13-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10013-Network Management and Monitoring
10-RMON2-MIB
10-RMON2-MIB 57.10 KB
RMON2-MIB
About this MIB
Use this MIB to monitor the data traffic on a network segment or the entire network. RMON2-MIB is an extended version of RMON to support multi-dimensional monitoring and statistics.
MIB file name
rfc4502-rmon2.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Scalar objects
probeCapabilities
Object (OID)
Access
Value range
Implementation
probeCapabilities (1.3.6.1.2.1.16.19.1)
read-only
BITS
BITS { etherStats(0), historyControl(1), etherHistory(2), alarm(3), hosts(4), hostTopN(5), matrix(6), filter(7), capture(8), event(9), tokenRingMLStats(10), tokenRingPStats(11), tokenRingMLHistory(12), tokenRingPHistory(13), ringStation(14), ringStationOrder(15), ringStationConfig(16), sourceRouting(17), protocolDirectory(18), protocolDistribution(19), addressMapping(20), nlHost(21), nlMatrix(22), alHost(23), alMatrix(24), usrHistory(25), probeConfig(26) }
An indication of the RMON MIB groups supported on a minimum of one interface by this probe.
As per the MIB.
probeSoftwareRev
Object (OID)
Access
Value range
Implementation
probeSoftwareRev (1.3.6.1.2.1.16.19.2)
read-only
OCTET STRING
OCTET STRING (0..15)
Software revision of this device.
As per the MIB.
probeHardwareRev
Object (OID)
Access
Value range
Implementation
probeHardwareRev (1.3.6.1.2.1.16.19.3)
read-only
DisplayString
OCTET STRING (0..31)
Hardware revision of this device.
Not supported.
probeDateTime
Object (OID)
Access
Value range
Implementation
probeDateTime (1.3.6.1.2.1.16.19.4)
read-only
OCTET STRING
OCTET STRING (0 | 8 | 11)
Probe's current date and time.
As per the MIB.
probeResetControl
Object (OID)
Access
Value range
Implementation
probeResetControl (1.3.6.1.2.1.16.19.5)
read-write
INTEGER
running(1), warmBoot(2), coldBoot(3)
Reset control setting on the device.
Supports only read operations.
Tabular objects
usrHistoryControlTable
About this table
Use this table to configure user-defined history control entries.
Support for operations
Create
Edit/Modify
Delete
Read
To create a row of instances, you must specify usrHistoryControlIndex and usrHistoryControlStatus in pairs.
Not supported
Supported
Supported
Columns
The table index is usrHistoryControlIndex.
Object (OID)
Access
Value range
Implementation
usrHistoryControlIndex (1.3.6.1.2.1.16.18.1.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Index of a usrHistoryControl entry.
As per the MIB.
usrHistoryControlObjects (1.3.6.1.2.1.16.18.1.1.2)
read-create
Integer32
Number of MIB objects on which historical data is collected.
Value range: 1 to 30.
Default value: 1.
usrHistoryControlBucketsRequested (1.3.6.1.2.1.16.18.1.1.3)
read-create
Integer32
Requested number of samples to be retained for the entry.
A maximum of 50 samples are supported.
You can set a value larger than 50 for this object, but only 50 samples are supported.
usrHistoryControlBucketsGranted (1.3.6.1.2.1.16.18.1.1.4)
read-only
Integer32
Granted number of samples to be retained for the entry.
As per the MIB.
usrHistoryControlInterval (1.3.6.1.2.1.16.18.1.1.5)
read-create
Integer32
Integer32 (1..2147483647)
Sampling interval, in seconds.
Value range: 1 to 4294967.
usrHistoryControlOwner (1.3.6.1.2.1.16.18.1.1.6)
read-create
OwnerString
OCTET STRING (0..127)
Owner of the entry.
Not-displayable characters or question marks are not allowed.
Default: Zero-length string.
usrHistoryControlStatus (1.3.6.1.2.1.16.18.1.1.7)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of the entry.
Supports only createAndWait(5) after the entry is created.
usrHistoryObjectTable
About this table
Use this table to configure user-defined data-collection entries.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are usrHistoryControlIndex and usrHistoryObjectIndex.
Object (OID)
Access
Value range
Implementation
usrHistoryObjectIndex (1.3.6.1.2.1.16.18.2.1.1)
not-accessible
Integer32
Index of a usrHistoryObject entry.
As per the MIB.
usrHistoryObjectVariable (1.3.6.1.2.1.16.18.2.1.2)
read-create
OBJECT IDENTIFIER
Standard MIB values.
OID of the variable to be sampled.
As per the MIB.
usrHistoryObjectSampleType (1.3.6.1.2.1.16.18.2.1.3)
read-create
INTEGER
absoluteValue(1), deltaValue(2)
Method of sampling the selected variable for storage in the usrHistoryTable.
As per the MIB.
usrHistoryTable
About this table
Use this table to obtain information about history samples.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are usrHistoryControlIndex, usrHistorySampleIndex, and usrHistoryObjectIndex.
Object (OID)
Access
Value range
Implementation
usrHistorySampleIndex (1.3.6.1.2.1.16.18.3.1.1)
not-accessible
Integer32
Index of a sample of this entry.
As per the MIB.
usrHistoryIntervalStart (1.3.6.1.2.1.16.18.3.1.2)
read-only
TimeTicks
Standard MIB values
Sampling start time.
As per the MIB.
usrHistoryIntervalEnd (1.3.6.1.2.1.16.18.3.1.3)
read-only
TimeStamp
Standard MIB values
Sampling end time.
As per the MIB.
usrHistoryAbsValue (1.3.6.1.2.1.16.18.3.1.4)
read-only
Gauge32
Standard MIB values
Absolute value of the monitored object.
As per the MIB.
usrHistoryValStatus
(1.3.6.1.2.1.16.18.3.1.5)
read-only
INTEGER
valueNotAvailable(1), valuePositive(2), valueNegative(3)
Indicates the validity and sign of the data in the associated instance of usrHistoryAbsValue.
As per the MIB.
