonitor input-usage command.
# Globally set the upper threshold to 95% and lower threshold to 80% for inbound bandwidth usage alarms.
[Sysname] ifmonitor input-usage high-threshold 95 low-threshold 80
flow-interval
ifmonitor output-error
Use ifmonitor output-error to set global output error packet alarm parameters.
Use undo ifmonitor output-error to restore the default.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packet alarms.
high-threshold high-value: Specifies the upper threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for output error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of output error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of output error packets exceeds the upper threshold on the interface.
With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output error packet alarm parameters in system view and interface view.
This command takes effect only when the output error packet alarm function is enabled by using the snmp-agent trap enable ifmonitor output-error command.
# Globally set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms.
[Sysname] ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage
Use ifmonitor output-usage to set global outbound bandwidth usage alarm parameters.
Use undo ifmonitor output-usage to restore the default.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
The upper threshold is 90% and the lower threshold is 80% for outbound bandwidth usage alarms.
high-threshold high-value: Specifies the upper threshold for outbound bandwidth usage alarms, in the range of 1% to 100%.
low-threshold low-value: Specifies the lower threshold for outbound bandwidth usage alarms, in the range of 1% to 100%.
With the outbound bandwidth usage alarm function enabled, when the outbound bandwidth usage on an interface in normal state within the statistic polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the outbound bandwidth usage on an interface in the alarm state within the statistic polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the outbound bandwidth usage alarm parameters in system view and interface view.
This command takes effect only when the inbound bandwidth usage alarm function is enabled by using the snmp-agent trap enable ifmonitor output-usage command.
# Globally set the upper threshold to 80% and lower threshold to 60% for outbound bandwidth usage alarms.
[Sysname] ifmonitor output-usage high-threshold 80 low-threshold 60
flow-interval
ifmonitor rx-pause
Use ifmonitor rx-pause to set global incoming pause frame alarm parameters.
Use undo ifmonitor rx-pause to restore the default.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for incoming pause frame alarms.
high-threshold high-value: Specifies the upper threshold for incoming pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for incoming pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for incoming pause frame, in the range of 1 to 65535 seconds.
With the incoming pause frame alarm function enabled, when the number of incoming pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the incoming pause frame alarm parameters in system view and interface view.
This command takes effect only when the incoming pause frame alarm function is enabled by using the snmp-agent trap enable ifmonitor rx-pause command.
# Globally set the upper threshold to 30, lower threshold to 20, and statistics collection and comparison interval to 4 seconds for incoming pause frame alarms.
[Sysname] ifmonitor rx-pause high-threshold 30 low-threshold 20 interval 4
ifmonitor runt
Use ifmonitor runt to configure global runt packet alarm parameters.
Use undo ifmonitor runt to restore the default.
ifmonitor runt slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor runt slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for runt packet alarms.
high-threshold high-value: Specifies the upper threshold for runt packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for runt packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for runt packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming runt packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming runt packets exceeds the upper threshold on the interface.
With the runt packet alarm function enabled, when the number of incoming runt packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming runt packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the runt packet alarm parameters in system view and interface view.
# Set the upper threshold to 5, lower threshold to 4, and statistics collection and comparison interval to 6 seconds for runt packet alarms.
[Sysname] ifmonitor runt high-threshold 5 low-threshold 4 interval 6
port ifmonitor runt
ifmonitor tx-pause
Use ifmonitor tx-pause to set global outgoing pause frame alarm parameters.
Use undo ifmonitor tx-pause to restore the default.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor tx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for outgoing pause frame alarms.
high-threshold high-value: Specifies the upper threshold for outgoing pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for outgoing pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for outgoing pause frame, in the range of 1 to 65535 seconds.
With the outgoing pause frame alarm function enabled, when the number of outgoing pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of outgoing pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the outgoing pause frame alarm parameters in system view and interface view.
This command takes effect only when the outgoing pause frame alarm function is enabled by using the snmp-agent trap enable ifmonitor tx-pause command.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 5 seconds for outgoing pause frame alarms.
