01-Fundamentals
HomeSupportResource CenterSwitchesS5590 SeriesS5590-EI SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S5590-EI Switch Series MIB Reference-6W10001-Fundamentals
02-HH3C-ISSU-MIB
02-HH3C-ISSU-MIB 80.00 KB
HH3C-ISSU-MIB
About this MIB
Use this table to perform in-service software upgrade (ISSU) operations.
You can obtain information from the hh3cIssuTestResultTable and cIssuUpgradeResultTable objects only if you have performed test or install operations by using the hh3cIssuUpgrageImageTable object.
MIB file name
hh3c-issu.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIssuUpgrade(133)
Scalar objects
hh3cIssuOpType
Object (OID)
Access
Value range
Implementation
hh3cIssuOpType (1.3.6.1.4.1.25506.2.133.1.1.2.1)
read-write
INTEGER
none(1)
done(2)
test(3)
install(4)
rollback(5)
ISSU operation.
As per the MIB.
hh3cIssuImageFileOverwrite
Object (OID)
Access
Value range
Implementation
hh3cIssuImageFileOverwrite (1.3.6.1.4.1.25506.2.133.1.1.2.2)
read-write
TruthValue
true(1)
false(2)
Enables or disables ISSU to overwrite the current image file when copying the upgrade image file to the node to be upgraded.
As per the MIB.
hh3cIssuOpTrapEnable
Object (OID)
Access
Value range
Implementation
hh3cIssuOpTrapEnable (1.3.6.1.4.1.25506.2.133.1.1.2.3)
read-write
TruthValue
true(1)
false(2)
SNMP ISSU notification control.
As per the MIB.
hh3cIssuOpStatus
Object (OID)
Access
Value range
Implementation
hh3cIssuOpStatus (1.3.6.1.4.1.25506.2.133.1.1.2.4)
read-only
INTEGER
none(1)
failure(2)
inProgress(3)
success(4)
rollbackInProgress(5)
rollbackSuccess(6)
ISSU upgrade state.
As per the MIB.
hh3cIssuFailedReason
Object (OID)
Access
Value range
Implementation
hh3cIssuFailedReason (1.3.6.1.4.1.25506.2.133.1.1.2.5)
read-only
DisplayString
OCTET STRING (0..255)
ISSU upgrade failure cause.
As per the MIB.
hh3cIssuOpTimeCompleted
Object (OID)
Access
Value range
Implementation
hh3cIssuOpTimeCompleted (1.3.6.1.4.1.25506.2.133.1.1.2.6)
read-only
DisplayString
Time when the ISSU operation finished.
As per the MIB.
hh3cIssuLastOpType
Object (OID)
Access
Value range
Implementation
hh3cIssuLastOpType (1.3.6.1.4.1.25506.2.133.1.1.2.7)
read-only
INTEGER
none(1)
done(2)
test(3)
install(4)
rollback(5)
Previous ISSU operation.
As per the MIB.
hh3cIssuLastOpStatus
Object (OID)
Access
Value range
Implementation
hh3cIssuLastOpStatus (1.3.6.1.4.1.25506.2.133.1.1.2.8)
read-only
INTEGER
none(1)
failure(2)
inProgress(3)
success(4)
rollbackSuccess(6)
State of the previous ISSU operation.
As per the MIB.
hh3cIssuLastOpFailedReason
Object (OID)
Access
Value range
Implementation
hh3cIssuLastOpFailedReason (1.3.6.1.4.1.25506.2.133.1.1.2.9)
read-only
DisplayString
Cause of the most recent ISSU upgrade failure.
As per the MIB.
hh3cIssuLastOpTimeCompleted
Object (OID)
Access
Value range
Implementation
hh3cIssuLastOpTimeCompleted(1.3.6.1.4.1.25506.2.133.1.1.2.10)
read-only
DisplayString
Time when the previous ISSU operation finished.
As per the MIB.
hh3cIssuCompatibleResultStatus
Object (OID)
Access
Value range
Implementation
hh3cIssuCompatibleResultStatus (1.3.6.1.4.1.25506.2.133.1.2.1.1)
read-only
INTEGER
none(1)
inCompatible(2)
compatible(3)
failure(4)
ISSU compatibility check result.
As per the MIB.
hh3cIssuCompatibleResultFailedReason
Object (OID)
Access
Value range
Implementation
hh3cIssuCompatibleResultFailedReason (1.3.6.1.4.1.25506.2.133.1.2.1.2)
read-only
DisplayString
Cause of ISSU compatibility check failure.
As per the MIB.
Tabular objects
hh3cIssuUpgradeImageTable
About this table
Use this table to set the image file for an ISSU or obtain information about the image file.
·     To verify the validity of the upgrade image file and obtain the recommended ISSU method, perform a test operation.
·     To do an ISSU, perform the install operation.
