| 01-Text | 291.39 KB |
Overview
CAUTION: The available H3C power adapter models and power cords vary by country or regions. For H3C power adapter models available for your country or region, contact the local H3C sales agent or engineers. Use of a power adapter model not compliant with local standards might result in damages. |
This document introduces H3C power adapters and provides their specifications.
H3C power adapters
ADP040-54V-GL
The part number of the ADP040-54V-GL power adapter is 0231A9BS.
Introduction
H3C ADP040-54V-GL is a highly efficient indoor desktop power adapter that supports wide input voltage range (90 VAC to 264 VAC). It provides output short-circuit and output overvoltage protection. You can use it to power an H3C indoor AP.
Figure 1 ADP040-54V-GL power adapter view
(1) AC power input receptacle |
(2) DC power cord |
(3) DC power output plug |
Figure 2 ADP040-54V-GL power adapter physical dimensions
Specifications
Table 1 describes the ADP040-54V-GL power adapter specifications.
Table 1 ADP040-54V-GL power adapter specifications
Item |
Specification |
Dimensions (H × W × D), excluding the DC power cord and DC power output plug |
110 × 62 × 31.5 mm (4.33 × 2.44 × 1.24 in) |
Rated input voltage |
100 VAC to 240 VAC @ 50/60 Hz |
Max input current |
1.5 A (115 VAC, fully loaded) 0.8 A (230 VAC, fully loaded) |
Rated output voltage |
54 VDC |
Max output current |
0.74 A |
Output power |
≤ 40 W |
Temperature |
Operating temperature: –10°C to +45°C (14°F to 113°F) Storage temperature: –40°C to +70°C (-40°F to 158°F) |
Humidity |
Operating humidity: 5% RH to 95% RH, noncondensing Storage humidity: 5% RH to 95% RH, noncondensing |
Certifications |
CE/TUV-GS/UL/EAC/PSE/CCC |
AC power cord |
Removable, C14 connector AC power cords supply according to countries or regions |
ADP040-54B
The part number of the ADP040-54B power adapter is 0231AKQ8.
Introduction
H3C ADP040-54B is a highly efficient indoor desktop power adapter that supports wide input voltage range (90 VAC to 264 VAC). It provides output short-circuit and output overvoltage protection. You can use it to power an H3C indoor AP.
Figure 3 ADP040-54B power adapter view
(2) DC power cord |
Figure 4 ADP040-54B power adapter physical dimensions (mm)
Specifications
Table 2 describes the ADP040-54B power adapter specifications.
Table 2 ADP040-54B power adapter specifications
Item |
Specification |
Max input current |
54 VDC |
0.74 A |
Output power |
≤ 40 W |
Temperature |
Humidity |
Certifications |
AC power cord |
RDW06305401170-C55-51
The part number of the RDW06305401170-C55-51 power adapter is 9802A02Y.
Introduction
H3C RDW06305401170-C55-51 is a highly efficient indoor desktop power adapter that supports wide input voltage range (90 VAC to 264 VAC). You can use it to connect power to an H3C indoor AP.
Figure 5 RDW06305401170-C55-51 power adapter view
(2) DC power cord |
Figure 6 RDW06305401170-C55-51-GL power adapter physical dimensions (mm)
Specifications
Table 3 describes the RDW06305401170-C55-51 power adapter specifications.
Table 3 RDW06305401170-C55-51 power adapter specifications
Item |
Specification |
129 × 53 × 30.1 mm (5.08 × 2.09 × 1.19 in) |
Max input current |
1.5 A (90 VAC, fully loaded) |
54 VDC |
1.17 A |
Output power |
63.18 W |
Temperature |
Operating temperature: –5°C to +45°C (23°F to 113°F) Storage temperature: –40°C to +70°C (-40°F to 158°F) |
Humidity |
Certifications |
CCC, PSE, UL, FCC |
AC power cord |
Removable, C8 connector AC power cords supply according to countries or regions |
