01-Typical configuration example
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-F Routers Configuration Examples All-In-One-R838x-6W10001-Typical configuration example
Table of Contents
Related Documents
21-Login_Management_Configuration_Examples
21-Login_Management_Configuration_Examples 239.61 KB
Introduction
This document provides login configuration examples. It also provides examples for implementing user access control by using command authorization and command accounting.
This document assumes that you have basic knowledge of login management.
Example: Configuring console login
Configure console login so users must pass local authentication to log in to the device through the console port.
Analysis
The port properties for the terminal emulation program must match the console port's default settings.
By default, a local user is assigned the default user role network-operator and is not assigned any service type. To enable the user to log in through the console port, you must assign the terminal service type to the user. To enable the user to manage the device, you must assign the network-admin user role to the user.
When you configure console login, follow these restrictions and guidelines:
·     Identify the console port carefully to make sure you are connecting to the correct port.
·     Prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
·     The required terminal emulation program varies by operating system.
¡     On the Windows Server 2003 or Windows XP operating system, use HyperTerminal.
¡     On the Windows Server 2008, Windows Vista, Windows 7, and other operating systems, use a third-party terminal emulation program. For information about how to use the third-party terminal emulation program, see the user guide or online help for the program.
Procedures
1.     Turn off the PC if the PC is on.
2.     Connect the DB-9 female connector of the console cable to the serial port of the PC.
3.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a configuration terminal to the console port
4.     Turn on the PC.
5.     On the PC, launch the terminal emulation program and create a connection to the device. Set the port properties so the port properties match the following console port default settings:
¡     Bits per second9600 bps.
¡     Flow controlNone.
¡     ParityNone.
¡     Stop bits—1.
¡     Data bits—8.
6.     Power on the device and press Enter as prompted.
The user view prompt appears. To get help, enter a question mark (?).
Line con1 is available.
Press ENTER to get started.
* Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.*
<Sysname> %Dec  9 17:08:07:804 2014 DeviceD SHELL/5/SHELL_LOGIN: -MDC=1; Console
logged in from con0.
<Sysname>
7.     Configure console line 1:
# Enter console line view.
[Sysname] line console 1
# Enable scheme authentication to use AAA to authenticate the console login user.
[Sysname-line-console1] authentication-mode scheme
[Sysname-line-console1] quit
# Create local user admin.
[Sysname] local-user admin class manage
New local user added.
# Set the password to 123 (plain text) for the local user.
[Sysname-luser-manage-admin] password simple 123
# Assign the terminal service type and the network-admin user role to the user. Reclaim the default user role.
[Sysname-luser-manage-admin] service-type terminal
[Sysname-luser-manage-admin] authorization-attribute user-role network-admin
[Sysname-luser-manage-admin] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-admin] quit
1.     Log in to the device through the console port again and press Enter as prompted.
The prompt for username login: appears.
2.     Enter the username admin.
The prompt for password Password: appears.
3.     Enter the password 123.
The user view prompt <Sysname> appears.
login: admin
Password:
<Sysname>
Configuration files
line console 1
 password hash $h$6$R1DZqFZrkA93GMAf$th9k1FcsjqRRy1A2reQXQkfmnTBSr/7//80W5gKuyeHYxNor/FVNl4tbBQLhaGeY5XFrVr1+WopPcC+dfaumgg==
Example: Configuring Telnet login
As shown in Figure 2, users need to log in to the device remotely to manage the device.
·     Configure Telnet login to enable users to Telnet to the device.
·     Configure Telnet user authentication so a Telnet user must provide the correct username and password at login.
·     Configure access control so only Telnet users at 192.168.0.46/24 and 192.168.0.52/24 can Telnet to the device.
·     Configure two local users.
¡     One local user can manage the device.
¡     One local user can use only the read commands of features.
Figure 2 Network diagram
Analysis
Telnet service is disabled by default. To enable Telnet login, you must enable Telnet service.
To control Telnet login, configure an ACL to permit access only from the specified IP addresses.
By default, a local user is assigned the default user role network-operator. To restrict a local user to read commands, you must create a user role that can access only read commands.
Procedures
# Log in to the device through the console port. (Details not shown.)
# Enable Telnet service.
# Enable scheme authentication to use AAA to authenticate the Telnet login user.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode scheme
[Sysname-line-vty0-63] quit
# Create the local user userA. Set the password to 123 (plain text).
[Sysname] local-user userA class manage
[Sysname-luser-manage-userA] password simple 123
# Assign the Telnet service type and the network-admin user role to the user. Reclaim the default user role.
[Sysname-luser-manage-userA] authorization-attribute user-role network-admin
[Sysname-luser-manage-userA] service-type telnet
[Sysname-luser-manage-userA] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userA] quit
# Create user role roleB. Add rule 1 to permit the user role to access read commands of all features.
[Sysname] role name roleB
[Sysname-role-roleB] rule 1 permit read feature
[Sysname-role-roleB] quit
# Create the local user userB. Set the password to 123 (plain text).
[Sysname] local-user userB class manage
[Sysname-luser-manage-userB] password simple 123
# Assign the Telnet service type and the roleB user role to the user. Reclaim the default user role.
[Sysname-luser-manage-userB] authorization-attribute user-role roleB
[Sysname-luser-manage-userB] service-type telnet
[Sysname-luser-manage-userB] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userB] quit
# Create ACL 2000 and add rules to permit only access from 192.168.0.46 and 192.168.0.52.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 192.168.0.46 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 192.168.0.52 0
[Sysname-acl-ipv4-basic-2000] rule 3 deny source any
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
1.     Telnet to the device from Host A as userA. (Details not shown.)
2.     Display the commands available in user view.
The commands for device configuration and management are included in the list.
login: userA
Password:
<Sysname> ?
