- 06-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
04-HH3C-DHCP4-MIB | 236.37 KB |
hh3cDhcpServer2AlwaysBroadcast
hh3cDhcpServer2BootpReplyRfc1048
hh3cDhcpServer2OnlineFailReason
hh3cDhcpServer2IfApplyPoolTable
hh3cDhcpServer2PoolStaticTable
hh3cDhcpServer2PoolOptionTable
hh3cDhcpServer2PoolForbidTable
hh3cDhcpServer2ValidClassTable
hh3cDhcpServer2RuleHwAddrTable
HH3C-DHCP4-MIB
About this MIB
The Dynamic Host Configuration Protocol (DHCP) provides a framework to assign configuration information to network devices.
DHCP adopts a client/server model. A DHCP client initiates a request for configuration parameters such as IP address, subnet mask, and the gateway address, and the DHCP server replies with the requested parameters.
Both BOOTP and DHCP use UDP protocols for packet encapsulation and use the same packet format. The major difference between BOOTP and DHCP is that BOOTP supports static configuration of the IP addresses while DHCP supports dynamic configuration.
The following figure shows a typical DHCP application scenario where the DHCP clients and the DHCP server reside on the same subnet.
The DHCP relay agent enables clients to get IP addresses and configuration parameters from a DHCP server on another subnet.
Typically, a DHCP relay agent can be a host or a router enabled with the DHCP relay agent feature.
MIB file name
hh3c-dhcp4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4(122)
Scalar objects
hh3cDhcpServer2Enabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to always broadcast responses. |
As per the MIB. |
hh3cDhcpServer2IgnoreBootp
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to ignore BOOTP requests. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the sending of BOOTP responses in RFC 1048 format. |
As per the MIB. |
hh3cDhcpServer2Opt82Enabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to handle Option 82. |
As per the MIB. |
hh3cDhcpServer2PingNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6) |
read-write |
Unsigned32 |
Unsigned32(0..10) |
Maximum number of attempts that the DHCP server pings an IP address before assigning the IP address to a DHCP client. |
As per the MIB. |
hh3cDhcpServer2PingTimeout
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7) |
read-write |
Unsigned32 |
Unsigned32(0..10000) |
Ping response timeout time for the DHCP server to ping an IP address. |
As per the MIB. |
hh3cDhcpServer2InformNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2InformNum (1.3.6.1.4.1.25506.2.122.1.2.7) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of DHCP-INFORM messages that the DHCP server receives. |
As per the MIB. |
hh3cDhcpServer2BootpReplyNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyNum (1.3.6.1.4.1.25506.2.122.1.2.8) |
read-only |
Counter64 |
Number of BOOTP-REPLY messages that the DHCP server sends. |
As per the MIB. |
hh3cDhcpServer2OfferNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OfferNum (1.3.6.1.4.1.25506.2.122.1.2.9) |
read-only |
Counter64 |
Number of DHCP-OFFER messages that the DHCP server sends. |
As per the MIB. |
hh3cDhcpServer2AckNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AckNum (1.3.6.1.4.1.25506.2.122.1.2.10) |
read-only |
Counter64 |
Number of DHCP-ACK messages that the DHCP server sends. |
As per the MIB. |
hh3cDhcpServer2NakNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2NakNum (1.3.6.1.4.1.25506.2.122.1.2.11) |
read-only |
Counter64 |
Number of DHCP-NAK messages that the DHCP server sends. |
As per the MIB. |
hh3cDhcpServer2TotalPoolUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2TotalPoolUsage (1.3.6.1.4.1.25506.2.122.1.2.12) |
read-only |
Unsigned32 |
Unsigned32(0..100) |
DHCP address pool usage. |
As per the MIB. |
hh3cDhcpServer2PoolNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolNumber (1.3.6.1.4.1.25506.2.122.1.2.13) |
read-only |
Unsigned32 |
Standard MIB values. |
Total number of DHCP address pools. |
As per the MIB. |
h3cDhcpServer2ConflictNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cDhcpServer2ConflictNum (1.3.6.1.4.1.25506.2.122.1.2.14) |
read-only |
Unsigned32 |
Total number of conflicting IP addresses on the DHCP server. |
As per the MIB. |
hh3cDhcpServer2AutoBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AutoBindNum (1.3.6.1.4.1.25506.2.122.1.2.15) |
read-only |
Unsigned32 |
Number of dynamic DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ManualBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ManualBindNum (1.3.6.1.4.1.25506.2.122.1.2.16) |
read-only |
Unsigned32 |
