- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Flow log commands
- 22-Information center commands
- 23-Packet capture commands
- 24-Flow monitor commands
| 08-Network synchronization commands | 127.04 KB |
display network-clock freq-deviation status
display network-clock freq-deviation-detect
display network-clock self-test-result
network-clock freq-deviation-detect enable
network-clock freq-deviation-source elect disable
network-clock freq-deviation-source elect recover
network-clock freq-deviation-threshold
network-clock source frequency
Use display network-clock freq-deviation status to display the frequency deviation status of clock signals received by the device.
# Display the frequency deviation status of clock signals received by the device.
<Sysname> display network-clock freq-deviation status
Frequency deviation detection: Enabled
Reference selection by clock source with deviated frequency: Disabled
Input interface Freq deviation status
XGE3/0/1 Abnormal
XGE3/0/2 Normal
XGE3/0/3 --
Input interface |
Clock signal input interface. |
Freq deviation status |
Frequency deviation status of the clock signal. · Abnormal: The frequency deviation of the line clock signal does not meet the requirement and this line clock will not compete in clock reference election. · Normal: The frequency deviation of the line clock signal meets the requirements and this line clock will compete in clock reference election. The system displays -- for a clock signal if its deviation status fails to be detected. |
Use display network-clock freq-deviation-detect to display information about clock frequency deviation detection.
# Display information about clock frequency deviation detection.
<Sysname> display network-clock freq-deviation-detect
Detection Freq offset Alarm threshold Status
Detection |
Whether clock frequency deviation is enabled: · Enabled. · Disabled . |
Freq offset |
Frequency deviation value, in ppb. |
Alarm threshold |
Frequency deviation alarm threshold, in ppb. |
Status |
Frequency deviation status. This field displays "-" if frequency deviation detection is not enabled. · Normal—The frequency deviation is in the acceptable ranges. · Alarm—The frequency deviation has crossed the alarm threshold. |
Use display network-clock self-test-result to display the self-test result of the network clock monitoring module.
# Display the self-test result of the network clock monitoring module.
<Sysname> display network-clock self-test-result
Clock module state: Normal
FPGA : Normal
E1 : Normal
Clock Chip : Normal
Clock module mode |
Status of the network clock monitoring module: · Normal—The network clock monitoring module is operating correctly. · Fault—The network clock monitoring module is not operating correctly. The network clock monitoring if faulty if the FPGA, CPLD, E1A, or E1B is faulty. |
FPGA |
Status of the FPGA: · Normal—The FPGA is operating correctly. · Fault—The FPGA is faulty. |
E1 |
Status of the E1 chip: · Normal—The E1 chip is operating correctly. · Fault—The E1 chip is faulty. |
Clock Chip |
Status of the clock chip: · Normal—The clock chip is operating correctly. · Fault—The clock chip is faulty. |
display network-clock source
Use display network-clock source to display information about the clock sources.
# Display information about the clock sources.
<Sysname> display network-clock source
Traced reference: XGE3/0/1
Reference State Priority SSM level Force SSM Sa-Bit LPU port Frequency
BITS0 Lost 255 Unknown ON 4 N/A 2 Mbps
BITS1 Lost 255 Unknown ON 4 N/A 2 Mbps
PTP N/A 255 Unknown ON N/A N/A N/A
XGE3/0/1 Normal 10 Unknown OFF N/A Yes N/A
Traced reference |
Traced clock source. If a clock source is traced, the network clock monitoring module distributes its timing signal to all interface cards. If no clock source has been traced, this field displays N/A. |
Reference |
Clock source: · BITS clock source. The available values include BITS0 and BITS1. · PTP clock source. The value is PTP. · Line clock source. The value is the line clock input port. This information is displayed only when a line clock input port is configured. |
State |
State of the clock source: · Normal—The clock source is operating correctly. · Lost—The clock source is not available or is in an error condition. · N/A—PTP is used for time synchronization. |
Priority |
Priority of the clock source. |
SSM level |
SSM quality level in descending order: · PRC—G.811 primary reference clock. · SSU-A—G.812 primary-level SSU. · SSU-B—G.812 second-level SSU. · SEC—SDH equipment clock. · DNU—Do not use for synchronization. · Unknown—Unknown quality level. |
Force SSM |
Whether to use the manually assigned SSM quality level: · ON—Uses the manually assigned SSM quality level. · OFF—Extracts the SSM quality level from the received timing signal. |
Sa bit |
Sa bit used by BITS to transmit the SSM: · sa4—Bit Sa4. · sa5—Bit Sa5. · sa6—Bit Sa6. · sa7—Bit Sa7. · sa8—Bit Sa8. This field displays N/A for line clock sources, because line clocks do not support the Sa bit configuration. |
LPU port |
Whether the line clock input port takes effect: · Yes—The line clock input port takes effect. · No—The line clock input port does not take effect. This field displays N/A for BITS 0, BITS 1, and PTP clock sources. |
Frequency |
Frequency of the BITS clock: · 2 Mbps. · 2 MHz. |
display network-clock status
Use display network-clock status to display the operating state of the network clock monitoring module.
