01-HH3C-BGP-EVPN-MIB | 47.29 KB |
HH3C-BGP-EVPN-MIB
About this MIB
Use this MIB to manage BGP EVPN configuration.
MIB file name
hh3c-bgp-evpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBgpEvpn(172)
Tabular objects
hh3cBgpEvpnNbrAddrTable
About this table
Use this table to configure the address and AS number of each BGP peer.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cBgpEvpnNbrAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBgpEvpnNbrAddr (1.3.6.1.4.1.25506.2.172.1.1.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
BGP peer address. |
As per the MIB. |
hh3cBgpEvpnNbrAsNumber (1.3.6.1.4.1.25506.2.172.1.1.1.2) |
read-only |
Unsigned32 |
Standard MIB values. |
BGP peer AS neighbor. |
As per the MIB. |
hh3cBgpEvpnNbrPrefixTable
About this table
Use this table to configure address prefix parameters for BGP EVPN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cBgpEvpnPAtrRD, hh3cBgpEvpnPAtrIpAddrPrefix, hh3cBgpEvpnPAtrIpAddrPrefixLen, and hh3cBgpEvpnPAtrPeer.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBgpEvpnPAtrRD (1.3.6.1.4.1.25506.2.172.1.1.2.1) |
not-accessible |
OCTET STRING |
OCTET STRING (3..21) |
Route distinguisher. |
As per the MIB. |
hh3cBgpEvpnPAtrAddrPrefix (1.3.6.1.4.1.25506.2.172.1.1.2.2) |
not-accessible |
IpAddress |
OCTET STRING (4) |
Address prefix. |
As per the MIB. |
hh3cBgpEvpnPAtrAddrPrefixLen (1.3.6.1.4.1.25506.2.172.1.1.2.3) |
not-accessible |
Integer32 |
Integer32(0..300) |
Address prefix length. |
As per the MIB. |
hh3cBgpEvpnPAtrPeer (1.3.6.1.4.1.25506.2.172.1.1.2.4) |
not-accessible |
IpAddress |
OCTET STRING (4) |
BGP EVPN peer address. |
As per the MIB. |
hh3cBgpEvpnPAtrRouteType (1.3.6.1.4.1.25506.2.172.1.1.2.5) |
read-only |
Unsigned32 |
Route type. |
As per the MIB. |
hh3cBgpEvpnPAtrOrigin (1.3.6.1.4.1.25506.2.172.1.1.2.6) |
read-only |
INTEGER |
igp(1) egp(2) incomplete(3) |
Ultimate origin of the path information. |
As per the MIB. |
hh3cBgpEvpnPAtrASPathSegment (1.3.6.1.4.1.25506.2.172.1.1.2.7) |
read-only |
OCTET STRING |
OCTET STRING (2..255) |
Sequence of AS path segments. |
As per the MIB. |
hh3cBgpEvpnPAtrNextHop (1.3.6.1.4.1.25506.2.172.1.1.2.8) |
read-only |
IpAddress |
OCTET STRING (4) |
Address of the border router. |
As per the MIB. |
hh3cBgpEvpnPAtrMultiExitDisc (1.3.6.1.4.1.25506.2.172.1.1.2.9) |
read-only |
Integer32 |
Integer32(-1..2147483647) |
Metric used to discriminate between multiple exit points to an adjacent autonomous system. |
As per the MIB. |
hh3cBgpEvpnPAtrLocalPref (1.3.6.1.4.1.25506.2.172.1.1.2.10) |
read-only |
Integer32 |
Originating BGP4 speaker's degree of preference for an advertised route. |
As per the MIB. |
hh3cBgpEvpnPAtrIGMPFlags (1.3.6.1.4.1.25506.2.172.1.1.2.11) |
read-only |
INTEGER |
igmpv1(1) igmpv2(2) igmpv3(3) |
IGMP version. |
Not supported. |
hh3cBgpEvpnPAtrMaxRespTime (1.3.6.1.4.1.25506.2.172.1.1.2.12) |
read-only |
Unsigned32 |
Maximum response time, the duration of (x, G) leave group synchronization procedure. |
As per the MIB. |
hh3cBgpEvpnPAtrPMSITunnel (1.3.6.1.4.1.25506.2.172.1.1.2.13) |
read-only |
OCTET STRING |
OCTET STRING (9..21) |
P-tunnel used for sending broadcast. |
As per the MIB. |
hh3cBgpEvpnPAtrL2VNI (1.3.6.1.4.1.25506.2.172.1.1.2.14) |
read-only |
Unsigned32 |
L2 VNI. |
As per the MIB. |
hh3cBgpEvpnPAtrL3VNI (1.3.6.1.4.1.25506.2.172.1.1.2.15) |
read-only |
Unsigned32 |
L3 VNI. |
As per the MIB. |
hh3cBgpEvpnPAtrBest (1.3.6.1.4.1.25506.2.172.1.1.2.16) |
read-only |
TruthValue |
true(1) false(2) |
BGP4 best path flag. |
As per the MIB. |
hh3cBgpEvpnPAtrUnknown (1.3.6.1.4.1.25506.2.172.1.1.2.17) |
read-only |
OCTET STRING |
OCTET STRING (0..255) |
One or more path attributes not understood by this BGP4 speaker. |
As per the MIB. |