Number of static DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ExpiredBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ExpiredBindNum (1.3.6.1.4.1.25506.2.122.1.2.17) |
read-only |
Unsigned32 |
Number of expired DHCP bindings. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OnlineFailReason (1.3.6.1.4.1.25506.2.122.1.2.24) |
accessible-for-notify |
OCTET STRING |
Reason for the DHCP server online failure. |
not support |
Tabular objects
hh3cDhcpServer2PoolTable
About this table
This table records the address pool configuration on a DHCP server.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported. When you create a new address pool, this table automatically creates an instance for the pool. |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2PoolIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolIndex (1.3.6.1.4.1.25506.2.122.2.1.1.1) |
not-accessible |
Unsigned32 |
DHCP address pool index. |
Implementation varies by product. |
hh3cDhcpServer2PoolName (1.3.6.1.4.1.25506.2.122.2.1.1.2) |
read-create |
OCTET STRING |
OCTET STRING (1..63) |
DHCP address pool name. |
As per the MIB. |
hh3cDhcpServer2PoolVpnName (1.3.6.1.4.1.25506.2.122.2.1.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..31) |
VPN to which the DHCP address pool is bound. |
As per the MIB. |
hh3cDhcpServer2PoolNetwork (1.3.6.1.4.1.25506.2.122.2.1.1.4) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary network address of the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolNetworkMask (1.3.6.1.4.1.25506.2.122.2.1.1.5) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Mask for the primary network address. |
As per the MIB. |
hh3cDhcpServer2PoolStartAddr (1.3.6.1.4.1.25506.2.122.2.1.1.6) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolEndAddr (1.3.6.1.4.1.25506.2.122.2.1.1.7) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseDay (1.3.6.1.4.1.25506.2.122.2.1.1.8) |
read-create |
Integer32 |
Integer32(0..365) |
Lease duration in days. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseHour (1.3.6.1.4.1.25506.2.122.2.1.1.9) |
read-create |
Integer32 |
Integer32 (0..23) |
Lease duration in hours. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseMinute (1.3.6.1.4.1.25506.2.122.2.1.1.10) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in minutes. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseSecond (1.3.6.1.4.1.25506.2.122.2.1.1.11) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in seconds. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseUnlimit (1.3.6.1.4.1.25506.2.122.2.1.1.12) |
read-create |
TruthValue |
true(1), false(2) |
Whether the lease duration is unlimited. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseTime (1.3.6.1.4.1.25506.2.122.2.1.1.13) |
read-create |
TimeTicks |
DHCP lease time in TimeTicks |
As per the MIB. |
hh3cDhcpServer2PoolDomainName (1.3.6.1.4.1.25506.2.122.2.1.1.14) |
read-create |
OCTET STRING |
Domain name suffix assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolGatewayIP (1.3.6.1.4.1.25506.2.122.2.1.1.15) |
read-create |
OCTET STRING |
OCTET STRING (0..127) |
Gateway IP address. |
As per the MIB. |
hh3cDhcpServer2PoolDNSIP(1.3.6.1.4.1.25506.2.122.2.1.1.16) |
read-create |
OCTET STRING |
DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolPrimaryDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.17) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecondDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.18) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolNetbiosType (1.3.6.1.4.1.25506.2.122.2.1.1.19) |
read-create |
INTEGER |
null(0), bnode(1) pnode(2), mnode(4), hnode(8) |
NETBIOS node type. |
As per the MIB. |
hh3cDhcpServer2PoolNbnsIP(1.3.6.1.4.1.25506.2.122.2.1.1.20) |
read-create |
OCTET STRING |
SIZE(0..127) |
NETBIOS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBootFileName (1.3.6.1.4.1.25506.2.122.2.1.1.21) |
read-create |
OCTET STRING |
SIZE(0..63) |
Name of a configuration file to be assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolBimsIP(1.3.6.1.4.1.25506.2.122.2.1.1.22) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
BIMS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBimsPort (1.3.6.1.4.1.25506.2.122.2.1.1.23) |
read-create |
Unsigned32 |
Unsigned32(0..65534) |
BIMS server port number. |
As per the MIB. |
hh3cDhcpServer2PoolBimsKeyStr (1.3.6.1.4.1.25506.2.122.2.1.1.24) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Shared key for the DHCP clients to encrypt packets sent to the BIMS server. |
Does not support GET. |