# Display the operating state of the network clock monitoring module.
<Sysname> display network-clock status
Mode : Auto
Reference : N/A
Traced reference : N/A
Lock mode : Unknown
SSM output level : SSUB
SSM control enable: On
Table 5 Command output
Mode |
Clock reference selection mode: · Auto—Automatic reference selection. · Manual—Manual reference selection. |
Reference |
Manually specified clock reference. This field displays N/A if no clock reference has been specified. |
Traced reference |
Clock reference that has been selected and traced. This field displays N/A if no clock reference has been selected. |
Lock mode |
Phase lock state of the clock monitoring module: · Freerun—Freerun mode. · Locked—Locked (traced) mode. · Holdover—Holdover state. · Pre-locked—Pre-locked mode. · Lost—The clock signal has been lost. · Unknown—No timing signal is available. The network clock monitoring module is in an exceptional condition. |
SSM output level |
Signal quality level of the clock source in the SSM, by descending order of quality: · PRC—G.811 primary reference clock. · SSU-A—G.812 primary-level SSU. · SSU-B—G.812 second-level SSU. · SEC—SDH equipment clock. · DNU—Do not use for synchronization. · Unknown—Unknown quality level. |
SSM control enable |
Contribution of SSM to automatic reference selection: · On—SSM is used in the selection process. · Off—SSM is not used in the selection process. |
display network-clock version
Use display network-clock version to display the version of the network clock monitoring module.
# Display version information for the network clock monitoring module.
<Sysname> display network-clock version
Clock card
Type : SR07CK3E
PCB : Ver.A
FPGA version: 100
Release date: 2022-06-02
Table 6 Command output
Type |
Model of the clock daughter card. |
PCB |
PCB version of the clock daughter card. |
FPGA version |
FPGA version. |
Release date |
Version compilation time of the clock daughter card. |
Use network-clock freq-deviation-detect enable to enable clock frequency deviation detection.
Use undo network-clock freq-deviation-detect enable to disable clock frequency deviation detection.
Clock frequency deviation detection is disabled.
After you enable clock frequency deviation detection, the system detects frequency deviation of clock signals.
# Enable clock frequency deviation detection.
[Sysname] network-clock freq-deviation-detect enable
Use network-clock freq-deviation-source elect disable to disable clocks with abnormal frequency deviation status from competing in clock reference election.
Use undo network-clock freq-deviation-source elect disable to enable clocks with abnormal frequency deviation status to compete in clock reference election.
Clocks with abnormal frequency deviation status are allowed to compete in clock reference election.
With clock frequency deviation detection enabled, if the frequency difference between the signal of a clock resource received on the device and the current clock reference exceeds the threshold, the system sets the frequency deviation status of the clock source to Abnormal. You can configure this command to disable clocks with abnormal frequency deviation status from competing in clock reference election.
Before configuring this command, you must enable clock frequency deviation detection.
# Disable clocks with abnormal frequency deviation status from competing in clock reference election.
[Sysname] network-clock freq-deviation-source elect disable
· network-clock freq-deviation-detect enable
· network-clock freq-deviation-source elect recover
· network-clock freq-deviation-threshold
Use network-clock freq-deviation-source elect recover to change the frequency deviation status of a clock signal to normal so that it can compete in the clock reference election.
