06-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10006-Layer 3 - IP Services
07-HH3C-FIB-MIB
07-HH3C-FIB-MIB 50.21 KB
HH3C-FIB-MIB
About this MIB
Use this MIB to detect whether the number of FIB entries reaches the threshold and whether the messages to be forwarded on the module are congested.
MIB file name
hh3c-fib.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFibTrap(216)
Notifications
hh3cFibBoardMsgCongestResume
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.216.1.0.2
The module recovered from a message congestion alarm.
Informational
Event
N/A
On
This notification is generated when the module recovers from a message congestion alarm.
Status control
ON
CLI: Use the snmp-agent trap enable fib command.
OFF
CLI: Use the undo snmp-agent trap enable fib command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.216.1.1.1 (hh3cFibChassisID)
Chassis number.
No
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.216.1.1.2 (hh3cFibSlotID)
Slot number.
No
Unsigned32
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cFibOverloadForward
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.216.2.0.1
The number of FIB entries on the device exceeded the threshold.
Error
Warning
1.3.6.1.4.1.25506.2.216.2.0.2
(hh3cFibOverloadForwardResume)
On
This notification is generated when the number of FIB entries on the device exceeds the threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.216.2.1.1 (hh3cFibOverloadModule)
Module name (FIB4/FIB6)
No
OCTET STRING
OCTET STRING (0..255)
Recommended action
Check whether the network is attacked.
Basic information
OID
Event
Severity
Default status
The device recovered from a FIB entry capacity usage alarm.
Informational
Event
N/A
On
This notification is generated when the device recovers from a FIB entry capacity usage alarm.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Module name (FIB4/FIB6).
No
OCTET STRING
Recommended action