hh3cDhcpServer2PoolNextServer (1.3.6.1.4.1.25506.2.122.2.1.1.25) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the next DHCP server. |
As per the MIB. |
hh3cDhcpServer2PoolTftpDomName (1.3.6.1.4.1.25506.2.122.2.1.1.26) |
read-create |
OCTET STRING |
OCTET STRING (0..63) |
TFTP server domain name. |
As per the MIB. |
hh3cDhcpServer2PoolTftpIP (1.3.6.1.4.1.25506.2.122.2.1.1.27) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
TFTP server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceAsIP (1.3.6.1.4.1.25506.2.122.2.1.1.28) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the backup network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailIP (1.3.6.1.4.1.25506.2.122.2.1.1.29) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Failover IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailStr (1.3.6.1.4.1.25506.2.122.2.1.1.30) |
read-create |
OCTET STRING |
OCTET STRING (0..39) |
Failover dialer string. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceNCPIP (1.3.6.1.4.1.25506.2.122.2.1.1.31) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the primary network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanId (1.3.6.1.4.1.25506.2.122.2.1.1.32) |
read-create |
Unsigned32 |
Unsigned32(2..4094|65535) |
Voice VLAN ID. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanEnbl (1.3.6.1.4.1.25506.2.122.2.1.1.33) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the voice VLAN. |
As per the MIB. |
hh3cDhcpServer2PoolRowStatus (1.3.6.1.4.1.25506.2.122.2.1.1.34) |
read-create |
RowStatus |
Active(1) createAndGo(4) destroy(6) |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolVerifyClass(1.3.6.1.4.1.25506.2.122.2.1.1.35) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the user class whitelist. |
As per the MIB. |
About this table
This table records the address pool bound to an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IfApplyPoolName (1.3.6.1.4.1.25506.2.122.2.2.1.1) |
read-write |
OCTET STRING |
Name of the address pool bound to an interface. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwTable
About this table
This table records the secondary network configuration in the DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex, h3cDhcpServer2PoolSecNw, and h3cDhcpServer2PoolSecNwMask.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolSecNw(1.3.6.1.4.1.25506.2.122.2.3.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwMask (1.3.6.1.4.1.25506.2.122.2.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Mask of the secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwGwIP (1.3.6.1.4.1.25506.2.122.2.3.1.3) |
read-create |
OCTET STRING |
Gateway IP address for the secondary network. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwStatus (1.3.6.1.4.1.25506.2.122.2.3.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolClassTable
About this table
This table records address ranges for DHCP user classes in a DHCP address pool on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolClassName (1.3.6.1.4.1.25506.2.122.2.4.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2PoolClassStart (1.3.6.1.4.1.25506.2.122.2.4.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassEnd (1.3.6.1.4.1.25506.2.122.2.4.1.3) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassStatus (1.3.6.1.4.1.25506.2.122.2.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records static bindings in a DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolStaticIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolStaticIP (1.3.6.1.4.1.25506.2.122.2.5.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in a static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticMask (1.3.6.1.4.1.25506.2.122.2.5.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address mask in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticCID (1.3.6.1.4.1.25506.2.122.2.5.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0|4..254) |
Client identifier in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHAddr (1.3.6.1.4.1.25506.2.122.2.5.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0|4..39) |
Hardware address in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHType (1.3.6.1.4.1.25506.2.122.2.5.1.5) |
read-create |
INTEGER |
default(1), ethernet(2), tokenRing(3) |
Hardware address type. |
As per the MIB. |
hh3cDhcpServer2PoolStaticStatus (1.3.6.1.4.1.25506.2.122.2.5.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records user-defined options in the DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolOptCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolOptCode (1.3.6.1.4.1.25506.2.122.2.6.1.1) |