Interface view
With clock frequency deviation detection enabled, if the frequency difference between the clock signal received on a device interface and the current clock reference exceeds the threshold, the system sets the frequency deviation status of the clock source to Abnormal. And the frequency deviation status cannot return to normal automatically after the frequency deviation of the clock falls into the acceptable range. If the network-clock freq-deviation-source elect disable command is configured, the clock source is not allowed to compete in clock reference election.
By using the network-clock freq-deviation-source elect recover command, you can change the frequency deviation status of a clock signal to normal so that it can compete in the clock reference election.
# Change the clock frequency deviation status of a clock signal to normal so that it can compete in the clock reference election.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] network-clock freq-deviation-source elect recover
· display network-clock freq-deviation-status
· network-clock freq-deviation-source elect disable
Use network-clock freq-deviation-threshold to set a clock frequency deviation threshold.
Use undo network-clock freq-deviation-threshold to restore the default.
network-clock freq-deviation-threshold offset-value
The clock frequency deviation threshold is 4600 ppb.
offset-value: Specifies a clock frequency deviation threshold. The value is in the range of 100 to 4600, in ppb.
When the clock frequency deviation crosses the deviation threshold, the system outputs a frequency deviation alarm.
# Set the clock frequency deviation threshold to 2000 ppb.
[Sysname] network-clock freq-deviation-threshold 2000
network-clock lpuport
Use network-clock lpuport to specify a line clock input port.
Use undo network-clock lpuport to remove a line clock input port.
network-clock lpuport interface-type interface-number
undo network-clock lpuport interface-type interface-number
No ports are specified as line clock input ports.
Only main physical interfaces can act as clock input ports.
When you specify a main interface as a clock input port, you must set its clock mode to slave. The network clock monitoring module extracts clock signal from an interface only when the interface is operating in slave mode.
# Specify Pos 3/0/1 as a line clock input port.
[Sysname] network-clock lpuport pos 3/0/1
network-clock source forcessm
Use network-clock source forcessm to configure the method for setting the quality level of a clock source.
Use undo network-clock source forcessm to restore the default.
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } forcessm { off | on }
undo network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } forcessm
The network clock monitoring module sets the quality level of a clock source to the user-assigned value. It does not extract the quality level from the SSM sent by the clock source.
bits0: Specifies the BITS 0 clock.
bits1: Specifies the BITS 1 clock.
lpuport interface-type interface-number: Specifies a line clock. The interface-type interface-number arguments specify the type and number of the line clock input port.
ptp: Specifies the Precision Timing Protocol (PTP).
off: Sets the quality level of a clock source to the value extracted from the SSM sent by the clock source.
on: Sets the quality level of a clock source to the user-assigned value.
# Set the quality level of BITS 0 to the value extracted from the SSM sent by the clock source.
[Sysname] network-clock source bits0 forcessm off
Use network-clock source frequency to set the frequency of a BITS clock.
Use undo network-clock source frequency to restore the default.
network-clock source { bits0 | bits1 } frequency { bps-2m | hz-2m }
undo network-clock source { bits0 | bits1 } frequency
The frequency of a BITS clock is 2 Mbps (bps-2m).
bps-2m: Sets the frequency to 2 Mbps.
hz-2m: Sets the frequency to 2 MHz.
# Set the frequency to 2 MHz for BITS 0.
[Sysname] network-clock source bits0 frequency hz-2m
network-clock source priority
Use network-clock source priority to set the priority of a clock source.
Use undo network-clock source priority to restore the default.
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } priority priority
undo network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } priority
All clock sources have a priority of 255.
ptp: Specifies PTP.
priority priority: Sets a priority value in the range of 1 to 255. The lower the value, the higher quality the timing signal.
# Assign a priority of 3 to BITS 0.
[Sysname] network-clock source bits0 priority 3
network-clock source sa-bit
Use network-clock source sa-bit to set the Sa bit used to transmit the SSM for a BITS clock.
Use undo network-clock source sa-bit to restore the default.
network-clock source { bits0 | bits1 } sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 }
undo network-clock source { bits0 | bits1 } sa-bit
BITS clocks use Sa4 to transmit the SSM.
sa-bit: Specifies an Sa bit.
· sa4—Specifies bit Sa4.
· sa5—Specifies bit Sa5.
· sa6—Specifies bit Sa6.
· sa7—Specifies bit Sa7.
· sa8—Specifies bit Sa8.