[Sysname] ifmonitor tx-pause high-threshold 20 low-threshold 10 interval 5
interface
Use interface to enter the view of a FlexE physical interface.
interface-type: Specifies the interface type of a FlexE physical interface.
interface-number: Specifies the interface number of the FlexE physical interface.
# Enter the view of FlexE-50-100G.
[Sysname] interface flexe-50-100g 1/0/1
[Sysname-FlexE-50-100G1/0/1]
interface flexe
Use interface flexe to enter the view of an existing FlexE logical interface, create a subinterface and enter its view, or enter the view of an existing subinterface.
interface flexe { interface-number | interface-number.subnumber }
interface-number: Specifies the interface number of a FlexE logical interface, which consists of the interface number and client ID of the Flex-group interface to which the FlexE logical interface belongs.
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
To create a FlexE logical interface, use the client command.
# Enter the view of FlexE logical interface FlexE1/0/1:10.
[Sysname] interface flexe 1/0/1:10
[Sysname-FlexE1/0/1:10]
client
Use interface flexe-group to create a FlexE group interface and enter its view or enter the view of an existing FlexE group interface.
Use undo interface flexe-group to remove a FlexE group interface.
interface flexe-group interface-number
undo interface flexe-group interface-number
interface-number: Specifies the interface number of the FlexE group interface. The last digit in the interface number represents the group number of the FlexE group interface.
After you create a FlexE group interface, you can add multiple FlexE physical interfaces to the FlexE group interface and create FlexE logical interfaces in the FlexE group interface as needed. Then, you can flexibly assign the total bandwidths of the FlexE physical interfaces to FlexE logical interfaces according to the bandwidth requirements of services.
The number of FlexE group interface must be equal to or smaller than the number of FlexE physical interfaces on the subslot.
You can delete a FlexE group interface only if the FlexE group interface does not have any FlexE physical or logical interfaces.
# Create FlexE group interface FlexE-Group 1/0/1 and enter its view.
bind interface
client
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 9964 bytes to pass through.
size: Specifies the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 9964.
# Allow jumbo frames to pass through FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on a FlexE interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of a FlexE interface goes up or comes down, the system immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Specifies the physical state change suppression interval on the FlexE interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
· If you do not specify the msec keyword, the value range for this argument is 0 to 300 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can use this command to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
On an interface, you can set different suppression intervals for link-up and link-down events. If you set the suppression interval multiple times for the same type of link suppression events, the most recent configuration takes effect.
# Set the link-down event suppression interval to 8 seconds on FlexE logical interface FlexE 1/0/1.
[Sysname-FlexE1/0/1:1] link-delay down 8
# Set the link-up event suppression interval to 800 milliseconds on FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] link-delay up msec 800 mode
loopback
CAUTION: After you enable loopback testing on a FlexE logical interface, the interface does not forward data traffic. |
Use loopback to enable loopback testing on a FlexE logical interface.
Use undo loopback to disable loopback testing on a FlexE logical interface.
loopback { internal }
undo loopback
Loopback testing is disabled on a FlexE logical interface.
internal: Enables internal loopback testing on the FlexE logical interface.
After you enable loopback testing on a FlexE logical interface, the FlexE logical interface switches to full duplex mode. After you disable loopback testing, the FlexE logical interface restores to its duplex setting.
The shutdown and loopback commands are mutually exclusive.
# Enable internal loopback testing on FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] loopback internal
mac-address
Use mac-address to set the MAC address of a FlexE logical interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is configured for a FlexE logical interface.
mac-address: Specifies a MAC address in the format of H-H-H.
# Set the MAC address of FlexE 1/0/1:1 to 0001-0001-0001.
[Sysname-FlexE1/0/1:1] mac-address 1-1-1
mtu
Use mtu to set the MTU of a FlexE interface.
mtu size
undo mtu
The MTU of a FlexE interface is 1500 bytes.
size: Specifies the MTU in bytes. The value range for this argument varies by interface type.
