03-Interface Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R838x-6W10003-Interface Configuration Guide
05-CPOS interface configuration
05-CPOS interface configuration 167.86 KB
Configuring CPOS interfaces
About CPOS interfaces
The low-speed tributary signals multiplexed to form an SDH signal are called channels. The channelized POS (CPOS) interface makes full use of SDH to provide the following benefits:
·     Provides precise bandwidth division.
·     Reduces the number of low-speed physical interfaces on devices.
·     Enhances aggregation capacity.
·     Improves the access capacity of leased lines.
CPOS interface application scenarios
CPOS E1 interfaces are typically used to aggregate E1 lines, as shown in Figure 1.
In actual applications, the connection between low-end devices and the CPOS interfaces might span more than one transmission network and might require relay.
Figure 1 CPOS E1 interface application scenario
CPOS interface types
The device supports the CPOS interfaces in Table 1.
Table 1 CPOS interfaces
Interface type
Channelization/multiplexing capabilities
CPOS E1
63 E1 channels (E1 channel configurable).
Overhead bytes
SDH provides layered precise monitoring and management.
SDH monitoring functions are implemented using overhead bytes. SDH provides monitoring at section and channel levels.
·     Sections are subdivided into regenerator and multiplex sections.
·     Channels are subdivided into higher-order and lower-order paths.
SDH provides a variety of overhead bytes, but only those involved in CPOS configuration are discussed in this section.
SOH
The section overhead (SOH) is further classified into the regenerator section overhead (RSOH) and the multiplex section overhead (MSOH).
The J0 regenerator section trace byte is included in RSOH to repeatedly send the section access point identifier. The receiver uses this identifier to make sure it is in continuous connection with the sender. This byte can be any character in the network of the same carrier. If the networks of two carriers are involved, the sending and receiving devices at network borders must use the same J0 byte. With the J0 byte, carriers can detect and troubleshoot faults in advance or use less time to recover networks.
POH
The payload of an STM-N frame includes the path overhead (POH), which monitors low-speed tributary signals.
The SOH monitors the section layer, and the POH monitors the path layer. The POH is divided into the higher-order path overhead and the lower-order path overhead.
Higher-order path overhead monitors paths at the VC-4/VC-3 level.
Similar to the J0 byte, the higher-order VC-N path trace byte J1 is included in the higher-order path overhead to repeatedly send the higher-order path access point identifier. The receiving end of the path uses this identifier to make sure it is in continuous connection with the specified sender. The sender and the receiver must use the same J1 byte.
In addition, the path signal label byte C2 is included in the higher-order path overhead to indicate the multiplexing structure of VC frames and the properties of payload, including the following:
·     Whether the path is carrying traffic.
·     What type of traffic is carried.
·     How the VC frames are mapped.
The sender and receiver must use the same C2 byte.
Configuring a CPOS interface
If no cable is connected to a physical interface, shut down the interface with the shutdown command to prevent problems.
Configuring basic settings of a CPOS interface
2.     Enter CPOS interface view.
controller cpos cpos-number
3.     (Optional.) Configure the interface description.
By default, the description of a CPOS interface is interface name Interface.
4.     Set the clock mode.
clock { master | slave }
The default setting is slave.
When two CPOS interfaces are directly connected, you must configure the two ends with different clock modes.
When connected to a SONET/SDH device, the CPOS interface must use the slave clock mode. The SONET/SDH network clock is more precise.
5.     Set the framing format.
frame-format { sdh | sonet }
The default setting is SDH.
6.     Set the AUG multiplexing mode.
multiplex mode { au-3 | au-4 }
By default:
¡     The AUG multiplexing mode is au-4 on a CPOS interface in SDH mode.
¡     The AUG multiplexing mode is au-3 on a CPOS interface in SONET mode, which cannot be modified.
7.     Bring up the CPOS interface.
By default, a CPOS interface is up.
Configuring physical state change suppression interval on a CPOS interface
The physical link state of an interface is either up or down. Each time the physical link of an interface comes up or goes down, the system then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change immediately for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
This feature takes effect only on physical state changes caused by alarms configured by using the alarm-detect command.
3.     Set the physical state change suppression interval on the interface.
link-delay seconds
By default, the physical state change suppression interval is 10 seconds.
Configuring overhead bytes on a CPOS interface
You must configure the same overhead bytes at both ends of a link.
On a CPOS interface, the framing format specified in the flag command must be the same as that configured by using the frame-format command.