not-accessible |
Integer32 |
Integer32(2..254), excluding 50..54, 56, 58, 59, 61, 82. |
Option code. |
As per the MIB. |
hh3cDhcpServer2PoolOptType (1.3.6.1.4.1.25506.2.122.2.6.1.2) |
read-create |
INTEGER |
ascii(1), hex(2), ip(3) |
Option type. |
As per the MIB. |
hh3cDhcpServer2PoolOptAscii (1.3.6.1.4.1.25506.2.122.2.6.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..255) |
ASCII string as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptHexStr (1.3.6.1.4.1.25506.2.122.2.6.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0..510) |
Hexadecimal number as the option content. |
The string length cannot exceed 256. |
hh3cDhcpServer2PoolOptIPStr (1.3.6.1.4.1.25506.2.122.2.6.1.5) |
read-create |
OCTET STRING |
IP address as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptRowStatus (1.3.6.1.4.1.25506.2.122.2.6.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records excluded IP addresses in a DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolForbidIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolForbidIP (1.3.6.1.4.1.25506.2.122.2.7.1.1) |
not-accessible |
InetAddressIPv4 |
IP address excluded from dynamic allocation. |
As per the MIB. |
hh3cDhcpServer2PoolForbidStatus (1.3.6.1.4.1.25506.2.122.2.7.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ClassTable
About this table
This table records DHCP user class information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2ClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ClassName (1.3.6.1.4.1.25506.2.122.2.8.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2ClassRowStatus (1.3.6.1.4.1.25506.2.122.2.8.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2RuleTable
About this table
This table records DHCP user class match rules.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RuleNumber (1.3.6.1.4.1.25506.2.122.2.9.1.1) |
not-accessible |
Integer32 |
Integer32(1..16) |
Rule ID. |
As per the MIB. |
hh3cDhcpServer2RuleOptCode (1.3.6.1.4.1.25506.2.122.2.9.1.2) |
read-create |
Integer32 |
Integer32(1..254) |
Option code. |
As per the MIB. |
hh3cDhcpServer2RuleOptHexStr (1.3.6.1.4.1.25506.2.122.2.9.1.3) |
read-create |
OCTET STRING |
Content to match specific options in packets. |
The length of the content cannot exceed 256. |
hh3cDhcpServer2RuleOptMask (1.3.6.1.4.1.25506.2.122.2.9.1.4) |
read-create |
OCTET STRING |
Hexadecimal mask for the match operation. |
If it is bound to hh3cDhcpServer2RuleOptHexStr, the entire command length cannot exceed 512. |
hh3cDhcpServer2RuleOptOffset (1.3.6.1.4.1.25506.2.122.2.9.1.5) |
read-create |
Integer32 |
Integer32(0..254) |
Offset in bytes after which the match operation starts |
As per the MIB. |
hh3cDhcpServer2RuleOptLength (1.3.6.1.4.1.25506.2.122.2.9.1.6) |
read-create |
Integer32 |
Integer32(0..128) |
Length of the option content to be matched. |
As per the MIB. |
hh3cDhcpServer2RuleRowStatus (1.3.6.1.4.1.25506.2.122.2.9.1.7) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ForbidTable
About this table
This table records excluded IP address ranges.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2ForbidVpnName, h3cDhcpServer2ForbidStart, and h3cDhcpServer2ForbidEnd.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ForbidVpnName (1.3.6.1.4.1.25506.2.122.2.10.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31) |
Name of the VPN to which the excluded IP address belongs. |
As per the MIB. |
hh3cDhcpServer2ForbidStart (1.3.6.1.4.1.25506.2.122.2.10.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidEnd (1.3.6.1.4.1.25506.2.122.2.10.1.3) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidRowStatus (1.3.6.1.4.1.25506.2.122.2.10.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2FreeTable
About this table
This table records free IP address ranges on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2FreeStart.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2FreeStart (1.3.6.1.4.1.25506.2.122.2.11.1.1) |
not-accessible |
InetAddressIPv4 |
Start IP address of a free IP address range. |
As per the MIB. |
hh3cDhcpServer2FreeEnd (1.3.6.1.4.1.25506.2.122.2.11.1.2) |
read-only |
InetAddressIPv4 |
End IP address of a free IP address range. |
As per the MIB. |
hh3cDhcpServer2ConflictTable
About this table
This table records conflicting IP addresses on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ConflictIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ConflictIP (1.3.6.1.4.1.25506.2.122.2.12.1.1) |
not-accessible |
InetAddressIPv4 |
Conflicting IP address. |
As per the MIB. |