The MTU set by using this command or the ip mtu command takes effect only on packets that the interface delivers to the CPU, for example, packets originated from or destined for the interface. Set a reasonable MTU on the interface to avoid fragmentation.
If you configure both the mtu and ip mtu commands on the interface, the MTU set by using the command takes priority.
# Set the MTU to 1430 bytes for FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] mtu 1430
ip mtu (Layer 3—IP Services Command Reference)
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
A FlexE logical interface does not suppress multicast traffic.
ratio: Specifies the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the FlexE logical interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the FlexE logical interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain multicast command and the multicast-suppression command on an interface.
# Set the multicast storm suppression threshold to 10000 kbps on FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] multicast-suppression kbps 10000
The actual value is 10048 on port FlexE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
unicast-suppression
port ifmonitor crc-error
Use port ifmonitor crc-error to set CRC error packet alarm parameters on a FlexE logical interface.
Use undo port ifmonitor crc-error to restore the default.
A FlexE logical interface uses the global CRC error packet alarm parameters.
ratio: Specifies the alarm thresholds in percentage. If you do not specify this keyword, you configure the alarm thresholds in absolute value.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
Use port ifmonitor giant to configure giant packet alarm parameters for an interface.
Use undo port ifmonitor giant to restore the default.
port ifmonitor giant high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global giant packet alarm parameters.
high-threshold high-value: Specifies the upper threshold for giant packet alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for giant packet alarms, in the range of 1 to 4294967295.
# Set the upper threshold to 5, lower threshold to 4, and statistics collection and comparison interval to 6 seconds for giant packet alarms on FlexE1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor giant high-threshold 5 low-threshold 4 interval 6
ifmonitor giant
port ifmonitor input-error
Use port ifmonitor input-error to set input error packet alarm parameters on a FlexE logical interface.
Use undo port ifmonitor input-error to restore the default.
A FlexE logical interface uses the global input error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage
Use port ifmonitor input-usage to set inbound bandwidth usage alarm parameters on a FlexE logical interface.
Use undo port ifmonitor input-usage to restore the default.
A FlexE interface uses the global inbound bandwidth usage alarm parameters.
# Set the upper threshold to 80% and lower threshold to 6% for inbound bandwidth usage alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor input-usage high-threshold 80 low-threshold 60
flow-interval
port ifmonitor output-error
Use port ifmonitor output-error to set output error packet alarm parameters on a FlexE logical interface.
Use undo port ifmonitor output-error to restore the default.
A FlexE logical interface uses the global output error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage
Use port ifmonitor output-usage to set outbound bandwidth usage alarm parameters on a FlexE logical interface.
Use undo port ifmonitor output-usage to restore the default.
A FlexE interface uses the global outbound bandwidth usage alarm parameters.
# Set the upper threshold to 9% and lower threshold to 7% for inbound bandwidth usage alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1]port ifmonitor output-usage high-threshold 9 low-threshold 7
flow-interval
port ifmonitor rx-pause
Use port ifmonitor rx-pause to set incoming pause frame alarm parameters on a FlexE logical interface.
Use undo port ifmonitor rx-pause to restore the default.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
A FlexE logical interface uses the global incoming pause frame alarm parameters.
# Set the upper threshold to 90, lower threshold to 50, and statistics collection and comparison interval to 5 seconds for incoming pause frame alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor runt
Use port ifmonitor runt to configure runt packet alarm parameters for an interface.
Use undo port ifmonitor runt to restore the default.
port ifmonitor runt high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global runt packet alarm parameters.
high-threshold high-value: Specifies the upper threshold for runt packet alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for runt packet alarms, in the range of 1 to 4294967295.
# Set the upper threshold to 5, lower threshold to 4, and statistics collection and comparison interval to 6 seconds for runt packet alarms on FlexE1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor runt high-threshold 5 low-threshold 4 interval 6
ifmonitor runt
port ifmonitor tx-pause
Use port ifmonitor tx-pause to set outgoing pause frame alarm parameters on a FlexE logical interface.
