H3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W102
HomeSupportResource CenterWirelessWSG1800X Wireless Integrated Services GatewayWSG1800X Wireless Integrated Services GatewayTechnical DocumentsInstall & UpgradeInstallation GuidesH3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W102
07-Appendix C Optional transceiver modules
07-Appendix C Optional transceiver modules 102.47 KB
1 Appendix C  Optional transceiver modules
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AC.
Figure1-1 SFP transceiver module
Figure1-2 Optical fibers with LC connectors
(1) LC connector
(2) Optical fiber
Specifications
A transceiver module that has "MM" in its name supports multi-mode optical fibers. A transceiver module that has "SM" in its name supports single-mode optical fibers.
The H3C transceiver modules are subject to change over time. For the most recent list of H3C transceiver modules, contact Technical Support or marketing staff.
Table1-1 SFP-GE-SX-MM850-A transceiver module specifications
Item
SFP-GE-SX-MM850-A
Central wavelength
850 nm
Max transmission distance
550 m (1804.46 ft)
Data rate
1250 Mb/s
Connector type
Duplex LC connector
Fiber mode
MMF
Fiber diameter
50 μm
Output power
9.5 to 0 dBm
Receiver sensitivity
–17 dBm
Light saturation
–3 dBm
Table1-2 SFP-GE-LX-SM1310-A specifications
Item
SFP-GE-LX-SM1310-A
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
1250 Mb/s
Connector type
Duplex LC connector
Fiber mode
SMF
Fiber diameter
9 μm
Output power
9.5 to –3 dBm
–20 dBm
Light saturation
–3 dBm
Table1-3 SFP-XG-LX-SM1310-E specifications
Item
SFP-XG-LX-SM1310-E
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
10.31 Gb/s
Connector type
Duplex LC connector
Fiber mode
SMF
Fiber diameter
9 μm
Output power
8.2 to +0.5 dBm
–14.4 dBm
Light saturation
0.5 dBm
Table1-4 SFP-XG-SX-MM850-E specifications
Item
SFP-XG-SX-MM850-E
Central wavelength
850 nm
300 m (984.25 ft)
Data rate
10.31 Gb/s
Connector type
Duplex LC connector
Fiber mode
MMF
Fiber diameter
50 μm
Output power
7.3 to –1 dBm
–9.9 dBm
Light saturation
0.5 dBm
  • Become a Partner
  • Partner Resources
