06-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10006-Layer 3 - IP Services
03-HH3C-ARP-TRAP-MIB
03-HH3C-ARP-TRAP-MIB 169.24 KB
HH3C-ARP-TRAP-MIB
About this MIB
Use this MIB to output notifications for the ARP module.
MIB file name
hh3c-arp-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPTrap(217)
Notifications
hh3cARPTrapThresholdAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.217.1.0.1
Number of global ARP entries exceeded the alarm threshold.
Informational
Major
1.3.6.1.4.1.25506.2.217.1.0.2 (hh3cARPTrapThresholdResume)
OFF
This notification is generated when the number of ARP entries on the device exceeds the alarm threshold, which means that the number of ARP entries on the device has approached the specification limit. Please check the ARP entries.
Status control
ON
CLI: Use the snmp-agent trap enable arp entry-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp entry-limit command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.1.1.4 (hh3cARPTrapEntryThreshold)
Alarm threshold for the number of global ARP entries.
No
INTEGER
Integer32 (1..2147483647)
1.3.6.1.4.1.25506.2.217.1.1.5 (hh3cARPTrapDynamicEntryNum)
Number of dynamic ARP entries.
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.2.6
(hhhh3cARPTrapStaticEntryNum)
Number of static ARP entries.
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.1.7
(hh3cARPTrapOtherEntryNum)
Number of other ARP entries.
No
INTEGER
Recommended action
Delete the useless dynamic ARP entries on the device. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID
Event
Severity
Default status
The number of ARP entries dropped below the alarm threshold.
Informational
Major
N/A
OFF
This notification is generated when the number of ARP entries on the device drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
INTEGER
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.1.6
(hh3cARPTrapStaticEntryNum)
No
INTEGER
No
INTEGER
Recommended action
No action is required.
hh3cARPTrapSlotThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.3
The number of ARP entries on the card exceeded the alarm threshold.
Informational
Major
1.3.6.1.4.1.25506.2.217.1.0.4(hh3cARPTrapSlotThresholdResume)
OFF
This notification is generated when the number of the ARP entries on a card exceeds the threshold, which means that the number of ARP entries on the card has approached the specification limit. Please check the ARP entries.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.1.1.1 (hh3cARPTrapEntryChassis)
Chassis number.
No
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.1.2
(hh3cARPTrapEntrySlot)
Slot number.
No
No
INTEGER
Alarm threshold for the number of ARP entries on the card.
No
INTEGER
No
INTEGER
Recommended action
Delete the useless dynamic ARP entries on the card. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID
Event
Severity
Default status
The number of ARP entries on the card dropped below the alarm threshold.
Informational
Major
N/A
OFF
This notification is generated when the number of ARP entries on the card drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Chassis number.
No
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.1.2 (hh3cARPTrapEntrySlot)
Slot number.
No
No
INTEGER
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapIfThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.5
The number of ARP entries on the interface exceeded the alarm threshold.
Informational
Major
1.3.6.1.4.1.25506.2.217.1.0.6(hh3cARPTrapIfThresholdResume)
OFF
This notification is generated when the number of ARP entries on an interface exceeds the alarm threshold, which means that the number of ARP entries on the interface has approached the specification limit. Please check the ARP entries.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.1.1.3
(hh3cARPTrapEntryIfName)
Interface name.
No
DisplayString
OCTET STRING  (0..255)
Alarm threshold for the number of ARP entries on the interface.
No
INTEGER
No
INTEGER
Recommended action
Delete the useless dynamic ARP entries on the interface. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID
Event
Severity
Default status
The number of ARP entries on the interface dropped below the alarm threshold.
Informational
Major
N/A
OFF
This notification is generated when the number of ARP entries on an interface drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface name
No
DisplayString
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapSuppThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.7
The number of ARP suppression entries on the device exceeded the alarm threshold.
Informational
Major
1.3.6.1.4.1.25506.2.217.1.0.8(hh3cARPTrapSuppThresholdResume)
OFF
This notification is generated when the number of ARP suppression entries on the device exceeds the alarm threshold, which means that the number of ARP suppression entries has approached the specification limit. Please check the ARP suppression entries.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Alarm threshold for the number of ARP suppression entries on the device.
No
INTEGER
1.3.6.1.4.1.25506.2.217.1.1.8 (hh3cARPTrapSuppEntryNum)
Number of ARP suppression entries on the device.
No
INTEGER
Recommended action
Delete the useless ARP suppression entries on the device. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID
Event
Severity
Default status
The number of ARP suppression entries on the device dropped below the alarm threshold.
Informational
Major
N/A
OFF
This notification is generated when the number of ARP suppression entries on the device drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapMACConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.1
Local MAC address conflicted.
Informational
Major
1.3.6.1.4.1.25506.2.217.2.1.0.2(hh3cARPTrapMACConflictResume)
OFF
This notification is generated when the sender MAC address in the received ARP packet is the same as the MAC address of the local device.
Status control
ON
CLI: Use the snmp-agent trap enable arp local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp local-conflict command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.1.1.1 (hh3cARPTrapLocalConflictIf)
Interface that received the ARP packet with a duplicate MAC address.