# Specify Sa5 as the SSM bit for BITS 0.
[Sysname] network-clock source bits0 sa-bit sa5
network-clock source ssm
Use network-clock source ssm to assign an SSM quality level to a clock source.
Use undo network-clock source ssm to restore the default.
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } ssm { dnu | prc | sec | ssua | ssub | unknown }
undo network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } ssm
The SSM quality level is unknown for all clock sources.
ptp: Specifies the PTP.
dnu: Sets the SSM quality level to DNU SSM quality level. DNU clock sources cannot participate in automatic clock reference selection.
prc: Sets the SSM quality level to G.811 primary reference clock.
sec: Sets the SSM quality level to SDH equipment clock.
ssua: Sets the SSM quality level to G.812 primary-level SSU.
ssub: Sets the SSM quality level to G.812 second-level SSU.
unknown: Sets the SSM quality level to unknown.
For the manually assigned SSM quality level to take effect, you must configure the network-clock source forcessm on command.
It takes time for an SSM quality level change to take effect. To verify the effectiveness of the change, use the display network-clock source command or check the log.
# Set the SSM quality level of BITS 0 to DNU.
[Sysname] network-clock source bits0 ssm dnu
network-clock ssmcontrol
Use network-clock ssmcontrol to control the use of SSM quality level in the automatic reference selection process.
Use undo network-clock ssmcontrol to restore the default.
network-clock ssmcontrol { off | on }
The SSM quality level is ignored in the automatic reference selection process.
off: Ignores the SSM quality level in clock reference selection.
on: Includes the SSM quality level as a factor for clock reference selection.
This command takes effect for automatic clock reference selection.
# Include the SSM quality level into the automatic clock reference selection process.
[Sysname] network-clock ssmcontrol on
network-clock ssm
network-clock ssm-degrade-threshold
Use network-clock ssm-degrade-threshold to set an SSM level degradation threshold for the clock reference.
Use undo network-clock ssm-degrade-threshold to restore the default.
network-clock ssm-degrade-threshold { dnu | prc | sec | ssua | ssub }
The SSM level degradation threshold is dnu.
After you configure the SSM level degradation threshold, the system outputs an SSM degradation alarm when the SSM level of the reference clock is degraded to a level lower than the threshold.
# Set the SSM level degradation threshold to prc.
[Sysname] network-clock ssm-degrade-threshold prc
network-clock work-mode
Use network-clock work-mode to set the clock reference selection mode.
Use undo network-clock work-mode to restore the default.
network-clock work-mode { auto | manual source { bits0 | bits1 | lpuport interface-type interface-number | ptp } }
Automatic reference selection mode applies.
auto: Enables automatic reference selection.
manual source: Enables manual reference selection.
bits0: Specifies BITS 0 as the reference.
bits1: Specifies BITS 1 as the reference.
ptp: Specifies the PTP synchronized clock as the reference.
lpuport interface-type interface-number: Specifies a line clock input port as the reference. The interface-type interface-number arguments specify an interface by its type and number.
To use the timing signal from an interface as the synchronization reference, you must also specify the interface as a line clock input port by using the network-clock lpuport command.
It takes time for a clock reference selection mode change to take effect. To verify the effectiveness of the change, use the display network-clock status command or check the log.
# Specify BITS 0 as the clock reference.
[Sysname] network-clock work-mode manual source bits0
# Enable automatic reference selection.
[Sysname] network-clock work-mode auto
reset network-clock
Use reset network-clock to reset the clock state of the device.
reset network-clock
If the clocks of two devices are locked to each other because of a misoperation, the clocks will form a loop. As a result, the clock quality will be reduced, and the phase-lock state of the clocks of the two devices will be switched from Locked to Holdover.
By default, when the clocks of two devices are locked to each other because of a misoperation, the phase-lock state of the clocks of the two devices will remain in Holdover state even if the wrong configuration is removed. To recover the clocks, you can use this command to reset the clock state of the device that acts as the clock source, so that the device can provide clock signals to the other end correctly. For example, the clocks of Device A and Device B are locked to each other and Device B acts as the clock source to provide Device A with clock signals. You can recover the clocks as follows:
1. Cancel the misconfiguration on Device B.
2. Use this command to reset the clock state of Device B.
3. After the clock state of Device B is reset, Device A will reselect B as the clock reference.
# Reset the clock state of the device.
<Sysname> reset network-clock
Synchronous Ethernet commands
display esmc
Use display esmc to display ESMC information.
display esmc [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays ESMC information for all interfaces.
