01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Command References-R6628Pxx-6W10101-Fundamentals Command Reference
09-Automatic configuration commands
09-Automatic configuration commands 32.38 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has a USB interface.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
