13-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10013-Network Management and Monitoring
03-DISMAN-TRACEROUTE-MIB
03-DISMAN-TRACEROUTE-MIB 109.50 KB
About this MIB
This MIB contains information about the traceroute (tracert) utility defined by RFC 4560 and the traceroute notifications. The traceroute utility is implemented by NQA UDP traceroute operations.
To implement DISMAN TRACEROUTE, the devices must support this MIB. This MIB cannot be used together with CLI.
MIB file name
rfc4560-disman-traceroute.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).traceRouteMIB(81)
Scalar objects
traceRouteMaxConcurrentRequests
Object (OID)
Access
Value range
Implementation
traceRouteMaxConcurrentRequests (1.3.6.1.2.1.81.1.1)
read-only
Unsigned32
Standard MIB values.
Maximum number of concurrent active traceroute requests that are allowed within an agent implementation.
Same as ping MaxConcurrentRequests.
Tabular objects
traceRouteCtlTable
About this table
Use this table to define probe parameters for a traceroute operation.
Support for operations
Create
Edit/Modify
Delete
Read
·     When create a traceroute operation entry, the default value of traceRouteCtlType is traceRouteUsingUdpProbes. At present, the traceRouteCtlType object supports only traceRouteUsingUdpProbes.
·     When create a traceroute operation entry, the values of the traceRouteCtlOwnerIndex and traceRouteCtlTestName objects must be different than the pingCtlOwnerIndex and pingCtlTestName objects.
·     Modifying any object in the traceRouteCtlTable except the following objects will clear the corresponding probe results, history records, and statistics information:
¡     traceRouteCtlTrapGeneration.
¡     traceRouteCtlDescr.
¡     traceRouteCtlMaxRows. If the new value for this object is lower than the previous value, the system deletes the excessive history records.
·     You must specify traceRouteCtlTargetAddressType and traceRouteCtlTargetAddress in pairs in an SNMP request.
·     You must specify traceRouteCtlSourceAddressType and traceRouteCtlSourceAddress in pairs in an SNMP request.
·     When traceRouteCtlAdminStatus is enabled, you cannot change the configuration in the traceRouteCtlTable.
Supported
Supported
Columns
The table indexes are traceRouteCtlOwnerIndex and traceRouteCtlTestName.
Table OID: 1.3.6.1.2.1.81.1.2.
Object (OID)
Access
Value range
Implementation
traceRouteCtlOwnerIndex (1.3.6.1.2.1.81.1.2.1.1)
not-accessible
SnmpAdminString
OCTET STRING (0..32)
Administrator name.
For the set operation, the uppercase letters in the value will be converted to lowercase letters.
The value cannot contain a minus sign (-) or question mark (?).
traceRouteCtlTestName (1.3.6.1.2.1.81.1.2.1.2)
not-accessible
SnmpAdminString
Operation tag.
traceRouteCtlTargetAddressType (1.3.6.1.2.1.81.1.2.1.3)
read-create
InetAddressType
Destination address type.
Supports only ipv4(1), dns(16), and unknown(0).
traceRouteCtlTargetAddress (1.3.6.1.2.1.81.1.2.1.4)
read-create
InetAddress
Destination address.
If the value for the traceRouteCtlTargetAddressType object is ipv4(1), the value for this object must be an IPv4 address.
If the value for the traceRouteCtlTargetAddressType object is dns(16), the value for this object can be a host name.
If the value for the traceRouteCtlTargetAddressType object is unknown(0), the value for this object must be a zero-length string.
traceRouteCtlByPassRouteTable(1.3.6.1.2.1.81.1.2.1.5)
read-create
TruthValue
Whether to bypass the routing table.
As per the MIB.
traceRouteCtlDataSize (1.3.6.1.2.1.81.1.2.1.6)
read-create
Unsigned32
Unsigned32 (0..65507)
Size of the data portion of a traceroute request, in octets.
Value range: 20 to 65507 octets.
Default: 100 octets.
traceRouteCtlTimeOut (1.3.6.1.2.1.81.1.2.1.7)
read-create
Unsigned32
Unsigned32 (1-60)
Timeout time for waiting for a response to a probe request..
