| 00-Preface | 99.98 KB |
Preface
This command reference covers the interface configuration commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
| Convention | Description |
| Boldface | Bold text represents commands and keywords that you enter literally as shown. |
| Italic | Italic text represents arguments that you replace with actual values. |
| [ ] | Square brackets enclose syntax choices (keywords or arguments) that are optional. |
| { x | y | ... } | Braces enclose a set of required syntax choices separated by vertical bars, from which you select one. |
| [ x | y | ... ] | Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none. |
| { x | y | ... } * | Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select a minimum of one. |
| [ x | y | ... ] * | Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you select one choice, multiple choices, or none. |
| &<1-n> | The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times. |
| # | A line that starts with a pound (#) sign is comments. |
GUI conventions
| Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window opens; click OK. |
| > | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
| An alert that calls attention to important information that if not understood or followed can result in personal injury. | |
| An alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software. | |
| An alert that calls attention to essential information. | |
| NOTE: | An alert that contains additional or supplementary information. |
| An alert that provides helpful information. |
Network topology icons
| Represents a generic network device, such as a router, switch, or firewall. | |
| Represents a routing-capable device, such as a router or Layer 3 switch. | |
| Represents a generic switch, such as a Layer 2 or Layer 3 switch, or a router that supports Layer 2 forwarding and other Layer 2 features. | |
| Represents an access controller, a unified wired-WLAN module, or the access controller engine on a unified wired-WLAN switch. | |
| Represents an access point. | |
| Represents a wireless terminator unit. | |
| Represents a wireless terminator. | |
| Represents a mesh access point. | |
| Represents omnidirectional signals. | |
| Represents directional signals. | |
| Represents a security product, such as a firewall, UTM, multiservice security gateway, or load balancing device. | |
| Represents a security module, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG module. |
Documentation feedback
We appreciate your comments.
 Login
Login
