- 04-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-mDNS relay configuration
- 06-mDNS gateway configuration
- 07-IP forwarding basics configuration
- 08-Fast forwarding configuration
- 09-Adjacency table configuration
- 10-IRDP configuration
- 11-IP performance optimization configuration
- 12-UDP helper configuration
- 13-IPv6 basics configuration
- 14-DHCPv6 configuration
- 15-IPv6 fast forwarding configuration
- 16-Tunneling configuration
- 17-GRE configuration
- 18-HTTP redirect configuration
| 18-HTTP redirect configuration | 51.79 KB |
Restrictions and guidelines: HTTP redirect configuration
HTTP redirect tasks at a glance
Specifying the HTTPS redirect listening port number
Associating an SSL server policy with the HTTPS redirect service
Configuring HTTP redirect
About HTTP redirect
HTTP redirect is a method to redirect users' HTTP or HTTPS requests to a specific URL. It is used in the following features:
· Redirect URL assignment in 802.1X authentication, MAC authentication, Web authentication, and port security.
· EAD assistant URL redirection in 802.1X authentication.
· URL redirection services in portal.
For URL redirection to function correctly in 802.1X authentication, MAC authentication, Web authentication, port security, and EAD assistant, make sure the packet incoming VLANs or VSIs have Layer 3 interfaces (VLAN or VSI interfaces) configured. Otherwise, redirection of HTTPS requests will fail.
No configuration is required to redirect HTTP requests.
To redirect HTTPS requests, perform the following tasks:
1. Specifying the HTTPS redirect listening port number
2. (Optional.) Associating an SSL server policy with the HTTPS redirect service
The device can redirect HTTPS requests only after you specify the TCP port number on which the HTTPS redirect service listens for HTTPS requests.
To avoid service unavailability caused by port conflict, do not specify a TCP port number used by a well-known protocol or used by any other TCP-based service. To display TCP port numbers that have been used by services, use the display tcp command. For more information about this command, see IP performance optimization commands in Layer 3—IP Services Command Reference.
If you perform this task multiple times, the most recent configuration takes effect.
1. Enter system view.
2. Specify the HTTPS redirect listening port number.
http-redirect https-port port-number
By default, the HTTPS redirect listening port number is 6654.
An SSL server policy is a set of SSL parameters used by the device when the device acts as the SSL server. You can configure parameters such as supported cipher suites and whether to perform digital certificate-based authentication on SSL clients for the SSL server policy.
You can use one of the following local certificates for HTTPS redirect service according to the security requirements and the configuration complexity:
· Self-signed certificate—Using this type of certificate is simple in configuration but has low security. You do not need to associate an SSL server policy with the HTTPS redirect service and the default SSL parameters are used. However, a self-signed certificate is not trusted by the browser. When the device redirects HTTPS requests to the specified URL, a certificate security warning prompt might appear on the browser. If you accept the security risks stated in the prompt, you can ignore the prompt to browse the page.
· CA-signed certificate—Using this type of certificate is complex in configuration but has high security. You must obtain a CA certificate, request a local certificate from the CA, create an SSL server policy, and associate the SSL server policy with the HTTPS redirect service.
For more information about digital certificates, see PKI in Security Configuration Guide. For more information about the SSL server policy configuration, see SSL in Security Configuration Guide.
HTTPS redirect is unavailable if the associated SSL server policy does not exist. You can first associate a nonexistent SSL server policy with the HTTPS redirect service and then configure the SSL server policy.
If you change the SSL server policy associated with the HTTPS redirect service, the new policy takes effect immediately.
2. Associate an SSL server policy with the HTTPS redirect service.
http-redirect ssl-server-policy policy-name
By default, no SSL server policy is associated with the HTTPS redirect service. The HTTPS redirect service uses the self-assigned certificate and the default SSL parameters.