3.     Configure the signal label byte (C2).
flag c2 path-number c2-value
By default, the C2 byte value is 2 (hexadecimal).
4.     Configure the synchronization status byte (S1).
flag s1 s1-value
By default, the S1 byte value is f (hexadecimal).
5.     Configure the AU type.
flag s1s0 path-number s1s0-value
By default, the value of S1S0 is 0 (hexadecimal) for SONET and 2 (hexadecimal) for SDH.
6.     Configure the regenerator section trace message.
flag j0 { sdh | sonet } flag-value
By default, the J0 byte value is 1 (hexadecimal) for SONET.   For SDH, the J0 byte is CR16000.
7.     Configure the path trace message.
flag j1 path-number { sdh | sonet } flag-value
By default, the J1 byte value for SDH is CR16000 for both SONET and SDH.
Configuring RDI, SD, or SF alarm actions for a CPOS interface
Signal degrade (SD) and signal fail (SF) alarms are used to indicate the current line performance. When a small number of bit errors occur, the interface sends an SD alarm. When a large number of bit errors occur, the line performance degrades seriously and the interface sends an SF alarm.
An RDI alarm occurs if the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end.
You can configure the CPOS interface to go down automatically when an RDI, SD, or SF alarm is detected on the interface.
3.     Set the SD or SF alarm threshold for the interface.
threshold { sd sdvalue | sf sfvalue } *
By default, the sdvalue argument is 6 and the sfvalue argument is 4.
4.     Configure the action to take when an RDI, SD, or SF alarm occurs on the CPOS interface.
alarm-detect { rdi | sd | sf } action link-down
By default, the device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
Enabling loopback on a CPOS interface
Perform this task to determine whether a CPOS link works correctly.
Loopback includes the following types:
·     Internal loopback—Tests the device where the CPOS interface resides. The CPOS interface sends outgoing packets back to the local device. If the device fails to receive the packets, the device fails.
·     External loopback—Tests the inter-device link. The CPOS interface sends incoming packets back to the remote device. If the remote device fails to receive the packets, the inter-device link fails.
Loopback is intended for testing only. Disable the feature when the CPOS interface is operating correctly.
After you enable this feature on a CPOS interface, the interface does not forward data traffic.
3.     Enable loopback.
loopback { local | remote }
By default, loopback is disabled.
Restoring the default settings for an interface
This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
3.     Restore the default settings for the interface.
default
Configuring an E1 channel
About E1 channels
The serial interfaces created for E1 channels have the same logical features as a synchronous serial interface. You can configure these serial interfaces in the same way you configure a standard synchronous serial interface. For more information about configuring synchronous serial interfaces, see "Configuring WAN interfaces."
Configuring basic settings of an E1 channel
3.     Set the framing format for the E1 channel.
e1 e1-number frame-format { crc4 | no-crc4 }
The default setting is no-CRC4.
4.     Set the clock mode for the E1 channel.
e1 e1-number clock { master | slave }
5.      (Optional.) Shut down the specified E1 channel.
e1 e1-number shutdown
By default, an E1 channel is up.
Configuring overhead bytes on an E1 channel
3.     Configure the low-order channel signal tag byte (C2).
e1 e1-number flag c2 c2-value
4.     Configure the low-order channel trace byte (J2).
e1 e1-number flag j2 { sdh | sonet } j2-string
By default, the cyclic value for the J2 byte is CR16000.
Configuring the E1 channel operating mode
E1 channels on CPOS interfaces support the unframed (clear channel) mode and the framed (channelized) mode.
·     Unframed mode—An E1 channel can form a 2.048 Mbps serial interface without timeslot division. It is numbered in the format of interface-number/channel-number:0.
·     Framed mode—All timeslots except timeslot 0 on the E1 channel can be bundled randomly to form serial interfaces.
For successful communication, make sure the local end has the same timeslot bundling settings as the remote end.
Configuring the unframed mode
3.     Configure the unframed mode.
e1 e1-number unframed
By default, an E1 channel operates in framed mode.
When you place an E1 channel in unframed mode, the system automatically creates a 2.048 Mbps serial interface.
Configuring the framed mode
3.     Configure the framed mode.
undo e1 e1-number unframed
4.     Bundle timeslots into a channel set.
e1 e1-number channel-set set-number timeslot-list range
By default, no channel sets exist on an E1 channel.
Enabling loopback on an E1 channel
You can test E1 channels by using the loopback command with different keywords.
·     Internal loopback—The sender's data is directly looped to the receiver.