Same as the standard MIB file.
traceRouteCtlProbesPerHop
(1.3.6.1.2.1.81.1.2.1.8)
read-create
Unsigned32
Unsigned32 (1-10)
Number of times to reissue a traceroute request with the same time-to-live (TTL) value.
Same as the standard MIB file..
traceRouteCtlPort
(1.3.6.1.2.1.81.1.2.1.9)
read-create
Unsigned32
Unsigned32 (1-65535)
Destination port number.
traceRouteCtlMaxTtl
(1.3.6.1.2.1.81.1.2.1.10)
read-create
Unsigned32
Unsigned32 (1-255)
Maximum TTL value.
traceRouteCtlDSField
(1.3.6.1.2.1.81.1.2.1.11)
read-create
Unsigned32
Unsigned32 (0-255)
Service type.
As per the MIB.
traceRouteCtlSourceAddressType (1.3.6.1.2.1.81.1.2.1.12)
read-create
InetAddressType
Source address type.
Supports only ipv4(1) and unknown(0).
Default:
unknown(0).
traceRouteCtlSourceAddress (1.3.6.1.2.1.81.1.2.1.13)
read-create
InetAddress
Source address.
If the value for the traceRouteCtlSourceAddressType object is ipv4(1), the value for this object must be an IPV4 address.
If the value for the traceRouteCtlSourceAddressType object is unknown(0), the value for this object must be a zero-length string.
traceRouteCtlIfIndex
(1.3.6.1.2.1.81.1.2.1.14)
read-create
InterfaceIndexOrZero
Output interface index.
traceRouteCtlMiscOptions
(1.3.6.1.2.1.81.1.2.1.15)
read-create
SnmpAdminString
OCTET STRING (0..255)
Implementation-dependent options.
Value range: 0 to 200 characters.
The corresponding function is not supported.
traceRouteCtlMaxFailures
(1.3.6.1.2.1.81.1.2.1.16)
read-create
Unsigned32
Unsigned32 (0-255)
Maximum number of consecutive timeouts allowed before a remote traceroute request is terminated.
traceRouteCtlDontFragment
(1.3.6.1.2.1.81.1.2.1.17)
read-create
TruthValue
Whether to enable setting of the don't fragment flag (DF) in the IP header.
traceRouteCtlInitialTtl
(1.3.6.1.2.1.81.1.2.1.18)
read-create
Unsigned32
Unsigned32 (1..255)
Initial TTL value.
traceRouteCtlFrequency (1.3.6.1.2.1.81.1.2.1.19)
read-create
Unsigned32
Interval between two consecutive traceroute probes.
Value range: 0 to 604800 seconds.
The return value for the read operation is not accurate if the value is not set to integer seconds at the CLI.
For example, if the value configured at the CLI is 1050 milliseconds, the return value for the read operation will be 2 seconds.
Default: 0 seconds.
traceRouteCtlStorageType (1.3.6.1.2.1.81.1.2.1.20)
read-create
StorageType
Storage type.
As per the MIB.
traceRouteCtlAdminStatus (1.3.6.1.2.1.81.1.2.1.21)
read-create
INTEGER
enabled(1)
disabled(2)
Operation status.
As per the MIB.
traceRouteCtlDescr (1.3.6.1.2.1.81.1.2.1.22)
read-create
SnmpAdminString
Description string for the remote traceroute operation.
The value cannot start with a space.
traceRouteCtlMaxRows (1.3.6.1.2.1.81.1.2.1.23)
read-create
Unsigned32
Maximum number of history records.
Value range: 0 to 50.
traceRouteCtlTrapGeneration (1.3.6.1.2.1.81.1.2.1.24)
read-create
BITS
BITS {
pathChange(0),
testFailure(1),
testCompletion(2)
Conditions to generate notifications.
As per the MIB.
traceRouteCtlCreateHopsEntries(1.3.6.1.2.1.81.1.2.1.25)
read-create
TruthValue
Whether to generate the hop table.
As per the MIB.
traceRouteCtlType  (1.3.6.1.2.1.81.1.2.1.26)
read-create
OBJECT IDENTIFIER
Traceroute operation type.
