- H3C WX5860X Access Controllers Installation Guide-5W101
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Troubleshooting
- 05-Hardware management and maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Removable components and compatibility matrixes
| 08-Appendix C Removable components and compatibility matrixes | 163.46 KB |
1 Removable components and compatibility matrixes
Transceiver module, fiber connector, and optical fiber views
Transceiver module specifications
Table1-1 Compatibility matrix between the device and removable components
Removable component model |
Product code |
BOM code |
Removable power supplies |
PSR650B-12A1 |
PSR650B-12A1-D |
0231AE0D |
PSR650B-12D1 |
PSR650B-12D1-GL |
0231ABDH |
Removable fan trays |
LSWM1BFANSCB |
LSWM1BFANSCB |
0231ACJP |
Expansion modules |
EWPXM1BSTX80 |
EWPXM1BSTX80 |
0231AFH1 |
WARNING! To avoid device damage or even bodily injury, make sure the power supply is powered off when you install or remove a power supply. |
The device uses removable power supplies and supports the PSR650B-12A1 and PSR650B-12D1 power supplies.
You can install one power supply, two power supplies, three power supplies, or four power supplies in redundancy for the device.
Table1-2 Power supplies available for the device
Power supply model |
Specifications |
PSR650B-12A1 |
· Rated input voltage range: 100 to 240 VAC @ 56/60 Hz · Max input voltage range: 90 to 264 VAC @ 47 to 63 Hz · Max output power: 650 W |
PSR650B-12D1 |
· Rated input voltage range: –40 to –60 VDC · Max input voltage range: –40 to –72 VDC · Max output power: 650 W · Melting current of power supply fuse: 30 A/250 V |
Removable fan trays
The device uses removable fan trays and supports the LSWM1BFANSCB fan trays.
Table1-3 LSWM1BFANSCB fan tray specifications
Item |
Specifications |
Dimensions (H × W × D) |
80 × 80 × 232.6 mm (3.15 × 3.15 × 9.16 in) |
Fan speed |
20000 R.P.M |
Max airflow |
120 CFM |
Input voltage |
12 V |
Maximum power consumption |
57 W |
Airflow direction |
From the port side to the power supply side |
Expansion modules
Table1-4 Expansion module specifications
Item |
Specifications |
EWPXM1BSTX80 |
Hardware acceleration module |
Port type and quantity |
· 8 × 1000BASE-T Ethernet copper ports · 8 × GE SFP fiber ports · 8 × 10GE SFP+ fiber ports · 2 × 40GE QSFP+ fiber ports A 1000BASE-T Ethernet copper port and a GE SFP fiber port form a combo interface. A 10GE SFP+ fiber port and a 40GE QSFP+ fiber port cannot be used simultaneously. |
Available transceiver modules and cables |
SFP-GE-SX-MM850-A and SFP-GE-LX-SM1310-A transceiver modules in Table1-5. SFP+ transceiver modules and cables in Table1-6 and Table1-7. QSFP+ transceiver modules and cables in Table1-8 and Table1-9.. |
To connect a fiber port on the device, use an SFP transceiver module and an optical fiber with LC connectors.
Figure1-1 SFP transceiver module
Figure1-2 SFP+ transceiver module
Figure1-3 Optical fiber with LC connectors
(1) LC connector |
(2) Optical fiber |
Table1-5 GE SFP transceiver modules available for the SFP and SFP+ ports
GE SFP transceiver module |
Central wavelength (nm) |
Connector |
Cable/Fiber type and diameter (µm) |
Modal bandwidth (MHz × km) |
Max transmission distance |
SFP-GE-SX-MM850-A |
850 |
LC |
Multi-mode, 50/125 |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
Multi-mode, 62.5/125 |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
Single-mode, 9/125 |
N/A |
10 km (6.21 miles) |
500 or 400 |
500 |
Table1-6 10-GE SFP+ transceiver modules available for the SFP+ ports
10-GE SFP+ module |
Connector |
Fiber diameter (µm) |
Multimode fiber modal bandwidth (MHz × km) |
SFP-XG-LX-SM1310-E |
1310 |
LC |
N/A |
SFP-XG-SX-MM850-E |
850 |
LC |
N/A |
300 m (984.25 ft) |
N/A |
33 m (108.27 ft) |
Table1-7 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable |
Cable length |
LSWM1STK |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
Table1-8 QSFP+ transceiver modules available for the QSFP+ ports
QSFP+ transceiver module |
Connector |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
N/A |
QSFP-40G-LR4L-WDM1300 |
LC |
N/A |
2 km (1.24 miles) |
Table1-9 QSFP+ cables available for the QSFP+ ports
QSFP+ network cable |
LSWM1QSTK0 |
1 m (3.28 ft) |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