·     To roll back the software, perform the rollback operation.
·     To clear the records of operations for the most recent ISSU, perform the done operation.
As shown in Figure 1, perform a test operation only in initial state. After you perform the test operation, perform an install operation depending on the test operation result.
You can perform a done operation to change the ISSU state to the initial state after you have performed a test, install or rollback operation. The done operation clears hh3cIssuUpgradeImageTable, restores the FileOverwrite and TrapEnable objects to their default values.
You can perform a rollback whenever you like. However, the operation does not take effect if you have only performed a test operation.
After you issue a rollback instruction, the system moves the current opType, opStatus, opFailedReason, and opTimeCompleted values to their respective LastOp entries if a rollback is allowed.
Five minutes later after an install or rollback operation succeeds, the system copies the current OpType, OpStatus, OpFailedReason, and OpTimeCompleted values to their respective LastOp objects. Another five minutes later, all these Op objects are restored to their default values.
Figure 1 ISSU operations
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
When you create an instance, you must also specify hh3cIssuUpgradeImageType, hh3cIssuUpgradeImageURL, and hh3cIssuUpgradeImageIndexRowStatus.
Columns
The table index is hh3cIssuUpgradeImageIndex.
Object (OID)
Access
Value range
Implementation
hh3cIssuUpgradeImageIndex (1.3.6.1.4.1.25506.2.133.1.1.1.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Image file index.
As per the MIB.
hh3cIssuUpgradeImageType (1.3.6.1.4.1.25506.2.133.1.1.1.1.2)
read-create
INTEGER
boot(1) system(2)
feature(3)
ipe(4)
patch(5)
Image file type.
As per the MIB.
(1.3.6.1.4.1.25506.2.133.1.1.1.1.3)
read-create
DisplayString
OCTET STRING (1..127)
Image file path.
As per the MIB.
hh3cIssuUpgradeImageRowStatus (1.3.6.1.4.1.25506.2.133.1.1.1.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
About this table
Use this table to obtain the result of an ISSU test operation.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIssuTestResultIndex.
Object (OID)
Access
Value range
Implementation
hh3cIssuTestResultIndex (1.3.6.1.4.1.25506.2.133.1.2.2.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Test result index.
As per the MIB.
hh3cIssuTestDeviceChassisID (1.3.6.1.4.1.25506.2.133.1.2.2.1.2)
read-only
Integer32
Integer32 (0..255)
Chassis number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceSlotID (1.3.6.1.4.1.25506.2.133.1.2.2.1.3)
read-only
Integer32
Integer32 (0..255)
Slot number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceCpuID (1.3.6.1.4.1.25506.2.133.1.2.2.1.4)
read-only
Integer32
Integer32 (0..7)
CPU number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceUpgradeWay (1.3.6.1.4.1.25506.2.133.1.2.2.1.5)
read-only
INTEGER
none(1)
reboot(2)
sequenceReboot(3)
issuReboot(4)
serviceUpgrade(5)
fileUpgrade(6)
incompatibleUpgrade(7)
Recommended ISSU upgrade method.
As per the MIB.
hh3cIssuUpgradeResultTable
About this table
Use this table to obtain the result of an ISSU install operation.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIssuUpgradeResultIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.133.1.2.3.1.1)
not-accessible
Integer32
Table index of hh3cIssuUpgradeResultTable.
As per the MIB.
hh3cIssuUpgradeDeviceChassisID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.2)
read-only
Integer32
Integer32 (0..255)
Chassis number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeDeviceSlotID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.3)
read-only
Integer32
Integer32 (0..255)
Slot number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeDeviceCpuID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.4)
read-only
Integer32
Integer32 (0..7)
CPU number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeState
(1.3.6.1.4.1.25506.2.133.1.2.3.1.5)
read-only
INTEGER
init(1)
loading(2)
loaded(3)
switching(4)
switchover(5)
committing(6)
committed(7)
rollbacking(8)
rollbacked(9)
Node state.
As per the MIB.
hh3cIssuDeviceUpgradeWay
(1.3.6.1.4.1.25506.2.133.1.2.3.1.6)
read-only
INTEGER
none(1),
reboot(2)
sequenceReboot(3)
issuReboot(4)
serviceUpgrade(5)
fileUpgrade(6)
ISSU method for the node.
As per the MIB.
hh3cIssuUpgradeDeviceStatus
(1.3.6.1.4.1.25506.2.133.1.2.3.1.7)
read-only
INTEGER
waitingUpgrade(1)
inProcess(2)
success(3)
failure(4)
Current upgrade state of the node.
As per the MIB.
hh3cIssuUpgradeFailedReason
(1.3.6.1.4.1.25506.2.133.1.2.3.1.8)
read-only
DisplayString
Upgrade failure cause.
As per the MIB.
  • Become a Partner
  • Partner Resources