This object cannot be edited after creation.
traceRouteCtlRowStatus (1.3.6.1.2.1.81.1.2.1.27)
read-create
RowStatus
Row status.
Supports only active(1), createAndgo(4), and destroy(6).
traceRouteResultsTable
About this table
This table contains information about traceroute probe results.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Table OID: 1.3.6.1.2.1.81.1.3.
Object (OID)
Access
Value range
Implementation
traceRouteResultsOperStatus (1.3.6.1.2.1.81.1.3.1.1)
read-only
INTEGER
enabled(1) ,
disabled(2),
completed(3)
Operation status of a remote traceroute operation.
As per the MIB.
traceRouteResultsCurHopCount (1.3.6.1.2.1.81.1.3.1.2)
read-only
Gauge32
Current TTL value for the traceroute request.
As per the MIB.
traceRouteResultsCurProbeCount (1.3.6.1.2.1.81.1.3.1.3)
read-only
Gauge32
Current probe count for the remote traceroute operation.
As per the MIB.
traceRouteResultsIpTgtAddrType (1.3.6.1.2.1.81.1.3.1.4)
read-only
InetAddressType
Type of address stored in the corresponding traceRouteResultsIpTgtAddr object.
As per the MIB.
traceRouteResultsIpTgtAddr (1.3.6.1.2.1.81.1.3.1.5)
read-only
InetAddress
IP address associated with a traceRouteCtlTargetAddress value when the destination address is specified as a DNS name.
As per the MIB.
traceRouteResultsTestAttempts (1.3.6.1.2.1.81.1.3.1.6)
read-only
Gauge32
Current number of probe attempts.
As per the MIB.
traceRouteResultsTestSuccesses (1.3.6.1.2.1.81.1.3.1.7)
read-only
Gauge32
Current number of succeeded probe attempts.
As per the MIB.
traceRouteResultsLastGoodPath (1.3.6.1.2.1.81.1.3.1.8)
read-only
DateAndTime
Date and time when the last complete path was determined.
As per the MIB.
traceRouteProbeHistoryTable
About this table
Use this table to obtain history information about each probe in a traceroute operation.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are traceRouteCtlOwnerIndex, traceRouteCtlTestName, traceRouteProbeHistoryIndex, traceRouteProbeHistoryHopIndex, and traceRouteProbeHistoryProbeIndex.
Table OID: 1.3.6.1.2.1.81.1.4.
Object (OID)
Access
Value range
Implementation
traceRouteProbeHistoryIndex (1.3.6.1.2.1.81.1.4.1.1)
not-accessible
Unsigned32
Unsigned32 (1..'ffffffff'h)
History record index of a traceroute operation.
As per the MIB.
traceRouteProbeHistoryHopIndex (1.3.6.1.2.1.81.1.4.1.2)
not-accessible
Unsigned32
Unsigned32 (1-255)
Index of a hop in the record.
As per the MIB.
traceRouteProbeHistoryProbeIndex (1.3.6.1.2.1.81.1.4.1.3)
not-accessible
Unsigned32
Unsigned (1-10)
Index of a probe for the hop in the traceroute path.
As per the MIB.
traceRouteProbeHistoryHAddrType(1.3.6.1.2.1.81.1.4.1.4)
read-only
InetAddressType
Type of address for the hop in the traceroute path.
As per the MIB.
traceRouteProbeHistoryHAddr (1.3.6.1.2.1.81.1.4.1.5)
read-only
InetAddress
Address of the hop in the traceroute path.
As per the MIB.
traceRouteProbeHistoryResponse (1.3.6.1.2.1.81.1.4.1.6)
read-only
Unsigned32
Amount of time measured in milliseconds from when the probe was sent to when its response was received or when it timed out.
As per the MIB.
traceRouteProbeHistoryStatus (1.3.6.1.2.1.81.1.4.1.7)
read-only
OperationResponseStatus
Probe result.
As per the MIB.
traceRouteProbeHistoryLastRC (1.3.6.1.2.1.81.1.4.1.8)
read-only
Integer32
The last implementation-method-specific reply code received.
