00-Preface | 26.25 KB |
Preface
This installation guide describes the procedures for installing and removing the SeerEngine-DC OpenStack plug-ins.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