hh3cDhcpServer2ConflictType (1.3.6.1.4.1.25506.2.122.2.12.1.2) |
read-only |
INTEGER |
detectByServer(1), detectByClient(2) |
Conflict type. |
As per the MIB. |
hh3cDhcpServer2ConflictTime (1.3.6.1.4.1.25506.2.122.2.12.1.3) |
read-only |
OCTET STRING |
OCTET STRING (1..19) |
Time when the conflict was detected. |
As per the MIB. |
hh3cDhcpServer2ConflictRowStatus (1.3.6.1.4.1.25506.2.122.2.12.1.4) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2ExpiredTable
About this table
This table records lease expiration information on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ExpiredIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ExpiredIP (1.3.6.1.4.1.25506.2.122.2.13.1.1) |
not-accessible |
InetAddressIPv4 |
Expired IP address. |
As per the MIB. |
hh3cDhcpServer2ExpiredClientId (1.3.6.1.4.1.25506.2.122.2.13.1.2) |
read-only |
OCTET STRING |
OCTET STRING (4..254) |
ID of the DHCP client of the expired IP address. |
As per the MIB. |
hh3cDhcpServer2ExpiredTime (1.3.6.1.4.1.25506.2.122.2.13.1.3) |
read-only |
OCTET STRING |
OCTET STRING (1..19), a time string in the format of MM/DD/YYYY hh:mm:ss. |
Time when the lease expired. |
As per the MIB. |
hh3cDhcpServer2ExpiredRowStatus (1.3.6.1.4.1.25506.2.122.2.13.1.4) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2IPInUseTable
About this table
This table records binding information about IP addresses in use on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2IPInUseIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPInUseIP (1.3.6.1.4.1.25506.2.122.2.14.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in use. |
As per the MIB. |
hh3cDhcpServer2IPInUseClientId (1.3.6.1.4.1.25506.2.122.2.14.1.2) |
read-only |
OCTET STRING |
Client ID of the IP address. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardAddr (1.3.6.1.4.1.25506.2.122.2.14.1.3) |
read-only |
OCTET STRING |
Hardware address of the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardType (1.3.6.1.4.1.25506.2.122.2.14.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cDhcpServer2IPInUseVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.5) |
read-only |
Unsigned32 |
Unsigned32(1..4094 | 65535) |
VLAN where the DHCP client resides. |
As per the MIB. |
hh3cDhcpServer2IPInUseEndLease (1.3.6.1.4.1.25506.2.122.2.14.1.6) |
read-only |
OCTET STRING |
Lease expiration time. |
As per the MIB. |
hh3cDhcpServer2IPInUseType (1.3.6.1.4.1.25506.2.122.2.14.1.7) |
read-only |
INTEGER |
staticUnallocated(1), staticOffered(2), staticCommitted(3), autoOffered(4), autoCommitted(5) |
Binding type. |
As per the MIB. |
hh3cDhcpServer2IPInUseIfIndex (1.3.6.1.4.1.25506.2.122.2.14.1.8) |
read-only |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Index of the interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseRowStatus (1.3.6.1.4.1.25506.2.122.2.14.1.9) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpTable
About this table
This table defines option information associated with the DHCP user class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2DefOptGrpClass.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DefOptGrpClass (1.3.6.1.4.1.25506.2.122.2.15.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpId (1.3.6.1.4.1.25506.2.122.2.15.1.2) |
read-create |
Integer32 |
Integer32(1..32768) |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpStatus(1.3.6.1.4.1.25506.2.122.2.15.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines user class whitelist.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ValidClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ValidClassName (1.3.6.1.4.1.25506.2.122.2.16.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2ValidClassStatus (1.3.6.1.4.1.25506.2.122.2.16.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines the user class hardware address match rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleHwAddrNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RuleHwAddrNumber (1.3.6.1.4.1.25506.2.122.2.17.1.1) |
not-accessible |
Integer32 |
Integer32 (1..16) |
Rule ID. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddress (1.3.6.1.4.1.25506.2.122.2.17.1.2) |
read-create |
OCTET STRING |
OCTET STRING (4..39) |
Hardware address. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrMask (1.3.6.1.4.1.25506.2.122.2.17.1.3) |
read-create |
OCTET STRING |
Hardware address mask. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrType (1.3.6.1.4.1.25506.2.122.2.17.1.4) |
read-create |
Integer32 |
1, representing the Ethernet |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrStatus (1.3.6.1.4.1.25506.2.122.2.17.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2OptionGroupTable