User view commands:
archive             Archive configuration
  arp                 Address Resolution Protocol (ARP) module
  backup              Backup operation
  bash                Enter the bash shell
  boot-loader         Software image file management
  bootrom             Update/read/backup/restore bootrom
  cd                  Change current directory
  cfd                 Connectivity Fault Detection (CFD) module
  clock               Specify the system clock
  connectto           Connect to target
  copy                Copy a file
  debugging           Enable system debugging functions
  delete              Delete a file
  diagnostic          Generic OnLine Diagnostics (GOLD) module
  diagnostic-logfile  Diagnostic log file configuration
  dir                 Display files and directories on the storage media
  display             Display current system information
  erase               Alias for 'delete'
  exception           Exception information configuration
  exit                Alias for 'quit'
  fdisk               Partition a storage medium
  fixdisk             Check and repair a storage medium
  format              Format a storage medium
  free                Release a connection
3.     Telnet to the device from Host B as userB. (Details not shown.)
4.     Display the commands available in user view.
Only read commands are displayed.
login: userB
Password:
<Sysname> ?
User view commands:
  md5sum       Compute the hash digest of a file using the MD5 algorithm
  more         Display the contents of a file
  no           Alias for 'undo'
  pwd          Display current working directory
  quit         Exit from current command view
  sha256sum    Compute the hash digest of a file using the SHA256 algorithm
  show         Alias for 'display'
  system-view  Enter System View
  write        Alias for 'save'
<Sysname>
5.     Telnet to the device from Host C. (Details not shown.)
Your access request is rejected.
Configuration files
acl basic 2000
 rule 3 deny
line vty 0 63
 password hash $h$6$I2Sg4Llj1qVUWQZ3$JA6KkU3zfVVRg48MM92X6cVpdiqR2JF887PKi3GQMwn
XXXcsWBuz7GIeJZeeNFMmMBaV7DPkKblnb0sGT2axvg==
 service-type telnet
 password hash $h$6$q+c3OcSxrPpDpsDf$BWkgfOyxBLyR5zyYgF/+VvN/1ofy81zoHDlFf80OjDl
a6/EiSJbSBl33PeazilSkWSYcttkg5v5bGecB7oYwAw==
 service-type telnet
role name roleB
Example: Configuring login user command authorization and accounting
As shown in Figure 3, Host A needs to log in to the device to manage the device.
For device security purposes, configure the device to perform the following tasks:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     Send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 3 Network diagram
Analysis
To implement command authorization and accounting, you must perform the following tasks:
·     Enable scheme authentication and configure a HWTACACS scheme on the device.
·     Configure an account on the HWTACACS server for the Telnet user and assign commands for the user to use.
The command authorization function takes effect immediately after you execute the command authorization command. Before executing this command, you must complete the following tasks:
·     Configure a user account on the HWTACACS server and specify the commands for the user to use.
·     Configure the required HWTACACS scheme on the device.
Procedures
Configuring the HWTACACS server
In this example, the HWTACACS server runs on IMC PLAT 7.1 (E0302) and IMC EIA 7.1 (E0301).
1.     Add a device area:
a.     Log in to IMC.
b.     Click the User tab.
c.     From the navigation tree, select Device User Policy > Authorization Conditions > Device Areas.
d.     Click Add.
e.     Set the area name to system and click OK.
Figure 4 Adding a device area
2.     Add a device:
a.     From the navigation tree, select Device User Policy > Device Management.
b.     Click Add.
c.     Enter expert for both Shared Key and Confirm Shared Key.
d.     Set the authentication port to 49.
e.     Select the device area system.
f.     Select Not Supported for Single Connection to disable establishing multiple sessions over a single TCP connection.
g.     Select Not Supported for Watchdog to disable the device from sending watchdog packets while the user is online.
h.     In the Device Management area, click Add Manually.
i.     Enter the IP address 192.168.2.1 and click OK.
j.     Click OK.
Figure 5 Adding a device
3.     Add a shell profile:
a.     From the navigation tree, select Device User Policy > Authorization Command > Shell Profiles.
b.     Click Add.
c.     Enter the profile name Shell Profile1.
d.     Select the privilege Level 1.
e.     Click OK.