ESMC information is not available for interfaces in asynchronous mode.
# Display ESMC information for all interfaces.
<Sysname> display esmc
Interface : Ten-GigabitEthernet3/0/1
Mode : Synchronous
ESMC status : Enable
ESMC bundle : 3
Port status : Up
Duplex mode : Full
QL received : QL-SEC
QL sent : QL-PRC
ESMC information packets received : 2195
ESMC information packets sent : 6034
ESMC event packets received : 1
ESMC event packets sent : 16
ESMC information rate : 1 packets/sec
ESMC expiration : 5 seconds
Table 7 Command output
Interface that receives ESMC messages. |
Mode |
Ethernet interface mode: Synchronous—Synchronous mode. Non-Synchronous—Asynchronous mode. |
ESMC status |
Whether ESMC is enabled: · Enable—ESMC is enabled. · Disable—ESMC is disabled. |
ESMC bundle |
ESMC bundle to which the interface is assigned. This field displays N/A if the interface is not assigned to any ESMC bundle. |
Duplex mode |
Duplex mode of the interface: · Full—The interface is operating in full-duplex mode. · Half—The interface is operating in half-duplex mode. |
QL received QL sent |
Quality level in the ESMC packet most recently received or sent on the interface: · PRC—G.811 primary reference clock. · SSU-A—G.812 primary-level SSU. · SSU-B—G.812 second-level SSU. · SEC—SDH equipment clock. · DNU—Do not use for synchronization. · UNK—Unknown quality level. |
ESMC information packets received ESMC information packets sent |
Number of received or sent ESMC information packets. |
ESMC event packets received ESMC event packets sent |
Number of received or sent ESMC event packets. |
ESMC information rate |
Transmission rate of ESMC information packets. The value is fixed at 1 pps. |
ESMC expiration |
ESMC expiration timer. The timer is fixed at 5 seconds. |
esmc enable
synchronous mode
esmc bundle
Use esmc bundle to assign an interface to an ESMC bundle.
Use undo esmc bundle to remove an interface from the ESMC bundle.
esmc bundle bundle-number
undo esmc bundle
An interface is not assigned to an ESMC bundle.
Ethernet interface view
FlexE physical interface view
bundle-number: Specifies an ESMC bundle by its number. The value range for the bundle-number argument is 1 to 64.
If a device has multiple interfaces directly connected to the peer device and the interfaces are enabled with SyncE and ESMC, assign these interfaces to an ESMC bundle. This configuration will prevent SyncE clock loops.
When the device selects one interface in an ESMC bundle for clock synchronization, the priority of ESMC messages sent from all interfaces in the bundle is set to DNU. This prevents the peer device from synchronizing with the clock of the device by using the clock information from these interfaces and ensures that no clock loops will be produced.
For this command to take effect, you must first configure the synchronous mode command.
# Assign Ten-GigabitEthernet3/0/1 to ESMC bundle 3.
[Sysname-Ten-GigabitEthernet3/0/1] synchronous mode
[Sysname-Ten-GigabitEthernet3/0/1] esmc bundle 3
esmc enable
synchronous mode
esmc enable
Use esmc enable to enable the Ethernet synchronization messaging channel (ESMC) on an Ethernet interface.
Use undo esmc enable to disable the Ethernet synchronization messaging channel (ESMC) on an Ethernet interface.
esmc enable
undo esmc enable
ESMC is disabled on Ethernet interfaces.
Before you can enable ESMC, you must configure the interface to operate in synchronous mode.
# Enable ESMC on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] esmc enable
display esmc
synchronous mode
synchronous mode
Use synchronous mode to enable the synchronous mode on an Ethernet interface.
Use undo synchronous mode to restore the default.
synchronous mode
Ethernet interfaces are regular Ethernet interfaces in non-synchronous mode. They do not extract timing signals, send, forward, or process ESMC packets.
You can configure an interface as a line clock input port only after you enable the synchronous mode on the interface.
# Enable the synchronous mode on Ten-GigabitEthernet 3/0/1.
display esmc
esmc enable
