02-HH3C-IPSEC-MONITOR-V2-MIB | 240.63 KB |
hh3cIPsecGlobalActiveTunnelsV2
hh3cIPsecGlobalInDecompOctetsV2
hh3cIPsecGlobalInReplayDropsV2
hh3cIPsecGlobalInDecryptFailsV2
hh3cIPsecGlobalOutUncompOctetsV2
hh3cIPsecGlobalOutEncryptFailsV2
hh3cIPsecGlobalNoMemoryDropsV2
hh3cIPsecGlobalNoFindSaDropsV2
hh3cIPsecGlobalQueueFullDropsV2
hh3cIPsecGlobalInvalidLenDropsV2
hh3cIPsecGlobalInvalidSaDropsV2
hh3cIPsecTunnelStartTrapCntlV2
hh3cIPsecAuthFailureTrapCntlV2
hh3cIPsecEncryFailureTrapCntlV2
hh3cIPsecDecryFailureTrapCntlV2
hh3cIPsecPolicyAttachTrapCntlV2
hh3cIPsecPolicyDetachTrapCntlV2
About this MIB
Use this MIB to obtain information about IPsec tunnels, IPsec-protected traffic, IPsec SAs, IPsec tunnel packet statistics, and IPsec trap notifications.
MIB file name
hh3c-ipsec-monitor-v2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIPsecMonitorV2(126)
Scalar objects
hh3cIPsecMIBVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecMIBVersion (1.3.6.1.4.1.25506.2.126.1.1.1) |
read-only |
DisplayString |
OCTET STRING (1..255) |
IPsec MIB version information. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalActiveTunnelsV2 (1.3.6.1.4.1.25506.2.126.1.6.1) |
read-only |
Gauge32 |
Gauge32 (0..4294967295) |
Total number of currently active IPsec Phase-2 tunnels. |
As per the MIB. |
hh3cIPsecGlobalActiveSasV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalActiveSasV2 (1.3.6.1.4.1.25506.2.126.1.6.2) |
read-only |
Gauge32 |
Total number of existing IPsec Phase-2 SAs. |
As per the MIB. |
hh3cIPsecGlobalInOctetsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInOctetsV2 (1.3.6.1.4.1.25506.2.126.1.6.3) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Total number of octets received by all current and previous IPsec Phase-2 tunnels. This value is accumulated before determining whether or not the packet should be decompressed. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInDecompOctetsV2 (1.3.6.1.4.1.25506.2.126.1.6.4) |
read-only |
Counter64 |
The total number of decompressed octets received by all current and previous IPsec Phase-2 Tunnels. This value is accumulated after a packet is decompressed. |
Not supported |
hh3cIPsecGlobalInPktsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInPktsV2 (1.3.6.1.4.1.25506.2.126.1.6.5) |
read-only |
Counter64 |
Total number of packets received by all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
hh3cIPsecGlobalInDropsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.6) |
read-only |
Counter64 |
Total number of inbound packets dropped by all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInReplayDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.7) |
read-only |
Counter64 |
Total number of inbound packets dropped due to anti-replay by all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
hh3cIPsecGlobalInAuthFailsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInAuthFailsV2 (1.3.6.1.4.1.25506.2.126.1.6.8) |
read-only |
Counter64 |
Total number of inbound packets that failed authentication on all current previous IPsec Phase-2 tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInDecryptFailsV2 (1.3.6.1.4.1.25506.2.126.1.6.9) |
read-only |
Counter64 |
Total number of inbound packets that failed decryption on all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
hh3cIPsecGlobalOutOctetsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalOutOctetsV2 (1.3.6.1.4.1.25506.2.126.1.6.10) |
read-only |
Counter64 |
Total number of octets sent by all current and previous IPsec Phase-2 tunnels. This value is accumulated before determining whether or not the packet should be compressed. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalOutUncompOctetsV2 (1.3.6.1.4.1.25506.2.126.1.6.11) |
read-only |
Counter64 |
The total number of uncompressed octets sent by all current and previous IPsec Phase-2 Tunnels. This value is accumulated before a packet is compressed. |
Not supported |
hh3cIPsecGlobalOutPktsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalOutPktsV2 (1.3.6.1.4.1.25506.2.126.1.6.12) |
read-only |
Counter64 |
Total number of packets sent by all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
hh3cIPsecGlobalOutDropsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalOutDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.13) |
read-only |
Counter64 |
Total number of outbound packets dropped by all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalOutEncryptFailsV2 (1.3.6.1.4.1.25506.2.126.1.6.14) |
read-only |
Counter64 |