Use undo port ifmonitor tx-pause to restore the default.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
A FlexE logical interface uses the global outgoing pause frame alarm parameters.
FlexE logical interface view
interval interval: Specifies the statistics collection and comparison interval for outgoing pause frames, in the range of 1 to 65535 seconds.
# Set the upper threshold to 50, lower threshold to 40, and statistics collection and comparison interval to 8 seconds for outgoing pause frame alarms on FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
port-type
Use port-type flexe to change the type of an interface from Ethernet to FlexE.
Use port-type ethernet to change the type of an interface from FlexE to Ethernet.
In 50-GE/50-100GE/100GE interface view:
port-type flexe
In FlexE-FG10G/FlexE-50-100G:
port-type ethernet
10-GE interface view
50-GE interface view
50-100GE interface view
100-GE interface view
FlexE-FG10G interface view
CAUTION: After the type of an interface is changed, the system deletes the original interface and creates a new interface that is numbered the same as the original interface. All the other commands are restored to the default on the new interface. |
The bandwidth of an interface in standard Ethernet mode is fixed. To assign bandwidth at the granularity of 5 Gbps, execute the port-type flexe command to switch the type of the interface from Ethernet to FlexE.
# Change standard Ethernet interface FiftyGigE 1/0/1 to a FlexE interface.
[Sysname] interface fiftygige 1/0/1
[Sysname-FiftyGigE1/0/1] port-type flexe
The interface FiftyGigE1/0/1 will be deleted. Continue? [Y/N]:
# Change FlexE interface FlexE-50-100G 1/0/1 to a standard Ethernet interface.
[Sysname-FlexE-50-100G1/0/1] port-type ethernet
The interfaces FlexE-50-100G1/0/1 and FlexE1/0/1 through FlexE1/0/3 will be deleted. Continue? [Y/N]:
shutdown
Use shutdown to shut down a FlexE interface.
Use undo shutdown to bring up a FlexE interface.
shutdown
A FlexE interface is up.
CAUTION: Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution. |
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] shutdown
[Sysname-FlexE1/0/1:1] undo shutdown
Use snmp-agent trap enable ifmonitor to enable interface alarm functions.
Use undo snmp-agent trap enable ifmonitor to disable interface alarm functions.
snmp-agent trap enable ifmonitor [ crc-error | giant | input-error | input-usage | output-error | output-usage | rx-pause | runt | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | giant | input-error | input-usage | output-error | output-usage | rx-pause | runt | tx-pause ] *
Interface alarm functions are enabled.
crc-error: Enables the CRC error packet alarm function.
giant: Enables the giant packet alarm function for interfaces.
input-error: Enables the input error packet alarm function.
input-usage: Enables the inbound bandwidth usage alarm function.
output-error: Enables the output error packet alarm function.
output-usage: Enables the outbound bandwidth usage alarm function.
rx-pause: Enables the incoming pause frame alarm function.
runt: Enables the runt packet alarm function for interfaces.
tx-pause: Enables the outgoing pause frame alarm function.
# Enable the CRC error packet alarm function.
[Sysname] snmp-agent trap enable ifmonitor crc-error
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
A FlexE logical interface does not suppress unknown unicast traffic.
ratio: Specifies the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the FlexE logical interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
Both the storm-constrain command and the unicast-suppression command can suppress unknown unicast storms on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress unknown unicast traffic.
For the unknown unicast traffic suppression result to be determined, do not configure both the storm-constrain unicast command and the unicast-suppression command on an interface.
The configured suppression threshold value in pps or kbps might be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the unknown unicast storm suppression threshold to 10000 kbps on FlexE logical interface FlexE 1/0/1:1.
[Sysname-FlexE1/0/1:1] unicast-suppression kbps 10000
The actual value is 10048 on port FlexE1/0/1:1 currently.
broadcast-suppression