No
OCTET STRING
OCTET STRING  (1..47)
1.3.6.1.4.1.25506.2.217.2.1.1.2
(hh3cARPTrapLocalConflictMac)
Sender MAC address in the ARP packet.
No
OCTET STRING
OCTET STRING  (1..15)
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcIp)
Sender IP address in the ARP packet.
No
IpAddress
Standard MIB values.
1.3.6.1.4.1.25506.2.217.2.1.1.8
(hh3cARPTrapLocalPeVlan)
Outer VLAN of the ARP packet.
No
INTEGER
1.3.6.1.4.1.25506.2.217.2.1.1.9
(hh3cARPTrapLocalCeVlan)
Inner VLAN of the ARP packet.
No
INTEGER
1.3.6.1.4.1.25506.2.217.2.1.1.10
(hh3cARPTrapLocalInboundIf)
Physical interface corresponding to the VLAN interface that received the ARP packet.
No
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
The local MAC address conflict was removed.
Informational
Major
N/A
OFF
This notification is generated when the local MAC address conflict is removed.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
OCTET STRING
No
OCTET STRING
No
IpAddress
No
INTEGER
No
INTEGER
No
OCTET STRING
Recommended action
Check whether an ARP packet attack or a loop exists on the network.
hh3cARPTrapMACIPConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.3
Local MAC and IP address conflicted.
Informational
Major
1.3.6.1.4.1.25506.2.217.2.1.0.4(hh3cARPTrapMACIPConflictResume)
OFF
This notification is generated when the sender MAC and IP addresses in the ARP packet are the same as the MAC and IP addresses of the local device.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface that received the ARP packet with duplicate MAC and IP addresses.
No
OCTET STRING
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.3 (hh3cARPLocalTrapConflictIP)
No
IpAddress
1.3.6.1.4.1.25506.2.217.2.1.1.6
(hh3cARPTrapLocalDstMac)
Target MAC address in the ARP packet.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.7 (hh3cARPTrapLocalDstIP)
Target IP address in the ARP packet.
No
IpAddress
No
INTEGER
No
INTEGER
No
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
The local MAC and IP address conflict was removed.
Informational
Major
N/A
OFF
This notification is generated when the local MAC and IP address conflict is removed.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
OCTET STRING
No
OCTET STRING
No
IpAddress
No
OCTET STRING
No
IpAddress
No
INTEGER
No
INTEGER
No
OCTET STRING
hh3cARPTrapIPConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.5
Local IP address conflicted.
Informational
Major
1.3.6.1.4.1.25506.2.217.2.1.0.6(hh3cARPTrapMACIPConflictResume)
OFF
This notification is generated when the sender IP address in the ARP packet is the same as the IP address of the local device.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface that received the ARP packet with a duplicate IP address.
No
OCTET STRING
(hh3cARPTrapLocalConflictIP)
No
IpAddress
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcMac)
No
OCTET STRING
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapIPConflictResume
Basic information
OID
Event
Severity
Default status
The local IP address conflict was removed.
Informational
Major
N/A
OFF
This notification is generated when the local IP address conflict is removed.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
OCTET STRING
No
IpAddress
No
OCTET STRING
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapHostMoveAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.2.0.1
The access ports changed frequently.
Error
Warning
N/A
OFF
This notification is generated when the user port migrates frequently.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-move command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-move command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.2.1.1 (hh3cARPTrapMoveUserIP)
Sender IP address in the ARP packet with a different ingress port.
No
IpAddress
1.3.6.1.4.1.25506.2.217.2.2.1.2 (hh3cARPTrapMoveUserMAC)
Sender MAC address in the ARP packet with a different ingress port.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.3 (hh3cARPTrapMoveLocalIf)
Port name before migration.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.4
(hh3cARPTrapMoveLocalPeVlan)
Outer VLAN of the ARP packet before port migration.
No
INTEGER
Interger32(1..2147483647)
1.3.6.1.4.1.25506.2.217.2.2.1.5
(hh3cARPTrapMoveLocalCeVlan)
Inner VLAN of the ARP packet before port migration.
No
INTEGER
1.3.6.1.4.1.25506.2.217.2.2.1.6
(hh3cARPTrapMoveRemoteIF)
Port name after migration.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.7
(hh3cARPTrapMoveRemotePeVlan)
Outer VLAN of the ARP packet after port migration.
No
INTEGER
1.3.6.1.4.1.25506.2.217.2.2.1.8 (hh3cARPTrapMoveRemoteCeVlan)
Inner VLAN of the ARP packet after port migration.
No
INTEGER
Recommended action
hh3cARPTrapHostMoveResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.2.0.2
The host recovered from a frequent access port change alarm.
Informational
N/A
N/A
OFF
This notification is generated when the host recovers from a frequent access port change alarm.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
IpAddress
No
OCTET STRING
No
OCTET STRING
No
INTEGER
No
INTEGER
No
OCTET STRING
No
INTEGER
No
INTEGER
Recommended action
hh3cARPTrapUserIpConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.3.0.1
User IP address conflicted.