About this table
This table defines a DHCP option group for a DHCP user class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2OptionGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionGroupId (1.3.6.1.4.1.25506.2.122.2.18.1.1) |
not-accessible |
Integer32 |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2OptionGroupStatus (1.3.6.1.4.1.25506.2.122.2.18.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2OptionTable
About this table
This table defines user option information in a DHCP option group.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2OptionGroupId and h3cDhcpServer2OptionCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionCode (1.3.6.1.4.1.25506.2.122.2.19.1.1) |
not-accessible |
Integer32 |
Integer32(2..254),excluding 50..54, 56, 58, 59, 61, 82 |
Option code. |
As per the MIB. |
hh3cDhcpServer2OptionType (1.3.6.1.4.1.25506.2.122.2.19.1.2) |
read-create |
INTEGER |
Option type. |
As per the MIB. |
hh3cDhcpServer2OptionAscii (1.3.6.1.4.1.25506.2.122.2.19.1.3) |
read-create |
OCTET STRING |
OCTET STRING(0|2..256) |
The value read from this object is 0 if ascii(1) is specified as the option type but no ASCII string is specified. |
hh3cDhcpServer2OptionHexStr (1.3.6.1.4.1.25506.2.122.2.19.1.4) |
read-create |
OCTET STRING |
OCTET STRING(0..510) |
The value read from this object is 0 if hex(2) is specified as the option type but no hexadecimal string is specified. |
hh3cDhcpServer2OptionIPStr (1.3.6.1.4.1.25506.2.122.2.19.1.5) |
read-create |
OCTET STRING |
OCTET STRING(0..127) |
As per the MIB. |
hh3cDhcpServer2OptionRowStatus (1.3.6.1.4.1.25506.2.122.2.19.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpRelay2ConfigGroup
About this table
This table configures global DHCP relay agent settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoRecord (1.3.6.1.4.1.25506.2.122.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of recording client information in relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRefresh (1.3.6.1.4.1.25506.2.122.3.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of refreshing relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoFlushTime (1.3.6.1.4.1.25506.2.122.3.1.3) |
read-write |
Unsigned32 |
Unsigned32(0..120) |
Interval at which the DHCP relay agent refreshes relay entries. |
As per the MIB. |
hh3cDhcpRelay2ReleaseAddr (1.3.6.1.4.1.25506.2.122.3.1.4) |
read-write |
OCTET STRING |
OCTET STRING (0..47) |
IP address release request sent to the server. |
The set operation enables the relay agent to send a release request for the specified IP address to the DHCP server. When you perform a get operation on this object, a value of 0 is returned. |
hh3cDhcpRelay2StatisticsGroup
About this table
This table records the global statistics on a DHCP relay agent.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2RxClientNum (1.3.6.1.4.1.25506.2.122.3.2.1) |
read-only |
Counter64 |
Number of received packets that are sent by the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2TxClientNum (1.3.6.1.4.1.25506.2.122.3.2.2) |
read-only |
Counter64 |
Number of packets sent to the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2RxServerNum (1.3.6.1.4.1.25506.2.122.3.2.3) |
read-only |
Counter64 |
Number of received packets sent by DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2TxServerNum (1.3.6.1.4.1.25506.2.122.3.2.4) |
read-only |
Counter64 |
Number of packets sent to the DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2BadNum (1.3.6.1.4.1.25506.2.122.3.2.5) |
read-only |
Counter64 |
Number of error packets processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpRequestNum (1.3.6.1.4.1.25506.2.122.3.2.6) |
read-only |
Counter64 |
Number of BOOTP requests processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DiscoverNum (1.3.6.1.4.1.25506.2.122.3.2.7) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2RequestNum (1.3.6.1.4.1.25506.2.122.3.2.8) |
read-only |
Counter64 |
Number of DHCP-REQUEST messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DeclineNum (1.3.6.1.4.1.25506.2.122.3.2.9) |
read-only |
Counter64 |
Number of DHCP-DECLINE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2ReleaseNum (1.3.6.1.4.1.25506.2.122.3.2.10) |
read-only |
Counter64 |
Number of DHCP-RELEASE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2InformNum (1.3.6.1.4.1.25506.2.122.3.2.11) |
read-only |
Counter64 |
Number of DHCP-INFORM messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpReplyNum (1.3.6.1.4.1.25506.2.122.3.2.12) |
