| 08-StationSW-MIB | 58.02 KB |
StationSW-MIB
About this MIB
This MIB is a private MIB defined by the State Grid No. 1084 specification.
Use this MIB to enable the device to proactively send a notification to the network management station when a specific event occurs, such as MAC address change, command execution, and user login through Telnet or SSH, user logout, and password modification.
MIB file name
station-sw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).nari(49763).stationSW(1)
Scalar objects
ucMacChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ucMacChange (1.3.6.1.4.1.49763.1.1.1) |
accessible-for-notify |
DisplayString |
OCTET STRING (0..512) |
MAC address change information. |
As per the MIB. |
Tabular objects
userTable
About this table
This table defines the variable bindings of the userTrap notification object.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is userIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
userIndex (1.3.6.1.4.1.49763.1.1.2.1.1) |
Integer32 |
Interger32 (1..2147483647) |
Index of a user. |
As per the MIB. |
userName (1.3.6.1.4.1.49763.1.1.2.1.2) |
DisplayString |
OCTET STRING (0..64) |
Name of the user. |
As per the MIB. |
userType (1.3.6.1.4.1.49763.1.1.2.1.3) |
UserTypeEnum |
http(1), https(2), snmp(3), telnet(4), ssh(5), cli(6), iec61850(7), console(8) |
Access method of the user. |
Supports only values telnet(4), ssh(5), and console(8). |
userStatus (1.3.6.1.4.1.49763.1.1.2.1.4) |
UserStatusEnum |
logIn(1), logOut(2), changePassword(3), loginFail(4) |
Status of the user. |
As per the MIB. |
userModified (1.3.6.1.4.1.49763.1.1.2.1.5) |
DisplayString |
Content modified by the user. |
As per the MIB. |
userIP (1.3.6.1.4.1.49763.1.1.2.1.6) |
DisplayString |
IP address of the user. |
As per the MIB. |
userOperTable
About this table
This table defines the variable bindings of the userOperTrap notification object.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is userOperIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
userOperIndex (1.3.6.1.4.1.49763.1.1.3.1.1) |
Integer32 |
Index of a user operation. |
As per the MIB. |
userOperName (1.3.6.1.4.1.49763.1.1.3.1.2) |
DisplayString |
Name of the user operation. |
As per the MIB. |
userOperIP (1.3.6.1.4.1.49763.1.1.3.1.3) |
DisplayString |
As per the MIB. |
userOperCommand (1.3.6.1.4.1.49763.1.1.3.1.4) |
DisplayString |
OCTET STRING (0..256) |
Command executed by the user. |
As per the MIB. |
Notifications
The following information describes the notifications included in the StationSW-MIB module.
ucMacChangeTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.49763.1.2.1 |
MAC address change. |
Informational |
N/A |
N/A |
ON |
This notification is generated when a MAC address is changed.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.49763.1.1.1 (ucMacChange) |
N/A |
DisplayString |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
userTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.49763.1.2.2 |
User status change |
Informational |
N/A |
N/A |
ON |
This notification is generated when a user logs in, logs out, or changes the password.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.49763.1.1.2.1.1 (userIndex) |
Index of a user. |
Yes |
Integer32 |
1.3.6.1.4.1.49763.1.1.2.1.2 (userName) |
Name of the user. |
No |
DisplayString |
1.3.6.1.4.1.49763.1.1.2.1.3 (userType) |
No |
UserTypeEnum |
1.3.6.1.4.1.49763.1.1.2.1.4 (userStatus) |
No |
UserStatusEnum |
1.3.6.1.4.1.49763.1.1.2.1.5 (userModified) |
No |
DisplayString |
1.3.6.1.4.1.49763.1.1.2.1.6 (userIP) |
No |
DisplayString |
Recommended action
userOperTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.49763.1.2.3 |
Command execution by a user |
Informational |
N/A |
N/A |
ON |
This notification is generated when a user executes a command at the CLI.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.49763.1.1.3.1.1 (userOperIndex) |
Yes |
Integer32 |
1.3.6.1.4.1.49763.1.1.3.1.2 (userOperName) |
No |
DisplayString |
1.3.6.1.4.1.49763.1.1.3.1.3 (userOperIP) |
No |
DisplayString |
1.3.6.1.4.1.49763.1.1.3.1.4 (userOperCommand) |
No |
DisplayString |
Recommended action