Total number of outbound packets that failed encryption on all current and previous IPsec Phase-2 tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalNoMemoryDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.15) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to insufficient memory. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalNoFindSaDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.16) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to SA not found. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalQueueFullDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.17) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to full queue. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInvalidLenDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.18) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to invalid packet length. |
As per the MIB. |
hh3cIPsecGlobalTooLongDropsV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalTooLongDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.19) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to too long packet. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecGlobalInvalidSaDropsV2 (1.3.6.1.4.1.25506.2.126.1.6.20) |
read-only |
Counter64 |
Total number of packets dropped by all current and previous IPsec Phase-2 tunnels due to invalid SA. |
Not supported |
hh3cIPsecPolicyNameV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicyNameV2 (1.3.6.1.4.1.25506.2.126.1.7.1) |
accessible-for-notify |
STRING |
OCTET STRING (1..63) |
Name of an IPsec policy in a trap notification. |
As per the MIB. |
hh3cIPsecPolicySeqNumV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicySeqNumV2 (1.3.6.1.4.1.25506.2.126.1.7.2) |
Integer32 |
Sequence number of an IPsec policy entry in a trap notification. |
As per the MIB. |
hh3cIPsecPolicySizeV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicySizeV2 (1.3.6.1.4.1.25506.2.126.1.7.3) |
Integer32 |
Number of IPsec policy entries in a trap notification. |
As per the MIB. |
hh3cIPsecTrapGlobalCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTrapGlobalCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.1) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable trap notifications for IPsec events globally. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTunnelStartTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.2) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecTunnelStartV2 trap notifications. |
As per the MIB. |
hh3cIPsecTunnelStopTrapCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTunnelStopTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.3) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecTunnelStopV2 trap notifications. |
As per the MIB. |
hh3cIPsecNoSaTrapCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecNoSaTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.4) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecNoSaFailureV2 trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecAuthFailureTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.5) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecAuthFailureV2 trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecEncryFailureTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.6) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecEncryFailureV2 trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecDecryFailureTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.7) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecDecryFailureV2 trap notifications. |
As per the MIB. |
hh3cIPsecInvalidSaTrapCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecInvalidSaTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.8) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecInvalidSaFailureV2 trap notifications. |
As per the MIB. |
hh3cIPsecPolicyAddTrapCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicyAddTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.9) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecPolicyAddV2 trap notifications. |
As per the MIB. |
hh3cIPsecPolicyDelTrapCntlV2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicyDelTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.10) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecPolicyDelV2 trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicyAttachTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.11) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecPolicyAttachV2 trap notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecPolicyDetachTrapCntlV2 (1.3.6.1.4.1.25506.2.126.1.8.12) |
read-write |
TruthValue |
Integer32 (0,1) |
Whether to enable hh3cIPsecPolicyDetachV2 trap notifications. |
As per the MIB. |
Tabular objects
hh3cIPsecTunnelV2Table
About this table
This table contains IPsec tunnel information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIPsecTunIndexV2.
