03-Layer 2—LAN Switching Command Reference
HomeSupportResource CenterTechnical DocumentsReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Command References-R6628Pxx-6W10003-Layer 2—LAN Switching Command Reference
07-Port isolation commands
07-Port isolation commands 47.19 KB
community-vlan vlan
Use community-vlan vlan to configure community VLANs in an isolation group.
Use undo community-vlan to restore the default.
community-vlan vlan { vlan-id-list | all }
undo community-vlan
An isolation group does not have any community VLANs.
Isolation group view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
all: Specifies all VLANs in the isolation group.
To modify the community VLANs for an isolation group, execute the undo community-vlan vlan command to remove the existing community VLANs, and then execute the community-vlan vlan command.
# Configure VLAN 3 as a community VLAN in isolation group 1.
[Sysname] port-isolate group 1
[Sysname-port-isolate-group1] community-vlan vlan 3
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ group-id ]
group-id: Specifies an isolation group by its ID.  The value range is 1 to 8.
# Display all isolation groups.
<Sysname> display port-isolate group
 Port isolation group information:
 Group ID: 1
 Group members:
    Ten-GigabitEthernet1/0/1
 Community VLAN ID: None
 Group ID: 5
 Group members:
    Ten-GigabitEthernet1/0/2            Ten-GigabitEthernet1/0/4
# Display information about isolation group 1.
<Sysname> display port-isolate group 1
 Group ID: 1
 Group members:
Group ID
ID of the isolation group.
Group members
Isolated ports in the isolation group. No ports indicates that the isolation group does not contain isolated ports.
Community VLAN ID
IDs of the community VLANs in the isolation group. The (default) attribute indicates that the VLAN is the default VLAN. None indicates that the isolation group does not contain community VLANs.
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable group group-id
The port is not assigned to an isolation group.
group group-id: Specifies an isolation group by its ID.   The value range is 1 to 8.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
To assign ports to an isolation group, make sure the isolation group already exists.
One port can be assigned to only one isolation group.
# Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to isolation group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port-isolate enable group 1
[Sysname-Ten-GigabitEthernet1/0/2] port-isolate enable group 1
port-isolate group
Use port-isolate group to create an isolation group.
Use undo port-isolate group to delete isolation groups.
port-isolate group group-id
undo port-isolate group { group-id | all }
No isolation groups exist.
all: Deletes all isolation groups.
# Create isolation group 1.
  • Become a Partner
  • Partner Resources
