- 13-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-MIRRORGROUP-MIB
- 05-HH3C-NETCONF-MIB
- 06-HH3C-NQA-MIB
- 07-HH3C-NTP-MIB
- 08-HH3C-RMON-EXT2-MIB
- 09-HH3C-SNMP-EXT-MIB
- 10-RMON2-MIB
- 11-RMON-MIB
- 12-SNMP-FRAMEWORK-MIB
- 13-SNMP-MPD-MIB
- 14-SNMP-NOTIFICATION-MIB
- 15-SNMP-TARGET-MIB
- 16-SNMP-USER-BASED-SM-MIB
- 17-SNMPv2-MIB
- 18-SNMP-VIEW-BASED-ACM-MIB
| 05-HH3C-NETCONF-MIB | 58.10 KB |
hh3cNetconfSessionPeerIPAddressType
hh3cNetconfSessionTerminationReason
HH3C-NETCONF-MIB
About this MIB
Use this MIB to notify SNMP NMSs of NETCONF session establishment and disconnection events.
MIB file name
hh3c-netconf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetconf(206)
Scalar objects
hh3cNetconfSessionId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionId (1.3.6.1.4.1.25506.2.206.1.1.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..2147483647) |
NETCONF session ID. |
Implementation varies by product. |
hh3cNetconfSessionUserName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionUserName (1.3.6.1.4.1.25506.2.206.1.1.2) |
DisplayString |
OCTET STRING (1..80) |
NETCONF session username. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.3) |
InetAddress |
Standard MIB values. |
Type of the remote IP address that established the NETCONF session with the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.4) |
InetAddressType |
Remote IP address that established the NETCONF session with the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionTerminationReason (1.3.6.1.4.1.25506.2.206.1.1.5) |
INTEGER |
other(1), closed(2), linkDown(3), idleTimeout(4), |
Reason. for the session to be disconnected by the NETCONF client. |
Options: other(1)—Any other reason than those listed below. closed(2)—Session was closed. linkDown(3)—Link went down. idleTimeout(4)—Session timed out. |
Notifications
hh3cNetconfServerSessionStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
(1.3.6.1.4.1.25506.2.206.2.0.1) |
NETCONF server established a session. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the NETCONF server established a session with a NETCONF client.
Status control
No action is required.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.206.1.1.1 (hh3cNetconfSessionId) |
No |
Integer32 |
1.3.6.1.4.1.25506.2.206.1.1.2 (hh3cNetconfSessionUserName) |
No |
DisplayString |
1.3.6.1.4.1.25506.2.206.1.1.3 (hh3cNetconfSessionPeerIPAddressType) |
No |
InetAddressType |
1.3.6.1.4.1.25506.2.206.1.1.4 (hh3cNetconfSessionPeerIPAddress) |
No |
InetAddress |
Recommended action
hh3cNetconfServerSessionEnd
Basic information
OID |
Event |
Type |
Severity |
Default status |
(1.3.6.1.4.1.25506.2.206.2.0.2) |
NETCONF server ended a session |
Error |
N/A |
N/A |
ON |
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
No |
DisplayString |
No |
InetAddressType |
No |
InetAddress |
1.3.6.1.4.1.25506.2.206.1.1.5 (hh3cNetconfSessionTerminationReason) |
Reasons for the session to be disconnected by the NETCONF client: |
No |
INTEGER |
Options: other(1)—Any other reason than those listed below. closed(2)—Session was closed. timeout(3)—Session exception occurred. idleTimeout(4)—Session timed out. |
Recommended action
· If the session was closed normally, no action is required.
· If the session was closed abnormally, check the physical link.