Object(OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTunIndexV2 (1.3.6.1.4.1.25506.2.126.1.2.1.1) |
Integer32 |
Integer32 (1..2147483647) |
Index of an IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunIfIndexV2 (1.3.6.1.4.1.25506.2.126.1.2.1.2) |
read-only |
InterfaceIndex |
Index of the interface. |
As per the MIB. |
hh3cIPsecTunIKETunnelIndexV2 (1.3.6.1.4.1.25506.2.126.1.2.1.3) |
read-only |
Integer32 |
Index of the IKE tunnel associated with the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunIKETunLocalIDTypeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.4) |
read-only |
Hh3cIPsecIDTypeV2 |
Integer32 (0..11) |
Type of the local ID of the IKE tunnel. |
As per the MIB. |
hh3cIPsecTunIKETunLocalIDVal1V2 (1.3.6.1.4.1.25506.2.126.1.2.1.5) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Value of the local ID of the IKE tunnel. |
As per the MIB. |
hh3cIPsecTunIKETunLocalIDVal2V2 (1.3.6.1.4.1.25506.2.126.1.2.1.6) |
read-only |
DisplayString |
The second specification of the IP address of the IKE tunnel local end. |
As per the MIB. |
hh3cIPsecTunIKETunRemoteIDTypeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.7) |
read-only |
Hh3cIPsecIDTypeV2 |
Integer32 (0..11) |
Type of the remote ID of the IKE tunnel. |
As per the MIB. |
hh3cIPsecTunIKETunRemoteIDVal1V2 (1.3.6.1.4.1.25506.2.126.1.2.1.8) |
read-only |
DisplayString |
Value of the remote ID of the IKE tunnel. |
As per the MIB. |
hh3cIPsecTunIKETunRemoteIDVal2V2 (1.3.6.1.4.1.25506.2.126.1.2.1.9) |
read-only |
DisplayString |
The second specification of the IP address of the IKE tunnel remote end. |
As per the MIB. |
hh3cIPsecTunLocalAddrTypeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.10) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the IP address of the IPsec tunnel local end. |
As per the MIB. |
hh3cIPsecTunLocalAddrV2 (1.3.6.1.4.1.25506.2.126.1.2.1.11) |
read-only |
InetAddress |
OCTET STRING (4) |
As per the MIB. |
hh3cIPsecTunRemoteAddrTypeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.12) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the IP address of the IPsec tunnel remote end. |
As per the MIB. |
hh3cIPsecTunRemoteAddrV2 (1.3.6.1.4.1.25506.2.126.1.2.1.13) |
read-only |
InetAddress |
OCTET STRING (4) |
As per the MIB. |
hh3cIPsecTunKeyTypeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.14) |
read-only |
Hh3cIPsecNegoTypeV2 |
Integer32(1,2,2147483647) |
Key negotiation mode of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunEncapModeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.15) |
read-only |
Hh3cIPsecEncapModeV2 |
Encapsulation mode of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInitiatorV2 (1.3.6.1.4.1.25506.2.126.1.2.1.16) |
read-only |
INTEGER |
Initiator of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunLifeSizeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.17) |
read-only |
Gauge32 |
Negotiated traffic-based IPsec SA lifetime, in kilobytes. |
As per the MIB. |
hh3cIPsecTunLifeTimeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.18) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Negotiated time-based IPsec SA lifetime, in seconds. |
As per the MIB. |
hh3cIPsecTunRemainTimeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.19) |
read-only |
Integer32 |
Remaining lifetime of the IPsec tunnel, in seconds. |
As per the MIB. |
hh3cIPsecTunActiveTimeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.20) |
read-only |
Integer32 |
Active period of time of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunRemainSizeV2 (1.3.6.1.4.1.25506.2.126.1.2.1.21) |
read-only |
Gauge32 |
Remaining lifetime of the IPsec tunnel, in kilobytes. |
outbound sa remain traffic duration |
hh3cIPsecTunTotalRefreshesV2 (1.3.6.1.4.1.25506.2.126.1.2.1.22) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Total number of SA refreshes. |
As per the MIB. |
hh3cIPsecTunCurrentSaInstancesV2 (1.3.6.1.4.1.25506.2.126.1.2.1.23) |
read-only |
Gauge32 |
Number of active and expiring SAs. |
As per the MIB. |
hh3cIPsecTunInSaEncryptAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.24) |
read-only |
Hh3cIPsecEncryptAlgoV2 |
Integer32 (0..14,2147483647) |
Encryption algorithm used by the inbound SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInSaAhAuthAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.25) |
read-only |
Hh3cIPsecAuthAlgoV2 |
Integer32 (0..5,2147483647) |
Authentication algorithm used by the inbound AH SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInSaEspAuthAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.26) |
read-only |
Authentication algorithm used by the inbound ESP SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunDiffHellmanGrpV2 (1.3.6.1.4.1.25506.2.126.1.2.1.27) |
read-only |
Hh3cIPsecDiffHellmanGrpV2 |
Integer32 (0,1,2,5,12,14,2147483647) |
DH group used in the IKE Phase-2 negotiation. |
As per the MIB. |
hh3cIPsecTunOutSaEncryptAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.28) |
read-only |
Encryption algorithm used by the outbound SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunOutSaAhAuthAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.29) |
read-only |
Authentication algorithm used by the outbound AH SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunOutSaEspAuthAlgoV2 (1.3.6.1.4.1.25506.2.126.1.2.1.30) |
read-only |
Authentication algorithm used by the outbound ESP SA of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunPolicyNameV2 (1.3.6.1.4.1.25506.2.126.1.2.1.31) |
read-only |
DisplayString |
Name of the IPsec policy used by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunPolicyNumV2 (1.3.6.1.4.1.25506.2.126.1.2.1.32) |
read-only |
Integer32 |
Sequence number of the IPsec policy entry used by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunStatusV2 (1.3.6.1.4.1.25506.2.126.1.2.1.33) |
read-only |
INTEGER |
Integer32 (1,2) |
State of the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunnelStatV2Table
About this table
This table contains IPsec tunnel packet statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object(OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTunInOctetsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.1) |
read-only |
Counter64 |
Total number of octets received by the IPsec tunnel. This value is accumulated before determining whether or not the packet should be decompressed. |
As per the MIB. |
hh3cIPsecTunInDecompOctetsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.2) |
read-only |
Counter64 |
Total number of decompressed octets received by the IPsec tunnel. This value is accumulated after the packet is decompressed. |
Not supported |
hh3cIPsecTunInPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.3) |
read-only |
Counter64 |
Total number of packets received by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.4) |
read-only |
Counter64 |
Total number of inbound packets dropped by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInReplayDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.5) |
read-only |
Counter64 |
Total number of inbound packets dropped by the IPsec tunnel due to anti-replay. |
As per the MIB. |
hh3cIPsecTunInAuthFailsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.6) |
read-only |
Counter64 |
Total number of inbound packets that failed authentication on the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunInDecryptFailsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.7) |
read-only |
Counter64 |
Total number of inbound packets that failed decryption on the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunOutOctetsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.8) |
read-only |
Counter64 |
Total number of octets sent by the IPsec tunnel. This value is accumulated after determining whether or not the packet should be compressed. |
As per the MIB. |
hh3cIPsecTunOutUncompOctetsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.9) |
read-only |
Counter64 |
Total number of uncompressed octets sent by this IPsec tunnel. This value is accumulated before the packet is compressed. |
Not supported |
hh3cIPsecTunOutPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.10) |
read-only |
Counter64 |
Total number of packets sent by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunOutDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.11) |
read-only |
Counter64 |
Total number of outbound packets dropped by the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunOutEncryptFailsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.12) |
read-only |
Counter64 |
Total number of outbound packets that failed encryption on the IPsec tunnel. |
As per the MIB. |
hh3cIPsecTunNoMemoryDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.13) |
read-only |
Counter64 |
Total number of packets dropped by the IPsec tunnel due to insufficient memory. |
Not supported |
hh3cIPsecTunQueueFullDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.14) |
read-only |
Counter64 |
Total number of packets dropped by the IPsec tunnel due to full queue. |
Not supported |
hh3cIPsecTunInvalidLenDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.15) |
read-only |
Counter64 |
Total number of packets dropped by the IPsec tunnel due to invalid length. |
As per the MIB. |
hh3cIPsecTunTooLongDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.16) |
read-only |
Counter64 |
Total number of packets dropped by the IPsec tunnel due to too long packet. |
As per the MIB. |
hh3cIPsecTunInvalidSaDropPktsV2 (1.3.6.1.4.1.25506.2.126.1.3.1.17) |
read-only |
Counter64 |
Total number of packets dropped by the IPsec tunnel due to invalid SA. |
As per the MIB. |
hh3cIPsecSaV2Table
About this table
This table contains IPsec SA information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIPsecTunIndexV2 and hh3cIPsecSaIndexV2.
