- 08-Local forwarding
- 01-Local Forwarding Mode and Local Portal Authentication Configuration Examples
- 02-Local Forwarding Mode Direct Portal Authentication Configuration Examples
- 03-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
- 04-Local Forwarding Configuration Examples
- 05-Wired Port Local Forwarding through Wireless Terminator Configuration Examples
- 06-Remote AP Configuration Examples
- 07-Downlink VLAN Management for Fit-Mode APs Configuration Examples
- 08-Downlink VLAN Management for Fit APs and Cloud APs Configuration Examples
08-Downlink VLAN Management for Fit APs and Cloud APs Configuration Examples | 105.42 KB |
H3C Access Controllers |
Downlink VLAN Management for Fit-Mode APs and Cloud-Mode APs |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring downlink VLAN management for fit-mode APs and cloud-mode APs
Configuring the cloud-managed AP
Introduction
The following information provides a downlink VLAN management configuration example for fit-mode APs and cloud-mode APs.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of AP management, radio management, WLAN access, VLAN, and local forwarding.
As shown in Figure 1, the switch acts as the DHCP server to assign IP addresses to the APs, the clients, and the PCs. The fit AP and the AC use VLAN 100 to establish a CAPWAP tunnel, the clients use VLAN 200 to access the wireless network, and the PCs use VLAN 300 to access the wired network.
· Configure local forwarding on the AC for the fit AP to directly forward the data traffic of Client 1.
· Connect PC 1 and PC 2 to downlink Ethernet interfaces on the fit AP and the cloud-managed AP, respectively. Make sure the PCs can visit the external network.
Analysis
For the configuration to be deployed to the AP, configure remote configuration synchronization or deploy the map file.
· For configuration to be deployed correctly, do not attach Tab characters or spaces to the end of command lines in the map file.
· Use the actual AP models and serial IDs to configure the APs.
· If a backup AC is configured, make sure the backup AC is also uploaded with the map file.
Procedures
Configuring the AC
1. Configure the interfaces of the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the interface. The AC will use this IP address to establish CAPWAP tunnels with the fit AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.1.2 24
[AC-Vlan-interface100] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, and assign the port to VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100
2. Configure a wireless service:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Set the VLAN to VLAN 200.
[AC-wlan-st-1] vlan 200
# Specify PSK as the AKM mode and specify 12345678 as the plaintext key.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Specify CCMP as the cipher suite and specify RSN as the security IE.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AP to forward client data traffic.
[AC-wlan-st-1] client forwarding-location ap
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure the fit AP:
NOTE: To simply AP configuration on a large-scale network, configure AP settings on a per AP group basis as a best practice. |
# Create manual AP ap1.
[AC] wlan ap ap1 model WA6320H
# Specify the AP serial ID.
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
# Create AP group group1 and configure ap1 as the AP grouping rule.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Bind service template 1 to radio 2 for AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320H
[AC-wlan-ap-group-group1-ap-model-WA6320H] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320H-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320H-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320H-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320H] quit
4. To deploy configuration through remote configuration synchronization:
# Create VLANs 200 and 300 in AP group group1.
[AC-wlan-ap-group-group1] vlan 200
[AC-wlan-ap-group-group1-vlan200] quit
[AC-wlan-ap-group-group1] vlan 300
[AC-wlan-ap-group-group1-vlan300] quit
# Specify uplink Ethernet interface GE1/0/1 that connects the AP to the switch as a trunk port, assign the port to all VLANs, set the PVID to 1, and disable port isolation.
[AC-wlan-ap-group-group1-ap-model-WA6320H] gigabitethernet 1
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-1] port-isolate disable
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-1] port link-type trunk
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-1] port trunk permit vlan all
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-1] port trunk pvid vlan 1
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-1] quit
# Specify downlink Ethernet interface GE1/0/2 that connects the AP to the PC as an access port, assign the port to VLAN 300, and disable port isolation.
[AC-wlan-ap-group-group1-ap-model-WA6320H] gigabitethernet 2
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-2] port-isolate disable
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-2] port access vlan 300
[AC-wlan-ap-group-group1-ap-model-WA6320H-gigabitethernet-2] quit
# Enable remote configuration synchronization.
[AC-wlan-ap-group-group1] remote-configuration enable
# Synchronize the configuration to the AP.
[AC-wlan-ap-group-group1] remote-configuration synchronize
5. To deploy configuration through a map configuration file:
NOTE: Use a text editor to edit the content of the apcfg.txt file in the configuration order, and upload the file to the AC. After the AP associates with the AC, use the map-configuration command to deploy the file to the AP for the configuration to take effect on the AP. |
# Edit the apcfg.txt file.
vlan 200
vlan 300
interface GigabitEthernet 1/0/1
undo port-isolate enable
interface GigabitEthernet 1/0/2
# Specify the AP configuration file as apcfg.txt in the AP group's AP model view.
[AC-wlan-ap-group-group1-ap-model-WA6320H] map-configuration apcfg.txt
1. Configure the AP interfaces:
# Create VLAN 200 and VLAN 300. The AP will use VLAN 200 to forward wireless traffic of Client 2 and use VLAN 300 for the wired network access of PC 2.
<AP> system-view
[AP] vlan 200
[AP-vlan200] quit
[AP] vlan 300
[AP-vlan300] quit
# Specify GigabitEthernet 1/0/1 that connects the AP to the switch as a trunk port, assign the port to all VLANs, and disable port isolation.