·     External loopback—Data received by the receiver is looped back directly without passing through the E1 framer.
Loopback is intended for testing only. Disable the feature when the E1 channel is operating correctly.
3.     Enable loopback.
e1 e1-number loopback { local | remote }
Display and maintenance commands for CPOS interfaces
Display CPOS interface status information.
display controller [ cpos [ cpos-number ] ]
Display status information for an E1 channel on a CPOS interface.
display controller [ cpos cpos-number e1 e1-number ]
Display the physical attributes of a controller interface.
display controller [ interface-type [ interface-number ] ] phy-option
Display information about an E1 serial interface.
display interface serial interface-number/channel-number:set-number
Clear statistics for a CPOS interface.
reset counters controller cpos interface-number
For more information about the display interface serial command, see Interface Command Reference.
CPOS interface configuration examples
Example: Configuring CPOS-E1 channels
As shown in Figure 2, branch nodes Router B through Router H are uplinked to the central node Router A through E1 links. Router A aggregates these E1 links by using a CPOS interface.
Add one additional E1 link on Router B to expand its capacity, and use an MP-group interface to bind the two E1 links.
Figure 2 Network diagram
For correct network synchronization, make sure the master clock mode is configured on the SONET/SDH devices connected to the routers.
1.     Configure Router A:
# Configure E1 channels 1 and 2 of CPOS 2/2/1 to operate in unframed mode.
[RouterA] controller cpos 3/1/1
[RouterA-Cpos 3/1/1] e1 1 unframed
[RouterA-Cpos 3/1/1] e1 2 unframed
# Create MP-group 3/1/1 and assign an IP address to it.
[RouterA] interface mp-group 3/1/1
[RouterA-Mp-group3/1/1] ip address 10.1.1.1 24
[RouterA-Mp-group3/1/1] quit
# Assign Serial 3/1/1/1:0 to MP-group 2/2/1.
[RouterA] interface serial3/1/1/1:0
[RouterA-Serial3/1/1/1:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1/1:0] quit
# Assign Serial 3/1/1/2:0 to MP-group 2/2/1.
[RouterA] interface serial3/1/1/2:0
[RouterA-Serial3/1/1/2:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1/2:0] quit
2.     Configure Router B:
# Configure E1 3/1/1 to operate in E1 mode.
<RouterB> system-view
[RouterB] controller e1 3/1/1
[RouterB-E1 3/1/1] using e1
[RouterB-E1 3/1/1] quit
# Configure E1 3/1/2 to operate in E1 mode.
[RouterB] controller e1 3/1/2
[RouterB-E1 3/1/2] using e1
[RouterB-E1 3/1/2] quit
[RouterB] interface mp-group 3/1/1
[RouterB-Mp-group3/1/1] ip address 10.1.1.2 24
[RouterB-Mp-group3/1/1] quit
# Assign Serial 3/1/1:0 to MP-group 2/4/1.
[RouterB] interface serial3/1/1:0
[RouterB-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/1:0] quit
# Assign Serial 3/1/2:0 to MP-group 2/4/1.
[RouterB] interface serial3/1/2:0
[RouterB-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/2:0] quit
# Execute the display interface serial 3/1/1:0, display interface mp-group 3/1/1, and display ppp mp commands to view the connectivity state.
# Verify that the routers can ping one another. (Details not shown.)
Troubleshooting CPOS interfaces
Loop and link layer protocol down state detected on serial interfaces created for E1 channels on the CPOS interface
Symptom
The H3C router is connected to another vendor's router through E1 channels on CPOS interfaces across an SDH network. PPP is used on the serial interface created for the E1 channel set.
The output from the display interface serial command shows the following errors:
·     The physical state of the serial interface is up, but the link protocol is down.
·     The serial interface is in a looped condition.
Solution
The symptom might occur when the router and its directly connected SDH device have different multiplex paths for the E1 channels. Multiplex path inconsistency can cause PPP negotiation failure because the SDH device transmits signals from the router in incorrect timeslots to the remote end. If the SDH device incorrectly maps a signal to an idle timeslot in a looped condition, the router can detect a loop on the serial interface.
To resolve the problem:
1.     Identify the multiplex path for the E1 channels on the router.
<Sysname> display controller cpos e1
2.     Verify that the router and its directly connected SDH device have the same multiplex path for E1 channels. (Details not shown.)
3.     Debug the loop condition.
<Sysname> debugging ppp lcp error
4.     If the problem persists, contact H3C Support.
  • Become a Partner
  • Partner Resources