As per the MIB.
traceRouteProbeHistoryTime (1.3.6.1.2.1.81.1.4.1.9)
read-only
DateAndTime
Time when the probe result was determined.
As per the MIB.
traceRouteHopsTable
About this table
This table contains information about each hop in a traceroute path.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are traceRouteCtlOwnerIndex, traceRouteCtlTestName, and traceRouteHopsHopIndex.
Table OID: 1.3.6.1.2.1.81.1.5.
Object (OID)
Access
Value range
Implementation
traceRouteHopsHopIndex (1.3.6.1.2.1.81.1.5.1.1)
not-accessible
Unsigned32
Unsigned32 (1..4294967295)
Hop index.
As per the MIB.
traceRouteHopsIpTgtAddressType (1.3.6.1.2.1.81.1.5.1.2)
read-only
InetAddressType
As per the MIB.
traceRouteHopsIpTgtAddress (1.3.6.1.2.1.81.1.5.1.3)
read-only
InetAddress
As per the MIB.
traceRouteHopsMinRtt (1.3.6.1.2.1.81.1.5.1.4)
read-only
Unsigned32
Minimum bidirectional delay.
As per the MIB.
traceRouteHopsMaxRtt (1.3.6.1.2.1.81.1.5.1.5)
read-only
Unsigned32
Maximum bidirectional delay.
As per the MIB.
traceRouteHopsAverageRtt (1.3.6.1.2.1.81.1.5.1.6)
read-only
Unsigned32
Average bidirectional delay
As per the MIB.
traceRouteHopsRttSumOfSquares (1.3.6.1.2.1.81.1.5.1.7)
read-only
Unsigned32
Sum of squares for delay.
As per the MIB.
traceRouteHopsSentProbes (1.3.6.1.2.1.81.1.5.1.8)
read-only
Unsigned32
Number of sent probe packets.
As per the MIB.
traceRouteHopsProbeResponses (1.3.6.1.2.1.81.1.5.1.9)
read-only
Unsigned32
Number of received probe reply packets.
As per the MIB.
traceRouteHopsLastGoodProbe (1.3.6.1.2.1.81.1.5.1.10)
read-only
DateAndTime
Date and time when the last probe reply packet was received.
As per the MIB.
Notifications
traceRoutePathChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.81.0.1
The traceroute path changed.
Informational
N/A
N/A
OFF
This notification is generated if the path obtained by the current traceroute operation is different from the path obtained by previous traceroute operations. The traceroute path changes if the value for the traceRouteCtlTrapGeneration object is pathChange(0).
Status control
ON
CLI: Use the reaction trap path-change command.
OFF
CLI: Use the undo reaction trap path-change command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.81.1.2.1.3 (traceRouteCtlTargetAddressType)
No
InetAddressType
1.3.6.1.2.1.81.1.2.1.4 (traceRouteCtlTargetAddress)
No
InetAddress
1.3.6.1.2.1.81.1.3.1.4 (traceRouteResultsIpTgtAddrType)
Destination address type in the probe result.
No
InetAddressType
1.3.6.1.2.1.81.1.3.1.5 (traceRouteResultsIpTgtAddr)
Destination address in the probe result.
No
InetAddress
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
traceRouteTestFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.81.0.2
A traceroute operation failed.
Informational
N/A
N/A
OFF
This notification is generated when a traceroute operation fails. A traceroute operation fails if the value for the traceRouteCtlTrapGeneration object is testFailure(1).
Status control
ON
CLI: Use the reaction trap test-failure [ accumulate-probe-failures ] command.
OFF
CLI: Use the undo reaction trap test-failure [ accumulate-probe-failures ] command.
Objects
OID (object name)
Index
Value range
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
traceRouteTestCompleted
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.81.0.3
A traceroute operation completed.
Informational
N/A
N/A
OFF
This notification is generated when a traceroute operation completes successfully. A traceroute operation completes successfully if the value for the traceRouteCtlTrapGeneration object is testCompletion(4).
Status control
ON
CLI: Use the reaction trap test-complete command.
OFF
CLI: Use the undo reaction trap test-complete command.
Objects
OID (object name)
Index
Value range
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
