06-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10006-Layer 3 - IP Services
12-HH3C-TUNNEL-TRAP-MIB
12-HH3C-TUNNEL-TRAP-MIB 47.29 KB
About this MIB
Use this MIB to output notifications for the tunnel module.
MIB file name
hh3c-tunnel-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTunnelTrap(226)
Notifications
hh3cTunnelTrapVxlanStatusUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.226.1.1.0.1
A VXLAN tunnel came up.
Error
Warning
N/A
OFF
This notification is generated when a VXLAN tunnel comes up at the link layer.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel vxlan-tunnel-status command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel vxlan-tunnel-status command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.226.1.1.1.1 (hh3cTunnelTrapVxlanStatusSType)
Tunnel source address type.
No
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.1.1.1.2 (hh3cTunnelTrapVxlanStatusSrcIP)
Tunnel source address.
No
InetAddress
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.226.1.1.1.3 (hh3cTunnelTrapVxlanStatusDType)
Tunnel destination address type.
No
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.2.226.1.1.1.4 (hh3cTunnelTrapVxlanStatusDstIP)
Tunnel destination address.
No
InetAddress
Recommended action
No action is required.
hh3cTunnelTrapVxlanStatusDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.1.1.0.2
A VXLAN tunnel went down.
Error
Warning
N/A
OFF
This notification is generated when a VXLAN tunnel goes down at the link layer.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
No
InetAddress
No
INTEGER
unknown(0),
ipv4(1),
ipv6(2)
No
InetAddress
Recommended action
