- H3C WX3820X Access Controllers Installation Guide-5W101
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Troubleshooting
- 05-Hardware management and maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
07-Appendix B LEDs | 92.51 KB |
6 LEDs
LEDs
(1) 100/1000BASE-T autosensing Ethernet port LEDs |
(2) 1000BASE-X SFP port LED |
(3) Power module LED (PWR1) |
(4) Power module LED (PWR2) |
(5) System status LED (SYS) |
(6) Expansion module status LED (SLOT1) |
(7) Expansion module status LED (SLOT2) |
(8) Expansion module status LED (SLOT3) |
(9) 100/1000BASE-T out-of-band management Ethernet port status LED (LINK/ACT) |
LED description
Table6-1 LED description
LED |
Mark |
Status |
Power module LED |
PWR1 PWR2 |
Steady green |
The power module is operating correctly. |
Steady red |
An exception has occurred on the power module. |
Off |
No power module is present. |
System status LED |
SYS |
Slow flashing green (once every 2 seconds) |
The device is operating correctly. |
Fast flashing green (four times per second) |
The device is starting up. |
Steady red |
The device has failed self-POST or other severe issues were detected. |
Off |
No power is input. |
Expansion module status LED |
SLOT1 SLOT2 SLOT3 |
Steady green |
The expansion module is in position. |
Steady red |
An error has occurred on the expansion module. |
Off |
No expansion module is present. |
Drive status LED |
N/A |
Steady green |
The drive is present and operating correctly. |
Fast flashing green |
Data is being read from or written to the drive. |
Off |
No drive is present. |
100/1000BASE-T out-of-band management Ethernet port LED |
LINK/ACT |
Steady green |
A link is present. |
Flashing green |
The port is receiving and sending data. |
Off |
No link is present. |
100/1000BASE-T autosensing Ethernet port LED |
N/A |
Steady yellow |
A 100 Mbps link is present. |
Flashing yellow |
The port is receiving and sending data at 100 Mbps. |
Steady green |
A 1000 Mbps link is present. |
Flashing green |
The port is receiving and sending data at 1000 Mbps. |
Off |
N/A |
Steady green |
Flashing green |
Off |