Object(OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecSaIndexV2 (1.3.6.1.4.1.25506.2.126.1.4.1.1) |
Integer32 |
Index of an SA in an IPsec tunnel. |
As per the MIB. |
hh3cIPsecSaDirectionV2 (1.3.6.1.4.1.25506.2.126.1.4.1.2) |
read-only |
INTEGER |
Integer32 (1,2) |
Direction of the SA. |
As per the MIB. |
hh3cIPsecSaSpiValueV2 (1.3.6.1.4.1.25506.2.126.1.4.1.3) |
read-only |
Unsigned32 |
Unsigned32 (1..4294967295) |
SPI value of the SA. |
As per the MIB. |
hh3cIPsecSaProtocolV2 (1.3.6.1.4.1.25506.2.126.1.4.1.4) |
read-only |
Hh3cIPsecSaProtocolV2 |
Integer32 (0,2,3,4) |
Security protocol used by the SA. |
As per the MIB. |
hh3cIPsecSaEncryptAlgoV2 (1.3.6.1.4.1.25506.2.126.1.4.1.5) |
read-only |
Encryption algorithm used by the SA. |
As per the MIB. |
hh3cIPsecSaAuthAlgoV2 (1.3.6.1.4.1.25506.2.126.1.4.1.6) |
read-only |
Authentication algorithm used by the SA. |
As per the MIB. |
hh3cIPsecSaStatusV2 (1.3.6.1.4.1.25506.2.126.1.4.1.7) |
read-only |
INTEGER |
Integer32 (1,2) |
Status of the SA. |
As per the MIB. |
hh3cIPsecTrafficV2Table
About this table
This table contains information about the traffic protected by IPsec tunnels.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object(OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIPsecTrafficLocalTypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.1) |
read-only |
Hh3cIPsecTrafficTypeV2 |
Integer32 (1,4,5,6,7,8) |
Type of the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalAddr1TypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.2) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the first IP address specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalAddr1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.3) |
read-only |
InetAddress |
OCTET STRING (4) |
The first IP address specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalAddr2TypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.4) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the second IP address specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalAddr2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.5) |
read-only |
InetAddress |
OCTET STRING (4) |
The second IP address specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalProtocol1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.6) |
read-only |
Integer32 |
Integer32 (0..255) |
The first protocol number specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalProtocol2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.7) |
read-only |
Integer32 |
The second protocol number specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalPort1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.8) |
read-only |
Integer32 |
Integer32 (0..65535) |
The first port number specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficLocalPort2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.9) |
read-only |
Integer32 |
The second port number specification for the local end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemoteTypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.10) |
read-only |
Type of the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemAddr1TypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.11) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the first IP address specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemAddr1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.12) |
read-only |
InetAddress |
OCTET STRING (4) |
The first IP address specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemAddr2TypeV2 (1.3.6.1.4.1.25506.2.126.1.5.1.13) |
read-only |
InetAddressType |
Integer32(1,2) |
Type of the second IP address specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemAddr2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.14) |
read-only |
InetAddress |
OCTET STRING (4) |
The second IP address specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemoPro1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.15) |
read-only |
Integer32 |
The first protocol number specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemoPro2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.16) |
read-only |
Integer32 |
The second protocol number specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemPort1V2 (1.3.6.1.4.1.25506.2.126.1.5.1.17) |
read-only |
Integer32 |
The first port number specification for the remote end's traffic. |
As per the MIB. |
hh3cIPsecTrafficRemPort2V2 (1.3.6.1.4.1.25506.2.126.1.5.1.18) |
read-only |
Integer32 |
The second port number specification for the remote end's traffic. |
As per the MIB. |
Notifications
The following information describes the notifications generated by HH3C-IPSEC-MONITOR-V2-MIB.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.1 |
IPsec tunnel created. |
Informational |
OFF |
This notification is generated when an IPsec tunnel is created.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec tunnel-start command.
· MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec tunnel-start command.
· MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.126.1.2.1.1 (hh3cIPsecTunIndexV2) |
Yes |
Integer32 |
1..2147483647 |
1.3.6.1.4.1.25506.2.126.1.2.1.10 (hh3cIPsecTunLocalAddrTypeV2) |
No |
InetAddressType |
Standard MIB values. |
1.3.6.1.4.1.25506.2.126.1.2.1.11 (hh3cIPsecTunLocalAddrV2) |
No |
InetAddress |
1.3.6.1.4.1.25506.2.126.1.2.1.12 (hh3cIPsecTunRemoteAddrTypeV2) |
No |
InetAddressType |
1.3.6.1.4.1.25506.2.126.1.2.1.13 (hh3cIPsecTunRemoteAddrV2) |
No |
InetAddress |
1.3.6.1.4.1.25506.2.126.1.2.1.18 (hh3cIPsecTunLifeTimeV2) |
Time-based lifetime of the IPsec tunnel, in seconds. |
No |
Integer32 |
1..2147483647 |
1.3.6.1.4.1.25506.2.126.1.2.1.17 (hh3cIPsecTunLifeSizeV2) |
Time-based lifetime of the IPsec tunnel, in kilobytes. |
No |
Gauge32 |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.2 |
IPsec tunnel deleted. |
Informational |
OFF |
This notification is generated when an IPsec tunnel is deleted.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec tunnel-stop command.
· MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec tunnel-stop command.
· MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..2147483647 |
No |
InetAddressType |
No |
InetAddress |
No |
InetAddressType |
No |
InetAddress |
1.3.6.1.4.1.25506.2.126.1.2.1.20 (hh3cIPsecTunActiveTimeV2) |
No |
Integer32 |
0..2147483647 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.3 |
No SA for IPsec tunnel. |
Informational |
OFF |
This notification is generated when no SA is available for an IPsec tunnel.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec no-sa-failure command.
· MIB: Set hh3cIPsecNoSaTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec no-sa-failure command.
· MIB: Set hh3cIPsecNoSaTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..2147483647 |
No |
InetAddressType |
No |
InetAddress |
No |
InetAddressType |
No |
InetAddress |
Recommended action
hh3cIPsecAuthFailFailureV2
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.4 |
IPsec authentication failure. |
Informational |
OFF |
This notification is generated when an IPsec authentication failure occurs.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec auth-failure command.
· MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec auth-failure command.
· MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..2147483647 |
No |
InetAddressType |
No |
InetAddress |
No |
InetAddressType |
No |
InetAddress |
Recommended action
hh3cIPsecEncryFailFailureV2
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.5 |
IPsec tunnel encryption failure. |
Informational |
OFF |
This notification is generated when an IPsec tunnel has an encryption failure.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec encrypt-failure command.
· MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec encrypt-failure command.
· MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..2147483647 |
No |
InetAddressType |
No |
InetAddress |
No |
InetAddressType |
No |
InetAddress |
Recommended action
hh3cIPsecDecryFailFailureV2
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.6 |
Informational |
OFF |
This notification is generated when an IPsec tunnel has a decryption failure.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec decrypt-failure command.
· MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec decrypt-failure command.
· MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..2147483647 |
No |
InetAddressType |
No |
InetAddress |
No |
InetAddressType |
No |
InetAddress |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.8 |
IPsec policy added. |
Informational |
OFF |
This notification is generated when an IPsec policy is added.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec policy-add command.
· MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec policy-add command.
· MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.126.1.7.1 (hh3cIPsecPolicyNameV2) |
Name of an IPsec policy. |
No |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.126.1.7.2 (hh3cIPsecPolicySeqNumV2) |
Sequence number an IPsec policy entry. |
No |
Integer32 |
1..2147483647 |
1.3.6.1.4.1.25506.2.126.1.7.3 (hh3cIPsecPolicySizeV2) |
Number of the IPsec policy entries. |
No |
InetAddressType |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.9 |
IPsec policy deleted. |
Informational |
OFF |
This notification is generated when an IPsec policy is deleted.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec policy-delete command.
· MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec policy-delete command.
· MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
Sequence number of an IPsec policy entry. |
No |
Integer32 |
1..2147483647 |
No |
InetAddressType |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.10 |
IPsec policy applied to interface. |
Informational |
OFF |
This notification is generated when an IPsec policy is applied to an interface.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec policy-attach command.
· MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec policy-attach command.
· MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
No |
Integer32 |
1..2147483647 |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of an interface. |
Yes |
InterfaceIndex |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.11 |
IPsec policy application removed from interface. |
Informational |
OFF |
This notification is generated when an IPsec policy application is removed from an interface.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec policy-detach command.
· MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec policy-detach command.
· MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
No |
Integer32 |
1..2147483647 |
Yes |
InterfaceIndex |
Recommended action
hh3cIPsecConnectionStartV2
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.12 |
IPsec connection created. |
Informational |
OFF |
This notification is generated when the first IPsec policy with a specific connection ID is added, that is, an IPsec connection is created.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec connection-start command.
· MIB: Set hh3cIPsecConnectionStartTrapV2 to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable ipsec connection-start command.
· MIB: Set hh3cIPsecConnectionStartTrapV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.126.1.10.1.1 (hh3cIPsecPolicyDescripV2) |
Description for an IPsec policy. |
Yes |
STRING (SIZE(1..79)) |
SIZE (1..79) |
Recommended action
hh3cIPsecConnectionStopV2
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.126.1.9.0.13 |
IPsec connection terminated. |
Informational |
OFF |
This notification is generated when the last IPsec policy of a specific connection ID is deleted, that is, an IPsec connection is terminated.
Status control
ON
· CLI: Use the snmp-agent trap enable ipsec connection-stop command.
· MIB: Set hh3cIPsecConnectionStopTrapV2 to true(1).
OFF
· MIB: Set hh3cIPsecConnectionStopTrapV2 to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Description for the IPsec policy. |
Yes |
SIZE (1..79) |
Recommended action