[AP] interface gigabitethernet 1/0/1
[AP-GigabitEthernet1/0/1] undo port-isolate enable
[AP-GigabitEthernet1/0/1] port link-type trunk
[AP-GigabitEthernet1/0/1] port trunk permit vlan all
[AP-GigabitEthernet1/0/1] quit
# Specify GE1/0/2 that connects the AP to PC 2 as an access port, configure the port to permit traffic from VLAN 300, and disable port isolation.
[AP] interface gigabitethernet 1/0/2
[AP-GigabitEthernet1/0/2] undo port-isolate enable
[AP-GigabitEthernet1/0/2] port link-type access
[AP-GigabitEthernet1/0/2] port access vlan 300
[AP-GigabitEthernet1/0/2] quit
# Create service template service1 and enter its view.
[AP] wlan service-template service1
[AP-wlan-st-service1] ssid service
[AP-wlan-st-service1] vlan 200
[AP-wlan-st-service1] akm mode psk
[AP-wlan-st-service1] preshared-key pass-phrase simple 12345678
[AP-wlan-st-service1] cipher-suite ccmp
[AP-wlan-st-service1] security-ie rsn
[AP-wlan-st-service1] service-template enable
[AP-wlan-st-service1] quit
3. Bind service template service1 to interface WLAN-Radio 1/0/1.
[AP] interface WLAN-Radio 1/0/1
[AP-WLAN-Radio1/0/1] undo shutdown
[AP-WLAN-Radio1/0/1] service-template service1
[AP-WLAN-Radio1/0/1] quit
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 2, VLAN 100, VLAN 200, VLAN 300, and the VLAN interfaces, and assign IP addresses to the VLAN interfaces. The switch will use VLAN 2 as the egress to the external network, VLAN 100 to forward packets between AC and AP, VLAN 200 to forward client traffic, and VLAN 300 for wired network access of the PCs.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
[Switch-Vlan-interface2] ip address 192.168.0.100 24
[Switch-Vlan-interface2] quit
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.168.1.1 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.168.2.1 24
[Switch-Vlan-interface200] quit
[Switch] vlan 300
[Switch-vlan300] quit
[Switch] interface vlan-interface 300
[Switch-Vlan-interface300] ip address 192.168.3.1 24
[Switch-Vlan-interface300] quit
# Specify GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the port to VLAN 100.
[Switch] interface GigabitEthernet 1/0/1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
# Specify GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, assign the port to all VLANs, and set the PVID to 100.
[Switch] interface GigabitEthernet 1/0/2
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan all
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2 that connects the switch to the fit AP.
# Specify GigabitEthernet 1/0/3 that connects the switch to the external network as an access port, and configure the port to permit traffic from VLAN 2.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 2
[Switch-GigabitEthernet1/0/3] quit
# Specify GigabitEthernet 1/0/4 that connects the switch to the cloud-managed AP as a trunk port, assign the port to all VLANs, and set the PVID to 100.
[Switch] interface GigabitEthernet 1/0/4
[Switch-GigabitEthernet1/0/4] port link-type trunk
[Switch-GigabitEthernet1/0/4] port trunk permit vlan all
[Switch-GigabitEthernet1/0/4] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/4 that connects the switch to the cloud-managed AP.
[Switch-GigabitEthernet1/0/4] poe enable
[Switch-GigabitEthernet1/0/4] quit
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign IP addresses to the APs, and specify subnet 192.168.1.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.168.1.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan100] forbidden-ip 192.168.1.2
[Switch-dhcp-pool-vlan100] gateway-list 192.168.1.1
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign IP addresses to the clients, specify subnet 192.168.2.0/24 in the DHCP address pool, and specify the gateway address as 192.168.2.1. Set the DNS server address according to the actual networking planning.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.168.2.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan200] gateway-list 192.168.2.1
[Switch-dhcp-pool-vlan200] dns-list 192.168.2.1
[Switch-dhcp-pool-vlan200] quit
# Create DHCP address pool vlan300 to assign IP addresses to the PCs, specify subnet 192.168.3.0/24 in the DHCP address pool, and specify the gateway address as 192.168.3.1. Set the DNS server address according to the actual networking planning.
[Switch] dhcp server ip-pool vlan300
[Switch-dhcp-pool-vlan300] network 192.168.3.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan300] gateway-list 192.168.3.1
[Switch-dhcp-pool-vlan300] dns-list 192.168.3.1
[Switch-dhcp-pool-vlan300] quit
3. Configure default routes for the switch to visit the external IP network. (Details not shown.)
# Verify that the IP addresses obtained by Client 1, PC 1, Client 2, and PC 2 are 192.168.2.2, 192.168.3.2, 192.168.2.3, and 192.168.3.3, respectively, and all the clients and PCs can visit the external network.
Configuration files
· AC:
Vlan 100
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.168.1.2 255.255.255.0
port trunk permit vlan 1 100
ap ap1
ap-model WA6320H
map-configuration flash:/apcfg.txt
radio 1
radio 2
radio enable
service-template 1
· Cloud-managed AP:
vlan 200
vlan 300
ssid service
vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface WLAN-Radio1/0/1
port link-mode bridge
· Switch:
dhcp enable
vlan 2
vlan 100
vlan 200
vlan 300
interface Vlan-interface2
ip address 192.168.0.100 255.255.255.0
interface Vlan-interface200
ip address 192.168.2.1 255.255.255.0
interface Vlan-interface300
ip address 192.168.3.1 255.255.255.0
poe enable
port access vlan 2
interface GigabitEthernet1/0/4
poe enable
Related documentation
· AP and WT Management Command Reference in H3C Access Controllers Command References
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