Figure 6 Adding a shell profile
4.     Add an authorization policy:
a.     From the navigation tree, select Device User Policy > Authorization Policies.
b.     Click Add.
c.     Enter the policy name tac.
d.     In the Access Authorization Info area, click Add to configure access authorization information.
e.     Select system for Device Area.
f.     Select Unlimited for Device Type and Authorized Time Range.
g.     Select the shell profile Shell Profile1.
h.     Select Unlimited for Authorization Command Set and click OK.
i.     Click OK.
Figure 7 Configuring access authorization information
Figure 8 Adding an authorization policy
5.     Add a device user:
a.     From the navigation tree, select Device User > All Device Users.
b.     Click Add.
c.     Enter the account name monitor and username telnet-user.
d.     Enter the login password 123 and confirm the password.
e.     Select the user authorization policy tac.
f.     Enter 5 for Max. Online Users to limit the number of online users that use the account.
g.     Click OK.
Figure 9 Adding a device user
Configuring the device
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other, and the device and Host A can reach each other. (Details not shown.)
# Create the HWTACACS scheme tac.
[Sysname] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication, authorization, and accounting.
[Sysname-hwtacacs-tac] primary authentication 192.168.2.20 49
[Sysname-hwtacacs-tac] primary authorization 192.168.2.20 49
[Sysname-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared keys to expert.
[Sysname-hwtacacs-tac] key authentication simple expert
[Sysname-hwtacacs-tac] key authorization simple expert
[Sysname-hwtacacs-tac] key accounting simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Sysname-hwtacacs-tac] user-name-format without-domain
[Sysname-hwtacacs-tac] quit
# Configure the system-predefined domain system.
[Sysname] domain name system
# Use the HWTACACS scheme tac for login user authentication, authorization, and accounting. Use local authentication, authorization, and accounting as the backup method.
[Sysname-isp-system] authentication login hwtacacs-scheme tac local
[Sysname-isp-system] authorization login hwtacacs-scheme tac local
[Sysname-isp-system] accounting login hwtacacs-scheme tac local
# Use the HWTACACS scheme tac for command authorization and accounting. Use local authorization as the backup command authorization method.
[Sysname-isp-system] authorization command hwtacacs-scheme tac local
[Sysname-isp-system] accounting command hwtacacs-scheme tac
[Sysname-isp-system] quit
# Create the local user monitor. Set the password to 123 (plain text).
[Sysname] local-user monitor class manage
[Sysname-luser-manage-monitor] password simple 123
# Assign the Telnet service type and the level-1 user role to the user. Reclaim the default user role.
[Sysname-luser-manage-monitor] service-type telnet
[Sysname-luser-manage-monitor] authorization-attribute user-role level-1
[Sysname-luser-manage-monitor] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-monitor] quit
# Enable command authorization and command accounting.
[Sysname-line-vty0-63] command authorization
[Sysname-line-vty0-63] command accounting
1.     Verify the command authorization feature:
# Telnet to the device and enter the username monitor and password 123.
C:\Documents and Settings\Administrator> telnet 192.168.1.1
login: monitor
Password:
<Sysname>
# Enter a question mark (?) to display commands available in user view and system view. Only commands permitted by the level-1 user role are displayed.
<Sysname> ?
User view commands:
  no           Alias for 'undo'
  ping         Ping function
  ssh2         Establish an Stelnet connection to an Stelnet server
  super        Switch to a user role
  system-view  Enter the System View
  telnet       Establish a telnet connection
  tracert      Tracert function
[Sysname] ?
System view commands:
  access-list  Alias for 'acl'
  end          Alias for 'return'
  hostname     Alias for 'sysname'
  logging      Alias for 'info-center'
  no           Alias for 'undo'
  ping         Ping function
  return       Exit to User View
2.     Verify the command accounting feature:
a.     Log in to IMC.
c.     From the navigation tree, select Device User > Log Management > Audit Logs.
d.     In the Query Audit Logs area, enter the account name monitor, select the audit time range, and click Query.
A log for user monitor shows that the user executed the system-view command.
Figure 10 Querying audit logs
e.     Click the Details icon  for the log of the Start audit type.
Figure 11 Displaying details about the log of the Start audit type
f.     Click the Details icon  for the log of the Enter Command At CLI audit type.
Figure 12 Displaying details about the log of the Enter Command At CLI audit type
Configuration files
hwtacacs scheme tac
 key authentication cipher $c$3$Fl1Mn3wBsh+vH6otPvoz+AdE7VaNS3c0Pw==
 key authorization cipher $c$3$2x6XI5xU7UGX6VqWFXNp2n3FG07uTNjiQw==
 key accounting cipher $c$3$2oKsuCOAZX1+3ibvTPxnJ1YvJ1MHqv73Lw==
domain name system
 password hash $h$6$5BqWnAJTpBbU5NbY$PbdgF+43eE5WMvj2iHPySfd5nGqj5AhDCDOXTiUMJvR
FFVsZaF8EW1tgpsQPRSq7SDKaGqwHTy9nsabAoGNaYg==
 service-type telnet
line vty 0 63
 idle-timeout 0 0
 command accounting
Related documentation
·     H3C SR8800-F Routers Fundamentals Configuration Guide-R8385P09
·     H3C SR8800-F Routers Fundamentals Command Reference-R8385P09