Error
Warning
N/A
OFF
This notification is generated when a user IP address conflict occurs. A conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-ip-conflict command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.3.1.1 (hh3cARPTrapUIPCPRcvMac)
Sender MAC address in the incoming ARP entry.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.2 (hh3cARPTrapUIPCPRcvPVid)
Outer VLAN of the local interface on which the conflict occurred.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.3
 (hh3cARPTrapUIPCPRcvCVid)
Inner VLAN of the local interface on which the conflict occurred.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.4 (hh3cARPTrapUIPCPRcvIf)
Local interface on which the conflict occurred.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.5
(hh3cARPTrapUIPCPLocalMac)
Sender MAC address in the local existing ARP entry.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.6
 (hh3cARPTrapUIPCPLocalPVid)
Outer VLAN of the incoming ARP packet.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.7 (hh3cARPTrapUIPCPLocalCVid)
Inner VLAN of the incoming ARP packet.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.8 (hh3cARPTrapUIPCPLocalIf)
Interface name that received the ARP packet.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.9 (hh3cARPTrapUIPCPIpAddr)
IP address in the local existing ARP entry.
No
IpAddress
Recommended action
hh3cARPTrapAckStrictCheckAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.4.0.1
The ARP packet received on the device was not the ARP reply to the ARP request sent by the device.
Error
Warning
N/A
OFF
This notification is generated when the device does not send an ARP request to the source IP address in the received ARP reply within the probe interval after ARP active acknowledgement in strict mode is configured.
Status control
ON
CLI: Use the snmp-agent trap enable arp active-ack command.
OFF
CLI: Use the undo snmp-agent trap enable arp active-ack command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.4.1.1 (217)
Interface that received the ARP packet.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.4.1.2
(hh3cARPTrapAckSourceIP)
Sender IP address in the received ARP packet.
No
IpAddress
Recommended action
Check whether an ARP packet attack exists on the network.
hh3cARPTrapSpeedLimitAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.5.0.1
The ARP packets or ARP Miss packets sending rate exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.5.1.2(hh3cARPTrapSpeedLimitResume)
OFF
This notification is generated when the ARP packets or ARP Miss packets sending rate exceeds the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.5.1.1 (hh3cARPTrapSpeedLimitChassis)
Chassis number
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.2 (hh3cARPTrapSpeedLimitSlot)
Slot number.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.3 (hh3cARPTrapSpeedLimitSupValue)
Alarm threshold of packet sending rate (pps).
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.4
(hh3cARPTrapSpeedLimitCurValue)
Current packet sending rate (pps).
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.5 (hh3cARPTrapSpeedLimitSupType)
Packet type.
No
INTEGER
packet(1)
miss(2)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.5.0.2
The ARP packets or ARP Miss packets recovered from a sending rate alarm.
Informational
Event
N/A
OFF
This notification is generated when the ARP packets or ARP Miss packets recover from a sending rate alarm.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Chassis number
No
Unsigned32
Slot number.
No
Unsigned32
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.4 (hh3cARPTrapSpeedLimitCurValue)
No
Unsigned32
Packet type.
No
INTEGER
packet(1)
miss(2)
Recommended action
hh3cARPTrapPacketValidCheckAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.6.0.1
The device received an invalid ARP packet.
Error
Warning
N/A
OFF
This notification is generated when the device receives an invalid ARP packet.
Status control
ON
CLI: Use the snmp-agent trap enable arp packet-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp packet-check command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.6.1.1 (hh3cARPTrapPktValidCheckIf)
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.6.1.2 (hh3cARPTrapPktValidCheckMac)
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.6.1.3
(hh3cARPTrapPktValidCheckIp)
No
IpAddress
1.3.6.1.4.1.25506.2.217.2.6.1.4 (hh3cARPTrapPktValidCheckVlan)
VLAN ID of the ARP packet.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.6.1.5 (hh3cARPTrapPktValidtCheckSvlan)
Service VLAN ID of the ARP packet.
No
Unsigned32
Recommended action
hh3cARPTrapGatewayCheckAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.7.0.1
The device intercepted an ARP packet with a forged gateway MAC address.
Error
Warning
N/A
OFF
This notification is generated when the device intercepts an ARP packet with a forged gateway MAC address.
Status control
ON
CLI: Use the snmp-agent trap enable arp gateway-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp gateway-check command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.7.1.1 (hh3cARPTrapGateWayCheckIf)
Interface that received the ARP attack packet.
No
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.7.1.2 (hh3cARPTrapGateWayCheckSlot)
Slot number.
No
Unsigned32
1.3.6.1.4.1.25506.2.217.2.7.1.3
(hh3cARPTrapGateWayCheckIp)
Sender IP address in the ARP attack packet.
No
IpAddress
Recommended action
hh3cARPTrapGatewayCheckResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.7.0.2
The device recovered from a gateway spoofing attack.
Informational
N/A
N/A
OFF
This notification is generated when the device recovers from a gateway spoofing attack.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
OCTET STRING
Slot number.
No
Unsigned32
No
IpAddress
Recommended action