read-only |
Counter64 |
Number of BOOTP replies processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2OfferNum (1.3.6.1.4.1.25506.2.122.3.2.13) |
read-only |
Counter64 |
Number of DHCP-OFFER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2AckNum (1.3.6.1.4.1.25506.2.122.3.2.14) |
read-only |
Counter64 |
Number of DHCP-ACK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2NakNum (1.3.6.1.4.1.25506.2.122.3.2.15) |
read-only |
Counter64 |
Number of DHCP-NAK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfConfigTable
About this table
This table records the DHCP relay agent configuration on an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2IfSelectRelay (1.3.6.1.4.1.25506.2.122.4.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfCheckMac (1.3.6.1.4.1.25506.2.122.4.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of MAC address check. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Enable (1.3.6.1.4.1.25506.2.122.4.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of support for option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Strategy (1.3.6.1.4.1.25506.2.122.4.1.1.4) |
read-write |
INTEGER |
drop(1), keep(2), replace(3) |
Strategy for handling DHCP requests that contain Option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.5) |
read-write |
INTEGER |
normal(1), verbose(2), userDefine(3) |
Mode of the circuit ID sub-option in option 82. |
The return value is normal(1) if the system reads an unsupported mode. |
hh3cDhcpRelay2IfOpt82CIDNodeType (1.3.6.1.4.1.25506.2.122.4.1.1.6) |
read-write |
INTEGER |
invalid(1), mac(2), sysname(3), userDefine(4) |
Access node identifier for the circuit ID sub-option in verbose mode. |
If no access node identifier is specified, the value read from this object is invalid(1). |
hh3cDhcpRelay2IfOpt82CIDNodeStr (1.3.6.1.4.1.25506.2.122.4.1.1.7) |
read-write |
OCTET STRING |
OCTET STRING (0..50) |
User-defined string as the access node identifier for the circuit ID sub-option in verbose mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.8) |
read-write |
OCTET STRING |
OCTET STRING (0|3..63) |
User-defined string as the access node identifier for the circuit ID sub-option in userDefine mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.9) |
read-write |
INTEGER |
hex(1), ascii(2), undefine(3) |
Padding format of the circuit ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.10) |
read-write |
INTEGER |
normal(1), sysname(2), userDefine(3) |
Mode of the remote ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.11) |
read-write |
OCTET STRING |
User-defined string as the access node identifier for the remote ID sub-option in userDefine mode. |
If the mode of the remote ID sub-option is sysname(2), the value read from this object is 0. |
hh3cDhcpRelay2IfOpt82RIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.12) |
read-write |
INTEGER |
hex(1), ascii(2) |
Padding format of the remote ID sub-option in normal mode. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrTable
About this table
This table describes the IP address of a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and h3cDhcpRelay2SrvAddrIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2SrvAddrIP (1.3.6.1.4.1.25506.2.122.4.2.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
DHCP server IP address. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrRowStatus (1.3.6.1.4.1.25506.2.122.4.2.1.2) |
read-create |
RowStatus |
Active createAndGo destroy |
Row status. |
As per the MIB. |
hh3cDhcpRelay2UserInfoTable
About this table
Use this table to delete DHCP relay entries.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpRelay2UserInfoVpnIndex and h3cDhcpRelay2UserInfoIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoVpnIndex (1.3.6.1.4.1.25506.2.122.4.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0 . 65534), 0 represents the public network. |
VPN to which the IP address of the relay entry belongs. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIpAddr (1.3.6.1.4.1.25506.2.122.4.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (0.255) |
Client IP address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoMacAddr (1.3.6.1.4.1.25506.2.122.4.3.1.3) |
read-only |
MacAddress |
OCTET STRING (6) |
Client MAC address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIfIndex (1.3.6.1.4.1.25506.2.122.4.3.1.4) |
read-only |
Index of the Layer 3 interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRowStatus (1.3.6.1.4.1.25506.2.122.4.3.1.5) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
