- 11-NMM Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-CWMP configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance configuration
- 11-Mirroring configuration
- 12-sFlow configuration
- 13-Information center configuration
- 14-PTP configuration
- 15-Network synchronization configuration
| 00-Preface | 102.11 KB |
Preface
This configuration guide describes the network management and monitoring fundamentals and configuration procedures. It describes how to view system information, collect traffic statistics, assess the network performance, synchronize time for all devices with clocks in your network, and use the ping, tracert, and debug commands to check and debug the current network connectivity.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
